1. ntsnet
  4. Monday, 10 April 2023
The two problems I have are -
1. The Sticky Menu won't stay - it just scrolls with the page.
2. Font Awesome is loading, but not showing the icons, only boxes with a line through them. Appears not to be finding the icon
With the stick menu problem, I had the same issue with the J3 template and you suggested this custom css -
.hornav, .hornavmenu,
.vegas-wrapper, .header-row {
z-index: 2080;
This worked for J3, but having tried it as a possible fix for the J4 version, it doesn't work!
Many thanks,
Paul
Link to the J4 site being built is below
  1. https://staging.somersetcaninemassage.co.uk
is there any solution available now for the sticky header problem?
Thanks for any information, even if its not solved, so we know we must switch to another template.
Oliver
is there a solution for this issue now? I have the same problem on J4 Harmony on a client site.
  1. https://neu.wiesbadener-schachverein.de/
So far I have tested the site with Chrome, Edge and Safari ( all current versions ) and all have the same problem. The header menu is sticky for a couple of times and then stops working! If you have found the same problem with Firefox, then it seems to be something with the template.
Sorry to pass on the bad news
Paul
Hi Paul
It has proven to be a difficult one for us to resolve :(
I just wish to check, we found the issue is only present in Firefox. In Chrome, the header sticks without issue. Are you finding the same?
Good luck with this one - I can't figure out why it will work two or three times exactly as expected, across different pages and then when you change to another page, it doesn't work and remains that way.
It must be in the sticky header code rather than other sections of the template!
Paul
Hi Paul
My apologies, I only realise that the header images are set via the template style settings and not the LayerSlideshow module. I have been able to replicate this issue locally which points to an issue with the template itself. We will examine this issue further and see can we find a resolution.
I can't seem to find that setting in the Template. The header image is set in the General / Body Header section and there is no showcase module.
This is the J4 Template.
Thanks,
Paul
Interesting.
Using Chrome the Home Page header is not sticking for me, but some of the other pages (About Me & Services/Treatment FAQs) do, but not all the time. Using Safari (16.41 on Monterey) then I couldn't get a sticky header at all, but cleared the caches and it worked for a while.
Using Safari (16.4 on Mac M1 Ventura 13.3) It seemed to work just fine at first, then moving between menu options and back to the Home Page and it stopped working. Same thing here too - clear the caches and it works for a while! Chrome also works, for a while...
Not sure why this should be
Hi Paul
Have you since been able to resolve this issue? Testing your homepage on both Chrome and Firefox, the header/menu is sticking on scroll.
OK, I have sorted the out the font-awesome stuff - I hadn't realised that we were now old to V5! My mistake.
Sticky menu still remains....
