1. Kiwi4711
  3. Wednesday, 19 April 2023
I installed the Layla template on Joomla 4.
On the menu "Rettungshunde" I placed a third level menu, which is not shown correctly. The font size of the second level is not correct, there is no link hover effect and the little arrow is missing.
Do I have to add something?
Thank you!
Kirsten
  1. https://www.testjoomla4.svlg07.de/
Hi Kirsten
.hornav ul ul .nav-item.module {
font-size: 13px;
padding: 7px 15px;
Thank you Ciaran, font-size is correct now. But there is still no link-hover effect and no right arrow.
Hi Kirsten
Is this still an issue for you? The arrow appears to be displayed (Rettungshunde -> Videos) and a hover effect is in place (tested chrome and firefox).
I can't see an arrow in "Videos-> Stöberprüfung" and no hover effect there (Chrome and Edge). I added a screenshot.
Kirsten
Hi Kirsten
.hornav ul.menu ul li a,
.hornav ul.menu ul li span {
display: block;
.hornav ul.menu .parent-indicator {
opacity: 1;
width: 10px;
Thank you Ciaran.
There is still no hover effect on "Videos", but the little arrow has now appeared.
Hi Kirsten
As 'videos' is now a divider, there is no hover effect. To amend this behaviour try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.hornav > ul > li > ul > li.divider:hover {
background: var(--button-color);
