1. youreinlucknow
  3. Wednesday, 26 September 2012
I'm using J51 Evolution template (great by the way) and I can not see the <hr/> in my articles.
I'm having the issue whether I use TinyMCE, JCK or JCE editors.
I've used Firebug to try finding the files to make the modifications I want to make (visible for one, preferably solid and black) but I can not find any "hr" anywhere in the template files.
Could you please help me find and fix this issue.?
Thanks,
Rob
Hi Rob
Would you have a URL to an example of your <hr> tag?
Well, I've used the various editors to insert the <hr> tag.
The code appears in the article like this: <hr />
It shows up as black in the back-end but when published it is not visible - although Firebug "sees it."
URL:
The site is off-line - under development.
I could set up admin rights for you if you think tat would help....
If you could it would be great. You can send any access details to info@joomla51.com
Thanks Rob
May I suggest adding the following to the Custom CSS field of your templates parameters..
[code type=css]hr {
border-bottom: 2px solid #000000;
height: 10px;
}[/code]
You can edit this to your own taste where #000000 is the line color, 2px the thickness and solid the state (solid/dashed/dotted/double).
Thanks for the quick reply and action.
I have zero knowledge of where to put the code you've suggested...."Custom CSS field of your templates parameters."
Could you tell me specifically where that is?
Thanks a bunch.
Rob
Sure.. from your Joomla administration navigate to Extensions -> Template Manager -> J51_[YourTemplate] -> Custom CSS. In the given field, add the code and click save.
Thanks so much Ciaran. Worked like a charm.
Cheers,
Rob
