1. pmabdelaziz
  3. Sunday, 15 March 2020
Hello, I bought your Progress bar extension but I am not able to produce animated, good looking progress bar as you have in the demo page https://www.joomla51.com/demo/0164/index.php/module-extensions/progress-module
here are my settings
http://amd-is.com/progress/1.png
http://amd-is.com/progress/2.png
http://amd-is.com/progress/3.png
and here is my progress bar
http://amd-is.com/progress/4.png
only the number counts but there is no animation in the bar itself and bar in not divided as in your demo.
Thank you for your reply. I attached screenshots of all settings. Is that not helping? Unfortunately, I can't create temporary accounts on that website. but you may investigate the previous screenshot and give me a solution or a screenshot of the correct settings.
Thank you,
May I ask are you using a Joomla51 template? If not may I suggest sending a copy of your template so we can try and replicate the issue locally (info@joomla51.com - For our reference please paste a link to this post in your email).
  3. # 3
