1. Bugsys
  3. Sunday, 28 October 2018
I have some problems with the template Hayley and the slideshow. (http://www.biancas-papierwelten.de)
1. Is it normal that the pictures are cut off at the bottom? How can I change it so that the whole pictures are displayed?
2. If you look the slideshow on the phone, the pictures are displayed completely. Slide title and caption are not displayed, which is also correct. But however, the black background box is still displayed. How can I delete the black caption box in the phone view?
And another question: How can I create a header image for the other pages (Karten, Boxen, Impressum, Datenschutz)? And can I create a different picture for any other pages?
Thank you very much and regards
Helmut
  1. http://www.biancas-papierwelten.de
Hi Helmut
1. Does increasing the Max Height field in the Settings tab of your module settings resolve the issue?
2. To amend you can add the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.layerslideshow .info-wrapper {
	display: none;
3. Presuming I understand you correctly, an option is available to set a header image in the Genereal -> Body/Header Styling tab of your template settings. To apply different template settings to different pages on your site, may I suggest the following.... https://www.joomla51.com/tutorials/joomla-basics/creating-multiple-template-styles
thank you for your great help!
Helmut
