1. Oliver
  4. Wednesday, 24 August 2022
can you pls have a look at a project website on https://fotomuc.joomla100.de
I have a little problem with the menu.
On the menu item "Bildergalerie" > Wettbewerbe" we have three menu levels:
If you got to the years 2022 and 2021 pls try to reach the submenu items of 2021. On severeal browsers I have tested it it's nearly impossible to reach the items under 2021.
A friend of mine tested it with ios and safari, same there.
The mousecursor is jumping up and down.
Is it possible that the menu is not made to show such deep menu levels?
Do you see a chance to fix this?
Thanks in advance
Oliver
  1. https://fotomuc.joomla100.de/
Hi Oliver
.hornav > ul > li > ul > li > ul,
.hornav > ul > li > ul > li > ul > li > ul {
left: 100%;
right: auto;
Awesome Ciaran - works fine :)
Thank you very much!
Kind regards
Oliver
