1. current
  4. Tuesday, 26 February 2019
we use SP page builder in combination with your templates and we have this issue:
when we activate from template settings -> module widths -> the module position 100% = YES and remove container padding, activate the builder module to this position, and there is rigth-left movement either with a browser or even more intense with a mobile device, there is a margin on the sides
the scroll down is not smooth and google marks it as an error for mobile devices
if you could please check these 3 sites using the same template Robyn (but also in others from joomla51 which we use a lot)
https://escapetokefalonia.com
https://www.ligarion-aroma.com
https://villachristinakefalonia.com
this is a combination of the two, but most likely a template minor setting or something, because spPB doesn't do it in other cases
thank you in advance
George & Rita Antonatos
kefalonia.website
Hi George & Rita
.sppb-section {
overflow: hidden;
problem solved! thanks very much!
