1. reitano
  4. Sunday, 07 August 2022
I'd like to use the Progress Module as a Custom Field in my Virtuemart website.
I want to use it for: "Installation time" and "Difficulty" on every product page, each one with its different amount.
Is it possible to do this, also with some templating or custom service?
Sorry to say at present our progress module does not integrate with Virtuemart. The only option would be to create each module manually and then assign to your Virtuemart page using an extension like https://regularlabs.com/advancedmodulemanager
Thanks ciaran, I thought so…
And you confirmed.
Is it possible to create the module for all products and fill with proper data in each page?
Maybe using a class, an id or a string?
Hello Reitano,
I just saw your website: very nice! Has many nice solutions. Congrats.
Just a little bug in the off-canvas menu... (see attached image).
About your question, why don't you consider using the VM Custom Fields?
Otherwise, one progress module in each product description...
Thanks! I'm working hard on it!
Yes, that is because that menu comes from another component and not with the template itself, now fixed.
I'm looking for a simple solution, cause a module in each product means at least 250-300 modules...
