1. bruno56
  3. Wednesday, 20 June 2018
HI,
the template is Boutique on joomla 3.88
page is
https://bioeticafestival.it/F/index.php/come-raggiungere-il-festival
google map does not appear - API V3 is registered and ok, permission to the domain is ok
Console says:
JQMIGRATE: Migrate is installed, version 1.4.1
jquery-migrate.min.js:2:542
SyntaxError: '' string literal contains an unescaped line break
come-raggiungere-il-festival:630:127
TypeError: this.settings.slides[nb] is undefined[Ulteriori informazioni]
but Iam not able to find the problem
help/suggestion very appreciated :-)
thanks
kind regards
Bruno
HI Ciaran,
Correct and thak you fo the suggetsion. Issue persist, so Boutique is OK,
Bruno
Hi Bruno
Just to ensure that this is a template related issue could I ask you to enable one of the default Joomla templates (Protostar) and check if the issue persists?
