1. ThomasBraun
  3. Friday, 19 July 2019
Hi there,
I have J51_Haley installed and would like to switch to J51_Stella.
Seems there is an issue with mod_j51layerslideshow.
I installed a copy of the site here: http://www.rent-a-ruin.de
Actually the version 1.1.4 of the layerslideshow-module (came with J51_Haley) is installed.
The slideshow does not work as it should as you may see.
When upgrading to the version that comes with J51_Stella (1.1.9), the slideshow dissappears.
btw: in the demo-installer the version of layerslideshow is 1.1.1.
I already updated the template files to the latest version this morning.
Original site with J51_Haley and working layerslideshow may be seen here: https://www.braun-immowert.de/
Any idea how to solve this?
best regads,
Thomas
  1. http://www.rent-a-ruin.de
Sorry for late response.
The all-video-plugin was updated meanwhile.
This update solved the problem so that everything is fine now with the slideshow.
Hi Thomas
Does your JW-plugin module use the Owl Carousel script (https://owlcarousel2.github.io/OwlCarousel2/)? And if so which version is it loading?
the problem is the plugin AllVideos (by JoomlaWorks). The J51-layer-slideshow does not work when it's activated.
Both are actual, JW-plugin and J51-module.
When activating the AllVideo plugin this error appears in the console:
Uncaught TypeError: jQuery(...).owlCarousel is not a function
at HTMLDocument.<anonymous> (75dce4b827a13a4a46da6150d79f2be0.js:82)
at u (75dce4b827a13a4a46da6150d79f2be0.js:1)
at Object.fireWith [as resolveWith] (75dce4b827a13a4a46da6150d79f2be0.js:1)
at ready (75dce4b827a13a4a46da6150d79f2be0.js:1)
Any way to solve that?
Best regrads,
Thomas
Oh I see, it works now after killing the plugins.
So I need to figure out now, which one causes the problem - after my vacation.
Thank you!
Thomas
Have you since resolved this issue? Your slideshow appears to be now working correctly!
I now disabled a lot, slideshow is not shown.
You may do anything you want at this site-copy.
I see one error which seems to come from the slideshow (cause it disappears when I switch off the slideshow):
(index):654 Uncaught TypeError: jQuery(...).owlCarousel is not a function
at HTMLDocument.<anonymous> ((index):654)
at u (jquery.min.js?7b425aaa8a9eaa31f8e2b29eeb563f8a:2)
at Object.fireWith [as resolveWith] (jquery.min.js?7b425aaa8a9eaa31f8e2b29eeb563f8a:2)
at Function.ready (jquery.min.js?7b425aaa8a9eaa31f8e2b29eeb563f8a:2)
at HTMLDocument._ (jquery.min.js?7b425aaa8a9eaa31f8e2b29eeb563f8a:2)
Hi Thomas
There is a number console errors on your site which I suspect is coming from one of your enabled plugins. Could you disable any plugins you are not using.
thanks for reply!
No, opening and saving does not help.
Please use the credentials I sent.
more me below problem is solved... I did a reinstall of the complete template (update from 17.July) and LayerSlideshow module. Now its running.
Oliver
quite the same problem here.
I installed a fresh version of Stella and then the mod_layerslideshow and configured 3 images (no text).
I can slide them manually but its not running automatically.
I uninstalled LayerSlideshow version 1.1.7 and installed 1.1.6 and then 1.1.5.. no of them running. So it might be a problem with the template itself? Or maybe with the reference of the js-file?
I have errors on maximum but I see none.
Only thing see I see in source code is a little syntax error in the reference of <script src="https://cdnjs.cloudflare.com/ajax/libs/waypoints/4.0.1/noframework.waypoints.min.js""></script> but thats not the reason I am sure.
Do you have found a solution? Or a workaround? Should I install an older version than 1.1.5?
Oliver
Hi Thomas
Does opening your slideshow module setting and saving resolve the issue? If not may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
