1. Oliver
  4. Wednesday, 04 September 2019
I found a little bug in inc/scripts.php in Carmen template.
There is a "wrong" quotation mark in code line 72 after the file ending .js:
line72: $document->addScript('https://cdnjs.cloudflare.com/ajax/libs/waypoints/4.0.1/noframework.waypoints.min.js"', true, false);
BTW: can I change the external script to internal? Are there any disadvantages?
I thought of:
line72: $document->addScript('templates/'.$this->template.'/js/noframework.waypoints.min.js', true, false);
and adding the js file to the template/js directory.
What do you think?
Oliver
Hi Oliver
My sincere apologies for the delay with your query. We somehow missed this one!
Thank you for bringing this issue to our attention. This will be fixed in the next update of the template.
Regarding loading the waypoint script locally, yes you are correct. Save the waypoint script locally (https://cdnjs.cloudflare.com/ajax/libs/waypoints/4.0.1/noframework.waypoints.min.js) and use the method you correctly described.
