1. andreash
  3. Thursday, 08 August 2019
I have the following problem with the Ariana template:
I chose the category blog layout. The amounts should be displayed with an introductory screen. On mobile phones this is a problem because the introductory image takes up too much space.
I think the picture would have to be squeezed over the post if the screen width falls below a certain size.
Thank you and kind regards
Andreas
  1. https://familienzeit-entdecken.de/tiere-hautnah
Many many thanks.
Andreas
.blog-alternative .item {
flex-direction: column;
