Some questions on template Layla.
After changing to template Layla, table rows sometimes have got a border (top and/or bottom), although there is no border code.
I have to set the border color to white to make this (grey) border invisible (or white if you want).
I have several pages with photos in tables. Not all tables have the same responsive view, although the code is the same.
Can main menu subitems made visible on smartphone as used to be in older templates? Now user has to return to the menu to see submenu items.
Can I change hyperlink formatting (color and font) in article text only, not affecting the hyperlinks in menus. I would also like to change hover effect only in article text. I used to change this directly in nexus.css but I cannot find it in the new template. Can you tell me in which line I can find these css rules?
How do I change main menu uppercase into lowercase (first character capital)? text-decoration: none doesn't change anything.
I would like to put the Search module on the position as shown in the template demo, but I can't find the name of that position.
Can I install an older version of J51_Layerslideshow to have nicer title and text effects?
Thank you for your answers.
Guy
