1. sadegh5
  3. Monday, 18 June 2012
Hello All
thanks for your excellent support :)
I have a query regarding cell padding and article distance
I want to remove the text from features articles and use images instead
The trouble is distance between articles makes them look awkward
In general, regardless, is there anyway to use images on frontage
here is a sample , http://qisan.com/ where three main boxes in the middle of the page woks as links
In a nutshell, I want to know is there anyway to reduce the distance between featured articles , any extension or CSS way, which every is possibe
I have done some research so I would not have to bother you but have not been successful to find workable solutions
Would appreciate and value your advice
Kind regards
sadegh :) :lol:
Hi Sadegh
Would placing each image in a Custom HTML module (Extensions -> Module Manager -> New -> Custom HTML) with the title turned off and each module/image in the user1 module position (will cascade vertically be a suitable solution?
