1. BurtNL
  3. Sunday, 11 November 2018
I'm using your templates Hayley and Sophia. In the slider (J51_LayerSlideshow) I would love to have a 'Read more' button, like it is available in the template Maya.
So for the visitor it becomes more clear the header is clickable and leads to more information.
I can't find a setting for a Read more button in the module or template settings.
How can I get the Read more button visible in the slider?
Thanks, Burt
HI Burt
To do so you will have to creating an override for your slideshow module. If you are not familiar with created module overrides in Joomla, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will create the override for you. For our reference please paste a link to this post in your email.
Thanks for your response Ciaran.
I managed to create an override for the slideshow module and added the 'Read more' button with the link as set in the module settings itself.
Thanks, Burt
Good work. Thank you for the update!
