1. green12
  3. Saturday, 06 January 2024
in joomla 4.4.1 I have problems with the icon module of the sophia template. These are the errors:
Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in /var/www/vhosts/http://paestumsites.it/httpdocs/mm4/modules/mod_j51icons/mod_j51icons.php on line 34
Warning: Undefined property: stdClass::$j51_override_style in /var/www/vhosts/http://paestumsites.it/httpdocs/mm4/modules/mod_j51icons/tmpl/default.php
could you help me? Thank you
  1. https://www.paestumsites.it/
any help with this problem?
Which version of the icon module are you using?
If you download your template sophia again from the j51 homepage, is there perhaps a newer version of the icon module included?
(Make a backup of the website beforehand!!)
When did the error occur? after an update?
Does opening the module settings and saving resolve the issue? If not, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
I'm using j51_icon version 2.0.20 installed together with sophia version 2.0.0 I think it's the latest package released.
I just upgraded from Joomla 3 to Joomla 4
Hi, I tried opening and saving the form but it didn't solve the problem. The problem only shows up if I enable error reporting on maximum.
I am not an expert in PHP warnings. But I also get several error messages from J51 extensions when I set error reporting to "Maximum".
Maybe cirian can say something about that?!
Bug reporting does not have to be set to "Maximum" in a LIVE page.
(But you definitely should have given this “MAXIMUM” INFO at the BEGINNING. Unfortunately, this is very often the PROBLEM in this FORUM, who don't bother to present their system and give all the IMPORTANT INFORMATION...)
I tried uninstalling Sophia and all the modules, I reinstalled everything but it still gives me the same error. I also noticed that it doesn't change the fonts. I set san serif for the logo but it shows a times font
Hi, as requested I am sending you the data to access my website
grazie
