I'm turning my web into a Progressive Web Application. In order to resemble an app menu at the bottom of the viewport, I use the module J51 Icons, which I include inside a 3rd party extension to float the module at the bottom.
I don't need icons descriptions or titles. Just icons.
The menu at the bottom is a bit too high, so I need to reduce its height. Apparently, there is some sort of margin or padding surrounding icons, but I cannot reduce it. I've inspecting the css code, but did not find the place.
I attach screen capture and web url.
Could you please provide me with some advice?
Thanks in advance for your help.
Regards,
Juan
