On the final stage of the installation when I select install 'default english sample data' and select install, I get this massive error message and the installation fails:
All the pre-installation checks pass fine.
Table 'ecweb_2016b.#__viewlevels' doesn't exist SQL=/*!40000 ALTER TABLE `#__viewlevels` ENABLE KEYS */
Table 'ecweb_2016b.#__viewlevels' doesn't exist SQL=INSERT INTO `#__viewlevels` VALUES (1,'Public',0,'[1]'),(2,'Registered',1,'[6,2,8]'),(3,'Special',2,'[6,3,8]'),(4,'Customer Access Level (Example)',3,'[6,3,12]')
Table 'ecweb_2016b.#__viewlevels' doesn't exist SQL=/*!40000 ALTER TABLE `#__viewlevels` DISABLE KEYS */
Table 'ecweb_2016b.#__viewlevels' doesn't exist SQL=LOCK TABLES `#__viewlevels` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__viewlevels` ( `id` int(10) unsigned NOT NULL AUTO_INCREMENT COMMENT 'Primary Key', `title` varchar(100) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `ordering` int(11) NOT NULL DEFAULT '0', `rules` varchar(5120) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'JSON encoded access control.', PRIMARY KEY (`id`), UNIQUE KEY `idx_assetgroup_title_lookup` (`title`) ) ENGINE=InnoDB AUTO_INCREMENT=5 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__utf8_conversion' doesn't exist SQL=/*!40000 ALTER TABLE `#__utf8_conversion` ENABLE KEYS */
Table 'ecweb_2016b.#__utf8_conversion' doesn't exist SQL=INSERT INTO `#__utf8_conversion` VALUES (2)
Table 'ecweb_2016b.#__utf8_conversion' doesn't exist SQL=/*!40000 ALTER TABLE `#__utf8_conversion` DISABLE KEYS */
Table 'ecweb_2016b.#__utf8_conversion' doesn't exist SQL=LOCK TABLES `#__utf8_conversion` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__utf8_conversion` ( `converted` tinyint(4) NOT NULL DEFAULT '0' ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__usergroups' doesn't exist SQL=/*!40000 ALTER TABLE `#__usergroups` ENABLE KEYS */
Table 'ecweb_2016b.#__usergroups' doesn't exist SQL=INSERT INTO `#__usergroups` VALUES (1,0,1,20,'Public'),(2,1,6,17,'Registered'),(3,2,7,14,'Author'),(4,3,8,11,'Editor'),(5,4,9,10,'Publisher'),(6,1,2,5,'Manager'),(7,6,3,4,'Administrator'),(8,1,18,19,'Super Users'),(10,3,12,13,'Shop Suppliers (Example)'),(12,2,15,16,'Customer Group (Example)')
Table 'ecweb_2016b.#__usergroups' doesn't exist SQL=/*!40000 ALTER TABLE `#__usergroups` DISABLE KEYS */
Table 'ecweb_2016b.#__usergroups' doesn't exist SQL=LOCK TABLES `#__usergroups` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__usergroups` ( `id` int(10) unsigned NOT NULL AUTO_INCREMENT COMMENT 'Primary Key', `parent_id` int(10) unsigned NOT NULL DEFAULT '0' COMMENT 'Adjacency List Reference Id', `lft` int(11) NOT NULL DEFAULT '0' COMMENT 'Nested set lft.', `rgt` int(11) NOT NULL DEFAULT '0' COMMENT 'Nested set rgt.', `title` varchar(100) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', PRIMARY KEY (`id`), UNIQUE KEY `idx_usergroup_parent_title_lookup` (`parent_id`,`title`), KEY `idx_usergroup_title_lookup` (`title`), KEY `idx_usergroup_adjacency_lookup` (`parent_id`), KEY `idx_usergroup_nested_set_lookup` (`lft`,`rgt`) USING BTREE ) ENGINE=InnoDB AUTO_INCREMENT=13 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__user_usergroup_map' doesn't exist SQL=/*!40000 ALTER TABLE `#__user_usergroup_map` ENABLE KEYS */
Table 'ecweb_2016b.#__user_usergroup_map' doesn't exist SQL=INSERT INTO `#__user_usergroup_map` VALUES (3,8),(16,8),(25,8),(26,2),(27,2),(28,2),(29,2),(30,2),(31,2),(32,2),(45,8),(75,8),(100,8),(238,8),(292,8),(321,8),(324,8),(455,8),(480,8),(557,8),(570,8),(579,8),(593,8),(619,8),(684,8),(728,8),(739,8),(772,8),(787,8),(871,8),(874,8),(879,8),(920,8),(925,8),(926,8),(975,8),(979,8)
Table 'ecweb_2016b.#__user_usergroup_map' doesn't exist SQL=/*!40000 ALTER TABLE `#__user_usergroup_map` DISABLE KEYS */
Table 'ecweb_2016b.#__user_usergroup_map' doesn't exist SQL=LOCK TABLES `#__user_usergroup_map` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__user_usergroup_map` ( `user_id` int(10) unsigned NOT NULL DEFAULT '0' COMMENT 'Foreign Key to #__users.id', `group_id` int(10) unsigned NOT NULL DEFAULT '0' COMMENT 'Foreign Key to #__usergroups.id', PRIMARY KEY (`user_id`,`group_id`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__user_profiles' doesn't exist SQL=/*!40000 ALTER TABLE `#__user_profiles` ENABLE KEYS */
Table 'ecweb_2016b.#__user_profiles' doesn't exist SQL=/*!40000 ALTER TABLE `#__user_profiles` DISABLE KEYS */
Table 'ecweb_2016b.#__user_profiles' doesn't exist SQL=LOCK TABLES `#__user_profiles` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__user_profiles` ( `user_id` int(11) NOT NULL, `profile_key` varchar(100) COLLATE utf8mb4_unicode_ci NOT NULL, `profile_value` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `ordering` int(11) NOT NULL DEFAULT '0', UNIQUE KEY `idx_user_id_profile_key` (`user_id`,`profile_key`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci COMMENT='Simple user profile storage table'
Table 'ecweb_2016b.#__user_notes' doesn't exist SQL=/*!40000 ALTER TABLE `#__user_notes` ENABLE KEYS */
Table 'ecweb_2016b.#__user_notes' doesn't exist SQL=/*!40000 ALTER TABLE `#__user_notes` DISABLE KEYS */
Table 'ecweb_2016b.#__user_notes' doesn't exist SQL=LOCK TABLES `#__user_notes` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__user_notes` ( `id` int(10) unsigned NOT NULL AUTO_INCREMENT, `user_id` int(10) unsigned NOT NULL DEFAULT '0', `catid` int(10) unsigned NOT NULL DEFAULT '0', `subject` varchar(100) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `body` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `state` tinyint(3) NOT NULL DEFAULT '0', `checked_out` int(10) unsigned NOT NULL DEFAULT '0', `checked_out_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `created_user_id` int(10) unsigned NOT NULL DEFAULT '0', `created_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `modified_user_id` int(10) unsigned NOT NULL, `modified_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `review_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `publish_up` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `publish_down` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', PRIMARY KEY (`id`), KEY `idx_user_id` (`user_id`), KEY `idx_category_id` (`catid`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__user_keys' doesn't exist SQL=/*!40000 ALTER TABLE `#__user_keys` ENABLE KEYS */
Table 'ecweb_2016b.#__user_keys' doesn't exist SQL=INSERT INTO `#__user_keys` VALUES (1,'admin','$2y$10$OdW1DXlzFOXNhNPva11OS.VlEJioJE/o.YQ9rmnNXGy8DNrF/bDZa','InrXdUdsKqK9Hev3kJuQ',0,'1430050207','e558cc3ab471d683d25efef8efca754b')
Table 'ecweb_2016b.#__user_keys' doesn't exist SQL=/*!40000 ALTER TABLE `#__user_keys` DISABLE KEYS */
Table 'ecweb_2016b.#__user_keys' doesn't exist SQL=LOCK TABLES `#__user_keys` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__user_keys` ( `id` int(10) unsigned NOT NULL AUTO_INCREMENT, `user_id` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL, `token` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL, `series` varchar(191) COLLATE utf8mb4_unicode_ci NOT NULL, `invalid` tinyint(4) NOT NULL, `time` varchar(200) COLLATE utf8mb4_unicode_ci NOT NULL, `uastring` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL, PRIMARY KEY (`id`), UNIQUE KEY `series` (`series`), UNIQUE KEY `series_2` (`series`), UNIQUE KEY `series_3` (`series`), KEY `user_id` (`user_id`(191)) ) ENGINE=InnoDB AUTO_INCREMENT=2 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__update_sites_extensions' doesn't exist SQL=/*!40000 ALTER TABLE `#__update_sites_extensions` ENABLE KEYS */
Table 'ecweb_2016b.#__update_sites_extensions' doesn't exist SQL=INSERT INTO `#__update_sites_extensions` VALUES (1,700),(2,700),(3,866),(4,801)
Table 'ecweb_2016b.#__update_sites_extensions' doesn't exist SQL=/*!40000 ALTER TABLE `#__update_sites_extensions` DISABLE KEYS */
Table 'ecweb_2016b.#__update_sites_extensions' doesn't exist SQL=LOCK TABLES `#__update_sites_extensions` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__update_sites_extensions` ( `update_site_id` int(11) NOT NULL DEFAULT '0', `extension_id` int(11) NOT NULL DEFAULT '0', PRIMARY KEY (`update_site_id`,`extension_id`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci COMMENT='Links extensions to update sites'
Table 'ecweb_2016b.#__update_sites' doesn't exist SQL=/*!40000 ALTER TABLE `#__update_sites` ENABLE KEYS */
Table 'ecweb_2016b.#__update_sites' doesn't exist SQL=INSERT INTO `#__update_sites` VALUES (1,'','collection','http://update.joomla.org/core/list.xml',1,1459462374,''),(2,'','collection','http://update.joomla.org/jed/list.xml',1,1459462374,''),(3,'Joomla! Update Component Update Site','extension','http://update.joomla.org/core/extensions/com_joomlaupdate.xml',1,0,''),(4,'Weblinks Update Site','extension','https://raw.githubusercontent.com/joomla-extensions/weblinks/master/manifest.xml',1,0,'')
Table 'ecweb_2016b.#__update_sites' doesn't exist SQL=/*!40000 ALTER TABLE `#__update_sites` DISABLE KEYS */
Table 'ecweb_2016b.#__update_sites' doesn't exist SQL=LOCK TABLES `#__update_sites` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__update_sites` ( `update_site_id` int(11) NOT NULL AUTO_INCREMENT, `name` varchar(100) COLLATE utf8mb4_unicode_ci DEFAULT '', `type` varchar(20) COLLATE utf8mb4_unicode_ci DEFAULT '', `location` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `enabled` int(11) DEFAULT '0', `last_check_timestamp` bigint(20) DEFAULT '0', `extra_query` varchar(1000) COLLATE utf8mb4_unicode_ci DEFAULT '', PRIMARY KEY (`update_site_id`) ) ENGINE=InnoDB AUTO_INCREMENT=5 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci COMMENT='Update Sites'
Table 'ecweb_2016b.#__ucm_history' doesn't exist SQL=/*!40000 ALTER TABLE `#__ucm_history` ENABLE KEYS */
Table 'ecweb_2016b.#__ucm_history' doesn't exist SQL=/*!40000 ALTER TABLE `#__ucm_history` DISABLE KEYS */
Table 'ecweb_2016b.#__ucm_history' doesn't exist SQL=LOCK TABLES `#__ucm_history` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__ucm_history` ( `version_id` int(10) unsigned NOT NULL AUTO_INCREMENT, `ucm_item_id` int(10) unsigned NOT NULL, `ucm_type_id` int(10) unsigned NOT NULL, `version_note` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '' COMMENT 'Optional version name', `save_date` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `editor_user_id` int(10) unsigned NOT NULL DEFAULT '0', `character_count` int(10) unsigned NOT NULL DEFAULT '0' COMMENT 'Number of characters in this version.', `sha1_hash` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '' COMMENT 'SHA1 hash of the version_data column.', `version_data` longtext COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'json-encoded string of version data', `keep_forever` tinyint(4) NOT NULL DEFAULT '0' COMMENT '0=auto delete; 1=keep', PRIMARY KEY (`version_id`), KEY `idx_ucm_item_id` (`ucm_type_id`,`ucm_item_id`), KEY `idx_save_date` (`save_date`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__ucm_content' doesn't exist SQL=/*!40000 ALTER TABLE `#__ucm_content` ENABLE KEYS */
Table 'ecweb_2016b.#__ucm_content' doesn't exist SQL=/*!40000 ALTER TABLE `#__ucm_content` DISABLE KEYS */
Table 'ecweb_2016b.#__ucm_content' doesn't exist SQL=LOCK TABLES `#__ucm_content` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__ucm_content` ( `core_content_id` int(10) unsigned NOT NULL AUTO_INCREMENT, `core_type_alias` varchar(400) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '' COMMENT 'FK to the content types table', `core_title` varchar(400) COLLATE utf8mb4_unicode_ci NOT NULL, `core_alias` varchar(400) CHARACTER SET utf8mb4 COLLATE utf8mb4_bin NOT NULL DEFAULT '', `core_body` longtext COLLATE utf8mb4_unicode_ci NOT NULL, `core_state` tinyint(1) NOT NULL DEFAULT '0', `core_checked_out_time` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `core_checked_out_user_id` int(10) unsigned NOT NULL DEFAULT '0', `core_access` int(10) unsigned NOT NULL DEFAULT '0', `core_params` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `core_featured` tinyint(4) unsigned NOT NULL DEFAULT '0', `core_metadata` varchar(2048) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'JSON encoded metadata properties.', `core_created_user_id` int(10) unsigned NOT NULL DEFAULT '0', `core_created_by_alias` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `core_created_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `core_modified_user_id` int(10) unsigned NOT NULL DEFAULT '0' COMMENT 'Most recent user that modified', `core_modified_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `core_language` char(7) COLLATE utf8mb4_unicode_ci NOT NULL, `core_publish_up` datetime NOT NULL, `core_publish_down` datetime NOT NULL, `core_content_item_id` int(10) unsigned DEFAULT NULL COMMENT 'ID from the individual type table', `asset_id` int(10) unsigned DEFAULT NULL COMMENT 'FK to the #__assets table.', `core_images` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `core_urls` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `core_hits` int(10) unsigned NOT NULL DEFAULT '0', `core_version` int(10) unsigned NOT NULL DEFAULT '1', `core_ordering` int(11) NOT NULL DEFAULT '0', `core_metakey` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `core_metadesc` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `core_catid` int(10) unsigned NOT NULL DEFAULT '0', `core_xreference` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'A reference to enable linkages to external data sets.', `core_type_id` int(10) unsigned DEFAULT NULL, PRIMARY KEY (`core_content_id`), KEY `tag_idx` (`core_state`,`core_access`), KEY `idx_access` (`core_access`), KEY `idx_language` (`core_language`), KEY `idx_modified_time` (`core_modified_time`), KEY `idx_created_time` (`core_created_time`), KEY `idx_core_modified_user_id` (`core_modified_user_id`), KEY `idx_core_checked_out_user_id` (`core_checked_out_user_id`), KEY `idx_core_created_user_id` (`core_created_user_id`), KEY `idx_core_type_id` (`core_type_id`), KEY `idx_alias` (`core_alias`(100)), KEY `idx_title` (`core_title`(100)), KEY `idx_content_type` (`core_type_alias`(100)) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci COMMENT='Contains core content data in name spaced fields'
Table 'ecweb_2016b.#__ucm_base' doesn't exist SQL=/*!40000 ALTER TABLE `#__ucm_base` ENABLE KEYS */
Table 'ecweb_2016b.#__ucm_base' doesn't exist SQL=/*!40000 ALTER TABLE `#__ucm_base` DISABLE KEYS */
Table 'ecweb_2016b.#__ucm_base' doesn't exist SQL=LOCK TABLES `#__ucm_base` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__ucm_base` ( `ucm_id` int(10) unsigned NOT NULL, `ucm_item_id` int(10) NOT NULL, `ucm_type_id` int(11) NOT NULL, `ucm_language_id` int(11) NOT NULL, PRIMARY KEY (`ucm_id`), KEY `idx_ucm_item_id` (`ucm_item_id`), KEY `idx_ucm_type_id` (`ucm_type_id`), KEY `idx_ucm_language_id` (`ucm_language_id`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__template_styles' doesn't exist SQL=/*!40000 ALTER TABLE `#__template_styles` ENABLE KEYS */
Table 'ecweb_2016b.#__template_styles' doesn't exist SQL=INSERT INTO `#__template_styles` VALUES (2,'bluestork',1,'0','Bluestork - Default','{\"useRoundedCorners\":\"1\",\"showSiteName\":\"0\"}'),(3,'atomic',0,'0','Atomic - Default','{}'),(4,'beez_20',0,'0','Beez2 - Default','{\"wrapperSmall\":\"53\",\"wrapperLarge\":\"72\",\"logo\":\"images\\/joomla_black.gif\",\"sitetitle\":\"Joomla!\",\"sitedescription\":\"Open Source Content Management\",\"navposition\":\"left\",\"templatecolor\":\"personal\",\"html5\":\"0\"}'),(5,'hathor',1,'0','Hathor - Default','{\"showSiteName\":\"0\",\"colourChoice\":\"\",\"boldText\":\"0\"}'),(6,'beez5',0,'0','Beez5 - Default','{\"wrapperSmall\":\"53\",\"wrapperLarge\":\"72\",\"logo\":\"images\\/sampledata\\/fruitshop\\/fruits.gif\",\"sitetitle\":\"Joomla!\",\"sitedescription\":\"Open Source Content Management\",\"navposition\":\"left\",\"html5\":\"0\"}'),(114,'beez_20',0,'0','Beez2 - Parks Site','{\"wrapperSmall\":\"53\",\"wrapperLarge\":\"72\",\"logo\":\"\",\"sitetitle\":\"Australian Parks\",\"sitedescription\":\"Parks Sample Site\",\"navposition\":\"center\",\"templatecolor\":\"nature\"}'),(266,'beez3',0,'0','beez3 - Default','{\"wrapperSmall\":\"53\",\"wrapperLarge\":\"72\",\"sitetitle\":\"\",\"sitedescription\":\"\",\"navposition\":\"center\",\"templatecolor\":\"nature\",\"backgroundcolor\":\"#eee\"}'),(267,'isis',1,'1','isis - Default','{\"templateColor\":\"#13294A\",\"headerColor\":\"#184A7D\",\"logoFile\":\"\",\"admin_menus\":\"1\",\"displayHeader\":\"1\",\"statusFixed\":\"1\",\"stickyToolbar\":\"1\"}'),(268,'protostar',0,'0','protostar - Default','{\"templateColor\":\"#08C\",\"templateBackgroundColor\":\"#F4F6F7\",\"logoFile\":\"\",\"sitetitle\":\"\",\"sitedescription\":\"\",\"googleFont\":\"1\",\"googleFontName\":\"Open+Sans\",\"fluidContainer\":\"0\"}'),(469,'j51_nadia',0,'0','J51_Nadia - Homepage','{\"bgcolor\":\"#38373d\",\"headerslideshow\":\"{\\\"header_slide_image\\\":[\\\"images\\/bg_image1.jpg\\\"]}\",\"headerslideinterval\":\"5000\",\"headerslidewidth\":\"2000\",\"headerslideheight\":\"0\",\"header_color\":\"#000000\",\"header_opacity\":\"0.6\",\"top1_color\":\"#ffffff\",\"top1_opacity\":\"0.9\",\"top1_bg\":\"\",\"top2_color\":\"#ffffff\",\"top2_opacity\":\"1.0\",\"top2_bg\":\"\",\"top3_color\":\"#f2f2f2\",\"top3_opacity\":\"0.9\",\"top3_bg\":\"\",\"elementcolor3\":\"#ffffff\",\"elementcolor4\":\"1.0\",\"elementcolor7\":\"#ffffff\",\"elementcolor16\":\"#38373d\",\"elementcolor13\":\"1.0\",\"bottom1_bg\":\"images\\/bg_image2.jpg\",\"elementcolor18\":\"#f2f2f2\",\"elementcolor19\":\"1.0\",\"bottom2_bg\":\"\",\"elementcolor9\":\"#0f0e10\",\"elementcolor20\":\"1.0\",\"body_fontsize\":\"16px\",\"body_fontstyle\":\"Source+Sans+Pro\",\"h1head_fontstyle\":\"Source+Sans+Pro\",\"articlehead_fontstyle\":\"Source+Sans+Pro\",\"modulehead_fontstyle\":\"Source+Sans+Pro\",\"hornav_fontstyle\":\"Source+Sans+Pro\",\"font_subset\":\"latin\",\"fontawesome_sw\":\"1\",\"body_font_color\":\"#383838\",\"articletitle_font_color\":\"#787878\",\"modulehead_font_color\":\"#0f0f0f\",\"content_link_color\":\"#8c8c8c\",\"button_color\":\"#111111\",\"button_hover_color\":\"#212121\",\"hornav_menu\":\"mainmenu\",\"hornav_font_color\":\"#ffffff\",\"hornav_ddbackground_color\":\"#0f0f0f\",\"hornavPosition\":\"0\",\"footer_menu\":\"samplemenu\",\"footermenuPosition\":\"0\",\"logoImage\":\"1\",\"logoimagefile\":\"\",\"logo_x\":\"0\",\"logo_y\":\"0\",\"logoText\":\"Nadia\",\"logo_fontstyle\":\"Great+Vibes\",\"logo_font_color\":\"#ffffff\",\"sloganText\":\"A JOOMLA51 TEMPLATE\",\"slogan_font_color\":\"#ffffff\",\"wrapper_width\":\"1140\",\"column_layout\":\"SCOLA-COM-SCOLB\",\"sidecola_width\":\"33\",\"sidecolb_width\":\"33\",\"responsive_sw\":\"1\",\"sidecol_responsive_pos\":\"after\",\"res_header_sw\":\"1\",\"res_top1_sw\":\"1\",\"res_top2_sw\":\"1\",\"res_top3_sw\":\"1\",\"res_sidecola_sw\":\"1\",\"res_sidecolb_sw\":\"1\",\"res_bottom_sw\":\"1\",\"res_base_sw\":\"1\",\"tabport_css\":\"\",\"mobland_css\":\"\",\"mobport_css\":\"\",\"top1_auto\":\"0\",\"top1_padding\":\"0\",\"top_1a_manual\":\"16.6\",\"top_1b_manual\":\"16.6\",\"top_1c_manual\":\"16.6\",\"top_1d_manual\":\"16.6\",\"top_1e_manual\":\"16.6\",\"top_1f_manual\":\"16.6\",\"top2_auto\":\"0\",\"top2_padding\":\"0\",\"top_2a_manual\":\"16.6\",\"top_2b_manual\":\"16.6\",\"top_2c_manual\":\"16.6\",\"top_2d_manual\":\"16.6\",\"top_2e_manual\":\"16.6\",\"top_2f_manual\":\"16.6\",\"top3_auto\":\"0\",\"top3_padding\":\"0\",\"top_3a_manual\":\"16.6\",\"top_3b_manual\":\"16.6\",\"top_3c_manual\":\"16.6\",\"top_3d_manual\":\"16.6\",\"top_3e_manual\":\"16.6\",\"top_3f_manual\":\"16.6\",\"contenttop_auto\":\"0\",\"contenttop_a_manual\":\"33\",\"contenttop_b_manual\":\"33\",\"contenttop_c_manual\":\"33\",\"contentbottom_auto\":\"0\",\"contentbottom_a_manual\":\"33\",\"contentbottom_b_manual\":\"33\",\"contentbottom_c_manual\":\"33\",\"bottom1_auto\":\"1\",\"bottom_padding\":\"0\",\"bottom_1a_manual\":\"100\",\"bottom_1b_manual\":\"33.3\",\"bottom_1c_manual\":\"33.3\",\"bottom_1d_manual\":\"33.3\",\"bottom_1e_manual\":\"16.6\",\"bottom_1f_manual\":\"16.6\",\"bottom2_auto\":\"1\",\"bottom2_padding\":\"0\",\"bottom_2a_manual\":\"100\",\"bottom_2b_manual\":\"33.3\",\"bottom_2c_manual\":\"33.3\",\"bottom_2d_manual\":\"33.3\",\"bottom_2e_manual\":\"16.6\",\"bottom_2f_manual\":\"16.6\",\"base1_auto\":\"0\",\"base1_padding\":\"0\",\"base_1a_manual\":\"16.6\",\"base_1b_manual\":\"16.6\",\"base_1c_manual\":\"16.6\",\"base_1d_manual\":\"16.6\",\"base_1e_manual\":\"16.6\",\"base_1f_manual\":\"16.6\",\"base2_auto\":\"0\",\"base2_padding\":\"0\",\"base_2a_manual\":\"16.6\",\"base_2b_manual\":\"16.6\",\"base_2c_manual\":\"16.6\",\"base_2d_manual\":\"16.6\",\"base_2e_manual\":\"16.6\",\"base_2f_manual\":\"16.6\",\"copyright\":\"© 2016 Your Copyright Info\",\"social_style\":\"#ffffff\",\"social_rss\":\"\",\"social_twitter\":\"\",\"social_facebook\":\"\",\"social_googleplus\":\"\",\"social_youtube\":\"\",\"social_pinterest\":\"\",\"social_instagram\":\"\",\"social_dribbble\":\"\",\"social_flickr\":\"\",\"social_linkedin\":\"\",\"social_vimeo\":\"\",\"social_yahoo\":\"\",\"social_tumblr\":\"\",\"social_custom\":\"{\\\"social_custom_icon\\\":[],\\\"social_custom_name\\\":[],\\\"social_custom_url\\\":[],\\\"social_custom_hover\\\":[]}\",\"custom_css\":\"\",\"customcss_sw\":\"0\",\"head_custom_code\":\"\",\"body_custom_code\":\"\"}'),(470,'j51_nadia',0,'1','J51_Nadia - Default','{\"bgcolor\":\"#ebebeb\",\"headerslideshow\":\"{\\\"header_slide_image\\\":[]}\",\"headerslideinterval\":\"5000\",\"headerslidewidth\":\"2000\",\"headerslideheight\":\"0\",\"header_color\":\"#000000\",\"header_opacity\":\"0.8\",\"top1_color\":\"#f5f5f5\",\"top1_opacity\":\"1.0\",\"top1_bg\":\"\",\"top2_color\":\"#ffffff\",\"top2_opacity\":\"1.0\",\"top2_bg\":\"\",\"top3_color\":\"#f2f2f2\",\"top3_opacity\":\"0.9\",\"top3_bg\":\"\",\"elementcolor3\":\"#ffffff\",\"elementcolor4\":\"1.0\",\"elementcolor7\":\"#ffffff\",\"elementcolor16\":\"#38373d\",\"elementcolor13\":\"1.0\",\"bottom1_bg\":\"images\\/bg_image2.jpg\",\"elementcolor18\":\"#f2f2f2\",\"elementcolor19\":\"1.0\",\"bottom2_bg\":\"\",\"elementcolor9\":\"#0f0e10\",\"elementcolor20\":\"1.0\",\"body_fontsize\":\"16px\",\"body_fontstyle\":\"Source+Sans+Pro\",\"h1head_fontstyle\":\"Source+Sans+Pro\",\"articlehead_fontstyle\":\"Source+Sans+Pro\",\"modulehead_fontstyle\":\"Source+Sans+Pro\",\"hornav_fontstyle\":\"Source+Sans+Pro\",\"font_subset\":\"latin\",\"fontawesome_sw\":\"1\",\"body_font_color\":\"#383838\",\"articletitle_font_color\":\"#616161\",\"modulehead_font_color\":\"#0f0f0f\",\"content_link_color\":\"#8c8c8c\",\"button_color\":\"#111111\",\"button_hover_color\":\"#212121\",\"hornav_menu\":\"mainmenu\",\"hornav_font_color\":\"#ffffff\",\"hornav_ddbackground_color\":\"#0f0f0f\",\"hornavPosition\":\"0\",\"footer_menu\":\"samplemenu\",\"footermenuPosition\":\"0\",\"logoImage\":\"1\",\"logoimagefile\":\"\",\"logo_x\":\"0\",\"logo_y\":\"0\",\"logoText\":\"Nadia\",\"logo_fontstyle\":\"Great+Vibes\",\"logo_font_color\":\"#ffffff\",\"sloganText\":\"A JOOMLA51 TEMPLATE\",\"slogan_font_color\":\"#ffffff\",\"wrapper_width\":\"1140\",\"column_layout\":\"SCOLA-COM-SCOLB\",\"sidecola_width\":\"25\",\"sidecolb_width\":\"25\",\"responsive_sw\":\"1\",\"sidecol_responsive_pos\":\"after\",\"res_header_sw\":\"1\",\"res_top1_sw\":\"1\",\"res_top2_sw\":\"1\",\"res_top3_sw\":\"1\",\"res_sidecola_sw\":\"1\",\"res_sidecolb_sw\":\"1\",\"res_bottom_sw\":\"1\",\"res_base_sw\":\"1\",\"tabport_css\":\"\",\"mobland_css\":\"\",\"mobport_css\":\"\",\"top1_auto\":\"0\",\"top1_padding\":\"0\",\"top_1a_manual\":\"16.6\",\"top_1b_manual\":\"16.6\",\"top_1c_manual\":\"16.6\",\"top_1d_manual\":\"16.6\",\"top_1e_manual\":\"16.6\",\"top_1f_manual\":\"16.6\",\"top2_auto\":\"0\",\"top2_padding\":\"0\",\"top_2a_manual\":\"16.6\",\"top_2b_manual\":\"16.6\",\"top_2c_manual\":\"16.6\",\"top_2d_manual\":\"16.6\",\"top_2e_manual\":\"16.6\",\"top_2f_manual\":\"16.6\",\"top3_auto\":\"0\",\"top3_padding\":\"0\",\"top_3a_manual\":\"16.6\",\"top_3b_manual\":\"16.6\",\"top_3c_manual\":\"16.6\",\"top_3d_manual\":\"16.6\",\"top_3e_manual\":\"16.6\",\"top_3f_manual\":\"16.6\",\"contenttop_auto\":\"0\",\"contenttop_a_manual\":\"33\",\"contenttop_b_manual\":\"33\",\"contenttop_c_manual\":\"33\",\"contentbottom_auto\":\"0\",\"contentbottom_a_manual\":\"33\",\"contentbottom_b_manual\":\"33\",\"contentbottom_c_manual\":\"33\",\"bottom1_auto\":\"0\",\"bottom_padding\":\"0\",\"bottom_1a_manual\":\"16.6\",\"bottom_1b_manual\":\"16.6\",\"bottom_1c_manual\":\"16.6\",\"bottom_1d_manual\":\"16.6\",\"bottom_1e_manual\":\"16.6\",\"bottom_1f_manual\":\"16.6\",\"bottom2_auto\":\"0\",\"bottom2_padding\":\"0\",\"bottom_2a_manual\":\"16.6\",\"bottom_2b_manual\":\"16.6\",\"bottom_2c_manual\":\"16.6\",\"bottom_2d_manual\":\"16.6\",\"bottom_2e_manual\":\"16.6\",\"bottom_2f_manual\":\"16.6\",\"base1_auto\":\"0\",\"base1_padding\":\"0\",\"base_1a_manual\":\"16.6\",\"base_1b_manual\":\"16.6\",\"base_1c_manual\":\"16.6\",\"base_1d_manual\":\"16.6\",\"base_1e_manual\":\"16.6\",\"base_1f_manual\":\"16.6\",\"base2_auto\":\"0\",\"base2_padding\":\"0\",\"base_2a_manual\":\"16.6\",\"base_2b_manual\":\"16.6\",\"base_2c_manual\":\"16.6\",\"base_2d_manual\":\"16.6\",\"base_2e_manual\":\"16.6\",\"base_2f_manual\":\"16.6\",\"copyright\":\"© 2016 Your Copyright Info\",\"social_style\":\"#ffffff\",\"social_rss\":\"\",\"social_twitter\":\"\",\"social_facebook\":\"\",\"social_googleplus\":\"\",\"social_youtube\":\"\",\"social_pinterest\":\"\",\"social_instagram\":\"\",\"social_dribbble\":\"\",\"social_flickr\":\"\",\"social_linkedin\":\"\",\"social_vimeo\":\"\",\"social_yahoo\":\"\",\"social_tumblr\":\"\",\"social_custom\":\"{\\\"social_custom_icon\\\":[],\\\"social_custom_name\\\":[],\\\"social_custom_url\\\":[],\\\"social_custom_hover\\\":[]}\",\"custom_css\":\"\",\"customcss_sw\":\"0\",\"head_custom_code\":\"\",\"body_custom_code\":\"\"}'),(471,'j51_nadia',0,'0','J51_Nadia - Header Slideshow Example','{\"bgcolor\":\"#ebebeb\",\"headerslideshow\":\"{\\\"header_slide_image\\\":[\\\"images\\/slideshow\\/slide1.jpg\\\",\\\"images\\/slideshow\\/slide2.jpg\\\",\\\"images\\/slideshow\\/slide3.jpg\\\"]}\",\"headerslideinterval\":\"4000\",\"headerslidewidth\":\"2000\",\"headerslideheight\":\"0\",\"header_color\":\"#000000\",\"header_opacity\":\"0.8\",\"top1_color\":\"#f5f5f5\",\"top1_opacity\":\"1.0\",\"top1_bg\":\"\",\"top2_color\":\"#ffffff\",\"top2_opacity\":\"1.0\",\"top2_bg\":\"\",\"top3_color\":\"#f2f2f2\",\"top3_opacity\":\"0.9\",\"top3_bg\":\"\",\"elementcolor3\":\"#ffffff\",\"elementcolor4\":\"1.0\",\"elementcolor7\":\"#ffffff\",\"elementcolor16\":\"#38373d\",\"elementcolor13\":\"1.0\",\"bottom1_bg\":\"images\\/bg_image2.jpg\",\"elementcolor18\":\"#f2f2f2\",\"elementcolor19\":\"1.0\",\"bottom2_bg\":\"\",\"elementcolor9\":\"#0f0e10\",\"elementcolor20\":\"1.0\",\"body_fontsize\":\"16px\",\"body_fontstyle\":\"Source+Sans+Pro\",\"h1head_fontstyle\":\"Source+Sans+Pro\",\"articlehead_fontstyle\":\"Source+Sans+Pro\",\"modulehead_fontstyle\":\"Source+Sans+Pro\",\"hornav_fontstyle\":\"Source+Sans+Pro\",\"font_subset\":\"latin\",\"fontawesome_sw\":\"1\",\"body_font_color\":\"#383838\",\"articletitle_font_color\":\"#787878\",\"modulehead_font_color\":\"#0f0f0f\",\"content_link_color\":\"#8c8c8c\",\"button_color\":\"#111111\",\"button_hover_color\":\"#212121\",\"hornav_menu\":\"mainmenu\",\"hornav_font_color\":\"#ffffff\",\"hornav_ddbackground_color\":\"#0f0f0f\",\"hornavPosition\":\"0\",\"footer_menu\":\"samplemenu\",\"footermenuPosition\":\"0\",\"logoImage\":\"1\",\"logoimagefile\":\"\",\"logo_x\":\"0\",\"logo_y\":\"0\",\"logoText\":\"Nadia\",\"logo_fontstyle\":\"Great+Vibes\",\"logo_font_color\":\"#ffffff\",\"sloganText\":\"A JOOMLA51 TEMPLATE\",\"slogan_font_color\":\"#ffffff\",\"wrapper_width\":\"1140\",\"column_layout\":\"SCOLA-COM-SCOLB\",\"sidecola_width\":\"25\",\"sidecolb_width\":\"25\",\"responsive_sw\":\"1\",\"sidecol_responsive_pos\":\"after\",\"res_header_sw\":\"1\",\"res_top1_sw\":\"1\",\"res_top2_sw\":\"1\",\"res_top3_sw\":\"1\",\"res_sidecola_sw\":\"1\",\"res_sidecolb_sw\":\"1\",\"res_bottom_sw\":\"1\",\"res_base_sw\":\"1\",\"tabport_css\":\"\",\"mobland_css\":\"\",\"mobport_css\":\"\",\"top1_auto\":\"0\",\"top1_padding\":\"0\",\"top_1a_manual\":\"16.6\",\"top_1b_manual\":\"16.6\",\"top_1c_manual\":\"16.6\",\"top_1d_manual\":\"16.6\",\"top_1e_manual\":\"16.6\",\"top_1f_manual\":\"16.6\",\"top2_auto\":\"0\",\"top2_padding\":\"0\",\"top_2a_manual\":\"16.6\",\"top_2b_manual\":\"16.6\",\"top_2c_manual\":\"16.6\",\"top_2d_manual\":\"16.6\",\"top_2e_manual\":\"16.6\",\"top_2f_manual\":\"16.6\",\"top3_auto\":\"0\",\"top3_padding\":\"0\",\"top_3a_manual\":\"16.6\",\"top_3b_manual\":\"16.6\",\"top_3c_manual\":\"16.6\",\"top_3d_manual\":\"16.6\",\"top_3e_manual\":\"16.6\",\"top_3f_manual\":\"16.6\",\"contenttop_auto\":\"0\",\"contenttop_a_manual\":\"33\",\"contenttop_b_manual\":\"33\",\"contenttop_c_manual\":\"33\",\"contentbottom_auto\":\"0\",\"contentbottom_a_manual\":\"33\",\"contentbottom_b_manual\":\"33\",\"contentbottom_c_manual\":\"33\",\"bottom1_auto\":\"0\",\"bottom_padding\":\"0\",\"bottom_1a_manual\":\"16.6\",\"bottom_1b_manual\":\"16.6\",\"bottom_1c_manual\":\"16.6\",\"bottom_1d_manual\":\"16.6\",\"bottom_1e_manual\":\"16.6\",\"bottom_1f_manual\":\"16.6\",\"bottom2_auto\":\"0\",\"bottom2_padding\":\"0\",\"bottom_2a_manual\":\"16.6\",\"bottom_2b_manual\":\"16.6\",\"bottom_2c_manual\":\"16.6\",\"bottom_2d_manual\":\"16.6\",\"bottom_2e_manual\":\"16.6\",\"bottom_2f_manual\":\"16.6\",\"base1_auto\":\"0\",\"base1_padding\":\"0\",\"base_1a_manual\":\"16.6\",\"base_1b_manual\":\"16.6\",\"base_1c_manual\":\"16.6\",\"base_1d_manual\":\"16.6\",\"base_1e_manual\":\"16.6\",\"base_1f_manual\":\"16.6\",\"base2_auto\":\"0\",\"base2_padding\":\"0\",\"base_2a_manual\":\"16.6\",\"base_2b_manual\":\"16.6\",\"base_2c_manual\":\"16.6\",\"base_2d_manual\":\"16.6\",\"base_2e_manual\":\"16.6\",\"base_2f_manual\":\"16.6\",\"copyright\":\"© 2016 Your Copyright Info\",\"social_style\":\"#ffffff\",\"social_rss\":\"\",\"social_twitter\":\"\",\"social_facebook\":\"\",\"social_googleplus\":\"\",\"social_youtube\":\"\",\"social_pinterest\":\"\",\"social_instagram\":\"\",\"social_dribbble\":\"\",\"social_flickr\":\"\",\"social_linkedin\":\"\",\"social_vimeo\":\"\",\"social_yahoo\":\"\",\"social_tumblr\":\"\",\"social_custom\":\"{\\\"social_custom_icon\\\":[],\\\"social_custom_name\\\":[],\\\"social_custom_url\\\":[],\\\"social_custom_hover\\\":[]}\",\"custom_css\":\"\",\"customcss_sw\":\"0\",\"head_custom_code\":\"\",\"body_custom_code\":\"\"}'),(472,'j51_nadia',0,'0','J51_Nadia - Layout Options - SSC','{\"bgcolor\":\"#ebebeb\",\"headerslideshow\":\"{\\\"header_slide_image\\\":[]}\",\"headerslideinterval\":\"5000\",\"headerslidewidth\":\"2000\",\"headerslideheight\":\"0\",\"header_color\":\"#000000\",\"header_opacity\":\"0.8\",\"top1_color\":\"#f5f5f5\",\"top1_opacity\":\"1.0\",\"top1_bg\":\"\",\"top2_color\":\"#ffffff\",\"top2_opacity\":\"1.0\",\"top2_bg\":\"\",\"top3_color\":\"#f2f2f2\",\"top3_opacity\":\"0.9\",\"top3_bg\":\"\",\"elementcolor3\":\"#ffffff\",\"elementcolor4\":\"1.0\",\"elementcolor7\":\"#ffffff\",\"elementcolor16\":\"#38373d\",\"elementcolor13\":\"1.0\",\"bottom1_bg\":\"images\\/bg_image2.jpg\",\"elementcolor18\":\"#f2f2f2\",\"elementcolor19\":\"1.0\",\"bottom2_bg\":\"\",\"elementcolor9\":\"#0f0e10\",\"elementcolor20\":\"1.0\",\"body_fontsize\":\"16px\",\"body_fontstyle\":\"Source+Sans+Pro\",\"h1head_fontstyle\":\"Source+Sans+Pro\",\"articlehead_fontstyle\":\"Source+Sans+Pro\",\"modulehead_fontstyle\":\"Source+Sans+Pro\",\"hornav_fontstyle\":\"Source+Sans+Pro\",\"font_subset\":\"latin\",\"fontawesome_sw\":\"1\",\"body_font_color\":\"#383838\",\"articletitle_font_color\":\"#787878\",\"modulehead_font_color\":\"#0f0f0f\",\"content_link_color\":\"#8c8c8c\",\"button_color\":\"#111111\",\"button_hover_color\":\"#212121\",\"hornav_menu\":\"mainmenu\",\"hornav_font_color\":\"#ffffff\",\"hornav_ddbackground_color\":\"#0f0f0f\",\"hornavPosition\":\"0\",\"footer_menu\":\"samplemenu\",\"footermenuPosition\":\"0\",\"logoImage\":\"1\",\"logoimagefile\":\"\",\"logo_x\":\"0\",\"logo_y\":\"0\",\"logoText\":\"Nadia\",\"logo_fontstyle\":\"Great+Vibes\",\"logo_font_color\":\"#ffffff\",\"sloganText\":\"A JOOMLA51 TEMPLATE\",\"slogan_font_color\":\"#ffffff\",\"wrapper_width\":\"1140\",\"column_layout\":\"SCOLA-SCOLB-COM\",\"sidecola_width\":\"25\",\"sidecolb_width\":\"25\",\"responsive_sw\":\"1\",\"sidecol_responsive_pos\":\"after\",\"res_header_sw\":\"1\",\"res_top1_sw\":\"1\",\"res_top2_sw\":\"1\",\"res_top3_sw\":\"1\",\"res_sidecola_sw\":\"1\",\"res_sidecolb_sw\":\"1\",\"res_bottom_sw\":\"1\",\"res_base_sw\":\"1\",\"tabport_css\":\"\",\"mobland_css\":\"\",\"mobport_css\":\"\",\"top1_auto\":\"0\",\"top1_padding\":\"0\",\"top_1a_manual\":\"16.6\",\"top_1b_manual\":\"16.6\",\"top_1c_manual\":\"16.6\",\"top_1d_manual\":\"16.6\",\"top_1e_manual\":\"16.6\",\"top_1f_manual\":\"16.6\",\"top2_auto\":\"0\",\"top2_padding\":\"0\",\"top_2a_manual\":\"16.6\",\"top_2b_manual\":\"16.6\",\"top_2c_manual\":\"16.6\",\"top_2d_manual\":\"16.6\",\"top_2e_manual\":\"16.6\",\"top_2f_manual\":\"16.6\",\"top3_auto\":\"0\",\"top3_padding\":\"0\",\"top_3a_manual\":\"16.6\",\"top_3b_manual\":\"16.6\",\"top_3c_manual\":\"16.6\",\"top_3d_manual\":\"16.6\",\"top_3e_manual\":\"16.6\",\"top_3f_manual\":\"16.6\",\"contenttop_auto\":\"0\",\"contenttop_a_manual\":\"33\",\"contenttop_b_manual\":\"33\",\"contenttop_c_manual\":\"33\",\"contentbottom_auto\":\"0\",\"contentbottom_a_manual\":\"33\",\"contentbottom_b_manual\":\"33\",\"contentbottom_c_manual\":\"33\",\"bottom1_auto\":\"0\",\"bottom_padding\":\"0\",\"bottom_1a_manual\":\"16.6\",\"bottom_1b_manual\":\"16.6\",\"bottom_1c_manual\":\"16.6\",\"bottom_1d_manual\":\"16.6\",\"bottom_1e_manual\":\"16.6\",\"bottom_1f_manual\":\"16.6\",\"bottom2_auto\":\"0\",\"bottom2_padding\":\"0\",\"bottom_2a_manual\":\"16.6\",\"bottom_2b_manual\":\"16.6\",\"bottom_2c_manual\":\"16.6\",\"bottom_2d_manual\":\"16.6\",\"bottom_2e_manual\":\"16.6\",\"bottom_2f_manual\":\"16.6\",\"base1_auto\":\"0\",\"base1_padding\":\"0\",\"base_1a_manual\":\"16.6\",\"base_1b_manual\":\"16.6\",\"base_1c_manual\":\"16.6\",\"base_1d_manual\":\"16.6\",\"base_1e_manual\":\"16.6\",\"base_1f_manual\":\"16.6\",\"base2_auto\":\"0\",\"base2_padding\":\"0\",\"base_2a_manual\":\"16.6\",\"base_2b_manual\":\"16.6\",\"base_2c_manual\":\"16.6\",\"base_2d_manual\":\"16.6\",\"base_2e_manual\":\"16.6\",\"base_2f_manual\":\"16.6\",\"copyright\":\"© 2016 Your Copyright Info\",\"social_style\":\"#ffffff\",\"social_rss\":\"\",\"social_twitter\":\"\",\"social_facebook\":\"\",\"social_googleplus\":\"\",\"social_youtube\":\"\",\"social_pinterest\":\"\",\"social_instagram\":\"\",\"social_dribbble\":\"\",\"social_flickr\":\"\",\"social_linkedin\":\"\",\"social_vimeo\":\"\",\"social_yahoo\":\"\",\"social_tumblr\":\"\",\"social_custom\":\"{\\\"social_custom_icon\\\":[],\\\"social_custom_name\\\":[],\\\"social_custom_url\\\":[],\\\"social_custom_hover\\\":[]}\",\"custom_css\":\"\",\"customcss_sw\":\"0\",\"head_custom_code\":\"\",\"body_custom_code\":\"\"}'),(473,'j51_nadia',0,'0','J51_Nadia - Layout Options - CSS','{\"bgcolor\":\"#ebebeb\",\"headerslideshow\":\"{\\\"header_slide_image\\\":[]}\",\"headerslideinterval\":\"5000\",\"headerslidewidth\":\"2000\",\"headerslideheight\":\"0\",\"header_color\":\"#000000\",\"header_opacity\":\"0.8\",\"top1_color\":\"#f5f5f5\",\"top1_opacity\":\"1.0\",\"top1_bg\":\"\",\"top2_color\":\"#ffffff\",\"top2_opacity\":\"1.0\",\"top2_bg\":\"\",\"top3_color\":\"#f2f2f2\",\"top3_opacity\":\"0.9\",\"top3_bg\":\"\",\"elementcolor3\":\"#ffffff\",\"elementcolor4\":\"1.0\",\"elementcolor7\":\"#ffffff\",\"elementcolor16\":\"#38373d\",\"elementcolor13\":\"1.0\",\"bottom1_bg\":\"images\\/bg_image2.jpg\",\"elementcolor18\":\"#f2f2f2\",\"elementcolor19\":\"1.0\",\"bottom2_bg\":\"\",\"elementcolor9\":\"#0f0e10\",\"elementcolor20\":\"1.0\",\"body_fontsize\":\"16px\",\"body_fontstyle\":\"Source+Sans+Pro\",\"h1head_fontstyle\":\"Source+Sans+Pro\",\"articlehead_fontstyle\":\"Source+Sans+Pro\",\"modulehead_fontstyle\":\"Source+Sans+Pro\",\"hornav_fontstyle\":\"Source+Sans+Pro\",\"font_subset\":\"latin\",\"fontawesome_sw\":\"1\",\"body_font_color\":\"#383838\",\"articletitle_font_color\":\"#787878\",\"modulehead_font_color\":\"#0f0f0f\",\"content_link_color\":\"#8c8c8c\",\"button_color\":\"#111111\",\"button_hover_color\":\"#212121\",\"hornav_menu\":\"mainmenu\",\"hornav_font_color\":\"#ffffff\",\"hornav_ddbackground_color\":\"#0f0f0f\",\"hornavPosition\":\"0\",\"footer_menu\":\"samplemenu\",\"footermenuPosition\":\"0\",\"logoImage\":\"1\",\"logoimagefile\":\"\",\"logo_x\":\"0\",\"logo_y\":\"0\",\"logoText\":\"Nadia\",\"logo_fontstyle\":\"Great+Vibes\",\"logo_font_color\":\"#ffffff\",\"sloganText\":\"A JOOMLA51 TEMPLATE\",\"slogan_font_color\":\"#ffffff\",\"wrapper_width\":\"1140\",\"column_layout\":\"COM-SCOLA-SCOLB\",\"sidecola_width\":\"25\",\"sidecolb_width\":\"25\",\"responsive_sw\":\"1\",\"sidecol_responsive_pos\":\"after\",\"res_header_sw\":\"1\",\"res_top1_sw\":\"1\",\"res_top2_sw\":\"1\",\"res_top3_sw\":\"1\",\"res_sidecola_sw\":\"1\",\"res_sidecolb_sw\":\"1\",\"res_bottom_sw\":\"1\",\"res_base_sw\":\"1\",\"tabport_css\":\"\",\"mobland_css\":\"\",\"mobport_css\":\"\",\"top1_auto\":\"0\",\"top1_padding\":\"0\",\"top_1a_manual\":\"16.6\",\"top_1b_manual\":\"16.6\",\"top_1c_manual\":\"16.6\",\"top_1d_manual\":\"16.6\",\"top_1e_manual\":\"16.6\",\"top_1f_manual\":\"16.6\",\"top2_auto\":\"0\",\"top2_padding\":\"0\",\"top_2a_manual\":\"16.6\",\"top_2b_manual\":\"16.6\",\"top_2c_manual\":\"16.6\",\"top_2d_manual\":\"16.6\",\"top_2e_manual\":\"16.6\",\"top_2f_manual\":\"16.6\",\"top3_auto\":\"0\",\"top3_padding\":\"0\",\"top_3a_manual\":\"16.6\",\"top_3b_manual\":\"16.6\",\"top_3c_manual\":\"16.6\",\"top_3d_manual\":\"16.6\",\"top_3e_manual\":\"16.6\",\"top_3f_manual\":\"16.6\",\"contenttop_auto\":\"0\",\"contenttop_a_manual\":\"33\",\"contenttop_b_manual\":\"33\",\"contenttop_c_manual\":\"33\",\"contentbottom_auto\":\"0\",\"contentbottom_a_manual\":\"33\",\"contentbottom_b_manual\":\"33\",\"contentbottom_c_manual\":\"33\",\"bottom1_auto\":\"0\",\"bottom_padding\":\"0\",\"bottom_1a_manual\":\"16.6\",\"bottom_1b_manual\":\"16.6\",\"bottom_1c_manual\":\"16.6\",\"bottom_1d_manual\":\"16.6\",\"bottom_1e_manual\":\"16.6\",\"bottom_1f_manual\":\"16.6\",\"bottom2_auto\":\"0\",\"bottom2_padding\":\"0\",\"bottom_2a_manual\":\"16.6\",\"bottom_2b_manual\":\"16.6\",\"bottom_2c_manual\":\"16.6\",\"bottom_2d_manual\":\"16.6\",\"bottom_2e_manual\":\"16.6\",\"bottom_2f_manual\":\"16.6\",\"base1_auto\":\"0\",\"base1_padding\":\"0\",\"base_1a_manual\":\"16.6\",\"base_1b_manual\":\"16.6\",\"base_1c_manual\":\"16.6\",\"base_1d_manual\":\"16.6\",\"base_1e_manual\":\"16.6\",\"base_1f_manual\":\"16.6\",\"base2_auto\":\"0\",\"base2_padding\":\"0\",\"base_2a_manual\":\"16.6\",\"base_2b_manual\":\"16.6\",\"base_2c_manual\":\"16.6\",\"base_2d_manual\":\"16.6\",\"base_2e_manual\":\"16.6\",\"base_2f_manual\":\"16.6\",\"copyright\":\"© 2016 Your Copyright Info\",\"social_style\":\"#ffffff\",\"social_rss\":\"\",\"social_twitter\":\"\",\"social_facebook\":\"\",\"social_googleplus\":\"\",\"social_youtube\":\"\",\"social_pinterest\":\"\",\"social_instagram\":\"\",\"social_dribbble\":\"\",\"social_flickr\":\"\",\"social_linkedin\":\"\",\"social_vimeo\":\"\",\"social_yahoo\":\"\",\"social_tumblr\":\"\",\"social_custom\":\"{\\\"social_custom_icon\\\":[],\\\"social_custom_name\\\":[],\\\"social_custom_url\\\":[],\\\"social_custom_hover\\\":[]}\",\"custom_css\":\"\",\"customcss_sw\":\"0\",\"head_custom_code\":\"\",\"body_custom_code\":\"\"}'),(474,'j51_nadia',0,'0','J51_Nadia - Example Style 1','{\"bgcolor\":\"#ebebeb\",\"headerslideshow\":\"{\\\"header_slide_image\\\":[\\\"images\\/bg_style1.jpg\\\"]}\",\"headerslideinterval\":\"5000\",\"headerslidewidth\":\"2000\",\"headerslideheight\":\"0\",\"header_color\":\"#002f4f\",\"header_opacity\":\"0.8\",\"top1_color\":\"#f5f5f5\",\"top1_opacity\":\"1.0\",\"top1_bg\":\"\",\"top2_color\":\"#002f4f\",\"top2_opacity\":\"1.0\",\"top2_bg\":\"\",\"top3_color\":\"#f2f2f2\",\"top3_opacity\":\"0.9\",\"top3_bg\":\"\",\"elementcolor3\":\"#ffffff\",\"elementcolor4\":\"1.0\",\"elementcolor7\":\"#ffffff\",\"elementcolor16\":\"#002f4f\",\"elementcolor13\":\"0.9\",\"bottom1_bg\":\"\",\"elementcolor18\":\"#f2f2f2\",\"elementcolor19\":\"0.6\",\"bottom2_bg\":\"\",\"elementcolor9\":\"#000f1a\",\"elementcolor20\":\"1.0\",\"body_fontsize\":\"16px\",\"body_fontstyle\":\"Source+Sans+Pro\",\"h1head_fontstyle\":\"Source+Sans+Pro\",\"articlehead_fontstyle\":\"Source+Sans+Pro\",\"modulehead_fontstyle\":\"Source+Sans+Pro\",\"hornav_fontstyle\":\"Source+Sans+Pro\",\"font_subset\":\"latin\",\"fontawesome_sw\":\"1\",\"body_font_color\":\"#383838\",\"articletitle_font_color\":\"#28506e\",\"modulehead_font_color\":\"#0f0f0f\",\"content_link_color\":\"#8c8c8c\",\"button_color\":\"#35698f\",\"button_hover_color\":\"#28506e\",\"hornav_menu\":\"mainmenu\",\"hornav_font_color\":\"#ffffff\",\"hornav_ddbackground_color\":\"#0f0f0f\",\"hornavPosition\":\"0\",\"footer_menu\":\"samplemenu\",\"footermenuPosition\":\"0\",\"logoImage\":\"1\",\"logoimagefile\":\"\",\"logo_x\":\"0\",\"logo_y\":\"0\",\"logoText\":\"Nadia\",\"logo_fontstyle\":\"Great+Vibes\",\"logo_font_color\":\"#ffffff\",\"sloganText\":\"A JOOMLA51 TEMPLATE\",\"slogan_font_color\":\"#ffffff\",\"wrapper_width\":\"1140\",\"column_layout\":\"SCOLA-COM-SCOLB\",\"sidecola_width\":\"25\",\"sidecolb_width\":\"40\",\"responsive_sw\":\"1\",\"sidecol_responsive_pos\":\"after\",\"res_header_sw\":\"1\",\"res_top1_sw\":\"1\",\"res_top2_sw\":\"1\",\"res_top3_sw\":\"1\",\"res_sidecola_sw\":\"1\",\"res_sidecolb_sw\":\"1\",\"res_bottom_sw\":\"1\",\"res_base_sw\":\"1\",\"tabport_css\":\"\",\"mobland_css\":\"\",\"mobport_css\":\"\",\"top1_auto\":\"0\",\"top1_padding\":\"0\",\"top_1a_manual\":\"16.6\",\"top_1b_manual\":\"16.6\",\"top_1c_manual\":\"16.6\",\"top_1d_manual\":\"16.6\",\"top_1e_manual\":\"16.6\",\"top_1f_manual\":\"16.6\",\"top2_auto\":\"0\",\"top2_padding\":\"0\",\"top_2a_manual\":\"16.6\",\"top_2b_manual\":\"16.6\",\"top_2c_manual\":\"16.6\",\"top_2d_manual\":\"16.6\",\"top_2e_manual\":\"16.6\",\"top_2f_manual\":\"16.6\",\"top3_auto\":\"0\",\"top3_padding\":\"0\",\"top_3a_manual\":\"16.6\",\"top_3b_manual\":\"16.6\",\"top_3c_manual\":\"16.6\",\"top_3d_manual\":\"16.6\",\"top_3e_manual\":\"16.6\",\"top_3f_manual\":\"16.6\",\"contenttop_auto\":\"0\",\"contenttop_a_manual\":\"33\",\"contenttop_b_manual\":\"33\",\"contenttop_c_manual\":\"33\",\"contentbottom_auto\":\"0\",\"contentbottom_a_manual\":\"33\",\"contentbottom_b_manual\":\"33\",\"contentbottom_c_manual\":\"33\",\"bottom1_auto\":\"0\",\"bottom_padding\":\"0\",\"bottom_1a_manual\":\"16.6\",\"bottom_1b_manual\":\"16.6\",\"bottom_1c_manual\":\"16.6\",\"bottom_1d_manual\":\"16.6\",\"bottom_1e_manual\":\"16.6\",\"bottom_1f_manual\":\"16.6\",\"bottom2_auto\":\"1\",\"bottom2_padding\":\"0\",\"bottom_2a_manual\":\"100\",\"bottom_2b_manual\":\"33.3\",\"bottom_2c_manual\":\"33.3\",\"bottom_2d_manual\":\"33.3\",\"bottom_2e_manual\":\"16.6\",\"bottom_2f_manual\":\"16.6\",\"base1_auto\":\"0\",\"base1_padding\":\"0\",\"base_1a_manual\":\"16.6\",\"base_1b_manual\":\"16.6\",\"base_1c_manual\":\"16.6\",\"base_1d_manual\":\"16.6\",\"base_1e_manual\":\"16.6\",\"base_1f_manual\":\"16.6\",\"base2_auto\":\"0\",\"base2_padding\":\"0\",\"base_2a_manual\":\"16.6\",\"base_2b_manual\":\"16.6\",\"base_2c_manual\":\"16.6\",\"base_2d_manual\":\"16.6\",\"base_2e_manual\":\"16.6\",\"base_2f_manual\":\"16.6\",\"copyright\":\"© 2016 Your Copyright Info\",\"social_style\":\"#ffffff\",\"social_rss\":\"\",\"social_twitter\":\"\",\"social_facebook\":\"\",\"social_googleplus\":\"\",\"social_youtube\":\"\",\"social_pinterest\":\"\",\"social_instagram\":\"\",\"social_dribbble\":\"\",\"social_flickr\":\"\",\"social_linkedin\":\"\",\"social_vimeo\":\"\",\"social_yahoo\":\"\",\"social_tumblr\":\"\",\"social_custom\":\"{\\\"social_custom_icon\\\":[],\\\"social_custom_name\\\":[],\\\"social_custom_url\\\":[],\\\"social_custom_hover\\\":[]}\",\"custom_css\":\"\",\"customcss_sw\":\"0\",\"head_custom_code\":\"\",\"body_custom_code\":\"\"}'),(475,'j51_nadia',0,'0','J51_Nadia - Example Style 2','{\"bgcolor\":\"#ebebeb\",\"headerslideshow\":\"{\\\"header_slide_image\\\":[\\\"images\\/bg_style2.jpg\\\"]}\",\"headerslideinterval\":\"5000\",\"headerslidewidth\":\"2000\",\"headerslideheight\":\"0\",\"header_color\":\"#302942\",\"header_opacity\":\"0.8\",\"top1_color\":\"#f5f5f5\",\"top1_opacity\":\"1.0\",\"top1_bg\":\"\",\"top2_color\":\"#2d2938\",\"top2_opacity\":\"1.0\",\"top2_bg\":\"\",\"top3_color\":\"#f2f2f2\",\"top3_opacity\":\"0.9\",\"top3_bg\":\"\",\"elementcolor3\":\"#ffffff\",\"elementcolor4\":\"1.0\",\"elementcolor7\":\"#ffffff\",\"elementcolor16\":\"#2d2938\",\"elementcolor13\":\"0.9\",\"bottom1_bg\":\"\",\"elementcolor18\":\"#f2f2f2\",\"elementcolor19\":\"0.6\",\"bottom2_bg\":\"\",\"elementcolor9\":\"#181421\",\"elementcolor20\":\"1.0\",\"body_fontsize\":\"16px\",\"body_fontstyle\":\"Source+Sans+Pro\",\"h1head_fontstyle\":\"Source+Sans+Pro\",\"articlehead_fontstyle\":\"Source+Sans+Pro\",\"modulehead_fontstyle\":\"Source+Sans+Pro\",\"hornav_fontstyle\":\"Source+Sans+Pro\",\"font_subset\":\"latin\",\"fontawesome_sw\":\"1\",\"body_font_color\":\"#383838\",\"articletitle_font_color\":\"#2d2938\",\"modulehead_font_color\":\"#0f0f0f\",\"content_link_color\":\"#8c8c8c\",\"button_color\":\"#665c80\",\"button_hover_color\":\"#9089a3\",\"hornav_menu\":\"mainmenu\",\"hornav_font_color\":\"#ffffff\",\"hornav_ddbackground_color\":\"#181421\",\"hornavPosition\":\"0\",\"footer_menu\":\"samplemenu\",\"footermenuPosition\":\"0\",\"logoImage\":\"1\",\"logoimagefile\":\"\",\"logo_x\":\"0\",\"logo_y\":\"0\",\"logoText\":\"Nadia\",\"logo_fontstyle\":\"Great+Vibes\",\"logo_font_color\":\"#ffffff\",\"sloganText\":\"A JOOMLA51 TEMPLATE\",\"slogan_font_color\":\"#ffffff\",\"wrapper_width\":\"1140\",\"column_layout\":\"SCOLA-COM-SCOLB\",\"sidecola_width\":\"25\",\"sidecolb_width\":\"40\",\"responsive_sw\":\"1\",\"sidecol_responsive_pos\":\"after\",\"res_header_sw\":\"1\",\"res_top1_sw\":\"1\",\"res_top2_sw\":\"1\",\"res_top3_sw\":\"1\",\"res_sidecola_sw\":\"1\",\"res_sidecolb_sw\":\"1\",\"res_bottom_sw\":\"1\",\"res_base_sw\":\"1\",\"tabport_css\":\"\",\"mobland_css\":\"\",\"mobport_css\":\"\",\"top1_auto\":\"0\",\"top1_padding\":\"0\",\"top_1a_manual\":\"16.6\",\"top_1b_manual\":\"16.6\",\"top_1c_manual\":\"16.6\",\"top_1d_manual\":\"16.6\",\"top_1e_manual\":\"16.6\",\"top_1f_manual\":\"16.6\",\"top2_auto\":\"0\",\"top2_padding\":\"0\",\"top_2a_manual\":\"16.6\",\"top_2b_manual\":\"16.6\",\"top_2c_manual\":\"16.6\",\"top_2d_manual\":\"16.6\",\"top_2e_manual\":\"16.6\",\"top_2f_manual\":\"16.6\",\"top3_auto\":\"0\",\"top3_padding\":\"0\",\"top_3a_manual\":\"16.6\",\"top_3b_manual\":\"16.6\",\"top_3c_manual\":\"16.6\",\"top_3d_manual\":\"16.6\",\"top_3e_manual\":\"16.6\",\"top_3f_manual\":\"16.6\",\"contenttop_auto\":\"0\",\"contenttop_a_manual\":\"33\",\"contenttop_b_manual\":\"33\",\"contenttop_c_manual\":\"33\",\"contentbottom_auto\":\"0\",\"contentbottom_a_manual\":\"33\",\"contentbottom_b_manual\":\"33\",\"contentbottom_c_manual\":\"33\",\"bottom1_auto\":\"0\",\"bottom_padding\":\"0\",\"bottom_1a_manual\":\"16.6\",\"bottom_1b_manual\":\"16.6\",\"bottom_1c_manual\":\"16.6\",\"bottom_1d_manual\":\"16.6\",\"bottom_1e_manual\":\"16.6\",\"bottom_1f_manual\":\"16.6\",\"bottom2_auto\":\"1\",\"bottom2_padding\":\"0\",\"bottom_2a_manual\":\"100\",\"bottom_2b_manual\":\"33.3\",\"bottom_2c_manual\":\"33.3\",\"bottom_2d_manual\":\"33.3\",\"bottom_2e_manual\":\"16.6\",\"bottom_2f_manual\":\"16.6\",\"base1_auto\":\"0\",\"base1_padding\":\"0\",\"base_1a_manual\":\"16.6\",\"base_1b_manual\":\"16.6\",\"base_1c_manual\":\"16.6\",\"base_1d_manual\":\"16.6\",\"base_1e_manual\":\"16.6\",\"base_1f_manual\":\"16.6\",\"base2_auto\":\"0\",\"base2_padding\":\"0\",\"base_2a_manual\":\"16.6\",\"base_2b_manual\":\"16.6\",\"base_2c_manual\":\"16.6\",\"base_2d_manual\":\"16.6\",\"base_2e_manual\":\"16.6\",\"base_2f_manual\":\"16.6\",\"copyright\":\"© 2016 Your Copyright Info\",\"social_style\":\"#ffffff\",\"social_rss\":\"\",\"social_twitter\":\"\",\"social_facebook\":\"\",\"social_googleplus\":\"\",\"social_youtube\":\"\",\"social_pinterest\":\"\",\"social_instagram\":\"\",\"social_dribbble\":\"\",\"social_flickr\":\"\",\"social_linkedin\":\"\",\"social_vimeo\":\"\",\"social_yahoo\":\"\",\"social_tumblr\":\"\",\"social_custom\":\"{\\\"social_custom_icon\\\":[],\\\"social_custom_name\\\":[],\\\"social_custom_url\\\":[],\\\"social_custom_hover\\\":[]}\",\"custom_css\":\"\",\"customcss_sw\":\"0\",\"head_custom_code\":\"\",\"body_custom_code\":\"\"}'),(476,'j51_nadia',0,'0','J51_Nadia - Example Style 3','{\"bgcolor\":\"#ebebeb\",\"headerslideshow\":\"{\\\"header_slide_image\\\":[\\\"images\\/bg_style3.jpg\\\"]}\",\"headerslideinterval\":\"5000\",\"headerslidewidth\":\"2000\",\"headerslideheight\":\"0\",\"header_color\":\"#40352b\",\"header_opacity\":\"0.8\",\"top1_color\":\"#f5f5f5\",\"top1_opacity\":\"1.0\",\"top1_bg\":\"\",\"top2_color\":\"#3f342a\",\"top2_opacity\":\"1.0\",\"top2_bg\":\"\",\"top3_color\":\"#f2f2f2\",\"top3_opacity\":\"0.9\",\"top3_bg\":\"\",\"elementcolor3\":\"#ffffff\",\"elementcolor4\":\"1.0\",\"elementcolor7\":\"#ffffff\",\"elementcolor16\":\"#332f2b\",\"elementcolor13\":\"0.9\",\"bottom1_bg\":\"\",\"elementcolor18\":\"#f2f2f2\",\"elementcolor19\":\"0.6\",\"bottom2_bg\":\"\",\"elementcolor9\":\"#211e1b\",\"elementcolor20\":\"1.0\",\"body_fontsize\":\"16px\",\"body_fontstyle\":\"Source+Sans+Pro\",\"h1head_fontstyle\":\"Source+Sans+Pro\",\"articlehead_fontstyle\":\"Source+Sans+Pro\",\"modulehead_fontstyle\":\"Source+Sans+Pro\",\"hornav_fontstyle\":\"Source+Sans+Pro\",\"font_subset\":\"latin\",\"fontawesome_sw\":\"1\",\"body_font_color\":\"#383838\",\"articletitle_font_color\":\"#575045\",\"modulehead_font_color\":\"#0f0f0f\",\"content_link_color\":\"#8c8c8c\",\"button_color\":\"#7a7164\",\"button_hover_color\":\"#575045\",\"hornav_menu\":\"mainmenu\",\"hornav_font_color\":\"#ffffff\",\"hornav_dd_color\":\"#8d8d8d\",\"hornav_ddbackground_color\":\"#26201a\",\"hornavPosition\":\"0\",\"footer_menu\":\"samplemenu\",\"footermenuPosition\":\"0\",\"logoImage\":\"1\",\"logoimagefile\":\"\",\"logo_x\":\"0\",\"logo_y\":\"0\",\"logoText\":\"Nadia\",\"logo_fontstyle\":\"Great+Vibes\",\"logo_font_color\":\"#ffffff\",\"sloganText\":\"A JOOMLA51 TEMPLATE\",\"slogan_font_color\":\"#ffffff\",\"wrapper_width\":\"1140\",\"column_layout\":\"SCOLA-COM-SCOLB\",\"sidecola_width\":\"25\",\"sidecolb_width\":\"40\",\"responsive_sw\":\"1\",\"sidecol_responsive_pos\":\"after\",\"res_header_sw\":\"1\",\"res_top1_sw\":\"1\",\"res_top2_sw\":\"1\",\"res_top3_sw\":\"1\",\"res_sidecola_sw\":\"1\",\"res_sidecolb_sw\":\"1\",\"res_bottom_sw\":\"1\",\"res_base_sw\":\"1\",\"tabport_css\":\"\",\"mobland_css\":\"\",\"mobport_css\":\"\",\"top1_auto\":\"0\",\"top1_padding\":\"0\",\"top_1a_manual\":\"16.6\",\"top_1b_manual\":\"16.6\",\"top_1c_manual\":\"16.6\",\"top_1d_manual\":\"16.6\",\"top_1e_manual\":\"16.6\",\"top_1f_manual\":\"16.6\",\"top2_auto\":\"0\",\"top2_padding\":\"0\",\"top_2a_manual\":\"16.6\",\"top_2b_manual\":\"16.6\",\"top_2c_manual\":\"16.6\",\"top_2d_manual\":\"16.6\",\"top_2e_manual\":\"16.6\",\"top_2f_manual\":\"16.6\",\"top3_auto\":\"0\",\"top3_padding\":\"0\",\"top_3a_manual\":\"16.6\",\"top_3b_manual\":\"16.6\",\"top_3c_manual\":\"16.6\",\"top_3d_manual\":\"16.6\",\"top_3e_manual\":\"16.6\",\"top_3f_manual\":\"16.6\",\"contenttop_auto\":\"0\",\"contenttop_a_manual\":\"33\",\"contenttop_b_manual\":\"33\",\"contenttop_c_manual\":\"33\",\"contentbottom_auto\":\"0\",\"contentbottom_a_manual\":\"33\",\"contentbottom_b_manual\":\"33\",\"contentbottom_c_manual\":\"33\",\"bottom1_auto\":\"0\",\"bottom_padding\":\"0\",\"bottom_1a_manual\":\"16.6\",\"bottom_1b_manual\":\"16.6\",\"bottom_1c_manual\":\"16.6\",\"bottom_1d_manual\":\"16.6\",\"bottom_1e_manual\":\"16.6\",\"bottom_1f_manual\":\"16.6\",\"bottom2_auto\":\"1\",\"bottom2_padding\":\"0\",\"bottom_2a_manual\":\"100\",\"bottom_2b_manual\":\"33.3\",\"bottom_2c_manual\":\"33.3\",\"bottom_2d_manual\":\"33.3\",\"bottom_2e_manual\":\"16.6\",\"bottom_2f_manual\":\"16.6\",\"base1_auto\":\"0\",\"base1_padding\":\"0\",\"base_1a_manual\":\"16.6\",\"base_1b_manual\":\"16.6\",\"base_1c_manual\":\"16.6\",\"base_1d_manual\":\"16.6\",\"base_1e_manual\":\"16.6\",\"base_1f_manual\":\"16.6\",\"base2_auto\":\"0\",\"base2_padding\":\"0\",\"base_2a_manual\":\"16.6\",\"base_2b_manual\":\"16.6\",\"base_2c_manual\":\"16.6\",\"base_2d_manual\":\"16.6\",\"base_2e_manual\":\"16.6\",\"base_2f_manual\":\"16.6\",\"copyright\":\"© 2016 Your Copyright Info\",\"social_style\":\"#ffffff\",\"social_rss\":\"\",\"social_twitter\":\"\",\"social_facebook\":\"\",\"social_googleplus\":\"\",\"social_youtube\":\"\",\"social_pinterest\":\"\",\"social_instagram\":\"\",\"social_dribbble\":\"\",\"social_flickr\":\"\",\"social_linkedin\":\"\",\"social_vimeo\":\"\",\"social_yahoo\":\"\",\"social_tumblr\":\"\",\"social_custom\":\"{\\\"social_custom_icon\\\":[],\\\"social_custom_name\\\":[],\\\"social_custom_url\\\":[],\\\"social_custom_hover\\\":[]}\",\"custom_css\":\"\",\"customcss_sw\":\"0\",\"head_custom_code\":\"\",\"body_custom_code\":\"\"}'),(477,'j51_nadia',0,'0','J51_Nadia - Example Style 4','{\"bgcolor\":\"#ebebeb\",\"headerslideshow\":\"{\\\"header_slide_image\\\":[\\\"images\\/bg_style4.jpg\\\"]}\",\"headerslideinterval\":\"5000\",\"headerslidewidth\":\"2000\",\"headerslideheight\":\"0\",\"header_color\":\"#1a3746\",\"header_opacity\":\"0.7\",\"top1_color\":\"#f5f5f5\",\"top1_opacity\":\"1.0\",\"top1_bg\":\"\",\"top2_color\":\"#1a3746\",\"top2_opacity\":\"1.0\",\"top2_bg\":\"\",\"top3_color\":\"#f2f2f2\",\"top3_opacity\":\"0.9\",\"top3_bg\":\"\",\"elementcolor3\":\"#ffffff\",\"elementcolor4\":\"1.0\",\"elementcolor7\":\"#ffffff\",\"elementcolor16\":\"#1a3746\",\"elementcolor13\":\"0.9\",\"bottom1_bg\":\"\",\"elementcolor18\":\"#f2f2f2\",\"elementcolor19\":\"0.6\",\"bottom2_bg\":\"\",\"elementcolor9\":\"#091d2a\",\"elementcolor20\":\"1.0\",\"body_fontsize\":\"16px\",\"body_fontstyle\":\"Source+Sans+Pro\",\"h1head_fontstyle\":\"Source+Sans+Pro\",\"articlehead_fontstyle\":\"Source+Sans+Pro\",\"modulehead_fontstyle\":\"Source+Sans+Pro\",\"hornav_fontstyle\":\"Source+Sans+Pro\",\"font_subset\":\"latin\",\"fontawesome_sw\":\"1\",\"body_font_color\":\"#383838\",\"articletitle_font_color\":\"#091d2a\",\"modulehead_font_color\":\"#0f0f0f\",\"content_link_color\":\"#8c8c8c\",\"button_color\":\"#355566\",\"button_hover_color\":\"#233b47\",\"hornav_menu\":\"mainmenu\",\"hornav_font_color\":\"#ffffff\",\"hornav_ddbackground_color\":\"#091d2a\",\"hornavPosition\":\"0\",\"footer_menu\":\"samplemenu\",\"footermenuPosition\":\"0\",\"logoImage\":\"1\",\"logoimagefile\":\"\",\"logo_x\":\"0\",\"logo_y\":\"0\",\"logoText\":\"Nadia\",\"logo_fontstyle\":\"Great+Vibes\",\"logo_font_color\":\"#ffffff\",\"sloganText\":\"A JOOMLA51 TEMPLATE\",\"slogan_font_color\":\"#ffffff\",\"wrapper_width\":\"1140\",\"column_layout\":\"SCOLA-COM-SCOLB\",\"sidecola_width\":\"25\",\"sidecolb_width\":\"40\",\"responsive_sw\":\"1\",\"sidecol_responsive_pos\":\"after\",\"res_header_sw\":\"1\",\"res_top1_sw\":\"1\",\"res_top2_sw\":\"1\",\"res_top3_sw\":\"1\",\"res_sidecola_sw\":\"1\",\"res_sidecolb_sw\":\"1\",\"res_bottom_sw\":\"1\",\"res_base_sw\":\"1\",\"tabport_css\":\"\",\"mobland_css\":\"\",\"mobport_css\":\"\",\"top1_auto\":\"0\",\"top1_padding\":\"0\",\"top_1a_manual\":\"16.6\",\"top_1b_manual\":\"16.6\",\"top_1c_manual\":\"16.6\",\"top_1d_manual\":\"16.6\",\"top_1e_manual\":\"16.6\",\"top_1f_manual\":\"16.6\",\"top2_auto\":\"0\",\"top2_padding\":\"0\",\"top_2a_manual\":\"16.6\",\"top_2b_manual\":\"16.6\",\"top_2c_manual\":\"16.6\",\"top_2d_manual\":\"16.6\",\"top_2e_manual\":\"16.6\",\"top_2f_manual\":\"16.6\",\"top3_auto\":\"0\",\"top3_padding\":\"0\",\"top_3a_manual\":\"16.6\",\"top_3b_manual\":\"16.6\",\"top_3c_manual\":\"16.6\",\"top_3d_manual\":\"16.6\",\"top_3e_manual\":\"16.6\",\"top_3f_manual\":\"16.6\",\"contenttop_auto\":\"0\",\"contenttop_a_manual\":\"33\",\"contenttop_b_manual\":\"33\",\"contenttop_c_manual\":\"33\",\"contentbottom_auto\":\"0\",\"contentbottom_a_manual\":\"33\",\"contentbottom_b_manual\":\"33\",\"contentbottom_c_manual\":\"33\",\"bottom1_auto\":\"0\",\"bottom_padding\":\"0\",\"bottom_1a_manual\":\"16.6\",\"bottom_1b_manual\":\"16.6\",\"bottom_1c_manual\":\"16.6\",\"bottom_1d_manual\":\"16.6\",\"bottom_1e_manual\":\"16.6\",\"bottom_1f_manual\":\"16.6\",\"bottom2_auto\":\"1\",\"bottom2_padding\":\"0\",\"bottom_2a_manual\":\"100\",\"bottom_2b_manual\":\"33.3\",\"bottom_2c_manual\":\"33.3\",\"bottom_2d_manual\":\"33.3\",\"bottom_2e_manual\":\"16.6\",\"bottom_2f_manual\":\"16.6\",\"base1_auto\":\"0\",\"base1_padding\":\"0\",\"base_1a_manual\":\"16.6\",\"base_1b_manual\":\"16.6\",\"base_1c_manual\":\"16.6\",\"base_1d_manual\":\"16.6\",\"base_1e_manual\":\"16.6\",\"base_1f_manual\":\"16.6\",\"base2_auto\":\"0\",\"base2_padding\":\"0\",\"base_2a_manual\":\"16.6\",\"base_2b_manual\":\"16.6\",\"base_2c_manual\":\"16.6\",\"base_2d_manual\":\"16.6\",\"base_2e_manual\":\"16.6\",\"base_2f_manual\":\"16.6\",\"copyright\":\"© 2016 Your Copyright Info\",\"social_style\":\"#ffffff\",\"social_rss\":\"\",\"social_twitter\":\"\",\"social_facebook\":\"\",\"social_googleplus\":\"\",\"social_youtube\":\"\",\"social_pinterest\":\"\",\"social_instagram\":\"\",\"social_dribbble\":\"\",\"social_flickr\":\"\",\"social_linkedin\":\"\",\"social_vimeo\":\"\",\"social_yahoo\":\"\",\"social_tumblr\":\"\",\"social_custom\":\"{\\\"social_custom_icon\\\":[],\\\"social_custom_name\\\":[],\\\"social_custom_url\\\":[],\\\"social_custom_hover\\\":[]}\",\"custom_css\":\"\",\"customcss_sw\":\"0\",\"head_custom_code\":\"\",\"body_custom_code\":\"\"}'),(478,'j51_nadia',0,'0','J51_Nadia - Example Style 5','{\"bgcolor\":\"#ebebeb\",\"headerslideshow\":\"{\\\"header_slide_image\\\":[\\\"images\\/bg_style5.jpg\\\"]}\",\"headerslideinterval\":\"5000\",\"headerslidewidth\":\"2000\",\"headerslideheight\":\"0\",\"header_color\":\"#bfbfbf\",\"header_opacity\":\"0.8\",\"top1_color\":\"#f5f5f5\",\"top1_opacity\":\"1.0\",\"top1_bg\":\"\",\"top2_color\":\"#a6a6a6\",\"top2_opacity\":\"1.0\",\"top2_bg\":\"\",\"top3_color\":\"#f2f2f2\",\"top3_opacity\":\"0.9\",\"top3_bg\":\"\",\"elementcolor3\":\"#ffffff\",\"elementcolor4\":\"1.0\",\"elementcolor7\":\"#ffffff\",\"elementcolor16\":\"#a8a8a8\",\"elementcolor13\":\"0.9\",\"bottom1_bg\":\"\",\"elementcolor18\":\"#f2f2f2\",\"elementcolor19\":\"0.6\",\"bottom2_bg\":\"\",\"elementcolor9\":\"#1f1f1f\",\"elementcolor20\":\"1.0\",\"body_fontsize\":\"16px\",\"body_fontstyle\":\"Source+Sans+Pro\",\"h1head_fontstyle\":\"Source+Sans+Pro\",\"articlehead_fontstyle\":\"Source+Sans+Pro\",\"modulehead_fontstyle\":\"Source+Sans+Pro\",\"hornav_fontstyle\":\"Source+Sans+Pro\",\"font_subset\":\"latin\",\"fontawesome_sw\":\"1\",\"body_font_color\":\"#383838\",\"articletitle_font_color\":\"#091d2a\",\"modulehead_font_color\":\"#0f0f0f\",\"content_link_color\":\"#8c8c8c\",\"button_color\":\"#757575\",\"button_hover_color\":\"#636363\",\"hornav_menu\":\"mainmenu\",\"hornav_font_color\":\"#ffffff\",\"hornav_dd_color\":\"#ffffff\",\"hornav_ddbackground_color\":\"#a6a6a6\",\"hornavPosition\":\"0\",\"footer_menu\":\"samplemenu\",\"footermenuPosition\":\"0\",\"logoImage\":\"1\",\"logoimagefile\":\"\",\"logo_x\":\"0\",\"logo_y\":\"0\",\"logoText\":\"Nadia\",\"logo_fontstyle\":\"Great+Vibes\",\"logo_font_color\":\"#ffffff\",\"sloganText\":\"A JOOMLA51 TEMPLATE\",\"slogan_font_color\":\"#ffffff\",\"wrapper_width\":\"1140\",\"column_layout\":\"SCOLA-COM-SCOLB\",\"sidecola_width\":\"25\",\"sidecolb_width\":\"40\",\"responsive_sw\":\"1\",\"sidecol_responsive_pos\":\"after\",\"res_header_sw\":\"1\",\"res_top1_sw\":\"1\",\"res_top2_sw\":\"1\",\"res_top3_sw\":\"1\",\"res_sidecola_sw\":\"1\",\"res_sidecolb_sw\":\"1\",\"res_bottom_sw\":\"1\",\"res_base_sw\":\"1\",\"tabport_css\":\"\",\"mobland_css\":\"\",\"mobport_css\":\"\",\"top1_auto\":\"0\",\"top1_padding\":\"0\",\"top_1a_manual\":\"16.6\",\"top_1b_manual\":\"16.6\",\"top_1c_manual\":\"16.6\",\"top_1d_manual\":\"16.6\",\"top_1e_manual\":\"16.6\",\"top_1f_manual\":\"16.6\",\"top2_auto\":\"0\",\"top2_padding\":\"0\",\"top_2a_manual\":\"16.6\",\"top_2b_manual\":\"16.6\",\"top_2c_manual\":\"16.6\",\"top_2d_manual\":\"16.6\",\"top_2e_manual\":\"16.6\",\"top_2f_manual\":\"16.6\",\"top3_auto\":\"0\",\"top3_padding\":\"0\",\"top_3a_manual\":\"16.6\",\"top_3b_manual\":\"16.6\",\"top_3c_manual\":\"16.6\",\"top_3d_manual\":\"16.6\",\"top_3e_manual\":\"16.6\",\"top_3f_manual\":\"16.6\",\"contenttop_auto\":\"0\",\"contenttop_a_manual\":\"33\",\"contenttop_b_manual\":\"33\",\"contenttop_c_manual\":\"33\",\"contentbottom_auto\":\"0\",\"contentbottom_a_manual\":\"33\",\"contentbottom_b_manual\":\"33\",\"contentbottom_c_manual\":\"33\",\"bottom1_auto\":\"0\",\"bottom_padding\":\"0\",\"bottom_1a_manual\":\"16.6\",\"bottom_1b_manual\":\"16.6\",\"bottom_1c_manual\":\"16.6\",\"bottom_1d_manual\":\"16.6\",\"bottom_1e_manual\":\"16.6\",\"bottom_1f_manual\":\"16.6\",\"bottom2_auto\":\"1\",\"bottom2_padding\":\"0\",\"bottom_2a_manual\":\"100\",\"bottom_2b_manual\":\"33.3\",\"bottom_2c_manual\":\"33.3\",\"bottom_2d_manual\":\"33.3\",\"bottom_2e_manual\":\"16.6\",\"bottom_2f_manual\":\"16.6\",\"base1_auto\":\"0\",\"base1_padding\":\"0\",\"base_1a_manual\":\"16.6\",\"base_1b_manual\":\"16.6\",\"base_1c_manual\":\"16.6\",\"base_1d_manual\":\"16.6\",\"base_1e_manual\":\"16.6\",\"base_1f_manual\":\"16.6\",\"base2_auto\":\"0\",\"base2_padding\":\"0\",\"base_2a_manual\":\"16.6\",\"base_2b_manual\":\"16.6\",\"base_2c_manual\":\"16.6\",\"base_2d_manual\":\"16.6\",\"base_2e_manual\":\"16.6\",\"base_2f_manual\":\"16.6\",\"copyright\":\"© 2016 Your Copyright Info\",\"social_style\":\"#ffffff\",\"social_rss\":\"\",\"social_twitter\":\"\",\"social_facebook\":\"\",\"social_googleplus\":\"\",\"social_youtube\":\"\",\"social_pinterest\":\"\",\"social_instagram\":\"\",\"social_dribbble\":\"\",\"social_flickr\":\"\",\"social_linkedin\":\"\",\"social_vimeo\":\"\",\"social_yahoo\":\"\",\"social_tumblr\":\"\",\"social_custom\":\"{\\\"social_custom_icon\\\":[],\\\"social_custom_name\\\":[],\\\"social_custom_url\\\":[],\\\"social_custom_hover\\\":[]}\",\"custom_css\":\"\",\"customcss_sw\":\"0\",\"head_custom_code\":\"\",\"body_custom_code\":\"\"}'),(479,'j51_nadia',0,'0','J51_Nadia - Example Style 6','{\"bgcolor\":\"#ebebeb\",\"headerslideshow\":\"{\\\"header_slide_image\\\":[\\\"images\\/bg_style6.jpg\\\"]}\",\"headerslideinterval\":\"5000\",\"headerslidewidth\":\"2000\",\"headerslideheight\":\"0\",\"header_color\":\"#414d3b\",\"header_opacity\":\"0.6\",\"top1_color\":\"#f5f5f5\",\"top1_opacity\":\"1.0\",\"top1_bg\":\"\",\"top2_color\":\"#272e24\",\"top2_opacity\":\"1.0\",\"top2_bg\":\"\",\"top3_color\":\"#f2f2f2\",\"top3_opacity\":\"0.9\",\"top3_bg\":\"\",\"elementcolor3\":\"#ffffff\",\"elementcolor4\":\"1.0\",\"elementcolor7\":\"#ffffff\",\"elementcolor16\":\"#272e24\",\"elementcolor13\":\"0.9\",\"bottom1_bg\":\"\",\"elementcolor18\":\"#f2f2f2\",\"elementcolor19\":\"0.6\",\"bottom2_bg\":\"\",\"elementcolor9\":\"#272e24\",\"elementcolor20\":\"1.0\",\"body_fontsize\":\"16px\",\"body_fontstyle\":\"Source+Sans+Pro\",\"h1head_fontstyle\":\"Source+Sans+Pro\",\"articlehead_fontstyle\":\"Source+Sans+Pro\",\"modulehead_fontstyle\":\"Source+Sans+Pro\",\"hornav_fontstyle\":\"Source+Sans+Pro\",\"font_subset\":\"latin\",\"fontawesome_sw\":\"1\",\"body_font_color\":\"#383838\",\"articletitle_font_color\":\"#091d2a\",\"modulehead_font_color\":\"#0f0f0f\",\"content_link_color\":\"#8c8c8c\",\"button_color\":\"#7e9473\",\"button_hover_color\":\"#586b4f\",\"hornav_menu\":\"mainmenu\",\"hornav_font_color\":\"#ffffff\",\"hornav_dd_color\":\"#ffffff\",\"hornav_ddbackground_color\":\"#414d3c\",\"hornavPosition\":\"0\",\"footer_menu\":\"samplemenu\",\"footermenuPosition\":\"0\",\"logoImage\":\"1\",\"logoimagefile\":\"\",\"logo_x\":\"0\",\"logo_y\":\"0\",\"logoText\":\"Nadia\",\"logo_fontstyle\":\"Great+Vibes\",\"logo_font_color\":\"#ffffff\",\"sloganText\":\"A JOOMLA51 TEMPLATE\",\"slogan_font_color\":\"#ffffff\",\"wrapper_width\":\"1140\",\"column_layout\":\"SCOLA-COM-SCOLB\",\"sidecola_width\":\"25\",\"sidecolb_width\":\"40\",\"responsive_sw\":\"1\",\"sidecol_responsive_pos\":\"after\",\"res_header_sw\":\"1\",\"res_top1_sw\":\"1\",\"res_top2_sw\":\"1\",\"res_top3_sw\":\"1\",\"res_sidecola_sw\":\"1\",\"res_sidecolb_sw\":\"1\",\"res_bottom_sw\":\"1\",\"res_base_sw\":\"1\",\"tabport_css\":\"\",\"mobland_css\":\"\",\"mobport_css\":\"\",\"top1_auto\":\"0\",\"top1_padding\":\"0\",\"top_1a_manual\":\"16.6\",\"top_1b_manual\":\"16.6\",\"top_1c_manual\":\"16.6\",\"top_1d_manual\":\"16.6\",\"top_1e_manual\":\"16.6\",\"top_1f_manual\":\"16.6\",\"top2_auto\":\"0\",\"top2_padding\":\"0\",\"top_2a_manual\":\"16.6\",\"top_2b_manual\":\"16.6\",\"top_2c_manual\":\"16.6\",\"top_2d_manual\":\"16.6\",\"top_2e_manual\":\"16.6\",\"top_2f_manual\":\"16.6\",\"top3_auto\":\"0\",\"top3_padding\":\"0\",\"top_3a_manual\":\"16.6\",\"top_3b_manual\":\"16.6\",\"top_3c_manual\":\"16.6\",\"top_3d_manual\":\"16.6\",\"top_3e_manual\":\"16.6\",\"top_3f_manual\":\"16.6\",\"contenttop_auto\":\"0\",\"contenttop_a_manual\":\"33\",\"contenttop_b_manual\":\"33\",\"contenttop_c_manual\":\"33\",\"contentbottom_auto\":\"0\",\"contentbottom_a_manual\":\"33\",\"contentbottom_b_manual\":\"33\",\"contentbottom_c_manual\":\"33\",\"bottom1_auto\":\"0\",\"bottom_padding\":\"0\",\"bottom_1a_manual\":\"16.6\",\"bottom_1b_manual\":\"16.6\",\"bottom_1c_manual\":\"16.6\",\"bottom_1d_manual\":\"16.6\",\"bottom_1e_manual\":\"16.6\",\"bottom_1f_manual\":\"16.6\",\"bottom2_auto\":\"1\",\"bottom2_padding\":\"0\",\"bottom_2a_manual\":\"100\",\"bottom_2b_manual\":\"33.3\",\"bottom_2c_manual\":\"33.3\",\"bottom_2d_manual\":\"33.3\",\"bottom_2e_manual\":\"16.6\",\"bottom_2f_manual\":\"16.6\",\"base1_auto\":\"0\",\"base1_padding\":\"0\",\"base_1a_manual\":\"16.6\",\"base_1b_manual\":\"16.6\",\"base_1c_manual\":\"16.6\",\"base_1d_manual\":\"16.6\",\"base_1e_manual\":\"16.6\",\"base_1f_manual\":\"16.6\",\"base2_auto\":\"0\",\"base2_padding\":\"0\",\"base_2a_manual\":\"16.6\",\"base_2b_manual\":\"16.6\",\"base_2c_manual\":\"16.6\",\"base_2d_manual\":\"16.6\",\"base_2e_manual\":\"16.6\",\"base_2f_manual\":\"16.6\",\"copyright\":\"© 2016 Your Copyright Info\",\"social_style\":\"#ffffff\",\"social_rss\":\"\",\"social_twitter\":\"\",\"social_facebook\":\"\",\"social_googleplus\":\"\",\"social_youtube\":\"\",\"social_pinterest\":\"\",\"social_instagram\":\"\",\"social_dribbble\":\"\",\"social_flickr\":\"\",\"social_linkedin\":\"\",\"social_vimeo\":\"\",\"social_yahoo\":\"\",\"social_tumblr\":\"\",\"social_custom\":\"{\\\"social_custom_icon\\\":[],\\\"social_custom_name\\\":[],\\\"social_custom_url\\\":[],\\\"social_custom_hover\\\":[]}\",\"custom_css\":\"\",\"customcss_sw\":\"0\",\"head_custom_code\":\"\",\"body_custom_code\":\"\"}')
Table 'ecweb_2016b.#__template_styles' doesn't exist SQL=/*!40000 ALTER TABLE `#__template_styles` DISABLE KEYS */
Table 'ecweb_2016b.#__template_styles' doesn't exist SQL=LOCK TABLES `#__template_styles` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__template_styles` ( `id` int(10) unsigned NOT NULL AUTO_INCREMENT, `template` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `client_id` tinyint(1) unsigned NOT NULL DEFAULT '0', `home` char(7) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '0', `title` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `params` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, PRIMARY KEY (`id`), KEY `idx_template` (`template`), KEY `idx_home` (`home`) ) ENGINE=InnoDB AUTO_INCREMENT=480 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__tags' doesn't exist SQL=/*!40000 ALTER TABLE `#__tags` ENABLE KEYS */
Table 'ecweb_2016b.#__tags' doesn't exist SQL=INSERT INTO `#__tags` VALUES (1,0,0,1,0,'','ROOT','root','','',1,0,'0000-00-00 00:00:00',1,'{}','','','',879,'2011-01-01 00:00:01','',0,'0000-00-00 00:00:00','','',0,'*',1,'0000-00-00 00:00:00','0000-00-00 00:00:00')
Table 'ecweb_2016b.#__tags' doesn't exist SQL=/*!40000 ALTER TABLE `#__tags` DISABLE KEYS */
Table 'ecweb_2016b.#__tags' doesn't exist SQL=LOCK TABLES `#__tags` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__tags` ( `id` int(10) unsigned NOT NULL AUTO_INCREMENT, `parent_id` int(10) unsigned NOT NULL DEFAULT '0', `lft` int(11) NOT NULL DEFAULT '0', `rgt` int(11) NOT NULL DEFAULT '0', `level` int(10) unsigned NOT NULL DEFAULT '0', `path` varchar(400) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `title` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL, `alias` varchar(400) CHARACTER SET utf8mb4 COLLATE utf8mb4_bin NOT NULL DEFAULT '', `note` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `description` longtext COLLATE utf8mb4_unicode_ci NOT NULL, `published` tinyint(1) NOT NULL DEFAULT '0', `checked_out` int(11) unsigned NOT NULL DEFAULT '0', `checked_out_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `access` int(10) unsigned NOT NULL DEFAULT '0', `params` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `metadesc` varchar(1024) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'The meta description for the page.', `metakey` varchar(1024) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'The meta keywords for the page.', `metadata` varchar(2048) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'JSON encoded metadata properties.', `created_user_id` int(10) unsigned NOT NULL DEFAULT '0', `created_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `created_by_alias` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `modified_user_id` int(10) unsigned NOT NULL DEFAULT '0', `modified_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `images` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `urls` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `hits` int(10) unsigned NOT NULL DEFAULT '0', `language` char(7) COLLATE utf8mb4_unicode_ci NOT NULL, `version` int(10) unsigned NOT NULL DEFAULT '1', `publish_up` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `publish_down` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', PRIMARY KEY (`id`), KEY `tag_idx` (`published`,`access`), KEY `idx_access` (`access`), KEY `idx_checkout` (`checked_out`), KEY `idx_left_right` (`lft`,`rgt`), KEY `idx_language` (`language`), KEY `idx_path` (`path`(100)), KEY `idx_alias` (`alias`(100)) ) ENGINE=InnoDB AUTO_INCREMENT=2 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__schemas' doesn't exist SQL=/*!40000 ALTER TABLE `#__schemas` ENABLE KEYS */
Table 'ecweb_2016b.#__schemas' doesn't exist SQL=INSERT INTO `#__schemas` VALUES (21,'3.4.0'),(700,'3.5.0-2016-03-01'),(853,'2.3.0-2012-07-31')
Table 'ecweb_2016b.#__schemas' doesn't exist SQL=/*!40000 ALTER TABLE `#__schemas` DISABLE KEYS */
Table 'ecweb_2016b.#__schemas' doesn't exist SQL=LOCK TABLES `#__schemas` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__schemas` ( `extension_id` int(11) NOT NULL, `version_id` varchar(20) COLLATE utf8mb4_unicode_ci NOT NULL, PRIMARY KEY (`extension_id`,`version_id`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__postinstall_messages' doesn't exist SQL=/*!40000 ALTER TABLE `#__postinstall_messages` ENABLE KEYS */
Table 'ecweb_2016b.#__postinstall_messages' doesn't exist SQL=INSERT INTO `#__postinstall_messages` VALUES (1,700,'PLG_TWOFACTORAUTH_TOTP_POSTINSTALL_TITLE','PLG_TWOFACTORAUTH_TOTP_POSTINSTALL_BODY','PLG_TWOFACTORAUTH_TOTP_POSTINSTALL_ACTION','plg_twofactorauth_totp',1,'action','site://plugins/twofactorauth/totp/postinstall/actions.php','twofactorauth_postinstall_action','site://plugins/twofactorauth/totp/postinstall/actions.php','twofactorauth_postinstall_condition','3.2.0',1),(2,700,'COM_CPANEL_MSG_EACCELERATOR_TITLE','COM_CPANEL_MSG_EACCELERATOR_BODY','COM_CPANEL_MSG_EACCELERATOR_BUTTON','com_cpanel',1,'action','admin://components/com_admin/postinstall/eaccelerator.php','admin_postinstall_eaccelerator_action','admin://components/com_admin/postinstall/eaccelerator.php','admin_postinstall_eaccelerator_condition','3.2.0',1),(3,700,'COM_CPANEL_MSG_PHPVERSION_TITLE','COM_CPANEL_MSG_PHPVERSION_BODY','','com_cpanel',1,'message','','','admin://components/com_admin/postinstall/phpversion.php','admin_postinstall_phpversion_condition','3.2.2',1),(4,700,'COM_CPANEL_MSG_HTACCESS_TITLE','COM_CPANEL_MSG_HTACCESS_BODY','','com_cpanel',1,'message','','','admin://components/com_admin/postinstall/htaccess.php','admin_postinstall_htaccess_condition','3.4.0',1),(5,700,'COM_CPANEL_MSG_ROBOTS_TITLE','COM_CPANEL_MSG_ROBOTS_BODY','','com_cpanel',1,'message','','','','','3.3.0',1),(6,700,'COM_CPANEL_MSG_LANGUAGEACCESS340_TITLE','COM_CPANEL_MSG_LANGUAGEACCESS340_BODY','','com_cpanel',1,'message','','','admin://components/com_admin/postinstall/languageaccess340.php','admin_postinstall_languageaccess340_condition','3.4.1',1),(7,700,'COM_CPANEL_MSG_STATS_COLLECTION_TITLE','COM_CPANEL_MSG_STATS_COLLECTION_BODY','','com_cpanel',1,'message','','','admin://components/com_admin/postinstall/statscollection.php','admin_postinstall_statscollection_condition','3.5.0',1)
Table 'ecweb_2016b.#__postinstall_messages' doesn't exist SQL=/*!40000 ALTER TABLE `#__postinstall_messages` DISABLE KEYS */
Table 'ecweb_2016b.#__postinstall_messages' doesn't exist SQL=LOCK TABLES `#__postinstall_messages` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__postinstall_messages` ( `postinstall_message_id` bigint(20) unsigned NOT NULL AUTO_INCREMENT, `extension_id` bigint(20) NOT NULL DEFAULT '700' COMMENT 'FK to #__extensions', `title_key` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '' COMMENT 'Lang key for the title', `description_key` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '' COMMENT 'Lang key for description', `action_key` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `language_extension` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT 'com_postinstall' COMMENT 'Extension holding lang keys', `language_client_id` tinyint(3) NOT NULL DEFAULT '1', `type` varchar(10) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT 'link' COMMENT 'Message type - message, link, action', `action_file` varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT '' COMMENT 'RAD URI to the PHP file containing action method', `action` varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT '' COMMENT 'Action method name or URL', `condition_file` varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT NULL COMMENT 'RAD URI to file holding display condition method', `condition_method` varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT NULL COMMENT 'Display condition method, must return boolean', `version_introduced` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '3.2.0' COMMENT 'Version when this message was introduced', `enabled` tinyint(3) NOT NULL DEFAULT '1', PRIMARY KEY (`postinstall_message_id`) ) ENGINE=InnoDB AUTO_INCREMENT=8 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__overrider' doesn't exist SQL=/*!40000 ALTER TABLE `#__overrider` ENABLE KEYS */
Table 'ecweb_2016b.#__overrider' doesn't exist SQL=/*!40000 ALTER TABLE `#__overrider` DISABLE KEYS */
Table 'ecweb_2016b.#__overrider' doesn't exist SQL=LOCK TABLES `#__overrider` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__overrider` ( `id` int(10) NOT NULL AUTO_INCREMENT COMMENT 'Primary Key', `constant` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL, `string` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `file` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL, PRIMARY KEY (`id`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__newsfeeds' doesn't exist SQL=/*!40000 ALTER TABLE `#__newsfeeds` ENABLE KEYS */
Table 'ecweb_2016b.#__newsfeeds' doesn't exist SQL=INSERT INTO `#__newsfeeds` VALUES (17,1,'Joomla! Announcements','joomla-announcements','http://www.joomla.org/announcements.feed?type=rss',1,5,3600,0,'0000-00-00 00:00:00',1,1,1,'en-GB','{\"show_feed_image\":\"\",\"show_feed_description\":\"\",\"show_item_description\":\"\",\"feed_character_count\":\"0\",\"newsfeed_layout\":\"\",\"feed_display_order\":\"\"}','2011-01-01 00:00:01',879,'','2011-12-27 12:25:05',42,'','','{\"robots\":\"\",\"rights\":\"\"}','','0000-00-00 00:00:00','0000-00-00 00:00:00','',1,0,''),(17,2,'New Joomla! Extensions','new-joomla-extensions','http://feeds.joomla.org/JoomlaExtensions',1,5,3600,0,'0000-00-00 00:00:00',4,1,1,'en-GB','{\"show_feed_image\":\"\",\"show_feed_description\":\"\",\"show_item_description\":\"\",\"feed_character_count\":\"0\",\"newsfeed_layout\":\"\",\"feed_display_order\":\"\"}','2011-01-01 00:00:01',879,'','2011-12-27 12:25:36',42,'','','{\"robots\":\"\",\"rights\":\"\"}','','0000-00-00 00:00:00','0000-00-00 00:00:00','',1,0,''),(17,3,'Joomla! Security News','joomla-security-news','http://feeds.joomla.org/JoomlaSecurityNews',1,5,3600,0,'0000-00-00 00:00:00',2,1,1,'en-GB','{\"show_feed_image\":\"\",\"show_feed_description\":\"\",\"show_item_description\":\"\",\"feed_character_count\":\"0\",\"newsfeed_layout\":\"\",\"feed_display_order\":\"\"}','2011-01-01 00:00:01',879,'','2011-12-27 12:24:55',42,'','','{\"robots\":\"\",\"rights\":\"\"}','','0000-00-00 00:00:00','0000-00-00 00:00:00','',1,0,''),(17,4,'Joomla! Connect','joomla-connect','http://feeds.joomla.org/JoomlaConnect',1,5,3600,0,'0000-00-00 00:00:00',3,1,1,'en-GB','{\"show_feed_image\":\"\",\"show_feed_description\":\"\",\"show_item_description\":\"\",\"feed_character_count\":\"0\",\"newsfeed_layout\":\"\",\"feed_display_order\":\"\"}','2011-01-01 00:00:01',879,'','2011-12-27 12:25:10',42,'','','{\"robots\":\"\",\"rights\":\"\"}','','0000-00-00 00:00:00','0000-00-00 00:00:00','',1,0,'')
Table 'ecweb_2016b.#__newsfeeds' doesn't exist SQL=/*!40000 ALTER TABLE `#__newsfeeds` DISABLE KEYS */
Table 'ecweb_2016b.#__newsfeeds' doesn't exist SQL=LOCK TABLES `#__newsfeeds` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__newsfeeds` ( `catid` int(11) NOT NULL DEFAULT '0', `id` int(10) unsigned NOT NULL AUTO_INCREMENT, `name` varchar(100) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `alias` varchar(400) CHARACTER SET utf8mb4 COLLATE utf8mb4_bin NOT NULL DEFAULT '', `link` varchar(200) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `published` tinyint(1) NOT NULL DEFAULT '0', `numarticles` int(10) unsigned NOT NULL DEFAULT '1', `cache_time` int(10) unsigned NOT NULL DEFAULT '3600', `checked_out` int(10) unsigned NOT NULL DEFAULT '0', `checked_out_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `ordering` int(11) NOT NULL DEFAULT '0', `rtl` tinyint(4) NOT NULL DEFAULT '0', `access` int(10) unsigned NOT NULL DEFAULT '0', `language` char(7) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `params` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `created` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `created_by` int(10) unsigned NOT NULL DEFAULT '0', `created_by_alias` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `modified` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `modified_by` int(10) unsigned NOT NULL DEFAULT '0', `metakey` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `metadesc` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `metadata` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `xreference` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'A reference to enable linkages to external data sets.', `publish_up` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `publish_down` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `description` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `version` int(10) unsigned NOT NULL DEFAULT '1', `hits` int(10) unsigned NOT NULL DEFAULT '0', `images` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, PRIMARY KEY (`id`), KEY `idx_access` (`access`), KEY `idx_checkout` (`checked_out`), KEY `idx_state` (`published`), KEY `idx_catid` (`catid`), KEY `idx_createdby` (`created_by`), KEY `idx_language` (`language`), KEY `idx_xreference` (`xreference`) ) ENGINE=InnoDB AUTO_INCREMENT=5 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__modules_menu' doesn't exist SQL=/*!40000 ALTER TABLE `#__modules_menu` ENABLE KEYS */
Table 'ecweb_2016b.#__modules_menu' doesn't exist SQL=INSERT INTO `#__modules_menu` VALUES (1,0),(2,0),(3,0),(4,0),(6,0),(7,0),(8,0),(9,0),(10,0),(12,0),(13,0),(14,0),(15,0),(22,231),(22,234),(22,238),(22,242),(22,243),(22,244),(22,296),(22,399),(22,400),(23,-463),(23,-462),(23,-433),(23,-432),(23,-431),(23,-430),(23,-429),(23,-427),(23,-400),(23,-399),(23,-296),(23,-244),(23,-243),(23,-242),(23,-238),(23,-234),(25,294),(26,-463),(26,-462),(26,-433),(26,-432),(26,-431),(26,-430),(26,-429),(26,-427),(26,-400),(26,-399),(26,-296),(26,-244),(26,-243),(26,-242),(26,-238),(26,-234),(32,309),(45,303),(57,238),(57,427),(57,429),(57,430),(57,431),(57,432),(57,433),(57,462),(57,463),(67,435),(71,285),(71,316),(79,0),(86,0),(101,469),(102,469),(103,469),(115,435),(119,469),(128,469),(129,469),(130,469),(131,469),(133,469),(134,469),(136,469),(137,469),(142,469),(143,469),(144,469),(145,469),(146,469),(149,201),(149,449),(149,450),(149,464),(149,470),(149,471),(149,472),(149,473),(149,474),(149,475),(149,476),(149,477),(149,478),(149,480),(149,481),(149,482),(149,486),(149,487),(149,488),(149,494),(149,495),(149,498),(149,499),(149,501),(149,502),(157,469),(163,0),(164,0),(165,0),(166,0),(171,0),(172,469),(172,497),(172,498),(172,499),(172,501),(173,469),(173,498),(173,499),(173,500),(173,501),(175,469),(176,469),(177,469),(178,469),(179,469),(180,469),(181,469),(182,469),(183,469),(184,469),(185,469),(186,469),(187,469),(188,469),(189,469),(190,469),(191,469),(192,469),(193,469),(194,469),(195,469),(196,469),(197,469),(198,469),(199,469),(200,469),(201,469),(202,468),(203,468),(205,468),(206,468),(207,468),(208,468),(209,468),(210,468),(211,468),(213,435),(213,464),(223,201),(223,449),(223,450),(223,464),(223,470),(223,471),(223,472),(223,473),(223,474),(223,475),(223,476),(223,482),(223,486),(223,487),(223,488),(223,493),(223,498),(223,499),(223,500),(223,501),(223,502),(223,503),(224,201),(224,449),(224,450),(224,464),(224,468),(224,470),(224,471),(224,472),(224,473),(224,474),(224,475),(224,476),(224,477),(224,478),(224,480),(224,481),(224,482),(224,483),(224,486),(224,487),(224,488),(224,493),(224,494),(224,495),(224,497),(224,498),(224,499),(224,500),(224,501),(224,502),(224,503),(225,201),(225,449),(225,450),(225,464),(225,468),(225,469),(225,470),(225,471),(225,472),(225,473),(225,474),(225,475),(225,476),(225,477),(225,478),(225,480),(225,481),(225,482),(225,486),(225,487),(225,488),(225,493),(225,494),(225,495),(225,498),(225,499),(225,501),(225,502),(225,503),(226,468),(233,0),(246,469),(247,469),(248,469),(249,469),(250,469),(251,469),(252,464),(252,469),(257,508),(258,508),(259,508),(260,508),(261,508),(262,508),(263,508),(264,508),(266,508),(267,508),(268,508),(269,508),(270,508),(271,508),(272,508),(273,508),(278,469),(304,512),(308,468),(357,469),(358,469),(359,469),(360,469),(372,469),(377,526),(377,531),(380,536),(384,469),(387,539),(388,540),(394,0),(404,559),(406,523),(406,524),(406,525),(406,527),(406,528),(406,529),(413,464),(422,464),(422,523),(422,562),(424,464),(425,464),(425,523),(425,524),(425,525),(425,526),(425,527),(425,528),(425,529),(428,469),(433,-469),(434,464),(434,523),(434,524),(434,525),(434,526),(434,527),(434,528),(434,529),(435,464),(435,523),(435,524),(435,525),(435,526),(435,527),(435,528),(435,529),(436,464),(436,523),(436,524),(436,525),(436,526),(436,527),(436,528),(436,529),(437,464),(437,523),(437,524),(437,525),(437,526),(437,527),(437,528),(437,529),(438,464),(438,523),(438,524),(438,525),(438,526),(438,527),(438,528),(438,529),(439,464),(439,523),(439,524),(439,525),(439,526),(439,527),(439,528),(439,529),(440,464),(440,523),(440,524),(440,525),(440,526),(440,527),(440,528),(440,529),(441,-469),(442,524),(442,525),(442,526),(442,527),(442,528),(442,529),(442,540),(443,523),(443,562),(444,523),(444,524),(444,525),(444,526),(444,527),(444,528),(444,529),(444,562)
Table 'ecweb_2016b.#__modules_menu' doesn't exist SQL=/*!40000 ALTER TABLE `#__modules_menu` DISABLE KEYS */
Table 'ecweb_2016b.#__modules_menu' doesn't exist SQL=LOCK TABLES `#__modules_menu` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__modules_menu` ( `moduleid` int(11) NOT NULL DEFAULT '0', `menuid` int(11) NOT NULL DEFAULT '0', PRIMARY KEY (`moduleid`,`menuid`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__modules' doesn't exist SQL=/*!40000 ALTER TABLE `#__modules` ENABLE KEYS */
Table 'ecweb_2016b.#__modules' doesn't exist SQL=INSERT INTO `#__modules` VALUES (2,0,'Login','','',1,'login',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_login',1,1,'',1,'*'),(3,0,'Popular Articles','','',3,'cpanel',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_popular',3,1,'{\"count\":\"5\",\"catid\":\"\",\"user_id\":\"0\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"0\",\"automatic_title\":\"1\"}',1,'*'),(4,0,'Recently Added Articles','','',4,'cpanel',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_latest',3,1,'{\"count\":\"5\",\"ordering\":\"c_dsc\",\"catid\":\"\",\"user_id\":\"0\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"0\",\"automatic_title\":\"1\"}',1,'*'),(8,0,'Toolbar','','',1,'toolbar',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_toolbar',3,1,'',1,'*'),(9,0,'Quick Icons','','',1,'icon',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_quickicon',3,1,'',1,'*'),(10,0,'Logged-in Users','','',2,'cpanel',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_logged',3,1,'{\"count\":\"5\",\"name\":\"1\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"0\",\"automatic_title\":\"1\"}',1,'*'),(12,0,'Admin Menu','','',1,'menu',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_menu',3,1,'{\"layout\":\"\",\"moduleclass_sfx\":\"\",\"shownew\":\"1\",\"showhelp\":\"1\",\"cache\":\"0\"}',1,'*'),(13,0,'Admin Submenu','','',1,'submenu',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_submenu',3,1,'',1,'*'),(14,0,'User Status','','',2,'status',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_status',3,1,'',1,'*'),(15,0,'Title','','',1,'title',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_title',3,1,'',1,'*'),(79,0,'Multilanguage status','','',1,'status',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',0,'mod_multilangstatus',3,1,'{\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"0\"}',1,'*'),(86,0,'Joomla Version','','',1,'footer',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_version',3,1,'{\"format\":\"short\",\"product\":\"1\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"0\"}',1,'*'),(101,244,'Module Top-2C','','
Lorem ipsum dolor sit amet consectetur adipisicing elit, sed do eiusmod tempor incididunt ut.
',1,'top-2c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(102,243,'Module Top-2B','','
',1,'top-2b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(103,242,'Module Top-2A','','
',1,'top-2a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(119,245,'Module Top-2D','','
',1,'top-2d',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(128,228,'Module Base-2A','','
Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut.
',1,'base-2a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(129,229,'Module Base-2B','','
',1,'base-2b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(130,234,'Module Footer-1','','
Nulla in enim quis ipsum pulvinar imperdiet vitae nec velit. Donec non urna quam. Aliquam congue magna nec risus iaculis posuere. Vivamus bibendum interdum molestie. Sed libero risus, varius eu dictum ac, pharetra ac elit. Aenean venenatis egestas iaculis. Nullam consectetur condimentum dolor at bibendum.
',1,'footer-1',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(131,235,'Module Footer-2','','
',1,'footer-2',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(133,216,'Module Bottom-2A','','
',1,'bottom-2a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(134,217,'Module Bottom-2B','','
',1,'bottom-2b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(136,254,'Module ContentTop-A','','
Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt.
',1,'contenttop-a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(137,255,'Module ContentTop-B','','
',1,'contenttop-b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(142,246,'Module Top-2E','','
',1,'top-2e',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(143,247,'Module Top-2F','','
',1,'top-2f',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(144,257,'Module Content Bottom-A','','
',1,'contentbottom-a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(145,258,'Module Content Bottom-B','','
',1,'contentbottom-b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(157,218,'Module Bottom-2C','','
',1,'bottom-2c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(163,0,'RS Latest Tweets','','',1,'base-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',-2,'mod_RSLatestTweets',1,1,'{\"username\":\"joomla51\",\"list\":\"\",\"fetch\":\"100\",\"count\":\"4\",\"loading_tweets\":\"loading tweets...\",\"avatar_size\":\"32\",\"filter\":\"0\",\"refresh\":\"10\",\"favorites\":\"0\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\"}',0,'*'),(164,0,'Twitter Feed','','',1,'base-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',-2,'mod_supremotweet',1,1,'{\"width\":\"250\",\"rpp\":\"4\",\"shellbg\":\"#333333\",\"shellcolor\":\"#ffffff\",\"tweetbg\":\"#000000\",\"tweetcolor\":\"#ffffff\",\"tweetlinks\":\"#4aed05\",\"username\":\"twitter\"}',0,'*'),(165,0,'Twitter Show','','',1,'base-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',-2,'mod_TwitterShow',1,1,'{\"moduleclass_sfx\":\"\",\"widget_type\":\"profile\",\"username\":\"twitter\",\"display_with\":\"javascript\",\"width\":\"200\",\"height\":\"350\",\"autowidth\":\"no\",\"shell_background\":\"#000000\",\"shell_color\":\"#ffffff\",\"tweet_background\":\"#000000\",\"tweet_color\":\"#ffffff\",\"links_color\":\"#4aed05\",\"live\":\"no\",\"scrollbar\":\"no\",\"rpp\":\"5\",\"hashtags\":\"yes\",\"timestamp\":\"yes\",\"avatars\":\"no\",\"interval\":\"2\",\"loop\":\"no\",\"search_query\":\"rainbow\",\"search_title\":\"It\'s a double rainbow\",\"search_subject\":\"Across the sky\",\"toptweets\":\"no\"}',0,'*'),(166,0,'Tweet Display Back','','',1,'base-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',-2,'mod_tweetdisplayback',1,1,'{\"twitterFeedType\":\"user\",\"twitterName\":\"twitter\",\"twitterList\":\"\",\"twitterCount\":\"3\",\"templateLayout\":\"default\",\"templateWidget\":\"profile\",\"templateCSS3\":\"0\",\"widgetLive\":\"true\",\"widgetScroll\":\"true\",\"widgetLoadBehavior\":\"default\",\"widgetInterval\":6,\"widgetLoop\":\"true\",\"widgetAvatar\":\"true\",\"widgetTimestamp\":\"true\",\"widgetHashtag\":\"true\",\"widgetTopTweet\":\"true\",\"widgetSearch\":\"\",\"widgetTitle\":\"\",\"widgetSubject\":\"\",\"widgetShellBackground\":\"#8ec1da\",\"widgetShellText\":\"#ffffff\",\"widgetTweetBackground\":\"#ffffff\",\"widgetTweetText\":\"#444444\",\"widgetTweetLinks\":\"#1985b5\",\"widgetWidth\":250,\"widgetHeight\":300,\"headerDisplay\":\"1\",\"headerclasssfx\":\"\",\"headerUser\":\"1\",\"headerName\":\"0\",\"headerAvatar\":\"1\",\"headerAvatarAlignment\":\"left\",\"headerBio\":\"1\",\"headerWeb\":\"1\",\"headerLocation\":\"1\",\"tweetclasssfx\":\"\",\"tweetAvatar\":\"1\",\"tweetAlignment\":\"left\",\"tweetName\":\"1\",\"tweetUserSeparator\":\" \",\"tweetCreated\":\"1\",\"tweetRelativeTime\":\"1\",\"tweetReply\":\"1\",\"tweetReplyLink\":\"1\",\"tweetRetweetCount\":\"1\",\"tweetSource\":\"1\",\"tweetLocation\":\"0\",\"tweetRetweets\":\"1\",\"tweetLinks\":\"1\",\"showMentions\":\"1\",\"showReplies\":\"1\",\"overrideCount\":\"0\",\"tweetsToScan\":\"3\",\"footerFollowLink\":\"1\",\"footerFollowType\":\"1\",\"footerFollowImg\":\"a\",\"footerFollowImgMeUs\":\"follow_me\",\"footerFollowText\":\"Follow me on Twitter\",\"footerPoweredBy\":\"1\",\"cache\":\"1\",\"cache_time\":\"900\",\"moduleclass_sfx\":\"\",\"bypassLimit\":\"0\",\"bypassIntent\":\"0\",\"cachemode\":\"static\"}',0,'*'),(171,0,'Tabs GK4','','',1,'bottom-2a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',-2,'mod_tabs_gk4',1,0,'{\"automatic_module_id\":\"1\",\"module_id\":\"gk-tab-1\",\"moduleclass_sfx\":\"\",\"module_height\":\"100\",\"tabs_data\":\"[{\\\"name\\\":\\\"Option Congue Nihil\\\",\\\"type\\\":\\\"xhtml\\\",\\\"content\\\":\\\"Claritas est etiam processus dynamicus, qui sequitur mutationem consuetudium lectorum. Mirum est notare quam littera gothica, quam nunc putamus. Lorem ipsum dolor sit amet, consectetur adipiscing elit. Cras nec suscipit magna. Suspendisse lacinia interdum felis eu consectetur. Vivamus sit amet ante est, sit amet rutrum augue. Cras non sem sem, at eleifend mi.\\\",\\\"published\\\":\\\"1\\\",\\\"access\\\":\\\"public\\\"},{\\\"name\\\":\\\"Cras nec suscipit\\\",\\\"type\\\":\\\"xhtml\\\",\\\"content\\\":\\\"Sed ultricies condimentum augue, sed congue erat dapibus nec. Etiam quis tempor nibh. Vestibulum urna dui, sodales ut ornare vitae, porta non augue. Curabitur nunc ipsum, facilisis nec luctus blandit, luctus at sem. Vestibulum pharetra augue vitae orci mollis scelerisque. Claritas est etiam processus dynamicus, qui sequitur mutationem consuetudium lectorum. Mirum est notare quam littera gothica, quam nunc putamus. Nam liber tempor cum soluta nobis eleifend option congue nihil imperdiet doming id quod mazim placerat facer possim assum.\\\",\\\"published\\\":\\\"1\\\",\\\"access\\\":\\\"public\\\"}]\",\"buttons\":\"1\",\"tabs_position\":\"top\",\"styleCSS\":\"style2\",\"activator\":\"click\",\"animation\":\"1\",\"animation_speed\":\"250\",\"animation_interval\":\"5000\",\"animation_type\":\"opacity\",\"animation_function\":\"Fx.Transitions.linear\",\"url_tab_selection\":\"1\",\"cookie_tab_selection\":\"0\",\"parse_plugins\":\"1\",\"useCSS\":\"1\",\"useScript\":\"1\"}',0,'*'),(172,320,'Module Sidecol-B','','
\r\n
',1,'sidecol-b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(173,276,'Module Sidecol-A','','
\r\n
',1,'sidecol-a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(175,236,'Module Top-1A','','
',1,'top-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(176,237,'Module Top-1B','','
',1,'top-1b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(177,238,'Module Top-1C','','
',1,'top-1c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(178,239,'Module Top-1D','','
',1,'top-1d',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(179,240,'Module Top-1E','','
',1,'top-1e',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(180,241,'Module Top-1F','','
',1,'top-1F',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(181,256,'Module ContentTop-C','','
',1,'contenttop-c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(182,259,'Module Content Bottom-C','','
',1,'contentbottom-c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(183,230,'Module Base-2C','','
',1,'base-2c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(184,231,'Module Base-2D','','
',1,'base-2d',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(185,232,'Module Base-2E','','
',1,'base-2e',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(186,233,'Module Base-2F','','
',1,'base-2f',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(187,210,'Module Bottom-1A','','
',1,'bottom-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(188,211,'Module Bottom-1B','','
',1,'bottom-1b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(189,212,'Module Bottom-1C','','
',1,'bottom-1c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(190,213,'Module Bottom-1D','','
',1,'bottom-1d',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(191,214,'Module Bottom-1E','','
',1,'bottom-1e',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(192,215,'Module Bottom-1F','','
',1,'bottom-1f',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(193,219,'Module Bottom-2D','','
',1,'bottom-2d',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(194,220,'Module Bottom-2E','','
',1,'bottom-2e',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(195,221,'Module Bottom-2F','','
',1,'bottom-2f',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(196,222,'Module Base-1A','','
',1,'base-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(197,223,'Module Base-1B','','
',1,'base-1b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(198,224,'Module Base-1C','','
',1,'base-1c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(199,225,'Module Base-1D','','
',1,'base-1d',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(200,227,'Module Base-1F','','
',1,'base-1f',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(201,226,'Module Base-1E','','
',1,'base-1e',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(202,277,'Styling','','
\r\n
',1,'bottom-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"fa-arrow-right\",\"style\":\"0\"}',0,'*'),(203,278,'Menus','','
',1,'bottom-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"fa-arrow-right\",\"style\":\"0\"}',0,'*'),(205,283,'Logo','','
This section of the template parameters allows full control over your site logo with an array of easy to use options. Upload your logo image via the \'Select Logo Image\' field and then use the X and Y axis field to tweak its position.
\r\n
',2,'bottom-1b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"fa-arrow-right\",\"style\":\"0\"}',0,'*'),(206,284,'Layout Options','','
',3,'bottom-1b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"fa-arrow-right\",\"style\":\"0\"}',0,'*'),(207,288,'Module Widths','','
',4,'bottom-1c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"fa-arrow-right\",\"style\":\"0\"}',0,'*'),(208,285,'Copyright Information','','
',4,'bottom-1b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"fa-arrow-right\",\"style\":\"0\"}',0,'*'),(209,289,'Social Media Icons','','
',5,'bottom-1c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"fa-arrow-right\",\"style\":\"0\"}',0,'*'),(210,279,'Custom CSS','','
',1,'bottom-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"fa-arrow-right\",\"style\":\"0\"}',0,'*'),(211,290,'Custom Code','','
',6,'bottom-1c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"fa-arrow-right\",\"style\":\"0\"}',0,'*'),(213,0,'J51_ImageHover','','',1,'bottom-2a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',-2,'mod_j51hover',1,1,'{\"hover_title\":\"Your Image Title\",\"hover_description\":\"Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor.\",\"textcolor\":\"#FFFFFF\",\"style\":\"FallIn\",\"Directory\":\"images\\/filler5.jpg\",\"pxHeight\":\"200\",\"pxWidth\":\"200\",\"hover_link\":\"http:\\/\\/http://www.joomla51.com\",\"bgcolor\":\"#122C44\",\"HOpacity\":\"0.7\"}',0,'*'),(223,0,'Latest Articles','','',1,'sidecol-a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',-2,'mod_featcats',1,1,'{\"catid\":[\"78\"],\"show_child_category_articles\":\"1\",\"levels\":\"1\",\"colcount\":\"4\",\"col_width\":\"190px\",\"cat_heading\":\"0\",\"count\":\"4\",\"item_heading\":\"0\",\"subcount\":\"0\",\"link_cats\":\"1\",\"link_titles\":\"1\",\"link_target\":\"0\",\"show_hits\":\"0\",\"show_front\":\"show\",\"author_filtering_type\":\"1\",\"created_by\":[\"\"],\"author_alias_filtering_type\":\"1\",\"created_by_alias\":[\"\"],\"excluded_articles\":\"\",\"date_filtering\":\"off\",\"date_field\":\"a.created\",\"start_date_range\":\"\",\"end_date_range\":\"\",\"relative_date\":\"30\",\"article_ordering\":\"a.title\",\"article_ordering_direction\":\"ASC\",\"show_date\":\"0\",\"show_date_field\":\"created\",\"show_date_format\":\"Y-m-d H:i:s\",\"show_author\":\"0\",\"show_introtext\":\"1\",\"introtext_limit\":\"100\",\"bold_firstsentence\":\"0\",\"show_readmore\":\"0\",\"show_readmore_title\":\"0\",\"readmore_limit\":\"15\",\"show_image\":\"1\",\"thumb_width\":\"40\",\"thumb_height\":\"40\",\"thumb_image\":\"1\",\"thumb_proportions\":\"bestfit\",\"thumb_bg\":\"#FFFFFF\",\"thumb_type\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"add_css\":\"1\",\"owncache\":\"1\",\"cache_time\":\"900\"}',0,'*'),(226,265,'Parameters Thumbnails','','',5,'parameters',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_j51thumbsgallery',1,0,'{\"path\":\"\\/images\\/params\",\"thumbwidth\":\"98\",\"thumbheight\":\"124\",\"margin\":\"4\",\"bordersize\":\"3\",\"bordercolor\":\"#e0e0e0\",\"outlinecolor\":\"#fafafa\",\"fade_opacity\":\"0.1\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(233,0,'ITPFacebookLikeBox','','',3,'sidecol-b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',-2,'mod_itpfblikebox',1,1,'{\"fbPageLink\":\"http:\\/\\/http://www.facebook.com\\/joomla51\",\"fbRendering\":\"0\",\"fbWidth\":\"250\",\"fbHeight\":\"427\",\"fbColour\":\"light\",\"fbBColour\":\"\",\"fbFaces\":\"1\",\"fbStream\":\"1\",\"fbHeader\":\"1\",\"fbDynamicLocale\":\"1\",\"fbLocale\":\"en_US\",\"moduleclass_sfx\":\"\",\"owncache\":\"1\",\"cache_time\":\"900\",\"facebookLikeAppId\":\"\",\"fbLoadJsLib\":\"1\",\"facebookRootDiv\":\"1\",\"facebookForceWall\":\"0\"}',0,'*'),(246,248,'Module Top-3A','','
',1,'top-3a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(247,249,'Module Top-3B','','
',1,'top-3b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(248,250,'Module Top-3C','','
',1,'top-3c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(249,251,'Module Top-3D','','
',1,'top-3d',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(250,252,'Module Top-3E','','
',1,'top-3e',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(251,253,'Module Top-3F','','
',1,'top-3f',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(252,0,'Slideshow CK','','',1,'showcase',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',-2,'mod_slideshowck',1,0,'{\"slides\":\"[{|qq|imgname|qq|:|qq|images\\/banners\\/slide1.png|qq|,|qq|imgcaption|qq|:|qq|This is a bridge|qq|,|qq|imgthumb|qq|:|qq|http:\\/\\/localhost\\/joomla\\/joomla25\\/images\\/banners\\/slide1.png|qq|,|qq|imglink|qq|:|qq||qq|,|qq|imgtarget|qq|:|qq|_parent|qq|,|qq|imgalignment|qq|:|qq|default|qq|,|qq|imgvideo|qq|:|qq||qq|,|qq|slideselect|qq|:|qq|image|qq|},{|qq|imgname|qq|:|qq|modules\\/mod_slideshowck\\/images\\/slides\\/road.jpg|qq|,|qq|imgcaption|qq|:|qq|This slideshow uses the JQuery script from Pixedelic<\\/a>|qq|,|qq|imgthumb|qq|:|qq|http:\\/\\/localhost\\/joomla\\/joomla25\\/modules\\/mod_slideshowck\\/images\\/slides\\/road.jpg|qq|,|qq|imglink|qq|:|qq||qq|,|qq|imgtarget|qq|:|qq|_parent|qq|,|qq|imgalignment|qq|:|qq|default|qq|,|qq|imgvideo|qq|:|qq||qq|,|qq|slideselect|qq|:|qq|image|qq|},{|qq|imgname|qq|:|qq|modules\\/mod_slideshowck\\/images\\/slides\\/big_bunny_fake.jpg|qq|,|qq|imgcaption|qq|:|qq|This is a Video slide|qq|,|qq|imgthumb|qq|:|qq|http:\\/\\/localhost\\/joomla\\/joomla25\\/modules\\/mod_slideshowck\\/images\\/slides\\/big_bunny_fake.jpg|qq|,|qq|imglink|qq|:|qq||qq|,|qq|imgtarget|qq|:|qq|_parent|qq|,|qq|imgalignment|qq|:|qq|default|qq|,|qq|imgvideo|qq|:|qq|http:\\/\\/player.vimeo.com\\/video\\/2203727|qq|,|qq|slideselect|qq|:|qq|video|qq|}]\",\"theme\":\"default\",\"skin\":\"camera_amber_skin\",\"alignment\":\"center\",\"loader\":\"pie\",\"width\":\"800\",\"height\":\"300\",\"navigation\":\"2\",\"thumbnails\":\"1\",\"thumbnailwidth\":\"100\",\"thumbnailheight\":\"75\",\"pagination\":\"1\",\"effect\":[\"random\"],\"transition\":\"linear\",\"time\":\"4000\",\"transperiod\":\"1500\",\"captioneffect\":\"moveFromLeft\",\"portrait\":\"0\",\"autoAdvance\":\"1\",\"hover\":\"1\",\"displayorder\":\"normal\",\"loadjquery\":\"1\",\"loadjqueryeasing\":\"1\",\"loadjquerymobile\":\"1\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"itemid\"}',0,'*'),(257,298,'title-mail','','
Module Class Suffix:
title-mail
',1,'top-3b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"title-mail\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(258,296,'title-pen','','
title-pen
',1,'top-3a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"title-pen\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(259,302,'title-bubble','','
title-bubble
',1,'top-3d',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"title-bubble\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(260,300,'title-screen','','
title-screen
',1,'top-3c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"title-screen\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(261,280,'title-tick','','
title-tick
',1,'bottom-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"title-tick\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(262,286,'title-plus','','
title-plus
',5,'bottom-1b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"title-plus\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(263,291,'title-arrow','','
title-arrow
',7,'bottom-1c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"title-arrow\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(264,294,'title-star','','
title-star
',1,'bottom-1d',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"title-star\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(266,297,'title-pen style-box','','Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut.
\r\nModule Class Suffix:
title-pen style-box',1,'top-3a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"title-pen style-box\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(267,281,'title-tick style-box','','Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut.
title-tick style-box',1,'bottom-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"title-tick style-box\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(268,299,'title-mail style-box','','Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut.
title-mail style-box',1,'top-3b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"title-mail style-box\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(269,287,'title-plus style-box','','Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut.
title-plus style-box',6,'bottom-1b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"title-plus style-box\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(270,292,'title-arrow style-box','','Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut.
title-arrow style-box',8,'bottom-1c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"title-arrow style-box\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(271,301,'title-screen style-box','','Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut.
title-screen style-box\r\n',1,'top-3c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"title-screen style-box\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(272,303,'title-bubble style-box','','Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut.
title-bubble style-box \r\n',1,'top-3d',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"title-bubble style-box\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(273,295,'title-star style-box','','Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut.
title-star style-box',1,'bottom-1d',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"title-star style-box\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(278,331,'Breadcrumbs','','',1,'breadcrumb',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_breadcrumbs',1,0,'{\"showHere\":\"1\",\"showHome\":\"1\",\"homeText\":\"\",\"showLast\":\"1\",\"separator\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"itemid\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(304,363,'Login Form','','',4,'sidecol-b',100,'2015-02-25 15:35:59','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_login',1,1,'{\"pretext\":\"\",\"posttext\":\"\",\"login\":\"\",\"logout\":\"\",\"greeting\":\"1\",\"name\":\"0\",\"usesecure\":\"0\",\"usetext\":\"0\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"0\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(308,293,'Responsive Options','','
',1,'bottom-1c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"fa-arrow-right\",\"style\":\"0\"}',0,'*'),(357,260,'Module Tab-1tab','','
',1,'top-1tab',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(358,261,'Module Tab-1tab','','
',1,'top-1tab',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(359,262,'Module Tab-1tab','','
',1,'top-1tab',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(360,263,'Module Tab-1tab','','
',1,'top-1tab',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(372,304,'Module Header-1','','
Module Header-1
',1,'header-1',879,'2016-03-23 10:25:14','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(377,311,'Endless Styling Possibilities','','
\r\n
Nadia allows you complete freedom in styling your template with a large selection of colour choosers for almost every element of your site.
',1,'top-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,0,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(380,315,'Animate on Scroll','','
animate fadeIn
\r\n
animate fadeInUp
\r\n
animate fadeInUpBig
\r\n
animate fadeInDown
\r\n
animate fadeInDownBig
\r\n
animate fadeInLeft
\r\n
animate fadeInLeftBig
\r\n
animate fadeInRight
\r\n
animate fadeInRightBig
\r\n
animate flip
\r\n
animate flipInX
\r\n
animate flipInY
\r\n
animate lightSpeedIn
\r\n
animate rotateIn
\r\n
animate rotateInDownLeft
\r\n
animate rotateInDownRight
\r\n
animate rotateInUpLeft
\r\n
animate rotateInUpRight
\r\n
animate slideInDown
\r\n
animate slideInRight
\r\n
animate slideInLeft
\r\n
animate rollIn
\r\n
animate bounce
\r\n
animate flash
\r\n
animate shake
\r\n
animate swing
\r\n
animate wobble
',1,'bottom-2a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,0,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(384,321,'Module Header-2','','
Module Header-2
',1,'header-2',879,'2016-03-23 10:25:15','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(387,329,'GridGallery Example','','',1,'bottom-2a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_j51gridgallery',1,0,'{\"j51_num_images\":\"9\",\"j51_randomize\":\"0\",\"j51_image_width\":\"310\",\"j51_image_width_tabl\":\"240\",\"j51_image_width_tabp\":\"180\",\"j51_image_width_mobl\":\"396\",\"j51_image_width_mobp\":\"280\",\"j51_image_margin_x\":\"10\",\"j51_image_margin_y\":\"10\",\"j51_overlay_color\":\"#ffffff\",\"j51_title_color\":\"#404040\",\"j51_text_color\":\"#666666\",\"j51_image1\":\"images\\/gridgallery\\/image1.jpg\",\"j51_image_alt1\":\"image1\",\"j51_title1\":\"Placerat facer possim\",\"j51_text1\":\"Oportere rationibus sed ea\",\"j51_disablecaption1\":\"no\",\"image_url1\":\"516\",\"j51_disableurl1\":\"no\",\"target_url1\":\"_self\",\"j51_animate_class1\":\"fadeInLeft\",\"j51_image2\":\"images\\/gridgallery\\/image2.jpg\",\"j51_image_alt2\":\"image2\",\"j51_title2\":\"Quam nunc putamus\",\"j51_text2\":\"Libris melius aperiam et sit\",\"j51_disablecaption2\":\"no\",\"image_url2\":\"517\",\"j51_disableurl2\":\"no\",\"target_url2\":\"_self\",\"j51_animate_class2\":\"fadeIn\",\"j51_image3\":\"images\\/gridgallery\\/image3.jpg\",\"j51_image_alt3\":\"image3\",\"j51_title3\":\"Velit esse molestie\",\"j51_text3\":\"Sed ea, vix et zril aeterno\",\"j51_disablecaption3\":\"no\",\"image_url3\":\"518\",\"j51_disableurl3\":\"no\",\"target_url3\":\"_self\",\"j51_animate_class3\":\"fadeInRight\",\"j51_image4\":\"images\\/gridgallery\\/image4.jpg\",\"j51_image_alt4\":\"image4\",\"j51_title4\":\"Placerat facer possim\",\"j51_text4\":\"Aperiam et sit, ei mei modo\",\"j51_disablecaption4\":\"no\",\"image_url4\":\"530\",\"j51_disableurl4\":\"no\",\"target_url4\":\"_self\",\"j51_animate_class4\":\"fadeInLeft\",\"j51_image5\":\"images\\/gridgallery\\/image5.jpg\",\"j51_image_alt5\":\"image5\",\"j51_title5\":\"Et everti tamquam\",\"j51_text5\":\"Mei modo tation sententiae.\",\"j51_disablecaption5\":\"no\",\"image_url5\":\"518\",\"j51_disableurl5\":\"no\",\"target_url5\":\"_self\",\"j51_animate_class5\":\"fadeIn\",\"j51_image6\":\"images\\/gridgallery\\/image6.jpg\",\"j51_image_alt6\":\"image6\",\"j51_title6\":\"Libris melius aperiam\",\"j51_text6\":\"Oportere rationibus sed ea\",\"j51_disablecaption6\":\"no\",\"image_url6\":\"516\",\"j51_disableurl6\":\"no\",\"target_url6\":\"_self\",\"j51_animate_class6\":\"fadeInRight\",\"j51_image7\":\"images\\/gridgallery\\/image7.jpg\",\"j51_image_alt7\":\"image7\",\"j51_title7\":\"Quam nunc putamus\",\"j51_text7\":\"Libris melius aperiam et sit\",\"j51_disablecaption7\":\"no\",\"image_url7\":\"517\",\"j51_disableurl7\":\"no\",\"target_url7\":\"_self\",\"j51_animate_class7\":\"fadeInLeft\",\"j51_image8\":\"images\\/gridgallery\\/image8.jpg\",\"j51_image_alt8\":\"image8\",\"j51_title8\":\"Quam nunc putamus\",\"j51_text8\":\"Mei modo tation sententiae\",\"j51_disablecaption8\":\"no\",\"image_url8\":\"517\",\"j51_disableurl8\":\"no\",\"target_url8\":\"_self\",\"j51_animate_class8\":\"fadeIn\",\"j51_image9\":\"images\\/gridgallery\\/image9.jpg\",\"j51_image_alt9\":\"image9\",\"j51_title9\":\"Velit esse molestie\",\"j51_text9\":\"Libris melius aperiam et sit\",\"j51_disablecaption9\":\"no\",\"image_url9\":\"518\",\"j51_disableurl9\":\"no\",\"target_url9\":\"_self\",\"j51_animate_class9\":\"fadeInRight\",\"j51_image10\":\"\",\"j51_image_alt10\":\"\",\"j51_title10\":\"\",\"j51_text10\":\"\",\"j51_disablecaption10\":\"no\",\"image_url10\":\"516\",\"j51_disableurl10\":\"no\",\"target_url10\":\"_self\",\"j51_animate_class10\":\"fadeInUp\",\"j51_image11\":\"\",\"j51_image_alt11\":\"\",\"j51_title11\":\"\",\"j51_text11\":\"\",\"j51_disablecaption11\":\"no\",\"image_url11\":\"516\",\"j51_disableurl11\":\"no\",\"target_url11\":\"_self\",\"j51_animate_class11\":\"fadeInUp\",\"j51_image12\":\"\",\"j51_image_alt12\":\"\",\"j51_title12\":\"\",\"j51_text12\":\"\",\"j51_disablecaption12\":\"no\",\"image_url12\":\"516\",\"j51_disableurl12\":\"no\",\"target_url12\":\"_self\",\"j51_animate_class12\":\"fadeInUp\",\"j51_image13\":\"\",\"j51_image_alt13\":\"\",\"j51_title13\":\"\",\"j51_text13\":\"\",\"j51_disablecaption13\":\"no\",\"image_url13\":\"516\",\"j51_disableurl13\":\"no\",\"target_url13\":\"_self\",\"j51_animate_class13\":\"fadeInUp\",\"j51_image14\":\"\",\"j51_image_alt14\":\"\",\"j51_title14\":\"\",\"j51_text14\":\"\",\"j51_disablecaption14\":\"no\",\"image_url14\":\"516\",\"j51_disableurl14\":\"no\",\"target_url14\":\"_self\",\"j51_animate_class14\":\"fadeInUp\",\"j51_image15\":\"\",\"j51_image_alt15\":\"\",\"j51_title15\":\"\",\"j51_text15\":\"\",\"j51_disablecaption15\":\"no\",\"image_url15\":\"516\",\"j51_disableurl15\":\"no\",\"target_url15\":\"_self\",\"j51_animate_class15\":\"fadeInUp\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(388,330,'ThumbsGallery Example','','',1,'thumbsgallery',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_j51thumbsgallery',1,0,'{\"path\":\"\\/images\\/thumbsgallery\",\"thumbwidth\":\"98\",\"thumbheight\":\"98\",\"margin\":\"4\",\"bordersize\":\"3\",\"bordercolor\":\"#e0e0e0\",\"outlinecolor\":\"#fafafa\",\"fade_opacity\":\"0.4\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(404,348,'Example Carousel','','',1,'bottom-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_j51carousel',1,0,'{\"j51_num_blocks\":\"6\",\"j51_randomize\":\"0\",\"j51_blocks_per_slide\":\"3\",\"j51_boxed\":\"1\",\"j51_horiz_padding\":\"20\",\"j51_vert_padding\":\"10\",\"j51_transition_interval\":\"3000\",\"j51_transition_duration\":\"400\",\"j51_transition_style\":\"fade\",\"j51_pagination\":\"true\",\"j51_navigation\":\"true\",\"j51_text_prev\":\"Prev\",\"j51_text_next\":\"Next\",\"j51_image_width_tabl\":\"3\",\"j51_image_width_tabp\":\"2\",\"j51_image_width_mobl\":\"1\",\"j51_image_width_mobp\":\"1\",\"j51_image1\":\"
\\\"image1\\\"<\\/h3>\\r\\n
Nam eget urna pellentesque nisl ultrices dapibus. Mauris accumsan vehicula nisl, sed tempus mauris facilisis eu. Donec a iaculis nisi, quis malesuada justo.<\\/p>\",\"j51_image2\":\"
\\\"\\\"<\\/h3>\\r\\n
Nam eget urna pellentesque nisl ultrices dapibus. Mauris accumsan vehicula nisl, sed tempus mauris facilisis eu. Donec a iaculis nisi, quis malesuada justo.<\\/p>\",\"j51_image3\":\"
Nam eget urna pellentesque nisl ultrices dapibus. Mauris accumsan vehicula nisl, sed tempus mauris facilisis eu. Donec a iaculis nisi, quis malesuada justo.<\\/p>\",\"j51_image4\":\"
Nam eget urna pellentesque nisl ultrices dapibus. Mauris accumsan vehicula nisl, sed tempus mauris facilisis eu. Donec a iaculis nisi, quis malesuada justo.<\\/p>\",\"j51_image5\":\"
Nam eget urna pellentesque nisl ultrices dapibus. Mauris accumsan vehicula nisl, sed tempus mauris facilisis eu. Donec a iaculis nisi, quis malesuada justo.<\\/p>\",\"j51_image6\":\"
Nam eget urna pellentesque nisl ultrices dapibus. Mauris accumsan vehicula nisl, sed tempus mauris facilisis eu. Donec a iaculis nisi, quis malesuada justo.<\\/p>\",\"j51_image7\":\"\",\"j51_image8\":\"\",\"j51_image9\":\"\",\"j51_image10\":\"\",\"j51_image11\":\"\",\"j51_image12\":\"\",\"j51_image13\":\"\",\"j51_image14\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"margin-top-10 text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(406,350,'Endless Styling Possibilities - text-light','','
\r\n
',1,'top-2a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,0,'{\"prepare_content\":\"1\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(413,359,'Homepage GridGallery','','',1,'top-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_j51gridgallery',1,0,'{\"j51_num_images\":\"3\",\"j51_randomize\":\"0\",\"j51_image_width\":\"310\",\"j51_image_width_tabl\":\"240\",\"j51_image_width_tabp\":\"180\",\"j51_image_width_mobl\":\"396\",\"j51_image_width_mobp\":\"280\",\"j51_image_margin_x\":\"20\",\"j51_image_margin_y\":\"10\",\"j51_overlay_color\":\"#ffffff\",\"j51_title_color\":\"#222222\",\"j51_text_color\":\"#444444\",\"j51_image1\":\"images\\/homepage\\/image1.jpg\",\"j51_image_alt1\":\"image1\",\"j51_title1\":\"Placerat De\",\"j51_text1\":\"Morbi in sem quis dui placerat ornare. Pellentesque odio nisi, euismod in.\",\"j51_disablecaption1\":\"no\",\"image_url1\":\"#\",\"j51_disableurl1\":\"no\",\"target_url1\":\"_self\",\"j51_animate_class1\":\"\",\"j51_image2\":\"images\\/homepage\\/image2.jpg\",\"j51_image_alt2\":\"image2\",\"j51_title2\":\"Quam nunc\",\"j51_text2\":\"Morbi in sem quis dui placerat ornare. Pellentesque odio nisi, euismod in.\",\"j51_disablecaption2\":\"no\",\"image_url2\":\"#\",\"j51_disableurl2\":\"no\",\"target_url2\":\"_self\",\"j51_animate_class2\":\"\",\"j51_image3\":\"images\\/homepage\\/image3.jpg\",\"j51_image_alt3\":\"image3\",\"j51_title3\":\"Eros Pede\",\"j51_text3\":\"Sed egestas, ante et vulputate volutpat, eros pede semper est, vitae luctus.\",\"j51_disablecaption3\":\"no\",\"image_url3\":\"#\",\"j51_disableurl3\":\"no\",\"target_url3\":\"_self\",\"j51_animate_class3\":\"\",\"j51_image4\":\"\",\"j51_image_alt4\":\"\",\"j51_title4\":\"\",\"j51_text4\":\"\",\"j51_disablecaption4\":\"no\",\"image_url4\":\"#\",\"j51_disableurl4\":\"no\",\"target_url4\":\"_self\",\"j51_animate_class4\":\"fadeInUp\",\"j51_image5\":\"\",\"j51_image_alt5\":\"\",\"j51_title5\":\"\",\"j51_text5\":\"\",\"j51_disablecaption5\":\"no\",\"image_url5\":\"\",\"j51_disableurl5\":\"no\",\"target_url5\":\"_self\",\"j51_animate_class5\":\"fadeInUp\",\"j51_image6\":\"\",\"j51_image_alt6\":\"\",\"j51_title6\":\"\",\"j51_text6\":\"\",\"j51_disablecaption6\":\"no\",\"image_url6\":\"\",\"j51_disableurl6\":\"no\",\"target_url6\":\"_self\",\"j51_animate_class6\":\"fadeInUp\",\"j51_image7\":\"\",\"j51_image_alt7\":\"\",\"j51_title7\":\"\",\"j51_text7\":\"\",\"j51_disablecaption7\":\"no\",\"image_url7\":\"\",\"j51_disableurl7\":\"no\",\"target_url7\":\"_self\",\"j51_animate_class7\":\"fadeInLeft\",\"j51_image8\":\"\",\"j51_image_alt8\":\"\",\"j51_title8\":\"\",\"j51_text8\":\"\",\"j51_disablecaption8\":\"no\",\"image_url8\":\"\",\"j51_disableurl8\":\"no\",\"target_url8\":\"_self\",\"j51_animate_class8\":\"fadeIn\",\"j51_image9\":\"\",\"j51_image_alt9\":\"\",\"j51_title9\":\"\",\"j51_text9\":\"\",\"j51_disablecaption9\":\"no\",\"image_url9\":\"\",\"j51_disableurl9\":\"no\",\"target_url9\":\"_self\",\"j51_animate_class9\":\"fadeInRight\",\"j51_image10\":\"\",\"j51_image_alt10\":\"\",\"j51_title10\":\"\",\"j51_text10\":\"\",\"j51_disablecaption10\":\"no\",\"image_url10\":\"\",\"j51_disableurl10\":\"no\",\"target_url10\":\"_self\",\"j51_animate_class10\":\"fadeInUp\",\"j51_image11\":\"\",\"j51_image_alt11\":\"\",\"j51_title11\":\"\",\"j51_text11\":\"\",\"j51_disablecaption11\":\"no\",\"image_url11\":\"\",\"j51_disableurl11\":\"no\",\"target_url11\":\"_self\",\"j51_animate_class11\":\"fadeInUp\",\"j51_image12\":\"\",\"j51_image_alt12\":\"\",\"j51_title12\":\"\",\"j51_text12\":\"\",\"j51_disablecaption12\":\"no\",\"image_url12\":\"\",\"j51_disableurl12\":\"no\",\"target_url12\":\"_self\",\"j51_animate_class12\":\"fadeInUp\",\"j51_image13\":\"\",\"j51_image_alt13\":\"\",\"j51_title13\":\"\",\"j51_text13\":\"\",\"j51_disablecaption13\":\"no\",\"image_url13\":\"\",\"j51_disableurl13\":\"no\",\"target_url13\":\"_self\",\"j51_animate_class13\":\"fadeInUp\",\"j51_image14\":\"\",\"j51_image_alt14\":\"\",\"j51_title14\":\"\",\"j51_text14\":\"\",\"j51_disablecaption14\":\"no\",\"image_url14\":\"\",\"j51_disableurl14\":\"no\",\"target_url14\":\"_self\",\"j51_animate_class14\":\"fadeInUp\",\"j51_image15\":\"\",\"j51_image_alt15\":\"\",\"j51_title15\":\"\",\"j51_text15\":\"\",\"j51_disablecaption15\":\"no\",\"image_url15\":\"\",\"j51_disableurl15\":\"no\",\"target_url15\":\"_self\",\"j51_animate_class15\":\"fadeInUp\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(422,370,'Homepage Carousel','','',1,'showcase',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_j51carousel',1,0,'{\"j51_num_blocks\":\"3\",\"j51_randomize\":\"0\",\"j51_blocks_per_slide\":\"1\",\"j51_boxed\":\"0\",\"j51_horiz_padding\":\"10\",\"j51_vert_padding\":\"140\",\"j51_transition_interval\":\"4000\",\"j51_transition_duration\":\"500\",\"j51_transition_style\":\"fadeUp\",\"j51_pagination\":\"false\",\"j51_navigation\":\"false\",\"j51_text_prev\":\"Prev\",\"j51_text_next\":\"Next\",\"j51_image_width_tabl\":\"1\",\"j51_image_width_tabp\":\"1\",\"j51_image_width_mobl\":\"1\",\"j51_image_width_mobp\":\"1\",\"j51_image1\":\"
\\r\\n A Unique and Innovative Design\\r\\n<\\/h2>\",\"j51_image2\":\"
\\r\\n Rich Template Options to style your Project\\r\\n<\\/h2>\",\"j51_image3\":\"
\\r\\n Fully Responsive on all devices\\r\\n<\\/h2>\",\"j51_image4\":\"\",\"j51_image5\":\"\",\"j51_image6\":\"\",\"j51_image7\":\"\",\"j51_image8\":\"\",\"j51_image9\":\"\",\"j51_image10\":\"\",\"j51_image11\":\"\",\"j51_image12\":\"\",\"j51_image13\":\"\",\"j51_image14\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light padding-bottom-60\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(424,372,'Homepage Sidecol Filler','','
\r\n
Proin gravida nibh vel velit auctor aliquet. Aenean sollicitudin, lorem quis bibendum auctor, nisi elit consequat ipsum, nec sagittis sem nibh id elit. Duis sed odio sit amet nibh vulputate cursus a sit amet mauris.
\r\n
',1,'sidecol-a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,0,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(425,373,'Homepage Text Bottom-2 Header','','
Build Something Beautiful!
\r\n
\r\n
All stock images on this template demo are for presentation purposes only, intended to represent a live site and are not included with the template or in any of the Joomla51 club membership plans. Use the Nadia Demo Installer to install an equivalent of the demo onto your site or local Joomla installation. Nadia is available as part of the Club Subscription.
',1,'bottom-2a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,0,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(428,376,'Module Showcase','','
\r\n Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut. Suspendisse lacinia interdum felis eu consectetur. Aenean venenatis egestas iaculis. Nullam consectetur condimentum dolor at bibendum. Nulla in enim quis ipsum pulvinar imperdiet vitae nec velit. Donec non urna quam. Aliquam congue magna nec risus iaculis posuere. Vivamus bibendum interdum molestie. Sed libero risus, varius eu dictum ac, pharetra ac elit.\r\n
',1,'showcase',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(433,382,'Disclaimer','','
Disclaimer
\r\n
',1,'base-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,0,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(434,383,'Vestibulum aucto','','
',2,'bottom-2b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(435,384,'Aenean sollicitudin','','
',2,'bottom-2c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(436,385,'Praesent placerat','','
',3,'bottom-2c',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(437,386,'Vivamus vestibulum','','
',1,'bottom-2d',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(438,387,'Cras ornare tristique','','
',3,'bottom-2b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(439,388,'Nunc dignissim','','
',1,'bottom-2d',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,1,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(440,389,'Design with Passion','','
Design with Passion
\r\n
\r\n
\r\n
\r\n
View Details Buy Now
',1,'bottom-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,0,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(441,390,'Base Logo','','\"logo\"',1,'base-1a',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_custom',1,0,'{\"prepare_content\":\"0\",\"backgroundimage\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(442,391,'Portfolio','','',1,'sidecol-b',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_j51thumbsgallery',1,0,'{\"path\":\"\\/images\\/thumbsgallery\",\"thumbwidth\":\"98\",\"thumbheight\":\"98\",\"margin\":\"4\",\"bordersize\":\"3\",\"bordercolor\":\"#e0e0e0\",\"outlinecolor\":\"#fafafa\",\"fade_opacity\":\"0.4\",\"moduleclass_sfx\":\"padding-bottom-50\",\"cache\":\"1\",\"cache_time\":\"900\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(443,392,'Example Styles Carousel - Dark Text','','',1,'showcase',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_j51carousel',1,0,'{\"j51_num_blocks\":\"3\",\"j51_randomize\":\"0\",\"j51_blocks_per_slide\":\"1\",\"j51_boxed\":\"0\",\"j51_horiz_padding\":\"10\",\"j51_vert_padding\":\"140\",\"j51_transition_interval\":\"4000\",\"j51_transition_duration\":\"500\",\"j51_transition_style\":\"fadeUp\",\"j51_pagination\":\"false\",\"j51_navigation\":\"false\",\"j51_text_prev\":\"Prev\",\"j51_text_next\":\"Next\",\"j51_image_width_tabl\":\"1\",\"j51_image_width_tabp\":\"1\",\"j51_image_width_mobl\":\"1\",\"j51_image_width_mobp\":\"1\",\"j51_image1\":\"
\\r\\n Fully Responsive on all devices\\r\\n<\\/h2>\",\"j51_image4\":\"\",\"j51_image5\":\"\",\"j51_image6\":\"\",\"j51_image7\":\"\",\"j51_image8\":\"\",\"j51_image9\":\"\",\"j51_image10\":\"\",\"j51_image11\":\"\",\"j51_image12\":\"\",\"j51_image13\":\"\",\"j51_image14\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*'),(444,393,'Example Styles Carousel - Light Text','','',1,'showcase',0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00',1,'mod_j51carousel',1,0,'{\"j51_num_blocks\":\"3\",\"j51_randomize\":\"0\",\"j51_blocks_per_slide\":\"1\",\"j51_boxed\":\"0\",\"j51_horiz_padding\":\"10\",\"j51_vert_padding\":\"140\",\"j51_transition_interval\":\"4000\",\"j51_transition_duration\":\"500\",\"j51_transition_style\":\"fadeUp\",\"j51_pagination\":\"false\",\"j51_navigation\":\"false\",\"j51_text_prev\":\"Prev\",\"j51_text_next\":\"Next\",\"j51_image_width_tabl\":\"1\",\"j51_image_width_tabp\":\"1\",\"j51_image_width_mobl\":\"1\",\"j51_image_width_mobp\":\"1\",\"j51_image1\":\"
\\r\\n Fully Responsive on all devices\\r\\n<\\/h2>\",\"j51_image4\":\"\",\"j51_image5\":\"\",\"j51_image6\":\"\",\"j51_image7\":\"\",\"j51_image8\":\"\",\"j51_image9\":\"\",\"j51_image10\":\"\",\"j51_image11\":\"\",\"j51_image12\":\"\",\"j51_image13\":\"\",\"j51_image14\":\"\",\"layout\":\"_:default\",\"moduleclass_sfx\":\"text-light\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\",\"module_tag\":\"div\",\"bootstrap_size\":\"0\",\"header_tag\":\"h3\",\"header_class\":\"\",\"style\":\"0\"}',0,'*')
Table 'ecweb_2016b.#__modules' doesn't exist SQL=/*!40000 ALTER TABLE `#__modules` DISABLE KEYS */
Table 'ecweb_2016b.#__modules' doesn't exist SQL=LOCK TABLES `#__modules` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__modules` ( `id` int(11) NOT NULL AUTO_INCREMENT, `asset_id` int(10) unsigned NOT NULL DEFAULT '0' COMMENT 'FK to the #__assets table.', `title` varchar(100) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `note` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `content` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `ordering` int(11) NOT NULL DEFAULT '0', `position` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `checked_out` int(10) unsigned NOT NULL DEFAULT '0', `checked_out_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `publish_up` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `publish_down` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `published` tinyint(1) NOT NULL DEFAULT '0', `module` varchar(50) COLLATE utf8mb4_unicode_ci DEFAULT NULL, `access` int(10) unsigned NOT NULL DEFAULT '0', `showtitle` tinyint(3) unsigned NOT NULL DEFAULT '1', `params` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `client_id` tinyint(4) NOT NULL DEFAULT '0', `language` char(7) COLLATE utf8mb4_unicode_ci NOT NULL, PRIMARY KEY (`id`), KEY `published` (`published`,`access`), KEY `newsfeeds` (`module`,`published`), KEY `idx_language` (`language`) ) ENGINE=InnoDB AUTO_INCREMENT=445 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__messages_cfg' doesn't exist SQL=/*!40000 ALTER TABLE `#__messages_cfg` ENABLE KEYS */
Table 'ecweb_2016b.#__messages_cfg' doesn't exist SQL=/*!40000 ALTER TABLE `#__messages_cfg` DISABLE KEYS */
Table 'ecweb_2016b.#__messages_cfg' doesn't exist SQL=LOCK TABLES `#__messages_cfg` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__messages_cfg` ( `user_id` int(10) unsigned NOT NULL DEFAULT '0', `cfg_name` varchar(100) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `cfg_value` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', UNIQUE KEY `idx_user_var_name` (`user_id`,`cfg_name`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__messages' doesn't exist SQL=/*!40000 ALTER TABLE `#__messages` ENABLE KEYS */
Table 'ecweb_2016b.#__messages' doesn't exist SQL=/*!40000 ALTER TABLE `#__messages` DISABLE KEYS */
Table 'ecweb_2016b.#__messages' doesn't exist SQL=LOCK TABLES `#__messages` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__messages` ( `message_id` int(10) unsigned NOT NULL AUTO_INCREMENT, `user_id_from` int(10) unsigned NOT NULL DEFAULT '0', `user_id_to` int(10) unsigned NOT NULL DEFAULT '0', `folder_id` tinyint(3) unsigned NOT NULL DEFAULT '0', `date_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `state` tinyint(1) NOT NULL DEFAULT '0', `priority` tinyint(1) unsigned NOT NULL DEFAULT '0', `subject` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `message` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, PRIMARY KEY (`message_id`), KEY `useridto_state` (`user_id_to`,`state`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__menu_types' doesn't exist SQL=/*!40000 ALTER TABLE `#__menu_types` ENABLE KEYS */
Table 'ecweb_2016b.#__menu_types' doesn't exist SQL=INSERT INTO `#__menu_types` VALUES (2,'usermenu','User Menu','A Menu for logged-in Users'),(3,'mainmenu','Main Menu','Links for major types of users'),(9,'joomla51','Joomla51',''),(11,'samplemenu','Sample Menu',''),(12,'home','Home',''),(15,'blog','Blog',''),(16,'friends','Friends','')
Table 'ecweb_2016b.#__menu_types' doesn't exist SQL=/*!40000 ALTER TABLE `#__menu_types` DISABLE KEYS */
Table 'ecweb_2016b.#__menu_types' doesn't exist SQL=LOCK TABLES `#__menu_types` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__menu_types` ( `id` int(10) unsigned NOT NULL AUTO_INCREMENT, `menutype` varchar(24) COLLATE utf8mb4_unicode_ci NOT NULL, `title` varchar(48) COLLATE utf8mb4_unicode_ci NOT NULL, `description` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', PRIMARY KEY (`id`), UNIQUE KEY `idx_menutype` (`menutype`) ) ENGINE=InnoDB AUTO_INCREMENT=17 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__menu' doesn't exist SQL=/*!40000 ALTER TABLE `#__menu` ENABLE KEYS */
Table 'ecweb_2016b.#__menu' doesn't exist SQL=INSERT INTO `#__menu` VALUES (1,'','Menu_Item_Root','root','','','','',1,0,0,0,0,'0000-00-00 00:00:00',0,0,'',0,'',0,169,0,'*',0),(2,'menu','com_banners','Banners','','Banners','index.php?option=com_banners','component',0,1,1,4,0,'0000-00-00 00:00:00',0,0,'class:banners',0,'',77,86,0,'*',1),(3,'menu','com_banners','Banners','','Banners/Banners','index.php?option=com_banners','component',0,2,2,4,0,'0000-00-00 00:00:00',0,0,'class:banners',0,'',78,79,0,'*',1),(4,'menu','com_banners_categories','Categories','','Banners/Categories','index.php?option=com_categories&extension=com_banners','component',0,2,2,6,0,'0000-00-00 00:00:00',0,0,'class:banners-cat',0,'',80,81,0,'*',1),(5,'menu','com_banners_clients','Clients','','Banners/Clients','index.php?option=com_banners&view=clients','component',0,2,2,4,0,'0000-00-00 00:00:00',0,0,'class:banners-clients',0,'',82,83,0,'*',1),(6,'menu','com_banners_tracks','Tracks','','Banners/Tracks','index.php?option=com_banners&view=tracks','component',0,2,2,4,0,'0000-00-00 00:00:00',0,0,'class:banners-tracks',0,'',84,85,0,'*',1),(7,'menu','com_contact','Contacts','','Contacts','index.php?option=com_contact','component',0,1,1,8,0,'0000-00-00 00:00:00',0,0,'class:contact',0,'',87,92,0,'*',1),(8,'menu','com_contact_contacts','Contacts','','Contacts/Contacts','index.php?option=com_contact','component',0,7,2,8,0,'0000-00-00 00:00:00',0,0,'class:contact',0,'',88,89,0,'*',1),(9,'menu','com_contact_categories','Categories','','Contacts/Categories','index.php?option=com_categories&extension=com_contact','component',0,7,2,6,0,'0000-00-00 00:00:00',0,0,'class:contact-cat',0,'',90,91,0,'*',1),(10,'menu','com_messages','Messaging','','Messaging','index.php?option=com_messages','component',0,1,1,15,0,'0000-00-00 00:00:00',0,0,'class:messages',0,'',95,100,0,'*',1),(11,'menu','com_messages_add','New Private Message','','Messaging/New Private Message','index.php?option=com_messages&task=message.add','component',0,10,2,15,0,'0000-00-00 00:00:00',0,0,'class:messages-add',0,'',96,97,0,'*',1),(13,'menu','com_newsfeeds','News Feeds','','News Feeds','index.php?option=com_newsfeeds','component',0,1,1,17,0,'0000-00-00 00:00:00',0,0,'class:newsfeeds',0,'',101,106,0,'*',1),(14,'menu','com_newsfeeds_feeds','Feeds','','News Feeds/Feeds','index.php?option=com_newsfeeds','component',0,13,2,17,0,'0000-00-00 00:00:00',0,0,'class:newsfeeds',0,'',102,103,0,'*',1),(15,'menu','com_newsfeeds_categories','Categories','','News Feeds/Categories','index.php?option=com_categories&extension=com_newsfeeds','component',0,13,2,6,0,'0000-00-00 00:00:00',0,0,'class:newsfeeds-cat',0,'',104,105,0,'*',1),(16,'menu','com_redirect','Redirect','','Redirect','index.php?option=com_redirect','component',0,1,1,24,0,'0000-00-00 00:00:00',0,0,'class:redirect',0,'',111,112,0,'*',1),(17,'menu','com_search','Basic Search','','Basic Search','index.php?option=com_search','component',0,1,1,19,0,'0000-00-00 00:00:00',0,0,'class:search',0,'',109,110,0,'*',1),(21,'menu','com_finder','Smart Search','','Smart Search','index.php?option=com_finder','component',0,1,1,27,0,'0000-00-00 00:00:00',0,0,'class:finder',0,'',107,108,0,'*',1),(201,'usermenu','Your Profile','your-profile','','your-profile','index.php?option=com_users&view=profile','component',1,1,1,25,0,'0000-00-00 00:00:00',0,2,'',0,'{\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',113,114,0,'*',0),(449,'usermenu','Submit an Article','submit-an-article','','submit-an-article','index.php?option=com_content&view=form&layout=edit','component',1,1,1,22,0,'0000-00-00 00:00:00',0,3,'',0,'{\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',115,116,0,'*',0),(450,'usermenu','Submit a Web Link','submit-a-web-link','','submit-a-web-link','index.php?option=com_weblinks&view=form&layout=edit','component',1,1,1,21,0,'0000-00-00 00:00:00',0,3,'',0,'{\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',117,118,0,'*',0),(464,'mainmenu','Home','home','','home','index.php?option=com_content&view=featured','component',1,1,1,22,0,'0000-00-00 00:00:00',0,1,'',469,'{\"featured_categories\":[\"\"],\"layout_type\":\"blog\",\"num_leading_articles\":\"0\",\"num_intro_articles\":\"1\",\"num_columns\":\"1\",\"num_links\":\"\",\"multi_column_order\":\"\",\"orderby_pri\":\"\",\"orderby_sec\":\"\",\"order_date\":\"\",\"show_pagination\":\"\",\"show_pagination_results\":\"\",\"show_title\":\"\",\"link_titles\":\"1\",\"show_intro\":\"1\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_readmore\":\"\",\"show_readmore_title\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_tags\":\"\",\"show_noauth\":\"\",\"show_feed_link\":\"\",\"feed_summary\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":\"0\",\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',1,2,1,'*',0),(468,'mainmenu','Template Parameters','parameters','','features/parameters','index.php?option=com_content&view=article&id=72','component',1,507,2,22,0,'0000-00-00 00:00:00',0,1,'',0,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_tags\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',16,17,0,'*',0),(469,'mainmenu','Module Positions','module-positions','','features/module-positions','index.php?option=com_content&view=article&id=71','component',1,507,2,22,0,'0000-00-00 00:00:00',0,1,'',0,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_tags\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',12,13,0,'*',0),(482,'mainmenu','Layout Options','layout-options','','layout-options','index.php?option=com_content&view=article&id=74','component',1,1,1,22,0,'0000-00-00 00:00:00',0,1,'',0,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_tags\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":\"0\",\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',33,46,0,'*',0),(483,'mainmenu','Content','left-column-layout','','layout-options/left-column-layout','index.php?option=com_content&view=article&id=74','component',1,482,2,22,0,'0000-00-00 00:00:00',0,1,'',483,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',34,35,0,'*',0),(486,'joomla51','Joomla51 Home','2012-02-22-16-57-49','','2012-02-22-16-57-49','http://www.joomla51.com/','url',1,1,1,0,0,'0000-00-00 00:00:00',1,1,'',0,'{\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"fa-link\",\"menu_image\":\"\",\"menu_text\":1}',119,120,0,'*',0),(487,'joomla51','Browse Templates','2012-02-22-16-58-26','','2012-02-22-16-58-26','http://www.joomla51.com/joomla-templates','url',1,1,1,0,0,'0000-00-00 00:00:00',1,1,'',0,'{\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"fa-th-list\",\"menu_image\":\"\",\"menu_text\":1}',121,122,0,'*',0),(488,'joomla51','Buy this Template!','2012-02-22-17-23-14','','2012-02-22-17-23-14','http://www.joomla51.com/','url',-2,1,1,0,0,'0000-00-00 00:00:00',1,1,'',0,'{\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1}',123,124,0,'*',0),(493,'mainmenu','Typography','typography','','typography','index.php?option=com_content&view=article&id=75','component',1,1,1,22,0,'0000-00-00 00:00:00',0,1,' ',0,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_tags\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":\"0\",\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',47,48,0,'*',0),(497,'mainmenu',' Content - Sidecol','content-sidecol','','layout-options/content-sidecol','index.php?option=com_content&view=article&id=74','component',1,482,2,22,0,'0000-00-00 00:00:00',0,1,'',483,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',36,37,0,'*',0),(498,'mainmenu',' Content - Sidecol - Sidecol','content-sidecol-sidecol','','layout-options/content-sidecol-sidecol','index.php?option=com_content&view=article&id=74','component',1,482,2,22,0,'0000-00-00 00:00:00',0,1,'',473,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',40,41,0,'*',0),(499,'mainmenu',' Sidecol - Content - Sidecol','sidecol-content-sidecol','','layout-options/sidecol-content-sidecol','index.php?option=com_content&view=article&id=74','component',1,482,2,22,0,'0000-00-00 00:00:00',0,1,'',483,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',42,43,0,'*',0),(500,'mainmenu','Sidecol - Content','sidecol-content','','layout-options/sidecol-content','index.php?option=com_content&view=article&id=74','component',1,482,2,22,0,'0000-00-00 00:00:00',0,1,'',483,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',38,39,0,'*',0),(501,'mainmenu','Sidecol - Sidecol - Content','sidecol-sidecol-content','','layout-options/sidecol-sidecol-content','index.php?option=com_content&view=article&id=74','component',1,482,2,22,0,'0000-00-00 00:00:00',0,1,'',472,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',44,45,0,'*',0),(502,'joomla51','Joomla51 Forum','2012-04-16-18-00-03','','2012-04-16-18-00-03','','url',1,1,1,0,0,'0000-00-00 00:00:00',1,1,'',0,'{\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"fa-comments\",\"menu_image\":\"\",\"menu_text\":1}',125,126,0,'*',0),(503,'joomla51','Joomla.org','2012-06-30-16-14-38','','2012-06-30-16-14-38','http://www.joomla.org','url',1,1,1,0,0,'0000-00-00 00:00:00',1,1,'',0,'{\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"fa-heart\",\"menu_image\":\"\",\"menu_text\":1}',127,128,0,'*',0),(507,'mainmenu','Template Features','features','','features','','url',1,1,1,0,0,'0000-00-00 00:00:00',0,1,' ',0,'{\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1}',3,32,0,'*',0),(509,'mainmenu','J!Stuff','j-stuff','','j-stuff','','url',1,1,1,0,0,'0000-00-00 00:00:00',0,1,' ',0,'{\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1}',49,62,0,'*',0),(510,'mainmenu','Single Article','singlearticle','','j-stuff/singlearticle','index.php?option=com_content&view=article&id=79','component',1,509,2,22,0,'0000-00-00 00:00:00',0,1,'',0,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"1\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"1\",\"link_author\":\"\",\"show_create_date\":\"1\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"1\",\"show_print_icon\":\"1\",\"show_email_icon\":\"1\",\"show_hits\":\"1\",\"show_tags\":\"1\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',50,51,0,'*',0),(511,'mainmenu','Category Blog','category-blog','','j-stuff/category-blog','index.php?option=com_content&view=category&layout=blog&id=78','component',1,509,2,22,0,'0000-00-00 00:00:00',0,1,'',0,'{\"layout_type\":\"blog\",\"show_category_heading_title_text\":\"\",\"show_category_title\":\"\",\"show_description\":\"\",\"show_description_image\":\"\",\"maxLevel\":\"\",\"show_empty_categories\":\"\",\"show_no_articles\":\"\",\"show_subcat_desc\":\"\",\"show_cat_num_articles\":\"\",\"page_subheading\":\"\",\"num_leading_articles\":\"1\",\"num_intro_articles\":\"4\",\"num_columns\":\"2\",\"num_links\":\"\",\"multi_column_order\":\"\",\"show_subcategory_content\":\"\",\"orderby_pri\":\"order\",\"orderby_sec\":\"rdate\",\"order_date\":\"\",\"show_pagination\":\"\",\"show_pagination_results\":\"\",\"show_title\":\"\",\"link_titles\":\"1\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"1\",\"link_author\":\"\",\"show_create_date\":\"1\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_readmore\":\"\",\"show_readmore_title\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"show_feed_link\":\"\",\"feed_summary\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',52,53,0,'*',0),(512,'mainmenu','Login Form','login-form','','j-stuff/login-form','index.php?option=com_content&view=article&id=82','component',1,509,2,22,0,'0000-00-00 00:00:00',0,1,'',483,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',54,55,0,'*',0),(513,'mainmenu','Single Contact','singlecontact','','j-stuff/singlecontact','index.php?option=com_contact&view=contact&id=1','component',-2,509,2,8,0,'0000-00-00 00:00:00',0,1,'',0,'{\"presentation_style\":\"sliders\",\"show_contact_category\":\"\",\"show_contact_list\":\"\",\"show_tags\":\"\",\"show_name\":\"\",\"show_position\":\"\",\"show_email\":\"\",\"show_street_address\":\"\",\"show_suburb\":\"\",\"show_state\":\"\",\"show_postcode\":\"\",\"show_country\":\"\",\"show_telephone\":\"\",\"show_mobile\":\"\",\"show_fax\":\"\",\"show_webpage\":\"\",\"show_misc\":\"\",\"show_image\":\"\",\"allow_vcard\":\"\",\"show_articles\":\"\",\"show_links\":\"\",\"linka_name\":\"\",\"linkb_name\":\"\",\"linkc_name\":\"\",\"linkd_name\":\"\",\"linke_name\":\"\",\"show_email_form\":\"\",\"show_email_copy\":\"\",\"banned_email\":\"\",\"banned_subject\":\"\",\"banned_text\":\"\",\"validate_session\":\"\",\"custom_reply\":\"\",\"redirect\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":\"0\",\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',56,57,0,'*',0),(514,'mainmenu','Registration Form','registrationform','','j-stuff/registrationform','index.php?option=com_users&view=registration','component',1,509,2,25,0,'0000-00-00 00:00:00',0,1,'',0,'{\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":1,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',58,59,0,'*',0),(516,'samplemenu','Placerat facer possim','placerat-facer-possim','','placerat-facer-possim','index.php?option=com_content&view=article&id=81','component',1,1,1,22,0,'0000-00-00 00:00:00',0,1,'',0,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_tags\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',129,130,0,'*',0),(517,'samplemenu','Quam nunc putamus','quam-nunc-putamus','','quam-nunc-putamus','index.php?option=com_content&view=article&id=82','component',1,1,1,22,0,'0000-00-00 00:00:00',0,1,'',0,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',131,132,0,'*',0),(518,'samplemenu','Velit esse molestie','velit-esse-molestie-consequat','','velit-esse-molestie-consequat','index.php?option=com_content&view=article&id=79','component',1,1,1,22,0,'0000-00-00 00:00:00',0,1,'',0,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_tags\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',133,134,0,'*',0),(519,'mainmenu','Responsive Design','responsive-design','','features/responsive-design','index.php?option=com_content&view=article&id=84','component',1,507,2,22,0,'0000-00-00 00:00:00',0,1,'',0,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_tags\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',10,11,0,'*',0),(520,'mainmenu','Replaceable Backgrounds','replaceable-background-image','','features/replaceable-background-image','index.php?option=com_content&view=article&id=85','component',-2,507,2,22,0,'0000-00-00 00:00:00',0,1,'',0,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_tags\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',14,15,0,'*',0),(521,'main','com_joomlaupdate','com-joomlaupdate','','com-joomlaupdate','index.php?option=com_joomlaupdate','component',0,1,1,866,0,'0000-00-00 00:00:00',0,1,'class:component',0,'',135,136,0,'',1),(522,'mainmenu','Category List','category-list','','j-stuff/category-list','index.php?option=com_content&view=category&id=9','component',1,509,2,22,0,'0000-00-00 00:00:00',0,1,'',0,'{\"show_category_title\":\"\",\"show_description\":\"\",\"show_description_image\":\"\",\"maxLevel\":\"\",\"show_empty_categories\":\"\",\"show_no_articles\":\"\",\"show_subcat_desc\":\"\",\"show_cat_num_articles\":\"\",\"page_subheading\":\"\",\"show_pagination_limit\":\"\",\"filter_field\":\"\",\"show_headings\":\"\",\"list_show_date\":\"\",\"date_format\":\"\",\"list_show_hits\":\"\",\"list_show_author\":\"\",\"orderby_pri\":\"\",\"orderby_sec\":\"\",\"order_date\":\"\",\"show_pagination\":\"\",\"show_pagination_results\":\"\",\"display_num\":\"10\",\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_readmore\":\"\",\"show_readmore_title\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"show_feed_link\":\"\",\"feed_summary\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":1,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',60,61,0,'*',0),(523,'mainmenu','Example Styles','example-styles','','example-styles','','url',1,1,1,0,0,'0000-00-00 00:00:00',0,1,'',0,'{\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1}',63,76,0,'*',0),(524,'mainmenu','Example Style 1','example-styles-1','','example-styles/example-styles-1','index.php?option=com_content&view=article&id=81','component',1,523,2,22,0,'0000-00-00 00:00:00',0,1,'',474,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"1\",\"link_author\":\"\",\"show_create_date\":\"1\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',64,65,0,'*',0),(525,'mainmenu','Example Style 2','example-styles-2','','example-styles/example-styles-2','index.php?option=com_content&view=article&id=81','component',1,523,2,22,0,'0000-00-00 00:00:00',0,1,'',475,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"1\",\"link_author\":\"\",\"show_create_date\":\"1\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',66,67,0,'*',0),(526,'mainmenu','Example Style 3','example-styles-3','','example-styles/example-styles-3','index.php?option=com_content&view=article&id=81','component',1,523,2,22,0,'0000-00-00 00:00:00',0,1,'',476,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"1\",\"link_author\":\"\",\"show_create_date\":\"1\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',68,69,0,'*',0),(527,'mainmenu','Example Style 4','example-styles-4','','example-styles/example-styles-4','index.php?option=com_content&view=article&id=81','component',1,523,2,22,0,'0000-00-00 00:00:00',0,1,'',477,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"1\",\"link_author\":\"\",\"show_create_date\":\"1\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_tags\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',70,71,0,'*',0),(528,'mainmenu','Example Style 5','example-styles-5','','example-styles/example-styles-5','index.php?option=com_content&view=article&id=81','component',1,523,2,22,0,'0000-00-00 00:00:00',0,1,'',478,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"1\",\"link_author\":\"\",\"show_create_date\":\"1\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_tags\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',72,73,0,'*',0),(529,'mainmenu','Example Style 6','example-styles-6','','example-styles/example-styles-6','index.php?option=com_content&view=article&id=81','component',1,523,2,22,0,'0000-00-00 00:00:00',0,1,'',479,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"1\",\"link_author\":\"\",\"show_create_date\":\"1\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',74,75,0,'*',0),(530,'samplemenu','Vivamus sit amet ante ','vivamus-sit-amet-ante','','vivamus-sit-amet-ante','index.php?option=com_content&view=article&id=76','component',1,1,1,22,0,'0000-00-00 00:00:00',0,1,'',0,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',137,138,0,'*',0),(531,'mainmenu','Color Choosers','colour-choosers','','features/colour-choosers','index.php?option=com_content&view=article&id=86','component',1,507,2,22,0,'0000-00-00 00:00:00',0,1,'',0,'{\"show_title\":\"0\",\"link_titles\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_tags\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',8,9,0,'*',0),(532,'main','com_tags','com-tags','','com-tags','index.php?option=com_tags','component',0,1,1,880,0,'0000-00-00 00:00:00',0,1,'class:tags',0,'',139,140,0,'',1),(533,'samplemenu','Nulla in enim quis','nulla-in-enim-quis','','nulla-in-enim-quis','index.php?option=com_content&view=article&id=80','component',-2,1,1,22,0,'0000-00-00 00:00:00',0,1,'',0,'{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_vote\":\"\",\"show_tags\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"\",\"menu_image\":\"\",\"menu_text\":1,\"page_title\":\"\",\"show_page_heading\":0,\"page_heading\":\"\",\"pageclass_sfx\":\"\",\"menu-meta_description\":\"\",\"menu-meta_keywords\":\"\",\"robots\":\"\",\"secure\":0}',141,142,0,'*',0),(534,'joomla51','Buy this Template','2013-11-05-21-53-17','','2013-11-05-21-53-17','http://www.joomla51.com/','url',1,1,1,0,0,'0000-00-00 00:00:00',1,1,'',0,'{\"menu-anchor_title\":\"\",\"menu-anchor_css\":\"fa-plus animate fadeInLeft\",\"menu_image\":\"\",\"menu_text\":1}',143,144,0,'*',0),(535,'main','com_postinstall','Post-installation messages','','Post-installation messages','index.php?option=com_postinstall','component',0,1,1,32,0,'0000-00-00 00:00:00',0,1,'class
Table 'ecweb_2016b.#__menu' doesn't exist SQL=/*!40000 ALTER TABLE `#__menu` DISABLE KEYS */
Table 'ecweb_2016b.#__menu' doesn't exist SQL=LOCK TABLES `#__menu` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__menu` ( `id` int(11) NOT NULL AUTO_INCREMENT, `menutype` varchar(24) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'The type of menu this item belongs to. FK to #__menu_types.menutype', `title` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'The display title of the menu item.', `alias` varchar(400) CHARACTER SET utf8mb4 COLLATE utf8mb4_bin NOT NULL COMMENT 'The SEF alias of the menu item.', `note` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `path` varchar(1024) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'The computed path of the menu item based on the alias field.', `link` varchar(1024) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'The actually link the menu item refers to.', `type` varchar(16) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'The type of link: Component, URL, Alias, Separator', `published` tinyint(4) NOT NULL DEFAULT '0' COMMENT 'The published state of the menu link.', `parent_id` int(10) unsigned NOT NULL DEFAULT '1' COMMENT 'The parent menu item in the menu tree.', `level` int(10) unsigned NOT NULL DEFAULT '0' COMMENT 'The relative level in the tree.', `component_id` int(10) unsigned NOT NULL DEFAULT '0' COMMENT 'FK to #__extensions.id', `checked_out` int(10) unsigned NOT NULL DEFAULT '0' COMMENT 'FK to #__users.id', `checked_out_time` timestamp NOT NULL DEFAULT '0000-00-00 00:00:00' COMMENT 'The time the menu item was checked out.', `browserNav` tinyint(4) NOT NULL DEFAULT '0' COMMENT 'The click behaviour of the link.', `access` int(10) unsigned NOT NULL DEFAULT '0' COMMENT 'The access level required to view the menu item.', `img` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'The image of the menu item.', `template_style_id` int(10) unsigned NOT NULL DEFAULT '0', `params` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'JSON encoded data for the menu item.', `lft` int(11) NOT NULL DEFAULT '0' COMMENT 'Nested set lft.', `rgt` int(11) NOT NULL DEFAULT '0' COMMENT 'Nested set rgt.', `home` tinyint(3) unsigned NOT NULL DEFAULT '0' COMMENT 'Indicates if this menu item is the home or default page.', `language` char(7) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `client_id` tinyint(4) NOT NULL DEFAULT '0', PRIMARY KEY (`id`), UNIQUE KEY `idx_client_id_parent_id_alias_language` (`client_id`,`parent_id`,`alias`(100),`language`), KEY `idx_componentid` (`component_id`,`menutype`,`published`,`access`), KEY `idx_menutype` (`menutype`), KEY `idx_left_right` (`lft`,`rgt`), KEY `idx_path` (`path`(191)), KEY `idx_language` (`language`), KEY `idx_alias` (`alias`(100)) ) ENGINE=InnoDB AUTO_INCREMENT=567 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__languages' doesn't exist SQL=/*!40000 ALTER TABLE `#__languages` ENABLE KEYS */
Table 'ecweb_2016b.#__languages' doesn't exist SQL=INSERT INTO `#__languages` VALUES (1,'en-GB','English (UK)','English (UK)','en','en','','','','',1,0,1)
Table 'ecweb_2016b.#__languages' doesn't exist SQL=/*!40000 ALTER TABLE `#__languages` DISABLE KEYS */
Table 'ecweb_2016b.#__languages' doesn't exist SQL=LOCK TABLES `#__languages` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__languages` ( `lang_id` int(11) unsigned NOT NULL AUTO_INCREMENT, `lang_code` char(7) CHARACTER SET utf8mb4 COLLATE utf8mb4_bin NOT NULL, `title` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL, `title_native` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL, `sef` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL, `image` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL, `description` varchar(512) COLLATE utf8mb4_unicode_ci NOT NULL, `metakey` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `metadesc` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `sitename` varchar(1024) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `published` int(11) NOT NULL DEFAULT '0', `access` int(10) unsigned NOT NULL DEFAULT '0', `ordering` int(11) NOT NULL DEFAULT '0', PRIMARY KEY (`lang_id`), UNIQUE KEY `idx_sef` (`sef`), UNIQUE KEY `idx_image` (`image`), UNIQUE KEY `idx_langcode` (`lang_code`), KEY `idx_ordering` (`ordering`) ) ENGINE=InnoDB AUTO_INCREMENT=2 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__finder_types' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_types` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_types' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_types` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_types' doesn't exist SQL=LOCK TABLES `#__finder_types` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_types` ( `id` int(10) unsigned NOT NULL AUTO_INCREMENT, `title` varchar(100) NOT NULL, `mime` varchar(100) NOT NULL, PRIMARY KEY (`id`), UNIQUE KEY `title` (`title`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_tokens_aggregate' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_tokens_aggregate` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_tokens_aggregate' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_tokens_aggregate` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_tokens_aggregate' doesn't exist SQL=LOCK TABLES `#__finder_tokens_aggregate` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_tokens_aggregate` ( `term_id` int(10) unsigned NOT NULL, `map_suffix` char(1) NOT NULL, `term` varchar(75) NOT NULL, `stem` varchar(75) NOT NULL, `common` tinyint(1) unsigned NOT NULL DEFAULT '0', `phrase` tinyint(1) unsigned NOT NULL DEFAULT '0', `term_weight` float unsigned NOT NULL, `context` tinyint(1) unsigned NOT NULL DEFAULT '2', `context_weight` float unsigned NOT NULL, `total_weight` float unsigned NOT NULL, `language` char(3) NOT NULL DEFAULT '', KEY `token` (`term`), KEY `keyword_id` (`term_id`) ) ENGINE=MEMORY DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_tokens' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_tokens` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_tokens' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_tokens` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_tokens' doesn't exist SQL=LOCK TABLES `#__finder_tokens` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_tokens` ( `term` varchar(75) NOT NULL, `stem` varchar(75) NOT NULL, `common` tinyint(1) unsigned NOT NULL DEFAULT '0', `phrase` tinyint(1) unsigned NOT NULL DEFAULT '0', `weight` float unsigned NOT NULL DEFAULT '1', `context` tinyint(1) unsigned NOT NULL DEFAULT '2', `language` char(3) NOT NULL DEFAULT '', KEY `idx_word` (`term`), KEY `idx_context` (`context`) ) ENGINE=MEMORY DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_terms_common' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_terms_common` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_terms_common' doesn't exist SQL=INSERT INTO `#__finder_terms_common` VALUES ('a','en'),('about','en'),('after','en'),('ago','en'),('all','en'),('am','en'),('an','en'),('and','en'),('ani','en'),('any','en'),('are','en'),('aren\'t','en'),('as','en'),('at','en'),('be','en'),('but','en'),('by','en'),('for','en'),('from','en'),('get','en'),('go','en'),('how','en'),('if','en'),('in','en'),('into','en'),('is','en'),('isn\'t','en'),('it','en'),('its','en'),('me','en'),('more','en'),('most','en'),('must','en'),('my','en'),('new','en'),('no','en'),('none','en'),('not','en'),('noth','en'),('nothing','en'),('of','en'),('off','en'),('often','en'),('old','en'),('on','en'),('onc','en'),('once','en'),('onli','en'),('only','en'),('or','en'),('other','en'),('our','en'),('ours','en'),('out','en'),('over','en'),('page','en'),('she','en'),('should','en'),('small','en'),('so','en'),('some','en'),('than','en'),('thank','en'),('that','en'),('the','en'),('their','en'),('theirs','en'),('them','en'),('then','en'),('there','en'),('these','en'),('they','en'),('this','en'),('those','en'),('thus','en'),('time','en'),('times','en'),('to','en'),('too','en'),('true','en'),('under','en'),('until','en'),('up','en'),('upon','en'),('use','en'),('user','en'),('users','en'),('veri','en'),('version','en'),('very','en'),('via','en'),('want','en'),('was','en'),('way','en'),('were','en'),('what','en'),('when','en'),('where','en'),('whi','en'),('which','en'),('who','en'),('whom','en'),('whose','en'),('why','en'),('wide','en'),('will','en'),('with','en'),('within','en'),('without','en'),('would','en'),('yes','en'),('yet','en'),('you','en'),('your','en'),('yours','en')
Table 'ecweb_2016b.#__finder_terms_common' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_terms_common` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_terms_common' doesn't exist SQL=LOCK TABLES `#__finder_terms_common` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_terms_common` ( `term` varchar(75) NOT NULL, `language` varchar(3) NOT NULL, KEY `idx_word_lang` (`term`,`language`), KEY `idx_lang` (`language`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_terms' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_terms` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_terms' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_terms` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_terms' doesn't exist SQL=LOCK TABLES `#__finder_terms` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_terms` ( `term_id` int(10) unsigned NOT NULL AUTO_INCREMENT, `term` varchar(75) NOT NULL, `stem` varchar(75) NOT NULL, `common` tinyint(1) unsigned NOT NULL DEFAULT '0', `phrase` tinyint(1) unsigned NOT NULL DEFAULT '0', `weight` float unsigned NOT NULL DEFAULT '0', `soundex` varchar(75) NOT NULL, `links` int(10) NOT NULL DEFAULT '0', `language` char(3) NOT NULL DEFAULT '', PRIMARY KEY (`term_id`), UNIQUE KEY `idx_term` (`term`), KEY `idx_term_phrase` (`term`,`phrase`), KEY `idx_stem_phrase` (`stem`,`phrase`), KEY `idx_soundex_phrase` (`soundex`,`phrase`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_taxonomy_map' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_taxonomy_map` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_taxonomy_map' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_taxonomy_map` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_taxonomy_map' doesn't exist SQL=LOCK TABLES `#__finder_taxonomy_map` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_taxonomy_map` ( `link_id` int(10) unsigned NOT NULL, `node_id` int(10) unsigned NOT NULL, PRIMARY KEY (`link_id`,`node_id`), KEY `link_id` (`link_id`), KEY `node_id` (`node_id`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_taxonomy' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_taxonomy` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_taxonomy' doesn't exist SQL=INSERT INTO `#__finder_taxonomy` VALUES (1,0,'ROOT',0,0,0)
Table 'ecweb_2016b.#__finder_taxonomy' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_taxonomy` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_taxonomy' doesn't exist SQL=LOCK TABLES `#__finder_taxonomy` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_taxonomy` ( `id` int(10) unsigned NOT NULL AUTO_INCREMENT, `parent_id` int(10) unsigned NOT NULL DEFAULT '0', `title` varchar(255) NOT NULL, `state` tinyint(1) unsigned NOT NULL DEFAULT '1', `access` tinyint(1) unsigned NOT NULL DEFAULT '0', `ordering` tinyint(1) unsigned NOT NULL DEFAULT '0', PRIMARY KEY (`id`), KEY `parent_id` (`parent_id`), KEY `state` (`state`), KEY `ordering` (`ordering`), KEY `access` (`access`), KEY `idx_parent_published` (`parent_id`,`state`,`access`) ) ENGINE=InnoDB AUTO_INCREMENT=2 DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links_termsf' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_termsf` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links_termsf' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_termsf` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links_termsf' doesn't exist SQL=LOCK TABLES `#__finder_links_termsf` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links_termsf` ( `link_id` int(10) unsigned NOT NULL, `term_id` int(10) unsigned NOT NULL, `weight` float unsigned NOT NULL, PRIMARY KEY (`link_id`,`term_id`), KEY `idx_term_weight` (`term_id`,`weight`), KEY `idx_link_term_weight` (`link_id`,`term_id`,`weight`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links_termse' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_termse` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links_termse' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_termse` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links_termse' doesn't exist SQL=LOCK TABLES `#__finder_links_termse` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links_termse` ( `link_id` int(10) unsigned NOT NULL, `term_id` int(10) unsigned NOT NULL, `weight` float unsigned NOT NULL, PRIMARY KEY (`link_id`,`term_id`), KEY `idx_term_weight` (`term_id`,`weight`), KEY `idx_link_term_weight` (`link_id`,`term_id`,`weight`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links_termsd' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_termsd` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links_termsd' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_termsd` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links_termsd' doesn't exist SQL=LOCK TABLES `#__finder_links_termsd` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links_termsd` ( `link_id` int(10) unsigned NOT NULL, `term_id` int(10) unsigned NOT NULL, `weight` float unsigned NOT NULL, PRIMARY KEY (`link_id`,`term_id`), KEY `idx_term_weight` (`term_id`,`weight`), KEY `idx_link_term_weight` (`link_id`,`term_id`,`weight`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links_termsc' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_termsc` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links_termsc' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_termsc` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links_termsc' doesn't exist SQL=LOCK TABLES `#__finder_links_termsc` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links_termsc` ( `link_id` int(10) unsigned NOT NULL, `term_id` int(10) unsigned NOT NULL, `weight` float unsigned NOT NULL, PRIMARY KEY (`link_id`,`term_id`), KEY `idx_term_weight` (`term_id`,`weight`), KEY `idx_link_term_weight` (`link_id`,`term_id`,`weight`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links_termsb' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_termsb` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links_termsb' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_termsb` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links_termsb' doesn't exist SQL=LOCK TABLES `#__finder_links_termsb` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links_termsb` ( `link_id` int(10) unsigned NOT NULL, `term_id` int(10) unsigned NOT NULL, `weight` float unsigned NOT NULL, PRIMARY KEY (`link_id`,`term_id`), KEY `idx_term_weight` (`term_id`,`weight`), KEY `idx_link_term_weight` (`link_id`,`term_id`,`weight`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links_termsa' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_termsa` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links_termsa' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_termsa` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links_termsa' doesn't exist SQL=LOCK TABLES `#__finder_links_termsa` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links_termsa` ( `link_id` int(10) unsigned NOT NULL, `term_id` int(10) unsigned NOT NULL, `weight` float unsigned NOT NULL, PRIMARY KEY (`link_id`,`term_id`), KEY `idx_term_weight` (`term_id`,`weight`), KEY `idx_link_term_weight` (`link_id`,`term_id`,`weight`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links_terms9' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms9` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms9' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms9` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms9' doesn't exist SQL=LOCK TABLES `#__finder_links_terms9` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links_terms9` ( `link_id` int(10) unsigned NOT NULL, `term_id` int(10) unsigned NOT NULL, `weight` float unsigned NOT NULL, PRIMARY KEY (`link_id`,`term_id`), KEY `idx_term_weight` (`term_id`,`weight`), KEY `idx_link_term_weight` (`link_id`,`term_id`,`weight`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links_terms8' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms8` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms8' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms8` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms8' doesn't exist SQL=LOCK TABLES `#__finder_links_terms8` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links_terms8` ( `link_id` int(10) unsigned NOT NULL, `term_id` int(10) unsigned NOT NULL, `weight` float unsigned NOT NULL, PRIMARY KEY (`link_id`,`term_id`), KEY `idx_term_weight` (`term_id`,`weight`), KEY `idx_link_term_weight` (`link_id`,`term_id`,`weight`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links_terms7' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms7` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms7' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms7` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms7' doesn't exist SQL=LOCK TABLES `#__finder_links_terms7` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links_terms7` ( `link_id` int(10) unsigned NOT NULL, `term_id` int(10) unsigned NOT NULL, `weight` float unsigned NOT NULL, PRIMARY KEY (`link_id`,`term_id`), KEY `idx_term_weight` (`term_id`,`weight`), KEY `idx_link_term_weight` (`link_id`,`term_id`,`weight`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links_terms6' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms6` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms6' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms6` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms6' doesn't exist SQL=LOCK TABLES `#__finder_links_terms6` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links_terms6` ( `link_id` int(10) unsigned NOT NULL, `term_id` int(10) unsigned NOT NULL, `weight` float unsigned NOT NULL, PRIMARY KEY (`link_id`,`term_id`), KEY `idx_term_weight` (`term_id`,`weight`), KEY `idx_link_term_weight` (`link_id`,`term_id`,`weight`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links_terms5' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms5` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms5' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms5` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms5' doesn't exist SQL=LOCK TABLES `#__finder_links_terms5` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links_terms5` ( `link_id` int(10) unsigned NOT NULL, `term_id` int(10) unsigned NOT NULL, `weight` float unsigned NOT NULL, PRIMARY KEY (`link_id`,`term_id`), KEY `idx_term_weight` (`term_id`,`weight`), KEY `idx_link_term_weight` (`link_id`,`term_id`,`weight`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links_terms4' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms4` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms4' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms4` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms4' doesn't exist SQL=LOCK TABLES `#__finder_links_terms4` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links_terms4` ( `link_id` int(10) unsigned NOT NULL, `term_id` int(10) unsigned NOT NULL, `weight` float unsigned NOT NULL, PRIMARY KEY (`link_id`,`term_id`), KEY `idx_term_weight` (`term_id`,`weight`), KEY `idx_link_term_weight` (`link_id`,`term_id`,`weight`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links_terms3' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms3` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms3' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms3` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms3' doesn't exist SQL=LOCK TABLES `#__finder_links_terms3` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links_terms3` ( `link_id` int(10) unsigned NOT NULL, `term_id` int(10) unsigned NOT NULL, `weight` float unsigned NOT NULL, PRIMARY KEY (`link_id`,`term_id`), KEY `idx_term_weight` (`term_id`,`weight`), KEY `idx_link_term_weight` (`link_id`,`term_id`,`weight`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links_terms2' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms2` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms2' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms2` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms2' doesn't exist SQL=LOCK TABLES `#__finder_links_terms2` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links_terms2` ( `link_id` int(10) unsigned NOT NULL, `term_id` int(10) unsigned NOT NULL, `weight` float unsigned NOT NULL, PRIMARY KEY (`link_id`,`term_id`), KEY `idx_term_weight` (`term_id`,`weight`), KEY `idx_link_term_weight` (`link_id`,`term_id`,`weight`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links_terms1' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms1` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms1' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms1` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms1' doesn't exist SQL=LOCK TABLES `#__finder_links_terms1` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links_terms1` ( `link_id` int(10) unsigned NOT NULL, `term_id` int(10) unsigned NOT NULL, `weight` float unsigned NOT NULL, PRIMARY KEY (`link_id`,`term_id`), KEY `idx_term_weight` (`term_id`,`weight`), KEY `idx_link_term_weight` (`link_id`,`term_id`,`weight`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links_terms0' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms0` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms0' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links_terms0` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links_terms0' doesn't exist SQL=LOCK TABLES `#__finder_links_terms0` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links_terms0` ( `link_id` int(10) unsigned NOT NULL, `term_id` int(10) unsigned NOT NULL, `weight` float unsigned NOT NULL, PRIMARY KEY (`link_id`,`term_id`), KEY `idx_term_weight` (`term_id`,`weight`), KEY `idx_link_term_weight` (`link_id`,`term_id`,`weight`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_links' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_links' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_links` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_links' doesn't exist SQL=LOCK TABLES `#__finder_links` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_links` ( `link_id` int(10) unsigned NOT NULL AUTO_INCREMENT, `url` varchar(255) NOT NULL, `route` varchar(255) NOT NULL, `title` varchar(400) DEFAULT NULL, `description` varchar(255) DEFAULT NULL, `indexdate` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `md5sum` varchar(32) DEFAULT NULL, `published` tinyint(1) NOT NULL DEFAULT '1', `state` int(5) DEFAULT '1', `access` int(5) DEFAULT '0', `language` varchar(8) NOT NULL, `publish_start_date` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `publish_end_date` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `start_date` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `end_date` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `list_price` double unsigned NOT NULL DEFAULT '0', `sale_price` double unsigned NOT NULL DEFAULT '0', `type_id` int(11) NOT NULL, `object` mediumblob NOT NULL, PRIMARY KEY (`link_id`), KEY `idx_type` (`type_id`), KEY `idx_md5` (`md5sum`), KEY `idx_url` (`url`(75)), KEY `idx_published_list` (`published`,`state`,`access`,`publish_start_date`,`publish_end_date`,`list_price`), KEY `idx_published_sale` (`published`,`state`,`access`,`publish_start_date`,`publish_end_date`,`sale_price`), KEY `idx_title` (`title`(100)) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__finder_filters' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_filters` ENABLE KEYS */
Table 'ecweb_2016b.#__finder_filters' doesn't exist SQL=/*!40000 ALTER TABLE `#__finder_filters` DISABLE KEYS */
Table 'ecweb_2016b.#__finder_filters' doesn't exist SQL=LOCK TABLES `#__finder_filters` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__finder_filters` ( `filter_id` int(10) unsigned NOT NULL AUTO_INCREMENT, `title` varchar(255) NOT NULL, `alias` varchar(255) NOT NULL, `state` tinyint(1) NOT NULL DEFAULT '1', `created` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `created_by` int(10) unsigned NOT NULL, `created_by_alias` varchar(255) NOT NULL, `modified` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `modified_by` int(10) unsigned NOT NULL DEFAULT '0', `checked_out` int(10) unsigned NOT NULL DEFAULT '0', `checked_out_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `map_count` int(10) unsigned NOT NULL DEFAULT '0', `data` mediumtext NOT NULL, `params` longtext, PRIMARY KEY (`filter_id`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4
Table 'ecweb_2016b.#__extensions' doesn't exist SQL=/*!40000 ALTER TABLE `#__extensions` ENABLE KEYS */
Table 'ecweb_2016b.#__extensions' doesn't exist SQL=INSERT INTO `#__extensions` VALUES (1,'com_mailto','component','com_mailto','',0,1,1,1,'{\"name\":\"com_mailto\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\\t\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_MAILTO_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mailto\"}','','','',0,'0000-00-00 00:00:00',0,0),(2,'com_wrapper','component','com_wrapper','',0,1,1,1,'{\"name\":\"com_wrapper\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\\n\\t\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_WRAPPER_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"wrapper\"}','','','',0,'0000-00-00 00:00:00',0,0),(3,'com_admin','component','com_admin','',1,1,1,1,'{\"name\":\"com_admin\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_ADMIN_XML_DESCRIPTION\",\"group\":\"\"}','','','',0,'0000-00-00 00:00:00',0,0),(4,'com_banners','component','com_banners','',1,1,1,0,'{\"name\":\"com_banners\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_BANNERS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"banners\"}','{\"purchase_type\":\"3\",\"track_impressions\":\"0\",\"track_clicks\":\"0\",\"metakey_prefix\":\"\"}','','',0,'0000-00-00 00:00:00',0,0),(5,'com_cache','component','com_cache','',1,1,1,1,'{\"name\":\"com_cache\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_CACHE_XML_DESCRIPTION\",\"group\":\"\"}','','','',0,'0000-00-00 00:00:00',0,0),(6,'com_categories','component','com_categories','',1,1,1,1,'{\"name\":\"com_categories\",\"type\":\"component\",\"creationDate\":\"December 2007\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_CATEGORIES_XML_DESCRIPTION\",\"group\":\"\"}','','','',0,'0000-00-00 00:00:00',0,0),(7,'com_checkin','component','com_checkin','',1,1,1,1,'{\"name\":\"com_checkin\",\"type\":\"component\",\"creationDate\":\"Unknown\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_CHECKIN_XML_DESCRIPTION\",\"group\":\"\"}','','','',0,'0000-00-00 00:00:00',0,0),(8,'com_contact','component','com_contact','',1,1,1,0,'{\"name\":\"com_contact\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_CONTACT_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"contact\"}','{\"contact_layout\":\"_:default\",\"show_contact_category\":\"hide\",\"save_history\":\"0\",\"history_limit\":5,\"show_contact_list\":\"0\",\"presentation_style\":\"sliders\",\"show_name\":\"1\",\"show_position\":\"1\",\"show_email\":\"0\",\"show_street_address\":\"1\",\"show_suburb\":\"1\",\"show_state\":\"1\",\"show_postcode\":\"1\",\"show_country\":\"1\",\"show_telephone\":\"1\",\"show_mobile\":\"1\",\"show_fax\":\"1\",\"show_webpage\":\"1\",\"show_misc\":\"1\",\"show_image\":\"1\",\"image\":\"\",\"allow_vcard\":\"0\",\"show_articles\":\"0\",\"show_profile\":\"0\",\"show_links\":\"0\",\"linka_name\":\"\",\"linkb_name\":\"\",\"linkc_name\":\"\",\"linkd_name\":\"\",\"linke_name\":\"\",\"show_tags\":\"1\",\"contact_icons\":\"1\",\"icon_address\":\"\",\"icon_email\":\"\",\"icon_telephone\":\"\",\"icon_mobile\":\"\",\"icon_fax\":\"\",\"icon_misc\":\"\",\"category_layout\":\"_:default\",\"show_category_title\":\"1\",\"show_description\":\"1\",\"show_description_image\":\"0\",\"maxLevel\":\"-1\",\"show_empty_categories\":\"0\",\"show_subcat_desc\":\"1\",\"show_cat_items\":\"1\",\"show_cat_tags\":\"1\",\"show_base_description\":\"1\",\"maxLevelcat\":\"-1\",\"show_empty_categories_cat\":\"0\",\"show_subcat_desc_cat\":\"1\",\"show_cat_items_cat\":\"1\",\"filter_field\":\"1\",\"show_pagination_limit\":\"1\",\"show_headings\":\"1\",\"show_position_headings\":\"1\",\"show_email_headings\":\"0\",\"show_telephone_headings\":\"1\",\"show_mobile_headings\":\"0\",\"show_fax_headings\":\"0\",\"show_suburb_headings\":\"1\",\"show_state_headings\":\"1\",\"show_country_headings\":\"1\",\"show_pagination\":\"2\",\"show_pagination_results\":\"1\",\"initial_sort\":\"ordering\",\"captcha\":\"\",\"show_email_form\":\"1\",\"show_email_copy\":\"1\",\"banned_email\":\"\",\"banned_subject\":\"\",\"banned_text\":\"\",\"validate_session\":\"1\",\"custom_reply\":\"0\",\"redirect\":\"\",\"show_feed_link\":\"1\"}','','',0,'0000-00-00 00:00:00',0,0),(9,'com_cpanel','component','com_cpanel','',1,1,1,1,'{\"name\":\"com_cpanel\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_CPANEL_XML_DESCRIPTION\",\"group\":\"\"}','','','',0,'0000-00-00 00:00:00',0,0),(10,'com_installer','component','com_installer','',1,1,1,1,'{\"name\":\"com_installer\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_INSTALLER_XML_DESCRIPTION\",\"group\":\"\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(11,'com_languages','component','com_languages','',1,1,1,1,'{\"name\":\"com_languages\",\"type\":\"component\",\"creationDate\":\"2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_LANGUAGES_XML_DESCRIPTION\",\"group\":\"\"}','{\"administrator\":\"en-GB\",\"site\":\"en-GB\"}','','',0,'0000-00-00 00:00:00',0,0),(12,'com_login','component','com_login','',1,1,1,1,'{\"name\":\"com_login\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_LOGIN_XML_DESCRIPTION\",\"group\":\"\"}','','','',0,'0000-00-00 00:00:00',0,0),(13,'com_media','component','com_media','',1,1,0,1,'{\"name\":\"com_media\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_MEDIA_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"media\"}','{\"upload_extensions\":\"bmp,csv,doc,gif,ico,jpg,jpeg,odg,odp,ods,odt,pdf,png,ppt,swf,txt,xcf,xls,BMP,CSV,DOC,GIF,ICO,JPG,JPEG,ODG,ODP,ODS,ODT,PDF,PNG,PPT,SWF,TXT,XCF,XLS\",\"upload_maxsize\":\"10\",\"file_path\":\"images\",\"image_path\":\"images\",\"restrict_uploads\":\"1\",\"allowed_media_usergroup\":\"3\",\"check_mime\":\"1\",\"image_extensions\":\"bmp,gif,jpg,png\",\"ignore_extensions\":\"\",\"upload_mime\":\"image\\/jpeg,image\\/gif,image\\/png,image\\/bmp,application\\/x-shockwave-flash,application\\/msword,application\\/excel,application\\/pdf,application\\/powerpoint,text\\/plain,application\\/x-zip\",\"upload_mime_illegal\":\"text\\/html\",\"enable_flash\":\"0\"}','','',0,'0000-00-00 00:00:00',0,0),(14,'com_menus','component','com_menus','',1,1,1,1,'{\"name\":\"com_menus\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_MENUS_XML_DESCRIPTION\",\"group\":\"\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(15,'com_messages','component','com_messages','',1,1,1,1,'{\"name\":\"com_messages\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_MESSAGES_XML_DESCRIPTION\",\"group\":\"\"}','','','',0,'0000-00-00 00:00:00',0,0),(16,'com_modules','component','com_modules','',1,1,1,1,'{\"name\":\"com_modules\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_MODULES_XML_DESCRIPTION\",\"group\":\"\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(17,'com_newsfeeds','component','com_newsfeeds','',1,1,1,0,'{\"name\":\"com_newsfeeds\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_NEWSFEEDS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"newsfeeds\"}','{\"show_feed_image\":\"1\",\"show_feed_description\":\"1\",\"show_item_description\":\"1\",\"feed_word_count\":\"0\",\"show_headings\":\"1\",\"show_name\":\"1\",\"show_articles\":\"0\",\"show_link\":\"1\",\"show_description\":\"1\",\"show_description_image\":\"1\",\"display_num\":\"\",\"show_pagination_limit\":\"1\",\"show_pagination\":\"1\",\"show_pagination_results\":\"1\",\"show_cat_items\":\"1\"}','','',0,'0000-00-00 00:00:00',0,0),(18,'com_plugins','component','com_plugins','',1,1,1,1,'{\"name\":\"com_plugins\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_PLUGINS_XML_DESCRIPTION\",\"group\":\"\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(19,'com_search','component','com_search','',1,1,1,1,'{\"name\":\"com_search\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_SEARCH_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"search\"}','{\"enabled\":\"0\",\"show_date\":\"1\"}','','',0,'0000-00-00 00:00:00',0,0),(20,'com_templates','component','com_templates','',1,1,1,1,'{\"name\":\"com_templates\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_TEMPLATES_XML_DESCRIPTION\",\"group\":\"\"}','{\"template_positions_display\":\"0\",\"upload_limit\":\"2\",\"image_formats\":\"gif,bmp,jpg,jpeg,png\",\"source_formats\":\"txt,less,ini,xml,js,php,css\",\"font_formats\":\"woff,ttf,otf\",\"compressed_formats\":\"zip\"}','','',0,'0000-00-00 00:00:00',0,0),(21,'com_weblinks','component','com_weblinks','',1,1,1,0,'{\"name\":\"com_weblinks\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2015 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.4.1\",\"description\":\"COM_WEBLINKS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"weblinks\"}','{\"show_comp_description\":\"1\",\"comp_description\":\"\",\"show_link_hits\":\"1\",\"show_link_description\":\"1\",\"show_other_cats\":\"0\",\"show_headings\":\"0\",\"show_numbers\":\"0\",\"show_report\":\"1\",\"count_clicks\":\"1\",\"target\":\"0\",\"link_icons\":\"\"}','','',0,'0000-00-00 00:00:00',0,0),(22,'com_content','component','com_content','',1,1,0,1,'{\"name\":\"com_content\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_CONTENT_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"content\"}','{\"article_layout\":\"_:default\",\"show_title\":\"1\",\"link_titles\":\"0\",\"show_intro\":\"0\",\"info_block_position\":\"0\",\"show_category\":\"0\",\"link_category\":\"0\",\"show_parent_category\":\"0\",\"link_parent_category\":\"0\",\"show_author\":\"0\",\"link_author\":\"0\",\"show_create_date\":\"0\",\"show_modify_date\":\"0\",\"show_publish_date\":\"0\",\"show_item_navigation\":\"0\",\"show_vote\":\"0\",\"show_readmore\":\"1\",\"show_readmore_title\":\"0\",\"readmore_limit\":\"100\",\"show_tags\":\"1\",\"show_icons\":\"0\",\"show_print_icon\":\"0\",\"show_email_icon\":\"0\",\"show_hits\":\"0\",\"show_noauth\":\"0\",\"urls_position\":\"0\",\"show_publishing_options\":\"1\",\"show_article_options\":\"1\",\"show_urls_images_frontend\":\"0\",\"show_urls_images_backend\":\"1\",\"targeta\":0,\"targetb\":0,\"targetc\":0,\"float_intro\":\"none\",\"float_fulltext\":\"left\",\"category_layout\":\"_:blog\",\"show_category_heading_title_text\":\"1\",\"show_category_title\":\"0\",\"show_description\":\"0\",\"show_description_image\":\"0\",\"maxLevel\":\"1\",\"show_empty_categories\":\"0\",\"show_no_articles\":\"1\",\"show_subcat_desc\":\"1\",\"show_cat_num_articles\":\"0\",\"show_base_description\":\"1\",\"maxLevelcat\":\"-1\",\"show_empty_categories_cat\":\"0\",\"show_subcat_desc_cat\":\"1\",\"show_cat_num_articles_cat\":\"1\",\"num_leading_articles\":\"1\",\"num_intro_articles\":\"4\",\"num_columns\":\"2\",\"num_links\":\"4\",\"multi_column_order\":\"0\",\"show_subcategory_content\":\"0\",\"show_pagination_limit\":\"1\",\"filter_field\":\"hide\",\"show_headings\":\"1\",\"list_show_date\":\"0\",\"date_format\":\"\",\"list_show_hits\":\"1\",\"list_show_author\":\"1\",\"orderby_pri\":\"order\",\"orderby_sec\":\"rdate\",\"order_date\":\"published\",\"show_pagination\":\"2\",\"show_pagination_results\":\"1\",\"show_feed_link\":\"1\",\"feed_summary\":\"0\",\"feed_show_readmore\":\"0\"}','','',0,'0000-00-00 00:00:00',0,0),(23,'com_config','component','com_config','',1,1,0,1,'{\"name\":\"com_config\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_CONFIG_XML_DESCRIPTION\",\"group\":\"\"}','{\"filters\":{\"1\":{\"filter_type\":\"NH\",\"filter_tags\":\"\",\"filter_attributes\":\"\"},\"6\":{\"filter_type\":\"BL\",\"filter_tags\":\"\",\"filter_attributes\":\"\"},\"7\":{\"filter_type\":\"NONE\",\"filter_tags\":\"\",\"filter_attributes\":\"\"},\"2\":{\"filter_type\":\"NH\",\"filter_tags\":\"\",\"filter_attributes\":\"\"},\"3\":{\"filter_type\":\"BL\",\"filter_tags\":\"\",\"filter_attributes\":\"\"},\"4\":{\"filter_type\":\"BL\",\"filter_tags\":\"\",\"filter_attributes\":\"\"},\"5\":{\"filter_type\":\"BL\",\"filter_tags\":\"\",\"filter_attributes\":\"\"},\"10\":{\"filter_type\":\"BL\",\"filter_tags\":\"\",\"filter_attributes\":\"\"},\"12\":{\"filter_type\":\"BL\",\"filter_tags\":\"\",\"filter_attributes\":\"\"},\"8\":{\"filter_type\":\"NONE\",\"filter_tags\":\"\",\"filter_attributes\":\"\"}}}','','',0,'0000-00-00 00:00:00',0,0),(24,'com_redirect','component','com_redirect','',1,1,0,1,'{\"name\":\"com_redirect\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_REDIRECT_XML_DESCRIPTION\",\"group\":\"\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(25,'com_users','component','com_users','',1,1,0,1,'{\"name\":\"com_users\",\"type\":\"component\",\"creationDate\":\"April 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"COM_USERS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"users\"}','{\"allowUserRegistration\":\"1\",\"new_usertype\":\"2\",\"guest_usergroup\":\"1\",\"useractivation\":\"1\",\"mail_to_admin\":\"0\",\"captcha\":\"\",\"frontend_userparams\":\"0\",\"site_language\":\"0\",\"change_login_name\":\"0\",\"reset_count\":\"10\",\"reset_time\":\"1\",\"mailSubjectPrefix\":\"\",\"mailBodySuffix\":\"\"}','','',0,'0000-00-00 00:00:00',0,0),(27,'com_finder','component','com_finder','',1,1,0,0,'{\"legacy\":false,\"name\":\"com_finder\",\"type\":\"component\",\"creationDate\":\"August 2011\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2012 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"2.5.0\",\"description\":\"COM_FINDER_XML_DESCRIPTION\",\"group\":\"\"}','{\"show_description\":\"1\",\"description_length\":255,\"allow_empty_query\":\"0\",\"show_url\":\"1\",\"show_advanced\":\"1\",\"expand_advanced\":\"0\",\"show_date_filters\":\"0\",\"highlight_terms\":\"1\",\"opensearch_name\":\"\",\"opensearch_description\":\"\",\"batch_size\":\"50\",\"memory_table_limit\":30000,\"title_multiplier\":\"1.7\",\"text_multiplier\":\"0.7\",\"meta_multiplier\":\"1.2\",\"path_multiplier\":\"2.0\",\"misc_multiplier\":\"0.3\",\"stemmer\":\"snowball\"}','','',0,'0000-00-00 00:00:00',0,0),(30,'com_contenthistory','component','com_contenthistory','',1,1,1,0,'{\"name\":\"com_contenthistory\",\"type\":\"component\",\"creationDate\":\"May 2013\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.2.0\",\"description\":\"COM_CONTENTHISTORY_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"contenthistory\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(31,'com_ajax','component','com_ajax','',1,1,1,0,'{\"name\":\"com_ajax\",\"type\":\"component\",\"creationDate\":\"August 2013\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.2.0\",\"description\":\"COM_AJAX_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"ajax\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(32,'com_postinstall','component','com_postinstall','',1,1,1,1,'{\"name\":\"com_postinstall\",\"type\":\"component\",\"creationDate\":\"September 2013\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.2.0\",\"description\":\"COM_POSTINSTALL_XML_DESCRIPTION\",\"group\":\"\"}','','','',0,'0000-00-00 00:00:00',0,0),(101,'SimplePie','library','simplepie','',0,1,1,1,'{\"name\":\"SimplePie\",\"type\":\"library\",\"creationDate\":\"2004\",\"author\":\"SimplePie\",\"copyright\":\"Copyright (c) 2004-2009, Ryan Parman and Geoffrey Sneddon\",\"authorEmail\":\"\",\"authorUrl\":\"http:\\/\\/simplepie.org\\/\",\"version\":\"1.2\",\"description\":\"LIB_SIMPLEPIE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"simplepie\"}','','','',0,'0000-00-00 00:00:00',0,0),(102,'phputf8','library','phputf8','',0,1,1,1,'{\"name\":\"phputf8\",\"type\":\"library\",\"creationDate\":\"2006\",\"author\":\"Harry Fuecks\",\"copyright\":\"Copyright various authors\",\"authorEmail\":\"hfuecks@gmail.com\",\"authorUrl\":\"http:\\/\\/sourceforge.net\\/projects\\/phputf8\",\"version\":\"0.5\",\"description\":\"LIB_PHPUTF8_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"phputf8\"}','','','',0,'0000-00-00 00:00:00',0,0),(103,'Joomla! Platform','library','joomla','',0,1,1,1,'{\"name\":\"Joomla! Platform\",\"type\":\"library\",\"creationDate\":\"2008\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"https:\\/\\/http://www.joomla.org\",\"version\":\"13.1\",\"description\":\"LIB_JOOMLA_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"joomla\"}','{\"mediaversion\":\"719973a1d4aa2f3af6e77b1e76cbb168\"}','','',0,'0000-00-00 00:00:00',0,0),(104,'IDNA Convert','library','idna_convert','',0,1,1,1,'{\"name\":\"IDNA Convert\",\"type\":\"library\",\"creationDate\":\"2004\",\"author\":\"phlyLabs\",\"copyright\":\"2004-2011 phlyLabs Berlin, http:\\/\\/phlylabs.de\",\"authorEmail\":\"phlymail@phlylabs.de\",\"authorUrl\":\"http:\\/\\/phlylabs.de\",\"version\":\"0.8.0\",\"description\":\"LIB_IDNA_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"idna_convert\"}','','','',0,'0000-00-00 00:00:00',0,0),(105,'FOF','library','fof','',0,1,1,1,'{\"name\":\"FOF\",\"type\":\"library\",\"creationDate\":\"2015-04-22 13:15:32\",\"author\":\"Nicholas K. Dionysopoulos \\/ Akeeba Ltd\",\"copyright\":\"(C)2011-2015 Nicholas K. Dionysopoulos\",\"authorEmail\":\"nicholas@akeebabackup.com\",\"authorUrl\":\"https:\\/\\/http://www.akeebabackup.com\",\"version\":\"2.4.3\",\"description\":\"LIB_FOF_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"fof\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(106,'PHPass','library','phpass','',0,1,1,1,'{\"name\":\"PHPass\",\"type\":\"library\",\"creationDate\":\"2004-2006\",\"author\":\"Solar Designer\",\"copyright\":\"\",\"authorEmail\":\"solar@openwall.com\",\"authorUrl\":\"http:\\/\\/http://www.openwall.com\\/phpass\\/\",\"version\":\"0.3\",\"description\":\"LIB_PHPASS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"phpass\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(200,'mod_articles_archive','module','mod_articles_archive','',0,1,1,1,'{\"name\":\"mod_articles_archive\",\"type\":\"module\",\"creationDate\":\"July 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_ARTICLES_ARCHIVE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_articles_archive\"}','','','',0,'0000-00-00 00:00:00',0,0),(201,'mod_articles_latest','module','mod_articles_latest','',0,1,1,1,'{\"name\":\"mod_articles_latest\",\"type\":\"module\",\"creationDate\":\"July 2004\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_LATEST_NEWS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_articles_latest\"}','','','',0,'0000-00-00 00:00:00',0,0),(202,'mod_articles_popular','module','mod_articles_popular','',0,1,1,0,'{\"name\":\"mod_articles_popular\",\"type\":\"module\",\"creationDate\":\"July 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_POPULAR_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_articles_popular\"}','','','',0,'0000-00-00 00:00:00',0,0),(203,'mod_banners','module','mod_banners','',0,1,1,1,'{\"name\":\"mod_banners\",\"type\":\"module\",\"creationDate\":\"July 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_BANNERS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_banners\"}','','','',0,'0000-00-00 00:00:00',0,0),(204,'mod_breadcrumbs','module','mod_breadcrumbs','',0,1,1,1,'{\"name\":\"mod_breadcrumbs\",\"type\":\"module\",\"creationDate\":\"July 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_BREADCRUMBS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_breadcrumbs\"}','','','',0,'0000-00-00 00:00:00',0,0),(205,'mod_custom','module','mod_custom','',0,1,1,1,'{\"name\":\"mod_custom\",\"type\":\"module\",\"creationDate\":\"July 2004\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_CUSTOM_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_custom\"}','','','',0,'0000-00-00 00:00:00',0,0),(206,'mod_feed','module','mod_feed','',0,1,1,1,'{\"name\":\"mod_feed\",\"type\":\"module\",\"creationDate\":\"July 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_FEED_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_feed\"}','','','',0,'0000-00-00 00:00:00',0,0),(207,'mod_footer','module','mod_footer','',0,1,1,1,'{\"name\":\"mod_footer\",\"type\":\"module\",\"creationDate\":\"July 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_FOOTER_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_footer\"}','','','',0,'0000-00-00 00:00:00',0,0),(208,'mod_login','module','mod_login','',0,1,1,1,'{\"name\":\"mod_login\",\"type\":\"module\",\"creationDate\":\"July 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_LOGIN_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_login\"}','','','',0,'0000-00-00 00:00:00',0,0),(209,'mod_menu','module','mod_menu','',0,1,1,1,'{\"name\":\"mod_menu\",\"type\":\"module\",\"creationDate\":\"July 2004\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_MENU_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_menu\"}','','','',0,'0000-00-00 00:00:00',0,0),(210,'mod_articles_news','module','mod_articles_news','',0,1,1,0,'{\"name\":\"mod_articles_news\",\"type\":\"module\",\"creationDate\":\"July 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_ARTICLES_NEWS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_articles_news\"}','','','',0,'0000-00-00 00:00:00',0,0),(211,'mod_random_image','module','mod_random_image','',0,1,1,0,'{\"name\":\"mod_random_image\",\"type\":\"module\",\"creationDate\":\"July 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_RANDOM_IMAGE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_random_image\"}','','','',0,'0000-00-00 00:00:00',0,0),(212,'mod_related_items','module','mod_related_items','',0,1,1,0,'{\"name\":\"mod_related_items\",\"type\":\"module\",\"creationDate\":\"July 2004\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_RELATED_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_related_items\"}','','','',0,'0000-00-00 00:00:00',0,0),(213,'mod_search','module','mod_search','',0,1,1,0,'{\"name\":\"mod_search\",\"type\":\"module\",\"creationDate\":\"July 2004\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_SEARCH_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_search\"}','','','',0,'0000-00-00 00:00:00',0,0),(214,'mod_stats','module','mod_stats','',0,1,1,0,'{\"name\":\"mod_stats\",\"type\":\"module\",\"creationDate\":\"July 2004\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_STATS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_stats\"}','','','',0,'0000-00-00 00:00:00',0,0),(215,'mod_syndicate','module','mod_syndicate','',0,1,1,1,'{\"name\":\"mod_syndicate\",\"type\":\"module\",\"creationDate\":\"May 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_SYNDICATE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_syndicate\"}','','','',0,'0000-00-00 00:00:00',0,0),(216,'mod_users_latest','module','mod_users_latest','',0,1,1,1,'{\"name\":\"mod_users_latest\",\"type\":\"module\",\"creationDate\":\"December 2009\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_USERS_LATEST_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_users_latest\"}','','','',0,'0000-00-00 00:00:00',0,0),(217,'mod_weblinks','module','mod_weblinks','',0,1,1,0,'{\"name\":\"mod_weblinks\",\"type\":\"module\",\"creationDate\":\"July 2009\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2015 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.4.1\",\"description\":\"MOD_WEBLINKS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_weblinks\"}','','','',0,'0000-00-00 00:00:00',0,0),(218,'mod_whosonline','module','mod_whosonline','',0,1,1,0,'{\"name\":\"mod_whosonline\",\"type\":\"module\",\"creationDate\":\"July 2004\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_WHOSONLINE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_whosonline\"}','','','',0,'0000-00-00 00:00:00',0,0),(219,'mod_wrapper','module','mod_wrapper','',0,1,1,0,'{\"name\":\"mod_wrapper\",\"type\":\"module\",\"creationDate\":\"October 2004\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_WRAPPER_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_wrapper\"}','','','',0,'0000-00-00 00:00:00',0,0),(220,'mod_articles_category','module','mod_articles_category','',0,1,1,1,'{\"name\":\"mod_articles_category\",\"type\":\"module\",\"creationDate\":\"February 2010\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_ARTICLES_CATEGORY_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_articles_category\"}','','','',0,'0000-00-00 00:00:00',0,0),(221,'mod_articles_categories','module','mod_articles_categories','',0,1,1,1,'{\"name\":\"mod_articles_categories\",\"type\":\"module\",\"creationDate\":\"February 2010\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_ARTICLES_CATEGORIES_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_articles_categories\"}','','','',0,'0000-00-00 00:00:00',0,0),(222,'mod_languages','module','mod_languages','',0,1,1,1,'{\"name\":\"mod_languages\",\"type\":\"module\",\"creationDate\":\"February 2010\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_LANGUAGES_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_languages\"}','','','',0,'0000-00-00 00:00:00',0,0),(223,'mod_finder','module','mod_finder','',0,1,0,0,'{\"legacy\":false,\"name\":\"mod_finder\",\"type\":\"module\",\"creationDate\":\"August 2011\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2012 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"2.5.0\",\"description\":\"MOD_FINDER_XML_DESCRIPTION\",\"group\":\"\"}','','','',0,'0000-00-00 00:00:00',0,0),(300,'mod_custom','module','mod_custom','',1,1,1,1,'{\"name\":\"mod_custom\",\"type\":\"module\",\"creationDate\":\"July 2004\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_CUSTOM_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_custom\"}','','','',0,'0000-00-00 00:00:00',0,0),(301,'mod_feed','module','mod_feed','',1,1,1,0,'{\"name\":\"mod_feed\",\"type\":\"module\",\"creationDate\":\"July 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_FEED_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_feed\"}','','','',0,'0000-00-00 00:00:00',0,0),(302,'mod_latest','module','mod_latest','',1,1,1,0,'{\"name\":\"mod_latest\",\"type\":\"module\",\"creationDate\":\"July 2004\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_LATEST_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_latest\"}','','','',0,'0000-00-00 00:00:00',0,0),(303,'mod_logged','module','mod_logged','',1,1,1,0,'{\"name\":\"mod_logged\",\"type\":\"module\",\"creationDate\":\"January 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_LOGGED_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_logged\"}','','','',0,'0000-00-00 00:00:00',0,0),(304,'mod_login','module','mod_login','',1,1,1,1,'{\"name\":\"mod_login\",\"type\":\"module\",\"creationDate\":\"March 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_LOGIN_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_login\"}','','','',0,'0000-00-00 00:00:00',0,0),(305,'mod_menu','module','mod_menu','',1,1,1,0,'{\"name\":\"mod_menu\",\"type\":\"module\",\"creationDate\":\"March 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_MENU_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_menu\"}','','','',0,'0000-00-00 00:00:00',0,0),(307,'mod_popular','module','mod_popular','',1,1,1,0,'{\"name\":\"mod_popular\",\"type\":\"module\",\"creationDate\":\"July 2004\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_POPULAR_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_popular\"}','','','',0,'0000-00-00 00:00:00',0,0),(308,'mod_quickicon','module','mod_quickicon','',1,1,1,1,'{\"name\":\"mod_quickicon\",\"type\":\"module\",\"creationDate\":\"Nov 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_QUICKICON_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_quickicon\"}','','','',0,'0000-00-00 00:00:00',0,0),(309,'mod_status','module','mod_status','',1,1,1,0,'{\"name\":\"mod_status\",\"type\":\"module\",\"creationDate\":\"Feb 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_STATUS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_status\"}','','','',0,'0000-00-00 00:00:00',0,0),(310,'mod_submenu','module','mod_submenu','',1,1,1,0,'{\"name\":\"mod_submenu\",\"type\":\"module\",\"creationDate\":\"Feb 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_SUBMENU_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_submenu\"}','','','',0,'0000-00-00 00:00:00',0,0),(311,'mod_title','module','mod_title','',1,1,1,0,'{\"name\":\"mod_title\",\"type\":\"module\",\"creationDate\":\"Nov 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_TITLE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_title\"}','','','',0,'0000-00-00 00:00:00',0,0),(312,'mod_toolbar','module','mod_toolbar','',1,1,1,1,'{\"name\":\"mod_toolbar\",\"type\":\"module\",\"creationDate\":\"Nov 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_TOOLBAR_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_toolbar\"}','','','',0,'0000-00-00 00:00:00',0,0),(313,'mod_multilangstatus','module','mod_multilangstatus','',1,1,1,0,'{\"name\":\"mod_multilangstatus\",\"type\":\"module\",\"creationDate\":\"September 2011\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_MULTILANGSTATUS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_multilangstatus\"}','{\"cache\":\"0\"}','','',0,'0000-00-00 00:00:00',0,0),(314,'mod_version','module','mod_version','',1,1,1,0,'{\"legacy\":false,\"name\":\"mod_version\",\"type\":\"module\",\"creationDate\":\"January 2012\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2012 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"2.5.0\",\"description\":\"MOD_VERSION_XML_DESCRIPTION\",\"group\":\"\"}','{\"format\":\"short\",\"product\":\"1\",\"cache\":\"0\"}','','',0,'0000-00-00 00:00:00',0,0),(400,'plg_authentication_gmail','plugin','gmail','authentication',0,0,1,0,'{\"name\":\"plg_authentication_gmail\",\"type\":\"plugin\",\"creationDate\":\"February 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_GMAIL_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"gmail\"}','{\"applysuffix\":\"0\",\"suffix\":\"\",\"verifypeer\":\"1\",\"user_blacklist\":\"\"}','','',0,'0000-00-00 00:00:00',1,0),(401,'plg_authentication_joomla','plugin','joomla','authentication',0,1,1,1,'{\"name\":\"plg_authentication_joomla\",\"type\":\"plugin\",\"creationDate\":\"November 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_AUTH_JOOMLA_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"joomla\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(402,'plg_authentication_ldap','plugin','ldap','authentication',0,0,1,0,'{\"name\":\"plg_authentication_ldap\",\"type\":\"plugin\",\"creationDate\":\"November 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_LDAP_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"ldap\"}','{\"host\":\"\",\"port\":\"389\",\"use_ldapV3\":\"0\",\"negotiate_tls\":\"0\",\"no_referrals\":\"0\",\"auth_method\":\"bind\",\"base_dn\":\"\",\"search_string\":\"\",\"users_dn\":\"\",\"username\":\"admin\",\"password\":\"bobby7\",\"ldap_fullname\":\"fullName\",\"ldap_email\":\"mail\",\"ldap_uid\":\"uid\"}','','',0,'0000-00-00 00:00:00',3,0),(403,'plg_content_contact','plugin','contact','content',0,1,1,0,'{\"name\":\"plg_content_contact\",\"type\":\"plugin\",\"creationDate\":\"January 2014\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.2.2\",\"description\":\"PLG_CONTENT_CONTACT_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"contact\"}','','','',0,'0000-00-00 00:00:00',1,0),(404,'plg_content_emailcloak','plugin','emailcloak','content',0,1,1,0,'{\"name\":\"plg_content_emailcloak\",\"type\":\"plugin\",\"creationDate\":\"November 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_CONTENT_EMAILCLOAK_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"emailcloak\"}','{\"mode\":\"1\"}','','',0,'0000-00-00 00:00:00',1,0),(405,'plg_content_geshi','plugin','geshi','content',0,0,1,0,'{\"legacy\":false,\"name\":\"plg_content_geshi\",\"type\":\"plugin\",\"creationDate\":\"November 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2012 Open Source Matters. All rights reserved.\",\"authorEmail\":\"\",\"authorUrl\":\"qbnz.com\\/highlighter\",\"version\":\"2.5.0\",\"description\":\"PLG_CONTENT_GESHI_XML_DESCRIPTION\",\"group\":\"\"}','{}','','',0,'0000-00-00 00:00:00',2,0),(406,'plg_content_loadmodule','plugin','loadmodule','content',0,1,1,0,'{\"name\":\"plg_content_loadmodule\",\"type\":\"plugin\",\"creationDate\":\"November 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_LOADMODULE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"loadmodule\"}','{\"style\":\"xhtml\"}','','',0,'0000-00-00 00:00:00',0,0),(407,'plg_content_pagebreak','plugin','pagebreak','content',0,1,1,1,'{\"name\":\"plg_content_pagebreak\",\"type\":\"plugin\",\"creationDate\":\"November 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_CONTENT_PAGEBREAK_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"pagebreak\"}','{\"title\":\"1\",\"multipage_toc\":\"1\",\"showall\":\"1\"}','','',0,'0000-00-00 00:00:00',4,0),(408,'plg_content_pagenavigation','plugin','pagenavigation','content',0,1,1,1,'{\"name\":\"plg_content_pagenavigation\",\"type\":\"plugin\",\"creationDate\":\"January 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_PAGENAVIGATION_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"pagenavigation\"}','{\"position\":\"1\"}','','',0,'0000-00-00 00:00:00',5,0),(409,'plg_content_vote','plugin','vote','content',0,1,1,1,'{\"name\":\"plg_content_vote\",\"type\":\"plugin\",\"creationDate\":\"November 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_VOTE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"vote\"}','{}','','',0,'0000-00-00 00:00:00',6,0),(410,'plg_editors_codemirror','plugin','codemirror','editors',0,1,1,1,'{\"name\":\"plg_editors_codemirror\",\"type\":\"plugin\",\"creationDate\":\"28 March 2011\",\"author\":\"Marijn Haverbeke\",\"copyright\":\"Copyright (C) 2014 by Marijn Haverbeke and others\",\"authorEmail\":\"marijnh@gmail.com\",\"authorUrl\":\"http:\\/\\/codemirror.net\\/\",\"version\":\"5.12\",\"description\":\"PLG_CODEMIRROR_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"codemirror\"}','{\"lineNumbers\":\"1\",\"lineWrapping\":\"1\",\"matchTags\":\"1\",\"matchBrackets\":\"1\",\"marker-gutter\":\"1\",\"autoCloseTags\":\"1\",\"autoCloseBrackets\":\"1\",\"autoFocus\":\"1\",\"theme\":\"default\",\"tabmode\":\"indent\"}','','',0,'0000-00-00 00:00:00',1,0),(411,'plg_editors_none','plugin','none','editors',0,1,1,1,'{\"name\":\"plg_editors_none\",\"type\":\"plugin\",\"creationDate\":\"September 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_NONE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"none\"}','{}','','',0,'0000-00-00 00:00:00',2,0),(412,'plg_editors_tinymce','plugin','tinymce','editors',0,1,1,1,'{\"name\":\"plg_editors_tinymce\",\"type\":\"plugin\",\"creationDate\":\"2005-2016\",\"author\":\"Ephox Corporation\",\"copyright\":\"Ephox Corporation\",\"authorEmail\":\"N\\/A\",\"authorUrl\":\"http:\\/\\/http://www.tinymce.com\",\"version\":\"4.3.3\",\"description\":\"PLG_TINY_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"tinymce\"}','{\"mode\":\"1\",\"skin\":\"0\",\"entity_encoding\":\"raw\",\"lang_mode\":\"0\",\"lang_code\":\"en\",\"text_direction\":\"ltr\",\"content_css\":\"1\",\"content_css_custom\":\"\",\"relative_urls\":\"1\",\"newlines\":\"0\",\"invalid_elements\":\"script,applet,iframe\",\"extended_elements\":\"\",\"toolbar\":\"top\",\"toolbar_align\":\"left\",\"html_height\":\"550\",\"html_width\":\"750\",\"resizing\":\"true\",\"resize_horizontal\":\"false\",\"element_path\":\"1\",\"fonts\":\"1\",\"paste\":\"1\",\"searchreplace\":\"1\",\"insertdate\":\"1\",\"format_date\":\"%Y-%m-%d\",\"inserttime\":\"1\",\"format_time\":\"%H:%M:%S\",\"colors\":\"1\",\"table\":\"1\",\"smilies\":\"1\",\"media\":\"1\",\"hr\":\"1\",\"directionality\":\"1\",\"fullscreen\":\"1\",\"style\":\"1\",\"layer\":\"1\",\"xhtmlxtras\":\"1\",\"visualchars\":\"1\",\"nonbreaking\":\"1\",\"template\":\"1\",\"blockquote\":\"1\",\"wordcount\":\"1\",\"advimage\":\"1\",\"advlink\":\"1\",\"advlist\":\"1\",\"autosave\":\"1\",\"contextmenu\":\"1\",\"inlinepopups\":\"1\",\"custom_plugin\":\"\",\"custom_button\":\"\"}','','',0,'0000-00-00 00:00:00',3,0),(413,'plg_editors-xtd_article','plugin','article','editors-xtd',0,1,1,0,'{\"name\":\"plg_editors-xtd_article\",\"type\":\"plugin\",\"creationDate\":\"October 2009\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_ARTICLE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"article\"}','{}','','',0,'0000-00-00 00:00:00',1,0),(414,'plg_editors-xtd_image','plugin','image','editors-xtd',0,1,1,0,'{\"name\":\"plg_editors-xtd_image\",\"type\":\"plugin\",\"creationDate\":\"August 2004\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_IMAGE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"image\"}','{}','','',0,'0000-00-00 00:00:00',2,0),(415,'plg_editors-xtd_pagebreak','plugin','pagebreak','editors-xtd',0,1,1,0,'{\"name\":\"plg_editors-xtd_pagebreak\",\"type\":\"plugin\",\"creationDate\":\"August 2004\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_EDITORSXTD_PAGEBREAK_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"pagebreak\"}','{}','','',0,'0000-00-00 00:00:00',3,0),(416,'plg_editors-xtd_readmore','plugin','readmore','editors-xtd',0,1,1,0,'{\"name\":\"plg_editors-xtd_readmore\",\"type\":\"plugin\",\"creationDate\":\"March 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_READMORE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"readmore\"}','{}','','',0,'0000-00-00 00:00:00',4,0),(417,'plg_search_categories','plugin','categories','search',0,1,1,0,'{\"name\":\"plg_search_categories\",\"type\":\"plugin\",\"creationDate\":\"November 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_SEARCH_CATEGORIES_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"categories\"}','{\"search_limit\":\"50\",\"search_content\":\"1\",\"search_archived\":\"1\"}','','',0,'0000-00-00 00:00:00',0,0),(418,'plg_search_contacts','plugin','contacts','search',0,1,1,0,'{\"name\":\"plg_search_contacts\",\"type\":\"plugin\",\"creationDate\":\"November 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_SEARCH_CONTACTS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"contacts\"}','{\"search_limit\":\"50\",\"search_content\":\"1\",\"search_archived\":\"1\"}','','',0,'0000-00-00 00:00:00',0,0),(419,'plg_search_content','plugin','content','search',0,1,1,0,'{\"name\":\"plg_search_content\",\"type\":\"plugin\",\"creationDate\":\"November 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_SEARCH_CONTENT_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"content\"}','{\"search_limit\":\"50\",\"search_content\":\"1\",\"search_archived\":\"1\"}','','',0,'0000-00-00 00:00:00',0,0),(420,'plg_search_newsfeeds','plugin','newsfeeds','search',0,1,1,0,'{\"name\":\"plg_search_newsfeeds\",\"type\":\"plugin\",\"creationDate\":\"November 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_SEARCH_NEWSFEEDS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"newsfeeds\"}','{\"search_limit\":\"50\",\"search_content\":\"1\",\"search_archived\":\"1\"}','','',0,'0000-00-00 00:00:00',0,0),(421,'plg_search_weblinks','plugin','weblinks','search',0,1,1,0,'{\"name\":\"plg_search_weblinks\",\"type\":\"plugin\",\"creationDate\":\"November 2005\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2015 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.4.1\",\"description\":\"PLG_SEARCH_WEBLINKS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"weblinks\"}','{\"search_limit\":\"50\",\"search_content\":\"1\",\"search_archived\":\"1\"}','','',0,'0000-00-00 00:00:00',0,0),(422,'plg_system_languagefilter','plugin','languagefilter','system',0,0,1,1,'{\"name\":\"plg_system_languagefilter\",\"type\":\"plugin\",\"creationDate\":\"July 2010\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_SYSTEM_LANGUAGEFILTER_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"languagefilter\"}','{}','','',0,'0000-00-00 00:00:00',1,0),(423,'plg_system_p3p','plugin','p3p','system',0,1,1,1,'{\"name\":\"plg_system_p3p\",\"type\":\"plugin\",\"creationDate\":\"September 2010\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_P3P_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"p3p\"}','{\"headers\":\"NOI ADM DEV PSAi COM NAV OUR OTRo STP IND DEM\"}','','',0,'0000-00-00 00:00:00',2,0),(424,'plg_system_cache','plugin','cache','system',0,0,1,1,'{\"name\":\"plg_system_cache\",\"type\":\"plugin\",\"creationDate\":\"February 2007\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_CACHE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"cache\"}','{\"browsercache\":\"0\",\"cachetime\":\"15\"}','','',0,'0000-00-00 00:00:00',9,0),(425,'plg_system_debug','plugin','debug','system',0,1,1,0,'{\"name\":\"plg_system_debug\",\"type\":\"plugin\",\"creationDate\":\"December 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_DEBUG_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"debug\"}','{\"profile\":\"1\",\"queries\":\"1\",\"memory\":\"1\",\"language_files\":\"1\",\"language_strings\":\"1\",\"strip-first\":\"1\",\"strip-prefix\":\"\",\"strip-suffix\":\"\"}','','',0,'0000-00-00 00:00:00',4,0),(426,'plg_system_log','plugin','log','system',0,1,1,1,'{\"name\":\"plg_system_log\",\"type\":\"plugin\",\"creationDate\":\"April 2007\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_LOG_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"log\"}','{}','','',0,'0000-00-00 00:00:00',5,0),(427,'plg_system_redirect','plugin','redirect','system',0,1,1,1,'{\"name\":\"plg_system_redirect\",\"type\":\"plugin\",\"creationDate\":\"April 2009\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_SYSTEM_REDIRECT_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"redirect\"}','{}','','',0,'0000-00-00 00:00:00',6,0),(428,'plg_system_remember','plugin','remember','system',0,1,1,1,'{\"name\":\"plg_system_remember\",\"type\":\"plugin\",\"creationDate\":\"April 2007\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_REMEMBER_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"remember\"}','{}','','',0,'0000-00-00 00:00:00',7,0),(429,'plg_system_sef','plugin','sef','system',0,1,1,0,'{\"name\":\"plg_system_sef\",\"type\":\"plugin\",\"creationDate\":\"December 2007\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_SEF_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"sef\"}','{}','','',0,'0000-00-00 00:00:00',8,0),(430,'plg_system_logout','plugin','logout','system',0,1,1,1,'{\"name\":\"plg_system_logout\",\"type\":\"plugin\",\"creationDate\":\"April 2009\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_SYSTEM_LOGOUT_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"logout\"}','{}','','',0,'0000-00-00 00:00:00',3,0),(431,'plg_user_contactcreator','plugin','contactcreator','user',0,0,1,1,'{\"name\":\"plg_user_contactcreator\",\"type\":\"plugin\",\"creationDate\":\"August 2009\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_CONTACTCREATOR_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"contactcreator\"}','{\"autowebpage\":\"\",\"category\":\"34\",\"autopublish\":\"0\"}','','',0,'0000-00-00 00:00:00',1,0),(432,'plg_user_joomla','plugin','joomla','user',0,1,1,0,'{\"name\":\"plg_user_joomla\",\"type\":\"plugin\",\"creationDate\":\"December 2006\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_USER_JOOMLA_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"joomla\"}','{\"autoregister\":\"1\"}','','',0,'0000-00-00 00:00:00',2,0),(433,'plg_user_profile','plugin','profile','user',0,0,1,1,'{\"name\":\"plg_user_profile\",\"type\":\"plugin\",\"creationDate\":\"January 2008\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_USER_PROFILE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"profile\"}','{\"register-require_address1\":\"1\",\"register-require_address2\":\"1\",\"register-require_city\":\"1\",\"register-require_region\":\"1\",\"register-require_country\":\"1\",\"register-require_postal_code\":\"1\",\"register-require_phone\":\"1\",\"register-require_website\":\"1\",\"register-require_favoritebook\":\"1\",\"register-require_aboutme\":\"1\",\"register-require_tos\":\"1\",\"register-require_dob\":\"1\",\"profile-require_address1\":\"1\",\"profile-require_address2\":\"1\",\"profile-require_city\":\"1\",\"profile-require_region\":\"1\",\"profile-require_country\":\"1\",\"profile-require_postal_code\":\"1\",\"profile-require_phone\":\"1\",\"profile-require_website\":\"1\",\"profile-require_favoritebook\":\"1\",\"profile-require_aboutme\":\"1\",\"profile-require_tos\":\"1\",\"profile-require_dob\":\"1\"}','','',0,'0000-00-00 00:00:00',0,0),(434,'plg_extension_joomla','plugin','joomla','extension',0,1,1,1,'{\"name\":\"plg_extension_joomla\",\"type\":\"plugin\",\"creationDate\":\"May 2010\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_EXTENSION_JOOMLA_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"joomla\"}','{}','','',0,'0000-00-00 00:00:00',1,0),(435,'plg_content_joomla','plugin','joomla','content',0,1,1,0,'{\"name\":\"plg_content_joomla\",\"type\":\"plugin\",\"creationDate\":\"November 2010\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_CONTENT_JOOMLA_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"joomla\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(436,'plg_system_languagecode','plugin','languagecode','system',0,0,1,0,'{\"name\":\"plg_system_languagecode\",\"type\":\"plugin\",\"creationDate\":\"November 2011\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_SYSTEM_LANGUAGECODE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"languagecode\"}','{}','','',0,'0000-00-00 00:00:00',10,0),(437,'plg_quickicon_joomlaupdate','plugin','joomlaupdate','quickicon',0,1,1,1,'{\"name\":\"plg_quickicon_joomlaupdate\",\"type\":\"plugin\",\"creationDate\":\"August 2011\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_QUICKICON_JOOMLAUPDATE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"joomlaupdate\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(438,'plg_quickicon_extensionupdate','plugin','extensionupdate','quickicon',0,1,1,1,'{\"name\":\"plg_quickicon_extensionupdate\",\"type\":\"plugin\",\"creationDate\":\"August 2011\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_QUICKICON_EXTENSIONUPDATE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"extensionupdate\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(439,'plg_captcha_recaptcha','plugin','recaptcha','captcha',0,1,1,0,'{\"name\":\"plg_captcha_recaptcha\",\"type\":\"plugin\",\"creationDate\":\"December 2011\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.4.0\",\"description\":\"PLG_CAPTCHA_RECAPTCHA_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"recaptcha\"}','{\"public_key\":\"\",\"private_key\":\"\",\"theme\":\"clean\"}','','',0,'0000-00-00 00:00:00',0,0),(440,'plg_system_highlight','plugin','highlight','system',0,1,1,0,'{\"legacy\":false,\"name\":\"plg_system_highlight\",\"type\":\"plugin\",\"creationDate\":\"August 2011\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2012 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"2.5.0\",\"description\":\"PLG_SYSTEM_HIGHLIGHT_XML_DESCRIPTION\",\"group\":\"\"}','{}','','',0,'0000-00-00 00:00:00',7,0),(441,'plg_content_finder','plugin','finder','content',0,0,1,0,'{\"legacy\":false,\"name\":\"plg_content_finder\",\"type\":\"plugin\",\"creationDate\":\"December 2011\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2012 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"2.5.0\",\"description\":\"PLG_CONTENT_FINDER_XML_DESCRIPTION\",\"group\":\"\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(442,'plg_finder_categories','plugin','categories','finder',0,1,1,0,'{\"name\":\"plg_finder_categories\",\"type\":\"plugin\",\"creationDate\":\"August 2011\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_FINDER_CATEGORIES_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"categories\"}','{}','','',0,'0000-00-00 00:00:00',1,0),(443,'plg_finder_contacts','plugin','contacts','finder',0,1,1,0,'{\"name\":\"plg_finder_contacts\",\"type\":\"plugin\",\"creationDate\":\"August 2011\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_FINDER_CONTACTS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"contacts\"}','{}','','',0,'0000-00-00 00:00:00',2,0),(444,'plg_finder_content','plugin','content','finder',0,1,1,0,'{\"name\":\"plg_finder_content\",\"type\":\"plugin\",\"creationDate\":\"August 2011\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_FINDER_CONTENT_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"content\"}','{}','','',0,'0000-00-00 00:00:00',3,0),(445,'plg_finder_newsfeeds','plugin','newsfeeds','finder',0,1,1,0,'{\"name\":\"plg_finder_newsfeeds\",\"type\":\"plugin\",\"creationDate\":\"August 2011\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_FINDER_NEWSFEEDS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"newsfeeds\"}','{}','','',0,'0000-00-00 00:00:00',4,0),(446,'plg_finder_weblinks','plugin','weblinks','finder',0,1,1,0,'{\"name\":\"plg_finder_weblinks\",\"type\":\"plugin\",\"creationDate\":\"August 2011\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2015 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.4.1\",\"description\":\"PLG_FINDER_WEBLINKS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"weblinks\"}','{}','','',0,'0000-00-00 00:00:00',5,0),(448,'plg_twofactorauth_totp','plugin','totp','twofactorauth',0,0,1,0,'{\"name\":\"plg_twofactorauth_totp\",\"type\":\"plugin\",\"creationDate\":\"August 2013\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.2.0\",\"description\":\"PLG_TWOFACTORAUTH_TOTP_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"totp\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(449,'plg_authentication_cookie','plugin','cookie','authentication',0,1,1,0,'{\"name\":\"plg_authentication_cookie\",\"type\":\"plugin\",\"creationDate\":\"July 2013\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2013 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_AUTH_COOKIE_XML_DESCRIPTION\",\"group\":\"\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(450,'plg_twofactorauth_yubikey','plugin','yubikey','twofactorauth',0,0,1,0,'{\"name\":\"plg_twofactorauth_yubikey\",\"type\":\"plugin\",\"creationDate\":\"September 2013\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.2.0\",\"description\":\"PLG_TWOFACTORAUTH_YUBIKEY_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"yubikey\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(451,'plg_search_tags','plugin','tags','search',0,0,1,0,'{\"name\":\"plg_search_tags\",\"type\":\"plugin\",\"creationDate\":\"March 2014\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_SEARCH_TAGS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"tags\"}','{\"search_limit\":\"50\",\"show_tagged_items\":\"1\"}','','',0,'0000-00-00 00:00:00',0,0),(452,'plg_system_updatenotification','plugin','updatenotification','system',0,1,1,0,'{\"name\":\"plg_system_updatenotification\",\"type\":\"plugin\",\"creationDate\":\"May 2015\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.5.0\",\"description\":\"PLG_SYSTEM_UPDATENOTIFICATION_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"updatenotification\"}','{\"lastrun\":1459483974}','','',0,'0000-00-00 00:00:00',0,0),(453,'plg_editors-xtd_module','plugin','module','editors-xtd',0,1,1,0,'{\"name\":\"plg_editors-xtd_module\",\"type\":\"plugin\",\"creationDate\":\"October 2015\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.5.0\",\"description\":\"PLG_MODULE_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"module\"}','','','',0,'0000-00-00 00:00:00',0,0),(454,'plg_system_stats','plugin','stats','system',0,1,1,0,'{\"name\":\"plg_system_stats\",\"type\":\"plugin\",\"creationDate\":\"November 2013\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.5.0\",\"description\":\"PLG_SYSTEM_STATS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"stats\"}','{\"mode\":3,\"lastrun\":1459439429,\"unique_id\":\"beb85bf92c598919adee15a37915d0cfb64aac41\",\"interval\":12}','','',0,'0000-00-00 00:00:00',0,0),(504,'hathor','template','hathor','',1,1,1,0,'{\"name\":\"hathor\",\"type\":\"template\",\"creationDate\":\"May 2010\",\"author\":\"Andrea Tarr\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters, Inc. All rights reserved.\",\"authorEmail\":\"hathor@tarrconsulting.com\",\"authorUrl\":\"http:\\/\\/http://www.tarrconsulting.com\",\"version\":\"3.0.0\",\"description\":\"TPL_HATHOR_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"templateDetails\"}','{\"showSiteName\":\"0\",\"colourChoice\":\"0\",\"boldText\":\"0\"}','','',0,'0000-00-00 00:00:00',0,0),(600,'English (en-GB)','language','en-GB','',0,1,1,1,'{\"name\":\"English (en-GB)\",\"type\":\"language\",\"creationDate\":\"November 2015\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.5.0\",\"description\":\"en-GB site language\",\"group\":\"\"}','','','',0,'0000-00-00 00:00:00',0,0),(601,'English (en-GB)','language','en-GB','',1,1,1,1,'{\"name\":\"English (en-GB)\",\"type\":\"language\",\"creationDate\":\"November 2015\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.5.0\",\"description\":\"en-GB administrator language\",\"group\":\"\"}','','','',0,'0000-00-00 00:00:00',0,0),(700,'files_joomla','file','joomla','',0,1,1,1,'{\"name\":\"files_joomla\",\"type\":\"file\",\"creationDate\":\"March 2016\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.5.0\",\"description\":\"FILES_JOOMLA_XML_DESCRIPTION\",\"group\":\"\"}','','','',0,'0000-00-00 00:00:00',0,0),(800,'PKG_JOOMLA','package','pkg_joomla','',0,1,1,1,'{\"legacy\":false,\"name\":\"PKG_JOOMLA\",\"type\":\"package\",\"creationDate\":\"2006\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2012 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http:\\/\\/http://www.joomla.org\",\"version\":\"2.5.0\",\"description\":\"PKG_JOOMLA_XML_DESCRIPTION\",\"group\":\"\"}','','','',0,'0000-00-00 00:00:00',0,0),(801,'pkg_weblinks','package','pkg_weblinks','',0,1,1,0,'{\"name\":\"pkg_weblinks\",\"type\":\"package\",\"creationDate\":\"December 2012\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2015 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.4.1\",\"description\":\"PKG_WEBLINKS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"pkg_weblinks\"}','','','',0,'0000-00-00 00:00:00',0,0),(806,'J51 Thumbs Gallery Module','module','mod_j51thumbsgallery','',0,1,0,0,'{\"legacy\":false,\"name\":\"J51 Thumbs Gallery Module\",\"type\":\"module\",\"creationDate\":\"Feb 2012\",\"author\":\"Joomla51.com\",\"copyright\":\"Copyright (C) 2012 Joomla51.com. All rights reserved.\",\"authorEmail\":\"info@joomla51.com\",\"authorUrl\":\"http://www.Joomla51.com\",\"version\":\"1.0\",\"description\":\"Joomla51 Thumbs Gallery Module\",\"group\":\"\"}','{\"path\":\"\",\"thumbwidth\":\"100\",\"thumbheight\":\"100\",\"fade_opacity\":\"0.5\",\"bordersize\":\"0.5\",\"bordercolor\":\"#FFFFFF\",\"outlinecolor\":\"#006699\",\"moduleclass_sfx\":\"\",\"cache\":\"1\",\"cache_time\":\"900\"}','','',0,'0000-00-00 00:00:00',0,0),(866,'com_joomlaupdate','component','com_joomlaupdate','',1,1,1,0,'{\"legacy\":false,\"name\":\"com_joomlaupdate\",\"type\":\"component\",\"creationDate\":\"February 2012\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2012 Open Source Matters. All rights reserved.\\t\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"2.5.0\",\"description\":\"COM_JOOMLAUPDATE_XML_DESCRIPTION\",\"group\":\"\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(880,'com_tags','component','com_tags','',1,1,1,0,'{\"name\":\"com_tags\",\"type\":\"component\",\"creationDate\":\"December 2013\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.1.0\",\"description\":\"COM_TAGS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"tags\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(881,'mod_tags_popular','module','mod_tags_popular','',0,1,1,0,'{\"name\":\"mod_tags_popular\",\"type\":\"module\",\"creationDate\":\"January 2013\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.1.0\",\"description\":\"MOD_TAGS_POPULAR_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_tags_popular\"}','{\"maximum\":\"5\",\"timeframe\":\"alltime\",\"owncache\":\"1\"}','','',0,'0000-00-00 00:00:00',0,0),(882,'mod_tags_similar','module','mod_tags_similar','',0,1,1,0,'{\"name\":\"mod_tags_similar\",\"type\":\"module\",\"creationDate\":\"January 2013\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.1.0\",\"description\":\"MOD_TAGS_SIMILAR_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_tags_similar\"}','{\"maximum\":\"5\",\"matchtype\":\"any\",\"owncache\":\"1\"}','','',0,'0000-00-00 00:00:00',0,0),(883,'mod_stats_admin','module','mod_stats_admin','',1,1,1,0,'{\"name\":\"mod_stats_admin\",\"type\":\"module\",\"creationDate\":\"July 2004\",\"author\":\"Joomla! Project\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"MOD_STATS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"mod_stats_admin\"}','{\"serverinfo\":\"0\",\"siteinfo\":\"0\",\"counter\":\"0\",\"increase\":\"0\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\"}','','',0,'0000-00-00 00:00:00',0,0),(884,'plg_finder_tags','plugin','tags','finder',0,0,1,0,'{\"name\":\"plg_finder_tags\",\"type\":\"plugin\",\"creationDate\":\"February 2013\",\"author\":\"Joomla! Project\",\"copyright\":\"(C) 2005 - 2016 Open Source Matters. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"http://www.joomla.org\",\"version\":\"3.0.0\",\"description\":\"PLG_FINDER_TAGS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"tags\"}','{}','','',0,'0000-00-00 00:00:00',0,0),(885,'beez3','template','beez3','',0,1,1,0,'{\"name\":\"beez3\",\"type\":\"template\",\"creationDate\":\"25 November 2009\",\"author\":\"Angie Radtke\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters, Inc. All rights reserved.\",\"authorEmail\":\"a.radtke@derauftritt.de\",\"authorUrl\":\"http:\\/\\/http://www.der-auftritt.de\",\"version\":\"3.1.0\",\"description\":\"TPL_BEEZ3_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"templateDetails\"}','{\"wrapperSmall\":\"53\",\"wrapperLarge\":\"72\",\"sitetitle\":\"\",\"sitedescription\":\"\",\"navposition\":\"center\",\"templatecolor\":\"nature\",\"backgroundcolor\":\"#eee\"}','','',0,'0000-00-00 00:00:00',0,0),(886,'protostar','template','protostar','',0,1,1,0,'{\"name\":\"protostar\",\"type\":\"template\",\"creationDate\":\"4\\/30\\/2012\",\"author\":\"Kyle Ledbetter\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters, Inc. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"\",\"version\":\"1.0\",\"description\":\"TPL_PROTOSTAR_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"templateDetails\"}','{\"templateColor\":\"#08C\",\"templateBackgroundColor\":\"#F4F6F7\",\"logoFile\":\"\",\"sitetitle\":\"\",\"sitedescription\":\"\",\"googleFont\":\"1\",\"googleFontName\":\"Open+Sans\",\"fluidContainer\":\"0\"}','','',0,'0000-00-00 00:00:00',0,0),(887,'isis','template','isis','',1,1,1,0,'{\"name\":\"isis\",\"type\":\"template\",\"creationDate\":\"3\\/30\\/2012\",\"author\":\"Kyle Ledbetter\",\"copyright\":\"Copyright (C) 2005 - 2016 Open Source Matters, Inc. All rights reserved.\",\"authorEmail\":\"admin@joomla.org\",\"authorUrl\":\"\",\"version\":\"1.0\",\"description\":\"TPL_ISIS_XML_DESCRIPTION\",\"group\":\"\",\"filename\":\"templateDetails\"}','{\"templateColor\":\"#13294A\",\"headerColor\":\"#184A7D\",\"logoFile\":\"\",\"admin_menus\":\"1\",\"displayHeader\":\"1\",\"statusFixed\":\"1\",\"stickyToolbar\":\"1\"}','','',0,'0000-00-00 00:00:00',0,0),(904,'J51_GridGallery','module','mod_j51gridgallery','',0,1,1,0,'{\"name\":\"J51_GridGallery\",\"type\":\"module\",\"creationDate\":\"May 2014\",\"author\":\"Joomla51\",\"copyright\":\"Copyright (C)2014 Joomla51\",\"authorEmail\":\"info@joomla51.com\",\"authorUrl\":\"http:\\/\\/http://www.joomla51.com\",\"version\":\"1.0\",\"description\":\"GridGallery module by Joomla51\",\"group\":\"\",\"filename\":\"mod_j51gridgallery\"}','{\"j51_num_images\":\"1\",\"j51_randomize\":\"0\",\"j51_image_width\":\"215\",\"j51_image_margin_x\":\"5\",\"j51_image_margin_y\":\"5\",\"j51_title_color\":\"#555555\",\"j51_text_color\":\"#AAAAAA\",\"j51_bg_color\":\"#FFFFFF\",\"j51_border_color\":\"#AAAAAA\",\"j51_image1\":\"\",\"image_alt1\":\"\",\"image_title1\":\"\",\"image_teaser1\":\"\",\"j51_disablecaption1\":\"no\",\"image_url1\":\"45\",\"target_url1\":\"_self\",\"j51_image2\":\"\",\"image_alt2\":\"\",\"image_title2\":\"\",\"image_teaser2\":\"\",\"j51_disablecaption2\":\"no\",\"image_url2\":\"45\",\"target_url2\":\"_self\",\"j51_image3\":\"\",\"image_alt3\":\"\",\"image_title3\":\"\",\"image_teaser3\":\"\",\"j51_disablecaption3\":\"no\",\"image_url3\":\"45\",\"target_url3\":\"_self\",\"j51_image4\":\"\",\"image_alt4\":\"\",\"image_title4\":\"\",\"image_teaser4\":\"\",\"j51_disablecaption4\":\"no\",\"image_url4\":\"45\",\"target_url4\":\"_self\",\"j51_image5\":\"\",\"image_alt5\":\"\",\"image_title5\":\"\",\"image_teaser5\":\"\",\"j51_disablecaption5\":\"no\",\"image_url5\":\"45\",\"target_url5\":\"_self\",\"j51_image6\":\"\",\"image_alt6\":\"\",\"image_title6\":\"\",\"image_teaser6\":\"\",\"j51_disablecaption6\":\"no\",\"image_url6\":\"45\",\"target_url6\":\"_self\",\"j51_image7\":\"\",\"image_alt7\":\"\",\"image_title7\":\"\",\"image_teaser7\":\"\",\"j51_disablecaption7\":\"no\",\"image_url7\":\"45\",\"target_url7\":\"_self\",\"j51_image8\":\"\",\"image_alt8\":\"\",\"image_title8\":\"\",\"image_teaser8\":\"\",\"j51_disablecaption8\":\"no\",\"image_url8\":\"45\",\"target_url8\":\"_self\",\"j51_image9\":\"\",\"image_alt9\":\"\",\"image_title9\":\"\",\"image_teaser9\":\"\",\"j51_disablecaption9\":\"no\",\"image_url9\":\"45\",\"target_url9\":\"_self\",\"j51_image10\":\"\",\"image_alt10\":\"\",\"image_title10\":\"\",\"image_teaser10\":\"\",\"j51_disablecaption10\":\"no\",\"image_url10\":\"45\",\"target_url10\":\"_self\",\"j51_image11\":\"\",\"image_alt11\":\"\",\"image_title11\":\"\",\"image_teaser11\":\"\",\"j51_disablecaption11\":\"no\",\"image_url11\":\"45\",\"target_url11\":\"_self\",\"j51_image12\":\"\",\"image_alt12\":\"\",\"image_title12\":\"\",\"image_teaser12\":\"\",\"j51_disablecaption12\":\"no\",\"image_url12\":\"45\",\"target_url12\":\"_self\",\"j51_image13\":\"\",\"image_alt13\":\"\",\"image_title13\":\"\",\"image_teaser13\":\"\",\"j51_disablecaption13\":\"no\",\"image_url13\":\"45\",\"target_url13\":\"_self\",\"j51_image14\":\"\",\"image_alt14\":\"\",\"image_title14\":\"\",\"image_teaser14\":\"\",\"j51_disablecaption14\":\"no\",\"image_url14\":\"45\",\"target_url14\":\"_self\",\"j51_image15\":\"\",\"image_alt15\":\"\",\"image_title15\":\"\",\"image_teaser15\":\"\",\"j51_disablecaption15\":\"no\",\"image_url15\":\"45\",\"target_url15\":\"_self\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\"}','','',0,'0000-00-00 00:00:00',0,0),(922,'J51_Carousel','module','mod_j51carousel','',0,1,1,0,'{\"name\":\"J51_Carousel\",\"type\":\"module\",\"creationDate\":\"November 2014\",\"author\":\"Joomla51\",\"copyright\":\"Copyright (C)2014 Joomla51\",\"authorEmail\":\"info@joomla51.com\",\"authorUrl\":\"http:\\/\\/http://www.joomla51.com\",\"version\":\"1.0\",\"description\":\"\\n\\t\\n <\\/style>
\\n\\t
J51-Carousel by Joomla51<\\/p>\\n\\t\\n \\t<\\/div>\\n \\t\\n\\t\",\"group\":\"\"}','{\"j51_num_images\":\"1\",\"j51_randomize\":\"0\",\"j51_image_width\":\"245\",\"j51_image_width_tabl\":\"141\",\"j51_image_width_tabp\":\"141\",\"j51_image_width_mobl\":\"205\",\"j51_image_width_mobp\":\"270\",\"j51_image_margin_x\":\"8\",\"j51_image_margin_y\":\"5\",\"j51_overlay_color\":\"#313a49\",\"j51_title_color\":\"#e6e6e6\",\"j51_text_color\":\"#b8b8b8\",\"j51_bg_color\":\"#2f1f0b\",\"j51_border_color\":\"#2f1f0b\",\"j51_image1\":\"\",\"j51_image_alt1\":\"\",\"j51_title1\":\"\",\"j51_text1\":\"\",\"j51_disablecaption1\":\"no\",\"image_url1\":\"45\",\"j51_disableurl1\":\"no\",\"target_url1\":\"_self\",\"j51_animate_class1\":\"fadeInUp\",\"j51_image2\":\"\",\"j51_image_alt2\":\"\",\"j51_title2\":\"\",\"j51_text2\":\"\",\"j51_disablecaption2\":\"no\",\"image_url2\":\"45\",\"j51_disableurl2\":\"no\",\"target_url2\":\"_self\",\"j51_animate_class2\":\"fadeInUp\",\"j51_image3\":\"\",\"j51_image_alt3\":\"\",\"j51_title3\":\"\",\"j51_text3\":\"\",\"j51_disablecaption3\":\"no\",\"image_url3\":\"45\",\"j51_disableurl3\":\"no\",\"target_url3\":\"_self\",\"j51_animate_class3\":\"fadeInUp\",\"j51_image4\":\"\",\"j51_image_alt4\":\"\",\"j51_title4\":\"\",\"j51_text4\":\"\",\"j51_disablecaption4\":\"no\",\"image_url4\":\"45\",\"j51_disableurl4\":\"no\",\"target_url4\":\"_self\",\"j51_animate_class4\":\"fadeInUp\",\"j51_image5\":\"\",\"j51_image_alt5\":\"\",\"j51_title5\":\"\",\"j51_text5\":\"\",\"j51_disablecaption5\":\"no\",\"image_url5\":\"45\",\"j51_disableurl5\":\"no\",\"target_url5\":\"_self\",\"j51_animate_class5\":\"fadeInUp\",\"j51_image6\":\"\",\"j51_image_alt6\":\"\",\"j51_title6\":\"\",\"j51_text6\":\"\",\"j51_disablecaption6\":\"no\",\"image_url6\":\"45\",\"j51_disableurl6\":\"no\",\"target_url6\":\"_self\",\"j51_animate_class6\":\"fadeInUp\",\"j51_image7\":\"\",\"j51_image_alt7\":\"\",\"j51_title7\":\"\",\"j51_text7\":\"\",\"j51_disablecaption7\":\"no\",\"image_url7\":\"45\",\"j51_disableurl7\":\"no\",\"target_url7\":\"_self\",\"j51_animate_class7\":\"fadeInUp\",\"j51_image8\":\"\",\"j51_image_alt8\":\"\",\"j51_title8\":\"\",\"j51_text8\":\"\",\"j51_disablecaption8\":\"no\",\"image_url8\":\"45\",\"j51_disableurl8\":\"no\",\"target_url8\":\"_self\",\"j51_animate_class8\":\"fadeInUp\",\"j51_image9\":\"\",\"j51_image_alt9\":\"\",\"j51_title9\":\"\",\"j51_text9\":\"\",\"j51_disablecaption9\":\"no\",\"image_url9\":\"45\",\"j51_disableurl9\":\"no\",\"target_url9\":\"_self\",\"j51_animate_class9\":\"fadeInUp\",\"j51_image10\":\"\",\"j51_image_alt10\":\"\",\"j51_title10\":\"\",\"j51_text10\":\"\",\"j51_disablecaption10\":\"no\",\"image_url10\":\"45\",\"j51_disableurl10\":\"no\",\"target_url10\":\"_self\",\"j51_animate_class10\":\"fadeInUp\",\"j51_image11\":\"\",\"j51_image_alt11\":\"\",\"j51_title11\":\"\",\"j51_text11\":\"\",\"j51_disablecaption11\":\"no\",\"image_url11\":\"45\",\"j51_disableurl11\":\"no\",\"target_url11\":\"_self\",\"j51_animate_class11\":\"fadeInUp\",\"j51_image12\":\"\",\"j51_image_alt12\":\"\",\"j51_title12\":\"\",\"j51_text12\":\"\",\"j51_disablecaption12\":\"no\",\"image_url12\":\"45\",\"j51_disableurl12\":\"no\",\"target_url12\":\"_self\",\"j51_animate_class12\":\"fadeInUp\",\"j51_image13\":\"\",\"j51_image_alt13\":\"\",\"j51_title13\":\"\",\"j51_text13\":\"\",\"j51_disablecaption13\":\"no\",\"image_url13\":\"45\",\"target_url13\":\"_self\",\"j51_animate_class13\":\"fadeInUp\",\"j51_image14\":\"\",\"j51_image_alt14\":\"\",\"j51_title14\":\"\",\"j51_text14\":\"\",\"j51_disablecaption14\":\"no\",\"image_url14\":\"45\",\"j51_disableurl14\":\"no\",\"target_url14\":\"_self\",\"j51_animate_class14\":\"fadeInUp\",\"j51_image15\":\"\",\"j51_image_alt15\":\"\",\"j51_title15\":\"\",\"j51_text15\":\"\",\"j51_disablecaption15\":\"no\",\"image_url15\":\"45\",\"j51_disableurl15\":\"no\",\"target_url15\":\"_self\",\"j51_animate_class15\":\"fadeInUp\",\"cache\":\"1\",\"cache_time\":\"900\",\"cachemode\":\"static\"}','','',0,'0000-00-00 00:00:00',0,0),(924,'J51_Nadia','template','j51_nadia','',0,1,1,0,'{\"name\":\"J51_Nadia\",\"type\":\"template\",\"creationDate\":\"January 2014\",\"author\":\"Joomla51\",\"copyright\":\"Joomla51\",\"authorEmail\":\"info@joomla51.com\",\"authorUrl\":\"http:\\/\\/http://www.joomla51.com\",\"version\":\"1.0\",\"description\":\"\\n \\n <\\/style>
\\n\\n\\n
We are delighted to bring you our latest Joomla template, Nadia. This elegant boxed design brings a visually stunning and attractive solution for your Joomla project. Carefully crafted lines and image placements allows you the perfect platform to showcase your portfolio. Features include a host of powerful editing options to mould your template exactly to your taste along with 58 module positions giving you unlimited layout control for your content. Be inspired today by our Nadia Joomla template!<\\/p>\\n\\n
Joomla51<\\/a>Template Tutorials<\\/a><\\/p>\\n\\n <\\/div>\\n \",\"group\":\"\",\"filename\":\"templateDetails\"}','{\"bgcolor\":\"#282729\",\"header_color\":\"#282729\",\"header_opacity\":\"0.0\",\"header_bg\":\"\",\"showcase_color\":\"#282729\",\"top1_color\":\"#282729\",\"top1_bg\":\"\",\"top2_color\":\"#ffffff\",\"top2_bg\":\"\",\"top3_color\":\"#f0f0f0\",\"top3_bg\":\"\",\"elementcolor3\":\"#ffffff\",\"elementcolor7\":\"#f7f7f7\",\"elementcolor16\":\"#f0f0f0\",\"bottom1_bg\":\"\",\"elementcolor18\":\"#282729\",\"bottom2_bg\":\"\",\"elementcolor9\":\"#0d0e0f\",\"body_fontsize\":\"16px\",\"body_fontstyle\":\"Open+Sans\",\"h1head_fontstyle\":\"Open+Sans\",\"articlehead_fontstyle\":\"Open+Sans\",\"modulehead_fontstyle\":\"Open+Sans\",\"hornav_fontstyle\":\"Open+Sans\",\"fontawesome_sw\":\"1\",\"body_font_color\":\"#656565\",\"articletitle_font_color\":\"#46474a\",\"modulehead_font_color\":\"#999999\",\"content_link_color\":\"#323335\",\"button_color\":\"#323335\",\"hornav_menu\":\"mainmenu\",\"hornav_font_color\":\"#ffffff\",\"hornav_ddbackground_color\":\"#ffffff\",\"hornavPosition\":\"0\",\"footer_menu\":\"mainmenu\",\"footermenuPosition\":\"0\",\"logoImage\":\"1\",\"logoimagefile\":\"\",\"logo_x\":\"20\",\"logo_y\":\"63\",\"logoText\":\"nadia\",\"logo_fontstyle\":\"Pacifico\",\"logo_font_color\":\"#ffffff\",\"sloganText\":\"\",\"slogan_font_color\":\"#f0f0f0\",\"wrapper_width\":\"1080\",\"column_layout\":\"SCOLA-COM-SCOLB\",\"sidecola_width\":\"25\",\"sidecolb_width\":\"25\",\"responsive_sw\":\"1\",\"sidecol_responsive_pos\":\"before\",\"res_top1_sw\":\"1\",\"res_top2_sw\":\"1\",\"res_top3_sw\":\"1\",\"res_sidecola_sw\":\"1\",\"res_sidecolb_sw\":\"1\",\"res_bottom_sw\":\"1\",\"res_base_sw\":\"1\",\"tabport_css\":\"\",\"mobland_css\":\"\",\"mobport_css\":\"\",\"top1_auto\":\"0\",\"top1_padding\":\"0\",\"top_1a_manual\":\"16.6\",\"top_1b_manual\":\"16.6\",\"top_1c_manual\":\"16.6\",\"top_1d_manual\":\"16.6\",\"top_1e_manual\":\"16.6\",\"top_1f_manual\":\"16.6\",\"top2_auto\":\"0\",\"top2_padding\":\"0\",\"top_2a_manual\":\"16.6\",\"top_2b_manual\":\"16.6\",\"top_2c_manual\":\"16.6\",\"top_2d_manual\":\"16.6\",\"top_2e_manual\":\"16.6\",\"top_2f_manual\":\"16.6\",\"top3_auto\":\"0\",\"top3_padding\":\"0\",\"top_3a_manual\":\"16.6\",\"top_3b_manual\":\"16.6\",\"top_3c_manual\":\"16.6\",\"top_3d_manual\":\"16.6\",\"top_3e_manual\":\"16.6\",\"top_3f_manual\":\"16.6\",\"contenttop_auto\":\"0\",\"contenttop_a_manual\":\"33\",\"contenttop_b_manual\":\"33\",\"contenttop_c_manual\":\"33\",\"contentbottom_auto\":\"0\",\"contentbottom_a_manual\":\"33\",\"contentbottom_b_manual\":\"33\",\"contentbottom_c_manual\":\"33\",\"bottom1_auto\":\"0\",\"bottom_padding\":\"0\",\"bottom_1a_manual\":\"16.6\",\"bottom_1b_manual\":\"16.6\",\"bottom_1c_manual\":\"16.6\",\"bottom_1d_manual\":\"16.6\",\"bottom_1e_manual\":\"16.6\",\"bottom_1f_manual\":\"16.6\",\"bottom2_auto\":\"0\",\"bottom2_padding\":\"0\",\"bottom_2a_manual\":\"16.6\",\"bottom_2b_manual\":\"16.6\",\"bottom_2c_manual\":\"16.6\",\"bottom_2d_manual\":\"16.6\",\"bottom_2e_manual\":\"16.6\",\"bottom_2f_manual\":\"16.6\",\"base1_auto\":\"0\",\"base1_padding\":\"0\",\"base_1a_manual\":\"16.6\",\"base_1b_manual\":\"16.6\",\"base_1c_manual\":\"16.6\",\"base_1d_manual\":\"16.6\",\"base_1e_manual\":\"16.6\",\"base_1f_manual\":\"16.6\",\"base2_auto\":\"0\",\"base2_padding\":\"0\",\"base_2a_manual\":\"16.6\",\"base_2b_manual\":\"16.6\",\"base_2c_manual\":\"16.6\",\"base_2d_manual\":\"16.6\",\"base_2e_manual\":\"16.6\",\"base_2f_manual\":\"16.6\",\"copyright\":\"(c) 2014 Your Copyright Info\",\"social_style\":\"social_style_light\",\"social_rss\":\"\",\"social_twitter\":\"\",\"social_facebook\":\"\",\"social_googleplus\":\"\",\"social_youtube\":\"\",\"social_pininterest\":\"\",\"social_blogger\":\"\",\"social_dribbble\":\"\",\"social_flickr\":\"\",\"social_skype\":\"\",\"social_linkedin\":\"\",\"social_vimeo\":\"\",\"social_yahoo\":\"\",\"social_tumblr\":\"\",\"social_deviantart\":\"\",\"social_delicious\":\"\",\"custom_css\":\"\",\"head_custom_code\":\"\",\"body_custom_code\":\"\"}','','',0,'0000-00-00 00:00:00',0,0)
Table 'ecweb_2016b.#__extensions' doesn't exist SQL=/*!40000 ALTER TABLE `#__extensions` DISABLE KEYS */
Table 'ecweb_2016b.#__extensions' doesn't exist SQL=LOCK TABLES `#__extensions` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__extensions` ( `extension_id` int(11) NOT NULL AUTO_INCREMENT, `name` varchar(100) COLLATE utf8mb4_unicode_ci NOT NULL, `type` varchar(20) COLLATE utf8mb4_unicode_ci NOT NULL, `element` varchar(100) COLLATE utf8mb4_unicode_ci NOT NULL, `folder` varchar(100) COLLATE utf8mb4_unicode_ci NOT NULL, `client_id` tinyint(3) NOT NULL, `enabled` tinyint(3) NOT NULL DEFAULT '1', `access` int(10) unsigned NOT NULL DEFAULT '1', `protected` tinyint(3) NOT NULL DEFAULT '0', `manifest_cache` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `params` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `custom_data` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `system_data` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `checked_out` int(10) unsigned NOT NULL DEFAULT '0', `checked_out_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `ordering` int(11) DEFAULT '0', `state` int(11) DEFAULT '0', PRIMARY KEY (`extension_id`), KEY `element_clientid` (`element`,`client_id`), KEY `element_folder_clientid` (`element`,`folder`,`client_id`), KEY `extension` (`type`,`element`,`folder`,`client_id`) ) ENGINE=InnoDB AUTO_INCREMENT=925 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__core_log_searches' doesn't exist SQL=/*!40000 ALTER TABLE `#__core_log_searches` ENABLE KEYS */
Table 'ecweb_2016b.#__core_log_searches' doesn't exist SQL=/*!40000 ALTER TABLE `#__core_log_searches` DISABLE KEYS */
Table 'ecweb_2016b.#__core_log_searches' doesn't exist SQL=LOCK TABLES `#__core_log_searches` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__core_log_searches` ( `search_term` varchar(128) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `hits` int(10) unsigned NOT NULL DEFAULT '0' ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__contentitem_tag_map' doesn't exist SQL=/*!40000 ALTER TABLE `#__contentitem_tag_map` ENABLE KEYS */
Table 'ecweb_2016b.#__contentitem_tag_map' doesn't exist SQL=/*!40000 ALTER TABLE `#__contentitem_tag_map` DISABLE KEYS */
Table 'ecweb_2016b.#__contentitem_tag_map' doesn't exist SQL=LOCK TABLES `#__contentitem_tag_map` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__contentitem_tag_map` ( `type_alias` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `core_content_id` int(10) unsigned NOT NULL COMMENT 'PK from the core content table', `content_item_id` int(11) NOT NULL COMMENT 'PK from the content type table', `tag_id` int(10) unsigned NOT NULL COMMENT 'PK from the tag table', `tag_date` timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP ON UPDATE CURRENT_TIMESTAMP COMMENT 'Date of most recent save for this tag-item', `type_id` mediumint(8) NOT NULL COMMENT 'PK from the content_type table', UNIQUE KEY `uc_ItemnameTagid` (`type_id`,`content_item_id`,`tag_id`), KEY `idx_tag_type` (`tag_id`,`type_id`), KEY `idx_date_id` (`tag_date`,`tag_id`), KEY `idx_core_content_id` (`core_content_id`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci COMMENT='Maps items from content tables to tags'
Table 'ecweb_2016b.#__content_types' doesn't exist SQL=/*!40000 ALTER TABLE `#__content_types` ENABLE KEYS */
Table 'ecweb_2016b.#__content_types' doesn't exist SQL=INSERT INTO `#__content_types` VALUES (1,'Article','com_content.article','{\"special\":{\"dbtable\":\"#__content\",\"key\":\"id\",\"type\":\"Content\",\"prefix\":\"JTable\",\"config\":\"array()\"},\"common\":{\"dbtable\":\"#__ucm_content\",\"key\":\"ucm_id\",\"type\":\"Corecontent\",\"prefix\":\"JTable\",\"config\":\"array()\"}}','','{\"common\":{\"core_content_item_id\":\"id\",\"core_title\":\"title\",\"core_state\":\"state\",\"core_alias\":\"alias\",\"core_created_time\":\"created\",\"core_modified_time\":\"modified\",\"core_body\":\"introtext\", \"core_hits\":\"hits\",\"core_publish_up\":\"publish_up\",\"core_publish_down\":\"publish_down\",\"core_access\":\"access\", \"core_params\":\"attribs\", \"core_featured\":\"featured\", \"core_metadata\":\"metadata\", \"core_language\":\"language\", \"core_images\":\"images\", \"core_urls\":\"urls\", \"core_version\":\"version\", \"core_ordering\":\"ordering\", \"core_metakey\":\"metakey\", \"core_metadesc\":\"metadesc\", \"core_catid\":\"catid\", \"core_xreference\":\"xreference\", \"asset_id\":\"asset_id\"}, \"special\": {\"fulltext\":\"fulltext\"}}','ContentHelperRoute::getArticleRoute','{\"formFile\":\"administrator\\/components\\/com_content\\/models\\/forms\\/article.xml\", \"hideFields\":[\"asset_id\",\"checked_out\",\"checked_out_time\",\"version\"],\"ignoreChanges\":[\"modified_by\", \"modified\", \"checked_out\", \"checked_out_time\", \"version\", \"hits\"],\"convertToInt\":[\"publish_up\", \"publish_down\", \"featured\", \"ordering\"],\"displayLookup\":[{\"sourceColumn\":\"catid\",\"targetTable\":\"#__categories\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"},{\"sourceColumn\":\"created_by\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"access\",\"targetTable\":\"#__viewlevels\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"},{\"sourceColumn\":\"modified_by\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"} ]}'),(2,'Weblink','com_weblinks.weblink','{\"special\":{\"dbtable\":\"#__weblinks\",\"key\":\"id\",\"type\":\"Weblink\",\"prefix\":\"WeblinksTable\",\"config\":\"array()\"},\"common\":{\"dbtable\":\"#__ucm_content\",\"key\":\"ucm_id\",\"type\":\"Corecontent\",\"prefix\":\"JTable\",\"config\":\"array()\"}}','','{\"common\":{\"core_content_item_id\":\"id\",\"core_title\":\"title\",\"core_state\":\"state\",\"core_alias\":\"alias\",\"core_created_time\":\"created\",\"core_modified_time\":\"modified\",\"core_body\":\"description\", \"core_hits\":\"hits\",\"core_publish_up\":\"publish_up\",\"core_publish_down\":\"publish_down\",\"core_access\":\"access\", \"core_params\":\"params\", \"core_featured\":\"featured\", \"core_metadata\":\"metadata\", \"core_language\":\"language\", \"core_images\":\"images\", \"core_urls\":\"url\", \"core_version\":\"version\", \"core_ordering\":\"ordering\", \"core_metakey\":\"metakey\", \"core_metadesc\":\"metadesc\", \"core_catid\":\"catid\", \"core_xreference\":\"xreference\", \"asset_id\":\"null\"}, \"special\": {}}','WeblinksHelperRoute::getWeblinkRoute','{\"formFile\":\"administrator\\/components\\/com_weblinks\\/models\\/forms\\/weblink.xml\", \"hideFields\":[\"asset_id\",\"checked_out\",\"checked_out_time\",\"version\",\"featured\",\"images\"], \"ignoreChanges\":[\"modified_by\", \"modified\", \"checked_out\", \"checked_out_time\", \"version\", \"hits\"], \"convertToInt\":[\"publish_up\", \"publish_down\", \"featured\", \"ordering\"], \"displayLookup\":[{\"sourceColumn\":\"catid\",\"targetTable\":\"#__categories\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"},{\"sourceColumn\":\"created_by\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"access\",\"targetTable\":\"#__viewlevels\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"},{\"sourceColumn\":\"modified_by\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"} ]}'),(3,'Contact','com_contact.contact','{\"special\":{\"dbtable\":\"#__contact_details\",\"key\":\"id\",\"type\":\"Contact\",\"prefix\":\"ContactTable\",\"config\":\"array()\"},\"common\":{\"dbtable\":\"#__ucm_content\",\"key\":\"ucm_id\",\"type\":\"Corecontent\",\"prefix\":\"JTable\",\"config\":\"array()\"}}','','{\"common\":{\"core_content_item_id\":\"id\",\"core_title\":\"name\",\"core_state\":\"published\",\"core_alias\":\"alias\",\"core_created_time\":\"created\",\"core_modified_time\":\"modified\",\"core_body\":\"address\", \"core_hits\":\"hits\",\"core_publish_up\":\"publish_up\",\"core_publish_down\":\"publish_down\",\"core_access\":\"access\", \"core_params\":\"params\", \"core_featured\":\"featured\", \"core_metadata\":\"metadata\", \"core_language\":\"language\", \"core_images\":\"image\", \"core_urls\":\"webpage\", \"core_version\":\"version\", \"core_ordering\":\"ordering\", \"core_metakey\":\"metakey\", \"core_metadesc\":\"metadesc\", \"core_catid\":\"catid\", \"core_xreference\":\"xreference\", \"asset_id\":\"null\"}, \"special\": {\"con_position\":\"con_position\",\"suburb\":\"suburb\",\"state\":\"state\",\"country\":\"country\",\"postcode\":\"postcode\",\"telephone\":\"telephone\",\"fax\":\"fax\",\"misc\":\"misc\",\"email_to\":\"email_to\",\"default_con\":\"default_con\",\"user_id\":\"user_id\",\"mobile\":\"mobile\",\"sortname1\":\"sortname1\",\"sortname2\":\"sortname2\",\"sortname3\":\"sortname3\"}}','ContactHelperRoute::getContactRoute','{\"formFile\":\"administrator\\/components\\/com_contact\\/models\\/forms\\/contact.xml\",\"hideFields\":[\"default_con\",\"checked_out\",\"checked_out_time\",\"version\",\"xreference\"],\"ignoreChanges\":[\"modified_by\", \"modified\", \"checked_out\", \"checked_out_time\", \"version\", \"hits\"],\"convertToInt\":[\"publish_up\", \"publish_down\", \"featured\", \"ordering\"], \"displayLookup\":[ {\"sourceColumn\":\"created_by\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"catid\",\"targetTable\":\"#__categories\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"},{\"sourceColumn\":\"modified_by\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"access\",\"targetTable\":\"#__viewlevels\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"},{\"sourceColumn\":\"user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"} ] }'),(4,'Newsfeed','com_newsfeeds.newsfeed','{\"special\":{\"dbtable\":\"#__newsfeeds\",\"key\":\"id\",\"type\":\"Newsfeed\",\"prefix\":\"NewsfeedsTable\",\"config\":\"array()\"},\"common\":{\"dbtable\":\"#__ucm_content\",\"key\":\"ucm_id\",\"type\":\"Corecontent\",\"prefix\":\"JTable\",\"config\":\"array()\"}}','','{\"common\":{\"core_content_item_id\":\"id\",\"core_title\":\"name\",\"core_state\":\"published\",\"core_alias\":\"alias\",\"core_created_time\":\"created\",\"core_modified_time\":\"modified\",\"core_body\":\"description\", \"core_hits\":\"hits\",\"core_publish_up\":\"publish_up\",\"core_publish_down\":\"publish_down\",\"core_access\":\"access\", \"core_params\":\"params\", \"core_featured\":\"featured\", \"core_metadata\":\"metadata\", \"core_language\":\"language\", \"core_images\":\"images\", \"core_urls\":\"link\", \"core_version\":\"version\", \"core_ordering\":\"ordering\", \"core_metakey\":\"metakey\", \"core_metadesc\":\"metadesc\", \"core_catid\":\"catid\", \"core_xreference\":\"xreference\", \"asset_id\":\"null\"}, \"special\": {\"numarticles\":\"numarticles\",\"cache_time\":\"cache_time\",\"rtl\":\"rtl\"}}','NewsfeedsHelperRoute::getNewsfeedRoute','{\"formFile\":\"administrator\\/components\\/com_newsfeeds\\/models\\/forms\\/newsfeed.xml\",\"hideFields\":[\"asset_id\",\"checked_out\",\"checked_out_time\",\"version\"],\"ignoreChanges\":[\"modified_by\", \"modified\", \"checked_out\", \"checked_out_time\", \"version\", \"hits\"],\"convertToInt\":[\"publish_up\", \"publish_down\", \"featured\", \"ordering\"],\"displayLookup\":[{\"sourceColumn\":\"catid\",\"targetTable\":\"#__categories\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"},{\"sourceColumn\":\"created_by\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"access\",\"targetTable\":\"#__viewlevels\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"},{\"sourceColumn\":\"modified_by\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"}]}'),(5,'User','com_users.user','{\"special\":{\"dbtable\":\"#__users\",\"key\":\"id\",\"type\":\"User\",\"prefix\":\"JTable\",\"config\":\"array()\"},\"common\":{\"dbtable\":\"#__ucm_content\",\"key\":\"ucm_id\",\"type\":\"Corecontent\",\"prefix\":\"JTable\",\"config\":\"array()\"}}','','{\"common\":{\"core_content_item_id\":\"id\",\"core_title\":\"name\",\"core_state\":\"null\",\"core_alias\":\"username\",\"core_created_time\":\"registerdate\",\"core_modified_time\":\"lastvisitDate\",\"core_body\":\"null\", \"core_hits\":\"null\",\"core_publish_up\":\"null\",\"core_publish_down\":\"null\",\"access\":\"null\", \"core_params\":\"params\", \"core_featured\":\"null\", \"core_metadata\":\"null\", \"core_language\":\"null\", \"core_images\":\"null\", \"core_urls\":\"null\", \"core_version\":\"null\", \"core_ordering\":\"null\", \"core_metakey\":\"null\", \"core_metadesc\":\"null\", \"core_catid\":\"null\", \"core_xreference\":\"null\", \"asset_id\":\"null\"}, \"special\": {}}','UsersHelperRoute::getUserRoute',''),(6,'Article Category','com_content.category','{\"special\":{\"dbtable\":\"#__categories\",\"key\":\"id\",\"type\":\"Category\",\"prefix\":\"JTable\",\"config\":\"array()\"},\"common\":{\"dbtable\":\"#__ucm_content\",\"key\":\"ucm_id\",\"type\":\"Corecontent\",\"prefix\":\"JTable\",\"config\":\"array()\"}}','','{\"common\":{\"core_content_item_id\":\"id\",\"core_title\":\"title\",\"core_state\":\"published\",\"core_alias\":\"alias\",\"core_created_time\":\"created_time\",\"core_modified_time\":\"modified_time\",\"core_body\":\"description\", \"core_hits\":\"hits\",\"core_publish_up\":\"null\",\"core_publish_down\":\"null\",\"core_access\":\"access\", \"core_params\":\"params\", \"core_featured\":\"null\", \"core_metadata\":\"metadata\", \"core_language\":\"language\", \"core_images\":\"null\", \"core_urls\":\"null\", \"core_version\":\"version\", \"core_ordering\":\"null\", \"core_metakey\":\"metakey\", \"core_metadesc\":\"metadesc\", \"core_catid\":\"parent_id\", \"core_xreference\":\"null\", \"asset_id\":\"asset_id\"}, \"special\": {\"parent_id\":\"parent_id\",\"lft\":\"lft\",\"rgt\":\"rgt\",\"level\":\"level\",\"path\":\"path\",\"extension\":\"extension\",\"note\":\"note\"}}','ContentHelperRoute::getCategoryRoute','{\"formFile\":\"administrator\\/components\\/com_categories\\/models\\/forms\\/category.xml\", \"hideFields\":[\"asset_id\",\"checked_out\",\"checked_out_time\",\"version\",\"lft\",\"rgt\",\"level\",\"path\",\"extension\"], \"ignoreChanges\":[\"modified_user_id\", \"modified_time\", \"checked_out\", \"checked_out_time\", \"version\", \"hits\", \"path\"],\"convertToInt\":[\"publish_up\", \"publish_down\"], \"displayLookup\":[{\"sourceColumn\":\"created_user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"access\",\"targetTable\":\"#__viewlevels\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"},{\"sourceColumn\":\"modified_user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"parent_id\",\"targetTable\":\"#__categories\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"}]}'),(7,'Contact Category','com_contact.category','{\"special\":{\"dbtable\":\"#__categories\",\"key\":\"id\",\"type\":\"Category\",\"prefix\":\"JTable\",\"config\":\"array()\"},\"common\":{\"dbtable\":\"#__ucm_content\",\"key\":\"ucm_id\",\"type\":\"Corecontent\",\"prefix\":\"JTable\",\"config\":\"array()\"}}','','{\"common\":{\"core_content_item_id\":\"id\",\"core_title\":\"title\",\"core_state\":\"published\",\"core_alias\":\"alias\",\"core_created_time\":\"created_time\",\"core_modified_time\":\"modified_time\",\"core_body\":\"description\", \"core_hits\":\"hits\",\"core_publish_up\":\"null\",\"core_publish_down\":\"null\",\"core_access\":\"access\", \"core_params\":\"params\", \"core_featured\":\"null\", \"core_metadata\":\"metadata\", \"core_language\":\"language\", \"core_images\":\"null\", \"core_urls\":\"null\", \"core_version\":\"version\", \"core_ordering\":\"null\", \"core_metakey\":\"metakey\", \"core_metadesc\":\"metadesc\", \"core_catid\":\"parent_id\", \"core_xreference\":\"null\", \"asset_id\":\"asset_id\"}, \"special\": {\"parent_id\":\"parent_id\",\"lft\":\"lft\",\"rgt\":\"rgt\",\"level\":\"level\",\"path\":\"path\",\"extension\":\"extension\",\"note\":\"note\"}}','ContactHelperRoute::getCategoryRoute','{\"formFile\":\"administrator\\/components\\/com_categories\\/models\\/forms\\/category.xml\", \"hideFields\":[\"asset_id\",\"checked_out\",\"checked_out_time\",\"version\",\"lft\",\"rgt\",\"level\",\"path\",\"extension\"], \"ignoreChanges\":[\"modified_user_id\", \"modified_time\", \"checked_out\", \"checked_out_time\", \"version\", \"hits\", \"path\"],\"convertToInt\":[\"publish_up\", \"publish_down\"], \"displayLookup\":[{\"sourceColumn\":\"created_user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"access\",\"targetTable\":\"#__viewlevels\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"},{\"sourceColumn\":\"modified_user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"parent_id\",\"targetTable\":\"#__categories\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"}]}'),(8,'Newsfeeds Category','com_newsfeeds.category','{\"special\":{\"dbtable\":\"#__categories\",\"key\":\"id\",\"type\":\"Category\",\"prefix\":\"JTable\",\"config\":\"array()\"},\"common\":{\"dbtable\":\"#__ucm_content\",\"key\":\"ucm_id\",\"type\":\"Corecontent\",\"prefix\":\"JTable\",\"config\":\"array()\"}}','','{\"common\":{\"core_content_item_id\":\"id\",\"core_title\":\"title\",\"core_state\":\"published\",\"core_alias\":\"alias\",\"core_created_time\":\"created_time\",\"core_modified_time\":\"modified_time\",\"core_body\":\"description\", \"core_hits\":\"hits\",\"core_publish_up\":\"null\",\"core_publish_down\":\"null\",\"core_access\":\"access\", \"core_params\":\"params\", \"core_featured\":\"null\", \"core_metadata\":\"metadata\", \"core_language\":\"language\", \"core_images\":\"null\", \"core_urls\":\"null\", \"core_version\":\"version\", \"core_ordering\":\"null\", \"core_metakey\":\"metakey\", \"core_metadesc\":\"metadesc\", \"core_catid\":\"parent_id\", \"core_xreference\":\"null\", \"asset_id\":\"asset_id\"}, \"special\": {\"parent_id\":\"parent_id\",\"lft\":\"lft\",\"rgt\":\"rgt\",\"level\":\"level\",\"path\":\"path\",\"extension\":\"extension\",\"note\":\"note\"}}','NewsfeedsHelperRoute::getCategoryRoute','{\"formFile\":\"administrator\\/components\\/com_categories\\/models\\/forms\\/category.xml\", \"hideFields\":[\"asset_id\",\"checked_out\",\"checked_out_time\",\"version\",\"lft\",\"rgt\",\"level\",\"path\",\"extension\"], \"ignoreChanges\":[\"modified_user_id\", \"modified_time\", \"checked_out\", \"checked_out_time\", \"version\", \"hits\", \"path\"],\"convertToInt\":[\"publish_up\", \"publish_down\"], \"displayLookup\":[{\"sourceColumn\":\"created_user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"access\",\"targetTable\":\"#__viewlevels\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"},{\"sourceColumn\":\"modified_user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"parent_id\",\"targetTable\":\"#__categories\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"}]}'),(9,'Weblinks Category','com_weblinks.category','{\"special\":{\"dbtable\":\"#__categories\",\"key\":\"id\",\"type\":\"Category\",\"prefix\":\"JTable\",\"config\":\"array()\"},\"common\":{\"dbtable\":\"#__ucm_content\",\"key\":\"ucm_id\",\"type\":\"Corecontent\",\"prefix\":\"JTable\",\"config\":\"array()\"}}','','{\"common\":{\"core_content_item_id\":\"id\",\"core_title\":\"title\",\"core_state\":\"published\",\"core_alias\":\"alias\",\"core_created_time\":\"created_time\",\"core_modified_time\":\"modified_time\",\"core_body\":\"description\", \"core_hits\":\"hits\",\"core_publish_up\":\"null\",\"core_publish_down\":\"null\",\"core_access\":\"access\", \"core_params\":\"params\", \"core_featured\":\"null\", \"core_metadata\":\"metadata\", \"core_language\":\"language\", \"core_images\":\"null\", \"core_urls\":\"null\", \"core_version\":\"version\", \"core_ordering\":\"null\", \"core_metakey\":\"metakey\", \"core_metadesc\":\"metadesc\", \"core_catid\":\"parent_id\", \"core_xreference\":\"null\", \"asset_id\":\"asset_id\"}, \"special\": {\"parent_id\":\"parent_id\",\"lft\":\"lft\",\"rgt\":\"rgt\",\"level\":\"level\",\"path\":\"path\",\"extension\":\"extension\",\"note\":\"note\"}}','WeblinksHelperRoute::getCategoryRoute','{\"formFile\":\"administrator\\/components\\/com_categories\\/models\\/forms\\/category.xml\", \"hideFields\":[\"asset_id\",\"checked_out\",\"checked_out_time\",\"version\",\"lft\",\"rgt\",\"level\",\"path\",\"extension\"], \"ignoreChanges\":[\"modified_user_id\", \"modified_time\", \"checked_out\", \"checked_out_time\", \"version\", \"hits\", \"path\"],\"convertToInt\":[\"publish_up\", \"publish_down\"], \"displayLookup\":[{\"sourceColumn\":\"created_user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"access\",\"targetTable\":\"#__viewlevels\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"},{\"sourceColumn\":\"modified_user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"parent_id\",\"targetTable\":\"#__categories\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"}]}'),(10,'Tag','com_tags.tag','{\"special\":{\"dbtable\":\"#__tags\",\"key\":\"tag_id\",\"type\":\"Tag\",\"prefix\":\"TagsTable\",\"config\":\"array()\"},\"common\":{\"dbtable\":\"#__ucm_content\",\"key\":\"ucm_id\",\"type\":\"Corecontent\",\"prefix\":\"JTable\",\"config\":\"array()\"}}','','{\"common\":{\"core_content_item_id\":\"id\",\"core_title\":\"title\",\"core_state\":\"published\",\"core_alias\":\"alias\",\"core_created_time\":\"created_time\",\"core_modified_time\":\"modified_time\",\"core_body\":\"description\", \"core_hits\":\"hits\",\"core_publish_up\":\"null\",\"core_publish_down\":\"null\",\"core_access\":\"access\", \"core_params\":\"params\", \"core_featured\":\"featured\", \"core_metadata\":\"metadata\", \"core_language\":\"language\", \"core_images\":\"images\", \"core_urls\":\"urls\", \"core_version\":\"version\", \"core_ordering\":\"null\", \"core_metakey\":\"metakey\", \"core_metadesc\":\"metadesc\", \"core_catid\":\"null\", \"core_xreference\":\"null\", \"asset_id\":\"null\"}, \"special\": {\"parent_id\":\"parent_id\",\"lft\":\"lft\",\"rgt\":\"rgt\",\"level\":\"level\",\"path\":\"path\"}}','TagsHelperRoute::getTagRoute','{\"formFile\":\"administrator\\/components\\/com_tags\\/models\\/forms\\/tag.xml\", \"hideFields\":[\"checked_out\",\"checked_out_time\",\"version\", \"lft\", \"rgt\", \"level\", \"path\", \"urls\", \"publish_up\", \"publish_down\"],\"ignoreChanges\":[\"modified_user_id\", \"modified_time\", \"checked_out\", \"checked_out_time\", \"version\", \"hits\", \"path\"],\"convertToInt\":[\"publish_up\", \"publish_down\"], \"displayLookup\":[{\"sourceColumn\":\"created_user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"}, {\"sourceColumn\":\"access\",\"targetTable\":\"#__viewlevels\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"}, {\"sourceColumn\":\"modified_user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"}]}'),(11,'Banner','com_banners.banner','{\"special\":{\"dbtable\":\"#__banners\",\"key\":\"id\",\"type\":\"Banner\",\"prefix\":\"BannersTable\",\"config\":\"array()\"},\"common\":{\"dbtable\":\"#__ucm_content\",\"key\":\"ucm_id\",\"type\":\"Corecontent\",\"prefix\":\"JTable\",\"config\":\"array()\"}}','','{\"common\":{\"core_content_item_id\":\"id\",\"core_title\":\"name\",\"core_state\":\"published\",\"core_alias\":\"alias\",\"core_created_time\":\"created\",\"core_modified_time\":\"modified\",\"core_body\":\"description\", \"core_hits\":\"null\",\"core_publish_up\":\"publish_up\",\"core_publish_down\":\"publish_down\",\"core_access\":\"access\", \"core_params\":\"params\", \"core_featured\":\"null\", \"core_metadata\":\"metadata\", \"core_language\":\"language\", \"core_images\":\"images\", \"core_urls\":\"link\", \"core_version\":\"version\", \"core_ordering\":\"ordering\", \"core_metakey\":\"metakey\", \"core_metadesc\":\"metadesc\", \"core_catid\":\"catid\", \"core_xreference\":\"null\", \"asset_id\":\"null\"}, \"special\":{\"imptotal\":\"imptotal\", \"impmade\":\"impmade\", \"clicks\":\"clicks\", \"clickurl\":\"clickurl\", \"custombannercode\":\"custombannercode\", \"cid\":\"cid\", \"purchase_type\":\"purchase_type\", \"track_impressions\":\"track_impressions\", \"track_clicks\":\"track_clicks\"}}','','{\"formFile\":\"administrator\\/components\\/com_banners\\/models\\/forms\\/banner.xml\", \"hideFields\":[\"checked_out\",\"checked_out_time\",\"version\", \"reset\"],\"ignoreChanges\":[\"modified_by\", \"modified\", \"checked_out\", \"checked_out_time\", \"version\", \"imptotal\", \"impmade\", \"reset\"], \"convertToInt\":[\"publish_up\", \"publish_down\", \"ordering\"], \"displayLookup\":[{\"sourceColumn\":\"catid\",\"targetTable\":\"#__categories\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"}, {\"sourceColumn\":\"cid\",\"targetTable\":\"#__banner_clients\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"}, {\"sourceColumn\":\"created_by\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"modified_by\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"}]}'),(12,'Banners Category','com_banners.category','{\"special\":{\"dbtable\":\"#__categories\",\"key\":\"id\",\"type\":\"Category\",\"prefix\":\"JTable\",\"config\":\"array()\"},\"common\":{\"dbtable\":\"#__ucm_content\",\"key\":\"ucm_id\",\"type\":\"Corecontent\",\"prefix\":\"JTable\",\"config\":\"array()\"}}','','{\"common\":{\"core_content_item_id\":\"id\",\"core_title\":\"title\",\"core_state\":\"published\",\"core_alias\":\"alias\",\"core_created_time\":\"created_time\",\"core_modified_time\":\"modified_time\",\"core_body\":\"description\", \"core_hits\":\"hits\",\"core_publish_up\":\"null\",\"core_publish_down\":\"null\",\"core_access\":\"access\", \"core_params\":\"params\", \"core_featured\":\"null\", \"core_metadata\":\"metadata\", \"core_language\":\"language\", \"core_images\":\"null\", \"core_urls\":\"null\", \"core_version\":\"version\", \"core_ordering\":\"null\", \"core_metakey\":\"metakey\", \"core_metadesc\":\"metadesc\", \"core_catid\":\"parent_id\", \"core_xreference\":\"null\", \"asset_id\":\"asset_id\"}, \"special\": {\"parent_id\":\"parent_id\",\"lft\":\"lft\",\"rgt\":\"rgt\",\"level\":\"level\",\"path\":\"path\",\"extension\":\"extension\",\"note\":\"note\"}}','','{\"formFile\":\"administrator\\/components\\/com_categories\\/models\\/forms\\/category.xml\", \"hideFields\":[\"asset_id\",\"checked_out\",\"checked_out_time\",\"version\",\"lft\",\"rgt\",\"level\",\"path\",\"extension\"], \"ignoreChanges\":[\"modified_user_id\", \"modified_time\", \"checked_out\", \"checked_out_time\", \"version\", \"hits\", \"path\"], \"convertToInt\":[\"publish_up\", \"publish_down\"], \"displayLookup\":[{\"sourceColumn\":\"created_user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"access\",\"targetTable\":\"#__viewlevels\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"},{\"sourceColumn\":\"modified_user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"parent_id\",\"targetTable\":\"#__categories\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"}]}'),(13,'Banner Client','com_banners.client','{\"special\":{\"dbtable\":\"#__banner_clients\",\"key\":\"id\",\"type\":\"Client\",\"prefix\":\"BannersTable\"}}','','','','{\"formFile\":\"administrator\\/components\\/com_banners\\/models\\/forms\\/client.xml\", \"hideFields\":[\"checked_out\",\"checked_out_time\"], \"ignoreChanges\":[\"checked_out\", \"checked_out_time\"], \"convertToInt\":[], \"displayLookup\":[]}'),(14,'User Notes','com_users.note','{\"special\":{\"dbtable\":\"#__user_notes\",\"key\":\"id\",\"type\":\"Note\",\"prefix\":\"UsersTable\"}}','','','','{\"formFile\":\"administrator\\/components\\/com_users\\/models\\/forms\\/note.xml\", \"hideFields\":[\"checked_out\",\"checked_out_time\", \"publish_up\", \"publish_down\"],\"ignoreChanges\":[\"modified_user_id\", \"modified_time\", \"checked_out\", \"checked_out_time\"], \"convertToInt\":[\"publish_up\", \"publish_down\"],\"displayLookup\":[{\"sourceColumn\":\"catid\",\"targetTable\":\"#__categories\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"}, {\"sourceColumn\":\"created_user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"}, {\"sourceColumn\":\"user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"}, {\"sourceColumn\":\"modified_user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"}]}'),(15,'User Notes Category','com_users.category','{\"special\":{\"dbtable\":\"#__categories\",\"key\":\"id\",\"type\":\"Category\",\"prefix\":\"JTable\",\"config\":\"array()\"},\"common\":{\"dbtable\":\"#__ucm_content\",\"key\":\"ucm_id\",\"type\":\"Corecontent\",\"prefix\":\"JTable\",\"config\":\"array()\"}}','','{\"common\":{\"core_content_item_id\":\"id\",\"core_title\":\"title\",\"core_state\":\"published\",\"core_alias\":\"alias\",\"core_created_time\":\"created_time\",\"core_modified_time\":\"modified_time\",\"core_body\":\"description\", \"core_hits\":\"hits\",\"core_publish_up\":\"null\",\"core_publish_down\":\"null\",\"core_access\":\"access\", \"core_params\":\"params\", \"core_featured\":\"null\", \"core_metadata\":\"metadata\", \"core_language\":\"language\", \"core_images\":\"null\", \"core_urls\":\"null\", \"core_version\":\"version\", \"core_ordering\":\"null\", \"core_metakey\":\"metakey\", \"core_metadesc\":\"metadesc\", \"core_catid\":\"parent_id\", \"core_xreference\":\"null\", \"asset_id\":\"asset_id\"}, \"special\":{\"parent_id\":\"parent_id\",\"lft\":\"lft\",\"rgt\":\"rgt\",\"level\":\"level\",\"path\":\"path\",\"extension\":\"extension\",\"note\":\"note\"}}','','{\"formFile\":\"administrator\\/components\\/com_categories\\/models\\/forms\\/category.xml\", \"hideFields\":[\"checked_out\",\"checked_out_time\",\"version\",\"lft\",\"rgt\",\"level\",\"path\",\"extension\"], \"ignoreChanges\":[\"modified_user_id\", \"modified_time\", \"checked_out\", \"checked_out_time\", \"version\", \"hits\", \"path\"], \"convertToInt\":[\"publish_up\", \"publish_down\"], \"displayLookup\":[{\"sourceColumn\":\"created_user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"}, {\"sourceColumn\":\"access\",\"targetTable\":\"#__viewlevels\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"},{\"sourceColumn\":\"modified_user_id\",\"targetTable\":\"#__users\",\"targetColumn\":\"id\",\"displayColumn\":\"name\"},{\"sourceColumn\":\"parent_id\",\"targetTable\":\"#__categories\",\"targetColumn\":\"id\",\"displayColumn\":\"title\"}]}')
Table 'ecweb_2016b.#__content_types' doesn't exist SQL=/*!40000 ALTER TABLE `#__content_types` DISABLE KEYS */
Table 'ecweb_2016b.#__content_types' doesn't exist SQL=LOCK TABLES `#__content_types` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__content_types` ( `type_id` int(10) unsigned NOT NULL AUTO_INCREMENT, `type_title` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `type_alias` varchar(400) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `table` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `rules` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `field_mappings` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `router` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `content_history_options` varchar(5120) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'JSON string for com_contenthistory options', PRIMARY KEY (`type_id`), KEY `idx_alias` (`type_alias`(100)) ) ENGINE=InnoDB AUTO_INCREMENT=16 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__content_rating' doesn't exist SQL=/*!40000 ALTER TABLE `#__content_rating` ENABLE KEYS */
Table 'ecweb_2016b.#__content_rating' doesn't exist SQL=INSERT INTO `#__content_rating` VALUES (24,5,1,'127.0.0.1')
Table 'ecweb_2016b.#__content_rating' doesn't exist SQL=/*!40000 ALTER TABLE `#__content_rating` DISABLE KEYS */
Table 'ecweb_2016b.#__content_rating' doesn't exist SQL=LOCK TABLES `#__content_rating` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__content_rating` ( `content_id` int(11) NOT NULL DEFAULT '0', `rating_sum` int(10) unsigned NOT NULL DEFAULT '0', `rating_count` int(10) unsigned NOT NULL DEFAULT '0', `lastip` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', PRIMARY KEY (`content_id`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__content_frontpage' doesn't exist SQL=/*!40000 ALTER TABLE `#__content_frontpage` ENABLE KEYS */
Table 'ecweb_2016b.#__content_frontpage' doesn't exist SQL=INSERT INTO `#__content_frontpage` VALUES (78,2),(101,1)
Table 'ecweb_2016b.#__content_frontpage' doesn't exist SQL=/*!40000 ALTER TABLE `#__content_frontpage` DISABLE KEYS */
Table 'ecweb_2016b.#__content_frontpage' doesn't exist SQL=LOCK TABLES `#__content_frontpage` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__content_frontpage` ( `content_id` int(11) NOT NULL DEFAULT '0', `ordering` int(11) NOT NULL DEFAULT '0', PRIMARY KEY (`content_id`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__content' doesn't exist SQL=/*!40000 ALTER TABLE `#__content` ENABLE KEYS */
Table 'ecweb_2016b.#__content' doesn't exist SQL=INSERT INTO `#__content` VALUES (9,105,'Contacts','contact','
The contact component provides a way to provide contact forms and information for your site or to create a complex directory that can be used for many different purposes. Help
','',-2,21,'2011-01-01 00:00:01',879,'Joomla!','2011-01-10 04:15:37',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\"}',2,2,'','',1,3,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(10,106,'Content','content','
The content component (com_content) is what you use to write articles. It is extremely flexible and has the largest number of built in views. Articles can be created and edited from the front end, making content the easiest component to use to create your site content. Help
','',-2,21,'2011-01-01 00:00:01',879,'','2011-01-10 04:28:12',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\"}',2,1,'','',1,5,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(11,107,'Cradle Mountain','cradle-mountain','
\r\n','\r\n
',-2,73,'2011-01-01 00:00:01',879,'Parks Webmaster','2012-01-17 04:42:36',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"images\\/sampledata\\/parks\\/landscape\\/250px_cradle_mountain_seen_from_barn_bluff.jpg\",\"float_intro\":\"\",\"image_intro_alt\":\"Cradle Mountain\",\"image_intro_caption\":\"\",\"image_fulltext\":\"images\\/sampledata\\/parks\\/landscape\\/800px_cradle_mountain_seen_from_barn_bluff.jpg\",\"float_fulltext\":\"none\",\"image_fulltext_alt\":\"Cradle Mountain\",\"image_fulltext_caption\":\"Source: http:\\/\\/commons.wikimedia.org\\/wiki\\/File:Rainforest,bluemountainsNSW.jpg Author: Alan J.W.C. License: GNU Free Documentation License v . 1.2 or later\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',4,1,'','',1,1,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(12,110,'Custom HTML Module','custom-html-module','
This module allows you to create your own HTML Module using a WYSIWYG editor. Help
\r\n
{loadmodule custom,Custom HTML}
','',-2,66,'2011-01-01 00:00:01',879,'','2011-12-27 11:12:46',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',13,1,'','',1,13,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(13,111,'Directions','directions','
Here\'s how to find our shop.
By car
Drive along Main Street to the intersection with First Avenue. Look for our sign.
By foot
From the center of town, walk north on Main Street until you see our sign.
By bus
Take the #73 Bus to the last stop. We are on the north east corner.
','',-2,29,'2011-01-01 00:00:01',879,'Fruit Shop Webmaster','2011-01-01 00:00:01',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',1,2,'','',1,0,'',0,'*',''),(14,112,'Editors','editors','
Editors are used thoughout Joomla! where content is created. TinyMCE is the default choice in most locations although CodeMirror is used in the template manager. No Editor provides a text box for html content.
\r\n
Default on:
\r\n
\r\n
CodeMirror Help
\r\n
TinyMCE Help
\r\n
No Editor Help
\r\n
\r\n
Default off:
\r\n
\r\n
None
\r\n
','',-2,25,'2011-01-01 00:00:01',879,'Joomla!','2011-09-06 05:45:40',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',2,5,'','',1,0,'',0,'*',''),(15,113,'Editors-xtd','editors-xtd','
These plugins are the buttons found beneath your editor. They only run when an editor plugin runs.
\r\n
Default on:
\r\n
\r\n
Editor Button: Image Help
\r\n
Editor Button: Readmore Help
\r\n
Editor Button: Page Break Help
\r\n
Editor Button: Article Help
\r\n
\r\n
Default off:
\r\n
\r\n
None
\r\n
','',-2,25,'2011-01-01 00:00:01',879,'Joomla!','2011-12-27 11:14:12',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',4,6,'','',1,1,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(16,114,'Feed Display','feed-display','
This module allows the displaying of a syndicated feed. Help
\r\n
{loadmodule feed,Feed Display}
','',-2,66,'2011-01-01 00:00:01',879,'','2011-09-17 22:22:08',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',3,2,'','',1,3,'',0,'*',''),(17,115,'First Blog Post','first-blog-post','
Lorem Ipsum is filler text that is commonly used by designers before the content for a new site is ready.
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Sed faucibus purus vitae diam posuere nec eleifend elit dictum. Aenean sit amet erat purus, id fermentum lorem. Integer elementum tristique lectus, non posuere quam pretium sed. Quisque scelerisque erat at urna condimentum euismod. Fusce vestibulum facilisis est, a accumsan massa aliquam in. In auctor interdum mauris a luctus. Morbi euismod tempor dapibus. Duis dapibus posuere quam. Pellentesque habitant morbi tristique senectus et netus et malesuada fames ac turpis egestas. In eu est nec erat sollicitudin hendrerit. Pellentesque sed turpis nunc, sit amet laoreet velit. Praesent vulputate semper nulla nec varius. Aenean aliquam, justo at blandit sodales, mauris leo viverra orci, sed sodales mauris orci vitae magna.
Quisque a massa sed libero tristique suscipit. Morbi tristique molestie metus, vel vehicula nisl ultrices pretium. Sed sit amet est et sapien condimentum viverra. Pellentesque habitant morbi tristique senectus et netus et malesuada fames ac turpis egestas. Phasellus viverra tortor porta orci convallis ac cursus erat sagittis. Vivamus aliquam, purus non luctus adipiscing, orci urna imperdiet eros, sed tincidunt neque sapien et leo. Cras fermentum, dolor id tempor vestibulum, neque lectus luctus mauris, nec congue tellus arcu nec augue. Nulla quis mi arcu, in bibendum quam. Sed placerat laoreet fermentum. In varius lobortis consequat. Proin vulputate felis ac arcu lacinia adipiscing. Morbi molestie, massa id sagittis luctus, sem sapien sollicitudin quam, in vehicula quam lectus quis augue. Integer orci lectus, bibendum in fringilla sit amet, rutrum eget enim. Curabitur at libero vitae lectus gravida luctus. Nam mattis, ligula sit amet vestibulum feugiat, eros sem sodales mi, nec dignissim ante elit quis nisi. Nulla nec magna ut leo convallis sagittis ac non erat. Etiam in augue nulla, sed tristique orci. Vestibulum quis eleifend sapien.
Nam ut orci vel felis feugiat posuere ut eu lorem. In risus tellus, sodales eu eleifend sed, imperdiet id nulla. Nunc at enim lacus. Etiam dignissim, arcu quis accumsan varius, dui dui faucibus erat, in molestie mauris diam ac lacus. Sed sit amet egestas nunc. Nam sollicitudin lacinia sapien, non gravida eros convallis vitae. Integer vehicula dui a elit placerat venenatis. Nullam tincidunt ligula aliquet dui interdum feugiat. Maecenas ultricies, lacus quis facilisis vehicula, lectus diam consequat nunc, euismod eleifend metus felis eu mauris. Aliquam dapibus, ipsum a dapibus commodo, dolor arcu accumsan neque, et tempor metus arcu ut massa. Curabitur non risus vitae nisl ornare pellentesque. Pellentesque nec ipsum eu dolor sodales aliquet. Vestibulum egestas scelerisque tincidunt. Integer adipiscing ultrices erat vel rhoncus.
Integer ac lectus ligula. Nam ornare nisl id magna tincidunt ultrices. Phasellus est nisi, condimentum at sollicitudin vel, consequat eu ipsum. In venenatis ipsum in ligula tincidunt bibendum id et leo. Vivamus quis purus massa. Ut enim magna, pharetra ut condimentum malesuada, auctor ut ligula. Proin mollis, urna a aliquam rutrum, risus erat cursus odio, a convallis enim lectus ut lorem. Nullam semper egestas quam non mattis. Vestibulum venenatis aliquet arcu, consectetur pretium erat pulvinar vel. Vestibulum in aliquet arcu. Ut dolor sem, pellentesque sit amet vestibulum nec, tristique in orci. Sed lacinia metus vel purus pretium sit amet commodo neque condimentum.
Aenean laoreet aliquet ullamcorper. Nunc tincidunt luctus tellus, eu lobortis sapien tincidunt sed. Donec luctus accumsan sem, at porttitor arcu vestibulum in. Sed suscipit malesuada arcu, ac porttitor orci volutpat in. Vestibulum consectetur vulputate eros ut porttitor. Aenean dictum urna quis erat rutrum nec malesuada tellus elementum. Quisque faucibus, turpis nec consectetur vulputate, mi enim semper mi, nec porttitor libero magna ut lacus. Quisque sodales, leo ut fermentum ullamcorper, tellus augue gravida magna, eget ultricies felis dolor vitae justo. Vestibulum blandit placerat neque, imperdiet ornare ipsum malesuada sed. Quisque bibendum quam porta diam molestie luctus. Sed metus lectus, ornare eu vulputate vel, eleifend facilisis augue. Maecenas eget urna velit, ac volutpat velit. Nam id bibendum ligula. Donec pellentesque, velit eu convallis sodales, nisi dui egestas nunc, et scelerisque lectus quam ut ipsum.
',-2,27,'2011-01-01 00:00:01',879,'','2011-01-01 00:00:01',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',1,2,'','',1,0,'',0,'*',''),(18,116,'Second Blog Post','second-blog-post','
Lorem Ipsum is text that is traditionally used by designers when working on a site before the content is ready.
Pellentesque bibendum metus ut dolor fermentum ut pulvinar tortor hendrerit. Nam vel odio vel diam tempus iaculis in non urna. Curabitur scelerisque, nunc id interdum vestibulum, felis elit luctus dui, ac dapibus tellus mauris tempus augue. Duis congue facilisis lobortis. Phasellus neque erat, tincidunt non lacinia sit amet, rutrum vitae nunc. Sed placerat lacinia fermentum. Integer justo sem, cursus id tristique eget, accumsan vel sapien. Curabitur ipsum neque, elementum vel vestibulum ut, lobortis a nisl. Fusce malesuada mollis purus consectetur auctor. Morbi tellus nunc, dapibus sit amet rutrum vel, laoreet quis mauris. Aenean nec sem nec purus bibendum venenatis. Mauris auctor commodo libero, in adipiscing dui adipiscing eu. Praesent eget orci ac nunc sodales varius.
Nam eget venenatis lorem. Vestibulum a interdum sapien. Suspendisse potenti. Quisque auctor purus nec sapien venenatis vehicula malesuada velit vehicula. Fusce vel diam dolor, quis facilisis tortor. Class aptent taciti sociosqu ad litora torquent per conubia nostra, per inceptos himenaeos. Pellentesque libero nisi, pellentesque quis cursus sit amet, vehicula vitae nisl. Curabitur nec nunc ac sem tincidunt auctor. Phasellus in mattis magna. Donec consequat orci eget tortor ultricies rutrum. Mauris luctus vulputate molestie. Proin tincidunt vehicula euismod. Nam congue leo non erat cursus a adipiscing ipsum congue. Nulla iaculis purus sit amet turpis aliquam sit amet dapibus odio tincidunt. Ut augue diam, congue ut commodo pellentesque, fermentum mattis leo. Sed iaculis urna id enim dignissim sodales at a ipsum. Quisque varius lobortis mollis. Nunc purus magna, pellentesque pellentesque convallis sed, varius id ipsum. Etiam commodo mi mollis erat scelerisque fringilla. Nullam bibendum massa sagittis diam ornare rutrum.
Praesent convallis metus ut elit faucibus tempus in quis dui. Donec fringilla imperdiet nibh, sit amet fringilla velit congue et. Quisque commodo luctus ligula, vitae porttitor eros venenatis in. Praesent aliquet commodo orci id varius. Nulla nulla nibh, varius id volutpat nec, sagittis nec eros. Cras et dui justo. Curabitur malesuada facilisis neque, sed tempus massa tincidunt ut. Sed suscipit odio in lacus auctor vehicula non ut lacus. In hac habitasse platea dictumst. Sed nulla nisi, lacinia in viverra at, blandit vel tellus. Nulla metus erat, ultrices non pretium vel, varius nec sem. Morbi sollicitudin mattis lacus quis pharetra. Donec tincidunt mollis pretium. Proin non libero justo, vitae mattis diam. Integer vel elit in enim varius posuere sed vitae magna. Duis blandit tempor elementum. Vestibulum molestie dui nisi.
Curabitur volutpat interdum lorem sed tempus. Sed placerat quam non ligula lacinia sodales. Cras ultrices justo at nisi luctus hendrerit. Quisque sit amet placerat justo. In id sapien eu neque varius pharetra sed in sapien. Etiam nisl nunc, suscipit sed gravida sed, scelerisque ut nisl. Mauris quis massa nisl, aliquet posuere ligula. Etiam eget tortor mauris. Sed pellentesque vestibulum commodo. Mauris vitae est a libero dapibus dictum fringilla vitae magna.
Nulla facilisi. Praesent eget elit et mauris gravida lobortis ac nec risus. Ut vulputate ullamcorper est, volutpat feugiat lacus convallis non. Maecenas quis sem odio, et aliquam libero. Integer vel tortor eget orci tincidunt pulvinar interdum at erat. Integer ullamcorper consequat eros a pellentesque. Cras sagittis interdum enim in malesuada. Etiam non nunc neque. Fusce non ligula at tellus porta venenatis. Praesent tortor orci, fermentum sed tincidunt vel, varius vel dui. Duis pulvinar luctus odio, eget porta justo vulputate ac. Nulla varius feugiat lorem sed tempor. Phasellus pulvinar dapibus magna eget egestas. In malesuada lectus at justo pellentesque vitae rhoncus nulla ultrices. Proin ut sem sem. Donec eu suscipit ipsum. Cras eu arcu porttitor massa feugiat aliquet at quis nisl.
',-2,27,'2011-01-01 00:00:01',879,'','2011-01-01 00:00:01',0,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',1,1,'','',1,0,'',0,'*',''),(19,117,'Footer Module','footer-module','
This module shows the Joomla! copyright information. Help
\r\n
{loadmodule footer,Footer}
','',-2,66,'2011-01-01 00:00:01',879,'Joomla!','2011-09-17 22:22:47',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',4,3,'','',1,4,'',0,'*',''),(20,118,'Fruit Shop','fruit-shop','
Welcome to the Fruit Shop
\r\n
We sell fruits from around the world. Please use our website to learn more about our business. We hope you will come to our shop and buy some fruit.
\r\n
This mini site will show you how you might want to set up a site for a business, in this example one selling fruit. It shows how to use access controls to manage your site content. If you were building a real site, you might want to extend it with e-commerce, a catalog, mailing lists or other enhancements, many of which are available through the Joomla! Extensions Directory.
\r\n
To understand this site you will probably want to make one user with group set to customer and one with group set to grower. By logging in with different privileges you can see how access control works.
','',-2,29,'2011-01-01 00:00:01',879,'Fruit Shop Webmaster','2011-12-27 11:17:59',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',2,1,'','',1,0,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(21,119,'Getting Help','getting-help','
There are lots of places you can get help with Joomla!. In many places in your site administrator you will see the help icon. Click on this for more information about the options and functions of items on your screen. Other places to get help are:
\r\n
\r\n
Support Forums
\r\n
Documentation
\r\n
Professionals
\r\n
Books
\r\n
','',-2,19,'2011-01-01 00:00:01',879,'Joomla!','2011-01-10 15:32:54',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',10,8,'','',1,27,'',0,'*',''),(22,120,'Getting Started','getting-started','
It\'s easy to get started creating your website. Knowing some of the basics will help.
\r\n
What is a Content Management System?
\r\n
A content management system is software that allows you to create and manage webpages easily by separating the creation of your content from the mechanics required to present it on the web.
\r\n
In this site, the content is stored in a database. The look and feel are created by a template. The Joomla! software brings together the template and the content to create web pages.
\r\n
Site and Administrator
\r\n
Your site actually has two separate sites. The site (also called the front end) is what visitors to your site will see. The administrator (also called the back end) is only used by people managing your site. You can access the administrator by clicking the \"Site Administrator\" link on the \"This Site\" menu or by adding /administrator to the end of you domain name.
\r\n
Log in to the administrator using the username and password created during the installation of Joomla.
\r\n
Logging in
\r\n
To login to the front end of your site use the login form or the login menu link on the \"This Site\" menu. Use the user name and password that were created as part of the installation process. Once logged-in you will be able to create and edit articles.
\r\n
In managing your site, you will be able to create content that only logged-in users are able to see.
\r\n
Creating an article
\r\n
Once you are logged-in, a new menu will be visible. To create a new article, click on the \"submit article\" link on that menu.
\r\n
The new article interface gives you a lot of options, but all you need to do is add a title and put something in the content area. To make it easy to find, set the state to published and put it in the Joomla category.
\r\n
You can edit an existing article by clicking on the edit icon (this only displays to users who have the right to edit).
\r\n
Learn more
\r\n
There is much more to learn about how to use Joomla! to create the web site you envision. You can learn much more at the Joomla! documentation site and on the Joomla! forums.
','',-2,19,'2011-01-01 00:00:01',879,'Joomla!','2011-12-27 11:21:44',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',2,9,'','',1,1,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(23,121,'Happy Orange Orchard','happy-orange-orchard','
At our orchard we grow the world\'s best oranges as well as other citrus fruit such as lemons and grapefruit. Our family has been tending this orchard for generations.
','',-2,30,'2011-01-01 00:00:01',879,'Fruit Shop Webmaster','2011-01-01 00:00:01',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',1,2,'','',1,0,'',0,'*',''),(25,123,'Koala','koala','
\r\n
\r\n
\r\n
\r\n
\r\n','\r\n
',-2,72,'2011-01-01 00:00:01',879,'Parks Webmaster','2012-01-17 05:15:00',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"images\\/sampledata\\/parks\\/animals\\/180px_koala_ag1.jpg\",\"float_intro\":\"\",\"image_intro_alt\":\"Koala Thumbnail\",\"image_intro_caption\":\"\",\"image_fulltext\":\"images\\/sampledata\\/parks\\/animals\\/800px_koala_ag1.jpg\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"Koala Climbing Tree\",\"image_fulltext_caption\":\"Source: http:\\/\\/commons.wikimedia.org\\/wiki\\/File:Koala-ag1.jpg Author: Arnaud Gaillard License: Creative Commons Share Alike Attribution Generic 1.0\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',9,2,'','',1,2,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(26,124,'Language Switcher','language-switcher','
The language switcher module allows you to take advantage of the language tags that are available when content, modules and menu links are created.
\r\n
This module displays a list of available Content Languages for switching between them.
\r\n
When switching languages, it redirects to the Home page, or associated menu item, defined for the chosen language. Thereafter, the navigation will be the one defined for that language.
\r\n
The language filter plugin must be enabled for this module to work properly.
\r\n
Help
\r\n
To view an example of the language switch moduler module, go to the site administrator and enable the language filter plugin and the language switcher module labelled \"language switcher\" and visit the fruit shop or park sample sites. Then follow the instructions in this tutorial.
','',-2,67,'2011-01-01 00:00:01',879,'Joomla!','2011-12-27 11:25:00',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',3,3,'','',1,3,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(27,125,'Latest Articles Module','latest-articles-module','
This module shows a list of the most recently published and current Articles. Some that are shown may have expired even though they are the most recent. Help
\r\n
{loadmodule articles_latest,Latest News}
','',-2,64,'2011-01-01 00:00:01',879,'','2011-12-27 11:25:41',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',9,1,'modules, content','',1,15,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(28,126,'Login Module','login-module','
This module displays a username and password login form. It also displays a link to retrieve a forgotten password. If user registration is enabled (in the Global Configuration settings), another link will be shown to enable self-registration for users. Help
\r\n
{loadmodule login,login}
','',-2,65,'2011-01-01 00:00:01',879,'Joomla!','2011-09-17 22:20:35',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',4,2,'','',1,5,'',0,'*',''),(29,127,'Menu Module','menu-module','
This module displays a menu on the site (frontend). Menus can be displayed in a wide variety of ways by using the menu options and css menu styles. Help
\r\n
{loadmodule mod_menu,Menu Example}
','',-2,75,'2011-01-01 00:00:01',879,'Joomla!','2011-09-17 22:18:45',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',8,1,'','',1,12,'',0,'*',''),(30,128,'Most Read Content','most-read-content','
This module shows a list of the currently published Articles which have the highest number of page views. Help
\r\n
{loadmodule articles_popular,Articles Most Read}
','',-2,64,'2011-01-01 00:00:01',879,'Joomla!','2011-12-27 11:26:41',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',6,2,'modules, content','',1,10,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(31,129,'News Flash','news-flash','
Displays a set number of articles from a category based on date or random selection. Help
\r\n
{loadmodule articles_news,News Flash}
','',-2,64,'2011-01-01 00:00:01',879,'','2011-09-17 22:16:46',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',4,3,'modules, content','',1,10,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(32,130,'Options','options','
As you make your Joomla! site you will control the details of the display using options also referred to as parameters. Options control everything from whether the author\'s name is displayed to who can view what to the number of items shown on a list.
\r\n','\r\n
Default options for each component are changed using the Options button on the component toolbar.
\r\n
Options can also be set on an individual item, such as an article or contact and in menu links.
\r\n
If you are happy with how your site looks, it is fine to leave all of the options set to the defaults that were created when your site was installed. As you become more experienced with Joomla you will use options more.
\r\n
',-2,19,'2011-01-01 00:00:01',879,'Joomla!','2012-02-22 21:39:35',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":null,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":null,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":null,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',6,10,'','',1,3,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(33,131,'Phyllopteryx','phyllopteryx','
\r\n','\r\n
',-2,72,'2011-01-01 00:00:01',879,'Parks Webmaster','2012-01-17 04:57:58',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"images\\/sampledata\\/parks\\/animals\\/200px_phyllopteryx_taeniolatus1.jpg\",\"float_intro\":\"\",\"image_intro_alt\":\"Phyllopteryx\",\"image_intro_caption\":\"\",\"image_fulltext\":\"images\\/sampledata\\/parks\\/animals\\/800px_phyllopteryx_taeniolatus1.jpg\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"Phyllopteryx\",\"image_fulltext_caption\":\"Source: http:\\/\\/en.wikipedia.org\\/wiki\\/File:Phyllopteryx_taeniolatus1.jpg Author: Richard Ling License: GNU Free Documentation License v 1.2 or later\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',2,3,'','',1,0,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(34,132,'Pinnacles','pinnacles','
\r\n','\r\n
',-2,73,'2011-01-01 00:00:01',879,'Parks Webmaster','2012-01-17 04:41:30',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"images\\/sampledata\\/parks\\/landscape\\/120px_pinnacles_western_australia.jpg\",\"float_intro\":\"\",\"image_intro_alt\":\"Kings Canyon\",\"image_intro_caption\":\"\",\"image_fulltext\":\"images\\/sampledata\\/parks\\/landscape\\/800px_pinnacles_western_australia.jpg\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"Kings Canyon\",\"image_fulltext_caption\":\"Source: http:\\/\\/commons.wikimedia.org\\/wiki\\/File:Pinnacles_Western_Australia.jpg Author: Martin Gloss License: GNU Free Documentation license v 1.2 or later.\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',3,4,'','',1,3,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(35,133,'Professionals','professionals','
Joomla! 2.5 continues development of the Joomla Framework and CMS as a powerful and flexible way to bring your vision of the web to reality. With the administrator now fully MVC, the ability to control its look and the management of extensions is now complete.
\r\n','\r\n
Working with multiple template styles and overrides for the same views, creating the design you want is easier than it has ever been. Limiting support to PHP 5.2.4 and above makes Joomla lighter and faster than ever. Languages files can now be overridden without having your changes lost during an upgrade. With the proper xml your users update extensions with a single click.
\r\n
Access control lists are now incorporated using a new system developed for Joomla. The ACL system is designed with developers in mind, so it is easy to incorporate into your extensions. The new nested sets libraries allow you to incorporate infinitely deep categories but also to use nested sets in a variety of other ways.
\r\n
A new forms library makes creating all kinds of user interaction simple. MooTools 1.3 provides a highly flexible javascript framework that is a major advance over MooTools 1.0.
\r\n
New events throughout the core make integration of your plugins where you want them a snap.
\r\n
The separation of the Joomla! Platform project from the Joomla! CMS project makes continuous development of new, powerful APIs and continuous improvement of existing APIs possible while maintaining the stability of the CMS that millions of webmasters and professionals rely upon.
\r\n
Learn about:
\r\n
\r\n
Changes since 1.5
\r\n
Working with ACL
\r\n
Working with nested categories
\r\n
Forms library
\r\n
Working with Mootools 1.3
\r\n
Using new features of the override system
\r\n
Joomla! API
\r\n
Using JDatabaseQuery
\r\n
New and updated events
\r\n
Xmlrpc
\r\n
Installing and updating extensions
\r\n
Setting up your development environment
\r\n
The Joomla! Platform Repository
\r\n
',-2,19,'2011-01-01 00:00:01',879,'Joomla!','2012-04-16 17:29:50',42,0,'0000-00-00 00:00:00','2011-01-09 16:41:13','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"right\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"images\\/filler4.jpg\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":null,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":null,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":null,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',20,5,'','',1,10,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(36,134,'Random Image Module','random-image-module','
This module displays a random image from your chosen image directory. Help
\r\n
{loadmodule random_image,Random Image}
','',-2,66,'2011-01-01 00:00:01',879,'','2012-01-17 16:11:13',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',6,4,'','',1,6,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(37,135,'Related Items Module','related-items-module','
This module displays other Articles that are related to the one currently being viewed. These relations are established by the Meta Keywords. All the keywords of the current Article are searched against all the keywords of all other published articles. Help
\r\n
{loadmodule related_items,Articles Related Items}
','',-2,64,'2011-01-01 00:00:01',879,'Joomla!','2011-12-27 11:37:34',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',5,4,'modules, content','',1,5,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(38,136,'Sample Sites','sample-sites','
Your installation includes sample data, designed to show you some of the options you have for building your website. In addition to information about Joomla! there are two sample \"sites within a site\" designed to help you get started with building your own site.
\r\n
The first site is a simple site about Australian Parks. It shows how you can quickly and easily build a personal site with just the building blocks that are part of Joomla. It includes a personal blog, weblinks, and a very simple image gallery.
\r\n','\r\n
The second site is slightly more complex and represents what you might do if you are building a site for a small business, in this case a Fruit Shop.
\r\n
In building either style site, or something completely different, you will probably want to add extensions and either create or purchase your own template. Many Joomla users start by modifying the templates that come with the core distribution so that they include special images and other design elements that relate to their site\'s focus.
',-2,19,'2011-01-01 00:00:01',879,'Joomla!','2012-02-22 21:39:59',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":null,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":null,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":null,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',4,11,'','',1,78,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(39,137,'Search','search-component','
Joomla! 2.5 offers two search options.
\r\n
The Basic Search component provides basic search functionality for the information contained in your core components. Many extensions can also be searched by the search component. Help
\r\n
The Smart Search component offers searching similar to that found in major search engines. Smart Search is disabled by default. If you choose to enable it you will need to take several steps. First, enable the Smart Search Plugin in the plugin manager. Then, if you are using the Basic Search Module replace it with the Smart Search Module. Finally, if you have already created content, go to the Smart Search component in your site administrator and click the Index icon. Once indexing of your content is complete, Smart Search will be ready to use. Help.
','',-2,21,'2011-01-01 00:00:01',879,'Joomla!','2011-12-27 11:41:48',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',4,3,'','',1,3,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(40,138,'Search Module','search-module','
This module will display a search box. Help
\r\n
{loadmodule search,Search}
','',-2,67,'2011-01-01 00:00:01',879,'Joomla!','2011-09-17 22:35:56',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',4,4,'','',1,6,'',0,'*',''),(41,139,'Search ','search-plugin','
The search component uses plugins to control which parts of your Joomla! site are searched. You may choose to turn off some areas to improve performance or for other reasons. Many third party Joomla! extensions have search plugins that extend where search takes place.
\r\n
Default On:
\r\n
\r\n
Content Help
\r\n
Contacts Help
\r\n
Weblinks Help
\r\n
News Feeds Help
\r\n
Categories Help
\r\n
','',-2,25,'2011-01-01 00:00:01',879,'Joomla!','2011-09-06 06:13:18',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',3,1,'','',1,0,'',0,'*',''),(42,140,'Site Map','site-map','
{loadposition sitemapload}
By putting all of your content into nested categories you can give users and search engines access to everything using a menu.
','',-2,14,'2011-01-01 00:00:01',879,'Joomla!','2011-01-01 00:00:01',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',1,1,'','',1,0,'',0,'*',''),(43,141,'Spotted Quoll','spotted-quoll','
\r\n
\r\n','\r\n
',-2,72,'2011-01-01 00:00:01',879,'Parks Webmaster','2012-01-17 05:02:58',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"images\\/sampledata\\/parks\\/animals\\/220px_spottedquoll_2005_seanmcclean.jpg\",\"float_intro\":\"\",\"image_intro_alt\":\"Spotted Quoll\",\"image_intro_caption\":\"\",\"image_fulltext\":\"images\\/sampledata\\/parks\\/animals\\/789px_spottedquoll_2005_seanmcclean.jpg\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"Spotted Quoll\",\"image_fulltext_caption\":\"Source: http:\\/\\/en.wikipedia.org\\/wiki\\/File:SpottedQuoll_2005_SeanMcClean.jpg Author: Sean McClean License: GNU Free Documentation License v 1.2 or later\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',4,4,'','',1,0,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(44,142,'Statistics Module','statistics','
This module shows information about your server installation together with statistics on the Web site users, number of Articles in your database and the number of Web links you provide.
\r\n
{loadmodule mod_stats,Statistics}
','',-2,67,'2011-01-01 00:00:01',879,'Joomla!','2011-12-27 11:43:25',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',6,5,'','',1,5,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(45,143,'Syndicate Module','syndicate-module','
The syndicate module will display a link that allows users to take a feed from your site. It will only display on pages for which feeds are possible. That means it will not display on single article, contact or weblinks pages, such as this one. Help
\r\n
{loadposition syndicate,Syndicate}
','',-2,67,'2011-01-01 00:00:01',879,'','2011-12-27 11:44:16',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',3,6,'','',1,2,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(46,144,'System','system','
System plugins operate every time a page on your site loads. They control such things as your URLS, whether users can check a \"remember me\" box on the login module, and whether caching is enabled. New is the redirect plugin that together with the redirect component will assist you in managing changes in URLs.
\r\n
Default on:
\r\n
\r\n
Remember me Help
\r\n
SEF Help
\r\n
Debug Help
\r\n
\r\n
Default off:
\r\n
\r\n
Cache Help
\r\n
Log Help
\r\n
Redirect Help
\r\n
','',-2,25,'2011-01-01 00:00:01',879,'Joomla!','2011-12-27 11:45:54',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',5,2,'','',1,1,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(47,145,'The Joomla! Community','the-joomla-community','
Joomla means All Together, and it is a community of people all working and having fun together that makes Joomla possible. Thousands of people each year participate in the Joomla community, and we hope you will be one of them.
\r\n
People with all kinds of skills, of all skill levels and from around the world are welcome to join in. Participate in the Joomla.org family of websites (the forum is a great place to start). Come to a Joomla! event. Join or start a Joomla! Users Group. Whether you are a developer, site administrator, designer, end user or fan, there are ways for you to participate and contribute.
','',-2,19,'2011-01-01 00:00:01',879,'Joomla!','2011-12-27 11:47:56',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',3,3,'','',1,0,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(48,146,'The Joomla! Project','the-joomla-project','
The Joomla Project consists of all of the people who make and support the Joomla Web Platform and Content Management System.
\r\n
Our mission is to provide a flexible platform for digital publishing and collaboration.
\r\n
The core values are:
\r\n
\r\n
Freedom
\r\n
Equality
\r\n
Trust
\r\n
Community
\r\n
Collaboration
\r\n
Usability
\r\n
\r\n
In our vision, we see:
\r\n
\r\n
People publishing and collaborating in their communities and around the world
\r\n
Software that is free, secure, and high-quality
\r\n
A community that is enjoyable and rewarding to participate in
\r\n
People around the world using their preferred languages
\r\n
A project that acts autonomously
\r\n
A project that is socially responsible
\r\n
A project dedicated to maintaining the trust of its users
\r\n
\r\n
There are millions of users around the world and thousands of people who contribute to the Joomla Project. They work in three main groups: the Production Working Group, responsible for everything that goes into software and documentation; the Community Working Group, responsible for creating a nurturing the community; and Open Source Matters, the non profit organization responsible for managing legal, financial and organizational issues.
\r\n
Joomla is a free and open source project, which uses the GNU General Public License version 2 or later.
','',-2,19,'2011-01-01 00:00:01',879,'','2011-12-27 11:47:48',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',2,1,'','',1,1,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(49,147,'Typography','typography','
H1 ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmonpqrstuvwzyz
H2 ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmonpqrstuvwzyz
H3 ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmonpqrstuvwzyz
H4 ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmonpqrstuvwzyz
H5 ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmonpqrstuvwzyz
H6 ABCDEFGHIJKLMNOPQRSTUVWXYZ abcdefghijklmonpqrstuvwzyz
P The quick brown fox ran over the lazy dog. THE QUICK BROWN FOX RAN OVER THE LAZY DOG.
Item
Item
Item
Item
Item
Item
Item
Item
Item
tem
Item
Item
Item
Item
Item
Item
Item
Item
','',-2,23,'2011-01-01 00:00:01',879,'Joomla!','2011-01-01 00:00:01',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',1,1,'','',1,0,'',0,'*',''),(50,148,'Upgraders','upgraders','
If you are an experienced Joomla! 1.5 user, this Joomla site will seem very familiar. There are new templates and improved user interfaces, but most functionality is the same. The biggest changes are improved access control (ACL) and nested categories. This release of Joomla has strong continuity with Joomla! 1.7 while adding enhancements.
\r\n','\r\n
The new user manager will let you manage who has access to what in your site. You can leave access groups exactly the way you had them in Joomla 1.5 or make them as complicated as you want. You can learn more about how access control works in on the Joomla! Documentation site
\r\n
In Joomla 1.5 and 1.0 content was organized into sections and categories. From 1.6 forward sections are gone, and you can create categories within categories, going as deep as you want. The sample data provides many examples of the use of nested categories.
\r\n
All layouts have been redesigned to improve accessibility and flexibility.
\r\n
Updating your site and extensions when needed is easier than ever thanks to installer improvements.
\r\n
',-2,19,'2011-01-01 00:00:01',879,'','2012-01-17 04:28:10',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',5,6,'','',1,7,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(51,149,'User','user-plugins','
Default on:
\r\n
\r\n
Joomla Help
\r\n
\r\n
Default off:
\r\n
Two new plugins are available but are disabled by default.
\r\n
\r\n
Contact Creator Help
Creates a new linked contact record for each new user created.
\r\n
Profile Help
This example profile plugin allows you to insert additional fields into user registration and profile display. This is intended as an example of the types of extensions to the profile you might want to create.
\r\n
','',-2,25,'2011-01-01 00:00:01',879,'Joomla!','2011-12-27 11:51:25',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',3,4,'','',1,0,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(52,150,'Users','users-component','
The users extension lets your site visitors register, login and logout, change their passwords and other information, and recover lost passwords. In the administrator it allows you to create, block and manage users and create user groups and access levels. Help
\r\n
Please note that some of the user views will not display if you are not logged-in to the site.
','',-2,21,'2011-01-01 00:00:01',879,'Joomla!','2011-01-10 04:52:55',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\"}',2,5,'','',1,1,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(53,151,'Using Joomla!','using-joomla','
With Joomla you can create anything from a simple personal website to a complex ecommerce or social site with millions of visitors.
\r\n
This section of the sample data provides you with a brief introduction to Joomla concepts and reference material to help you understand how Joomla works.
\r\n
When you no longer need the sample data, you can can simply unpublish the sample data category found within each extension in the site administrator or you may completely delete each item and all of the categories.
','',-2,19,'2011-01-01 00:00:01',879,'Joomla!','2011-12-27 11:52:45',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',2,7,'','',1,19,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(54,152,'Weblinks','weblinks','
Weblinks (com_weblinks) is a component that provides a structured way to organize external links and present them in a visually attractive, consistent and informative way. Help
','',-2,21,'2011-01-01 00:00:01',879,'Joomla!','2011-01-10 04:20:10',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\"}',2,6,'','',1,3,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(55,153,'Weblinks Module','weblinks-module','
This module displays the list of weblinks in a category. Help
\r\n
{loadmodule weblinks,Weblinks}
','',-2,66,'2011-01-01 00:00:01',879,'Joomla!','2011-09-17 22:32:10',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',7,5,'','',1,23,'',0,'*',''),(56,154,'Who\'s Online','whos-online','
The Who\'s Online Module displays the number of Anonymous Users (e.g. Guests) and Registered Users (ones logged-in) that are currently accessing the Web site. Help
\r\n
{loadmodule whosonline,Who\'s Online}
','',-2,65,'2011-01-01 00:00:01',879,'Joomla!','2011-09-17 22:19:45',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',4,1,'','',1,5,'',0,'*',''),(57,155,'Wobbegone','wobbegone','
\r\n','\r\n
',-2,72,'2011-01-01 00:00:01',879,'Parks Webmaster','2012-01-17 05:01:59',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"images\\/sampledata\\/parks\\/animals\\/180px_wobbegong.jpg\",\"float_intro\":\"\",\"image_intro_alt\":\"Wobbegon\",\"image_intro_caption\":\"\",\"image_fulltext\":\"images\\/sampledata\\/parks\\/animals\\/800px_wobbegong.jpg\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"Wobbegon\",\"image_fulltext_caption\":\"Source: http:\\/\\/en.wikipedia.org\\/wiki\\/File:Wobbegong.jpg Author: Richard Ling Rights: GNU Free Documentation License v 1.2 or later\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',2,1,'','',1,0,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(58,156,'Wonderful Watermelon','wonderful-watermelon','
Watermelon is a wonderful and healthy treat. We grow the world\'s sweetest watermelon. We have the largest watermelon patch in our country.
','',-2,30,'2011-01-01 00:00:01',879,'Fruit Shop Webmaster','2011-01-01 00:00:01',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',1,1,'','',1,0,'',0,'*',''),(59,157,'Wrapper Module','wrapper-module','
This module shows an iFrame window to specified location. Help
\r\n
{loadmodule wrapper,Wrapper}
','',-2,67,'2011-01-01 00:00:01',879,'Joomla!','2011-09-17 22:35:00',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',8,1,'','',1,15,'',0,'*',''),(60,158,'News Feeds','news-feeds','
News Feeds (com_newsfeeds) provides a way to organize and present news feeds. News feeds are a way that you present information from another site on your site. For example, the joomla.org website has numerous feeds that you can incorporate on your site. You an use menus to present a single feed, a list of feeds in a category, or a list of all feed categories. Help
','',-2,21,'2011-01-01 00:00:01',879,'Joomla!','2011-12-27 11:27:31',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',3,4,'','',1,2,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(62,160,'Content','content-plugins','
Content plugins run when specific kinds of pages are loaded. They do things ranging from protecting email addresses from harvesters to creating page breaks.
\r\n
Default on:
\r\n
\r\n
Email Cloaking Help
\r\n
Load Module Help
\r\n
Page Break Help
\r\n
Page Navigation Help
\r\n
Vote Help
\r\n
\r\n
Default off:
\r\n
\r\n
Code Highlighter (GeSHi) Help
\r\n
','',-2,25,'2011-01-01 00:00:01',879,'Joomla!','2011-09-06 06:11:50',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',2,7,'','',1,1,'',0,'*',''),(65,163,'Ormiston Pound','ormiston-pound','
\r\n','\r\n
',-2,73,'2011-01-01 00:00:01',879,'Parks Webmaster','2012-01-17 04:51:33',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','{\"image_intro\":\"images\\/sampledata\\/parks\\/landscape\\/180px_ormiston_pound.jpg\",\"float_intro\":\"none\",\"image_intro_alt\":\"Ormiston Pound\",\"image_intro_caption\":\"\",\"image_fulltext\":\"images\\/sampledata\\/parks\\/landscape\\/800px_ormiston_pound.jpg\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"Ormiston Pound\",\"image_fulltext_caption\":\"Source: http:\\/\\/commons.wikimedia.org\\/wiki\\/File:Ormiston_Pound.JPG Author: License: GNU Free Public Documentation License\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',5,3,'','',1,1,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(66,165,'Latest Users Module','latest-users-module','
This module displays the latest registered users. Help
\r\n
{loadmodule users_latest,Users Latest}
','',-2,65,'2011-01-01 00:00:01',879,'Joomla!','2011-09-17 22:21:05',42,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"1\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"1\",\"link_category\":\"1\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',4,3,'','',1,6,'',0,'*',''),(67,168,'What\'s New in 1.5?','whats-new-in-15','
This article deliberately archived as an example.
As with previous releases, Joomla! provides a unified and easy-to-use framework for delivering content for Web sites of all kinds. To support the changing nature of the Internet and emerging Web technologies, Joomla! required substantial restructuring of its core functionality and we also used this effort to simplify many challenges within the current user interface. Joomla! 1.5 has many new features.
\r\n
In Joomla! 1.5, you\'\'ll notice:
\r\n
\r\n
Substantially improved usability, manageability, and scalability far beyond the original Mambo foundations
\r\n
Expanded accessibility to support internationalisation, double-byte characters and right-to-left support for Arabic, Farsi, and Hebrew languages among others
\r\n
Extended integration of external applications through Web services
\r\n
Enhanced content delivery, template and presentation capabilities to support accessibility standards and content delivery to any destination
\r\n
A more sustainable and flexible framework for Component and Extension developers
\r\n
Backward compatibility with previous releases of Components, Templates, Modules, and other Extensions
\r\n
','',2,9,'2011-01-01 00:00:01',879,'Joomla! 1.5','2011-01-01 00:00:01',0,0,'0000-00-00 00:00:00','2011-01-01 00:00:01','0000-00-00 00:00:00','','','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_readmore\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_hits\":\"\",\"page_title\":\"\",\"alternative_readmore\":\"\",\"layout\":\"\"}',1,19,'','',1,0,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(68,170,'Captcha','captcha','
The Captcha plugins are used to prevent spam submissions on your forms such as registration, contact and login. You basic installation of Joomla includes one Captcha plugin which leverages the ReCaptcha® service but you may install other plugins connecting to different Captcha systems.
\r\n
Default on:
\r\n
\r\n
ReCaptcha help
\r\n
\r\n
Note: ReCaptcha is a the trademark of Google Inc. and is an independent product not associated with or endorsed by the Joomla Project. You will need to register and agree to the Terms of Service at Recaptcha.net to use this plugin. Complete instructions are available if you edit the ReCaptcha plugin in the Plugin Manager.
','',-2,25,'2012-01-17 03:20:45',879,'Joomla!','2012-01-17 03:35:46',42,0,'0000-00-00 00:00:00','2012-01-17 03:20:45','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',2,1,'','',1,0,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(69,171,'Quick Icons','quick-icons','
The Quick Icon plugin group is used to provide notification that updates to Joomla! or installed extensions are available and should be applied. These notifications display on your administrator control panel, which is the page you see when you first log in to your site administrator.
\r\n
Default on:
\r\n
\r\n
Quick icon - Joomla! extensions updates notification Help.
\r\n
Quick icon - Joomla! update notification Help
\r\n
','',-2,25,'2012-01-17 03:27:39',879,'Joomla!','0000-00-00 00:00:00',0,0,'0000-00-00 00:00:00','2012-01-17 03:27:39','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',1,0,'','',1,0,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(70,170,'Smart Search','smart-search','
This module provides search using the Smart Search component. You should only use it if you have indexed your content and either have enabled the Smart Search content plugin or are keeping the index of your site updated manually. Help.
\r\n
{loadmodule finder,Smart Search}
','',-2,67,'2012-01-17 03:42:36',879,'','2012-01-17 16:15:48',42,0,'0000-00-00 00:00:00','2012-01-17 03:42:36','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":\"\",\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":\"\",\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":\"\",\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',10,0,'','',1,13,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(71,170,'Module Positions','module-positions','
There is a total of 56 available module positions all of which are fully collapsible. By default your module widths will automatically adjust depending on the number of modules published within its containing row however within the templates parameters you can disable this feature and customise the width of each individual module.
','',1,9,'2012-02-21 11:31:28',879,'','2015-04-16 11:41:01',16,0,'0000-00-00 00:00:00','2012-02-21 11:31:28','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',13,18,'','',1,4185,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(72,171,'Template Parameters','template-parameters','
{loadposition parameters}
\r\n
\r\n
','',1,9,'2012-02-21 11:32:09',879,'','2014-11-29 10:52:48',979,0,'0000-00-00 00:00:00','2012-02-21 11:32:09','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',35,17,'','',1,3639,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(73,172,'Template Styles','template-styles','
There is a total of 6 color styles available giving your the template flexibility in match the color scheme best suited to your needs. Color styles available are Black, Red, Blue, Green, Bronze and Purple and can be set by navigating to your templates parameters (Extensions -> Template Manager -> J51 [Template Name] and simply selecting the color style of your choice from the \'Template Style\' dropdown menu.
\r\n
','',1,9,'2012-02-21 11:45:36',879,'','2012-03-26 22:12:52',42,0,'0000-00-00 00:00:00','2012-02-21 11:45:36','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":null,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":null,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":null,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',2,16,'','',1,292,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(74,173,'Layout Options','layout-options','
\r\n
\r\n
\r\n
From your \'Side Column Layout\' buttons simply set the layout of your side columns in relation to your site content with options for both your side columns to appear on either the left or the right or on either side of your content/component area.
\r\n
\r\n
','',1,9,'2012-02-21 12:11:45',879,'','2016-02-26 13:05:33',728,0,'0000-00-00 00:00:00','2012-02-21 12:11:45','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',51,15,'','',1,7041,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(75,174,'Typography','typography','
Heading1 (h1) looks like this
\r\n
Lorem ipsum dolor sit amet, consectetuer adipiscing elit, sed diam nonummy nibh euismod tincidunt ut laoreet dolore magna aliquam erat volutpat. Ut wisi enim ad minim veniam, quis nostrud exerci tation ullamcorper suscipit lobortis nisl ut aliquip ex.
\r\n
Heading2 (h2) looks like this
\r\n
\r\n
Heading3 (h3) looks like this
\r\n
\r\n
Heading4 (h4) looks like this
\r\n
\r\n
Heading5 (h5) looks like this
\r\n
\r\n
\r\n
<pre> or <div class=\"code\">
\r\n
To display note use: <p class=\"note\">Sample of your note !</p>
\r\n
To display pin note use :<p class=\"pin\">Sample of your pin note !</p>
\r\n
To display clip note use:<p class=\"clip\">Sample of your clip note</p>
\r\n
To display download note use:<p class=\"down\">Sample of your download note</p>
\r\n
\r\n
Ordered List
\r\n
\r\n
Lorem ipsum dolor sit amet consectetur
\r\n
\r\n
\r\n
\r\n
\r\n
Un-Ordered List
\r\n
\r\n
\r\n
\r\n
\r\n
\r\n
\r\n
Un-Ordered List witch class=\"tick\"
\r\n
<ul class=\"tick\"><li>Your list item goes here!</li></ul>
\r\n
\r\n
\r\n
\r\n
\r\n
\r\n
\r\n
Un-Ordered List witch class=\"star\"
\r\n
<ul class=\"star\"><li>Your list item goes here!</li></ul>
\r\n
\r\n
\r\n
\r\n
\r\n
\r\n
\r\n
Un-Ordered List witch class=\"plus\"
\r\n
<ul class=\"plus\"><li>Your list item goes here!</li></ul>
\r\n
\r\n
\r\n
\r\n
\r\n
\r\n
\r\n
Blockquote
\r\n
<blockquote><p>Your list item goes here!</p></blockquote>
\r\n
\r\n
\r\n
\r\n
Emphasis Tags
\r\n
<em class=\"highlight black\">your text</em>
\r\n
An emphasis tag that allows you to highlight some text in black.
\r\n
<em class=\"highlight blue\">your text</em>
\r\n
An emphasis tag that allows you to highlight some text in blue.
\r\n
<em class=\"highlight red\">your text</em>
\r\n
An emphasis tag that allows you to highlight some text in red.
\r\n
<em class=\"highlight green\">your text</em>
\r\n
An emphasis tag that allows you to highlight some text in green.
\r\n
<em class=\"highlight yellow\">your text</em>
\r\n
An emphasis tag that allows you to highlight some text in yellow.
\r\n
Image Frames
\r\n
<img src=\"images/yourimage.jpg\" class=\"frame-1\"/>
\r\n
\r\n
<img src=\"images/yourimage.jpg\" class=\"frame-2\"/>
\r\n
','',1,9,'2012-03-11 15:41:15',879,'','2015-04-17 22:18:41',16,0,'0000-00-00 00:00:00','2012-03-11 15:41:15','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',97,14,'','',1,2554,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(76,175,'Vivamus sit amet ante','sample-2','
\r\n
\r\n
\r\n','\r\n
\r\n
',1,78,'2012-06-08 20:06:56',879,'','2014-02-13 17:14:25',455,0,'0000-00-00 00:00:00','2012-06-08 20:06:56','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"1\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',95,4,'','',1,130,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(77,176,'Lacinia interdum felis','sample-1','
Praesent laoreet aliquet nulla. Aliquam arcu. Proin vel neque non ligula sodales sagittis. Cum sociis natoque penatibus et magnis dis parturient montes, nascetur ridiculus mus. Sed magna. Pellentesque aliquet mollis arcu. Morbi at felis. Suspendisse ligula. Aenean venenatis egestas iaculis. Nullam consectetur condimentum dolor at bibendum. Nulla in enim quis ipsum pulvinar imperdiet vitae nec velit. Donec non urna quam. Claritas est etiam processus dynamicus, qui sequitur mutationem consuetudium lectorum.
\r\n\r\n
Mirum est notare quam littera gothica, quam nunc putamus. Cras non sem sem, at eleifend mi. Vivamus sit amet ante est, sit amet rutrum augue. Cras non sem sem, at eleifend mi. Nam liber tempor cum soluta nobis eleifend option congue nihil imperdiet doming id quod mazim placerat facer possim assum. Duis autem vel eum iriure dolor in hendrerit in vulputate velit esse molestie consequat, curabitur eget nisl a risus.
\r\n','\r\n
\r\n
\r\n
',-2,78,'2012-06-08 20:06:56',879,'','2012-07-29 15:41:48',42,0,'0000-00-00 00:00:00','2012-06-08 20:06:56','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":null,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":null,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":null,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',34,5,'','',1,35,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(79,179,'Velit esse molestie','sample-3','
Sed ut perspiciatis unde omnis iste natus error sit voluptatem accusantium doloremque laudantium, totam rem aperiam. Claritas est etiam processus dynamicus, qui sequitur mutationem consuetudium lectorum. Aenean venenatis egestas iaculis.
\r\n','\r\n
\"\"Lorem ipsum dolor sit amet, consectetuer adipiscing elit, sed diam nonummy nibh euismod tincidunt ut laoreet dolore magna aliquam erat volutpat. Ut wisi enim ad minim veniam, quis nostrud exerci tation ullamcorper suscipit lobortis nisl ut aliquip ex ea commodo consequat. Duis autem vel eum iriure dolor in hendrerit in vulputate velit esse molestie consequat, vel illum dolore eu feugiat nulla facilisis at vero eros et accumsan et iusto odio dignissim qui blandit praesent luptatum zzril delenit augue duis dolore te feugait nulla facilisi. Nam liber tempor cum soluta nobis eleifend option congue nihil imperdiet doming id quod mazim placerat facer possim assum. Claritas est etiam processus dynamicus, qui sequitur mutationem consuetudium lectorum.
\r\n
\r\n
',1,78,'2012-06-08 20:06:56',879,'','2015-02-16 11:58:36',100,0,'0000-00-00 00:00:00','2012-06-08 20:06:56','0000-00-00 00:00:00','{\"image_intro\":\"images\\/filler3.jpg\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',35,5,'','',1,787,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(80,180,'Nulla in enim quis','sample-4','
\r\n
\r\n','\r\n
\r\n
\r\n
\r\n
\r\n
',1,78,'2012-06-08 20:06:56',879,'','2014-09-10 18:57:27',238,0,'0000-00-00 00:00:00','2012-06-08 20:06:56','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',104,3,'','',1,626,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(81,181,'Placerat facer possim','placerat-facer-possim','
\r\n
\r\n','\r\n
{loadposition portfolio}
\r\n
\r\n
Lorem ipsum dolor sit amet, consectetuer adipiscing elit, sed diam nonummy nibh euismod tincidunt ut laoreet dolore magna aliquam erat volutpat. Ut wisi enim ad minim veniam, quis nostrud exerci tation ullamcorper suscipit lobortis nisl ut aliquip ex ea commodo consequat. Duis autem vel eum iriure dolor in hendrerit in vulputate velit esse molestie consequat, vel illum dolore eu feugiat nulla facilisis at vero eros et accumsan et iusto odio dignissim. Duis autem vel eum iriure dolor in hendrerit in vulputate velit esse molestie consequat, vel illum dolore eu feugiat nulla facilisis at vero eros et accumsan et iusto odio dignissim qui blandit praesent luptatum zzril delenit augue duis dolore te feugait nulla facilisi.
',1,78,'2012-06-08 20:06:56',879,'','2014-11-27 16:35:53',979,0,'0000-00-00 00:00:00','2012-06-08 20:06:56','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',55,7,'','',1,6423,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(82,182,'Integer consectetur euismo','integer-consectetur-euismo','
\r\n
\r\n','\r\n
\r\n
\r\n
Typi non habent claritatem insitam; est usus legentis in iis qui facit eorum claritatem. Investigationes demonstraverunt lectores legere me lius quod ii legunt saepius. Claritas est etiam processus dynamicus, qui sequitur mutationem consuetudium lectorum. Mirum est notare quam littera gothica, quam nunc putamus parum claram, anteposuerit litterarum formas humanitatis per seacula quarta decima et quinta decima. Eodem modo typi, qui nunc nobis videntur parum clari, fiant sollemnes in futurum. Mauris ornare libero in risus ullamcorper dignissim. Suspendisse metus libero, dictum et laoreet hendrerit, dapibus non velit. Integer consectetur euismod sem vitae vestibulum. Nam quis enim non nunc fermentum volutpat at ac nunc. Praesent non dolor quis turpis placerat suscipit. Nunc quis velit magna. Lorem ipsum dolor sit amet, consectetur adipiscing elit.
\r\n
',1,78,'2012-06-08 20:06:56',879,'','2014-07-30 19:37:03',324,0,'0000-00-00 00:00:00','2012-06-08 20:06:56','0000-00-00 00:00:00','{\"image_intro\":\"images\\/filler2.jpg\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',30,6,'','',1,1308,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(83,183,'Module Variations','module-variations','
This template comes with different module styles and icons. For each module you can pick a style and combine it with an icon creating your own unique look.
\r\n
You can set your module style via the Module Class Suffix field within your modules parameters. Navigate to Extensions -> Module Manager -> [YourModule] -> Advanced Options -> Module Class Suffix.
','',1,9,'2012-09-02 13:46:53',879,'','2012-09-25 09:18:50',25,0,'0000-00-00 00:00:00','2012-09-02 13:46:53','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":null,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":null,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":null,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',3,13,'','',1,1864,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(84,184,'Responsive Design','responsive-design','
\r\n
\"\"So how does it work? With the use of media queries different CSS style rules are loaded depending on characteristics of the device your site is been viewed with, most commonly the width of your browser. With each set of rules your site will be styled to best display on the matching device.
\r\n
\r\n
','',1,9,'2012-09-24 17:58:01',879,'','2015-05-12 10:35:43',321,0,'0000-00-00 00:00:00','2012-09-24 17:58:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',16,12,'','',1,1691,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(85,185,'Replaceable Background Image','replaceable-background','
\"headerAs well as the many color choosers which allow you to customize each element of your template, this template also allows you to edit the background image visible in the header, slideshow and bottom module positions from within your templates parameters.
\r\n
Using the corresponding field under the Styling tab of your templates parameters hit the \'Select\' button to access your Media Manager. From here you can upload the header background image of your choice directly from your computer. You can also remove this image and replace it with the color of your choice
\r\n
','',1,9,'2013-01-25 22:01:45',879,'','2015-04-16 13:19:20',16,0,'0000-00-00 00:00:00','2013-01-25 22:01:45','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',26,11,'','',1,561,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(86,186,'Color Choosers','colour-chooser','
\"Colour
','',1,9,'2013-02-24 13:49:01',879,'','2014-11-28 12:56:18',979,0,'0000-00-00 00:00:00','2013-02-24 13:49:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',21,10,'','',1,283,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(87,187,'Element Styles','element-styles','
Your template comes with a host of Color Choosers and background image options allowing you total control of the look and feel of your site. Simply navigate to Extensions -> Template Manager -> [YourTemplate] to access the full range of easy to use styling options to give your template your very own look to suit your website.
\r\n\"Colour\r\n\r\n','',1,9,'2013-02-24 13:49:01',879,'','2013-04-28 19:01:27',3,0,'0000-00-00 00:00:00','2013-02-24 13:49:01','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":null,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":null,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":null,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_intro\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"0\",\"link_author\":\"\",\"show_create_date\":\"0\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',7,9,'','',1,262,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(88,188,'Welcom To Nadia','homepage','
\r\n
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Nam sapien risus, blandit at fringilla ac, varius sed dolor. Donec augue lacus, vulputate sed consectetur facilisis, interdum pharetra ligula. Nulla suscipit erat nibh, ut porttitor nisl dapibus eu.
\r\n
Phasellus porta eros vel lacus euismod consequat. Phasellus eleifend, nibh non feugiat hendrerit, lacus enim adipiscing eros, a pharetra erat neque eget est. Quisque vitae aliquet urna. Integer suscipit lectus eu enim porttitor fringilla. Ut blandit, urna in auctor euismod, arcu eros pharetra metus, a porta purus libero a nibh. Nam eget urna pellentesque nisl ultrices dapibus. Mauris accumsan vehicula nisl, sed tempus mauris facilisis eu. Donec a iaculis nisi, quis malesuada justo.
\r\n
','',1,9,'2013-06-21 11:59:02',879,'','2015-01-20 01:06:03',926,0,'0000-00-00 00:00:00','2013-06-21 11:59:02','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',96,8,'','',1,2120,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(89,308,'Mauris ligula justo','sample-5','
Nam quis enim non nunc fermentum volutpat at ac nunc. Praesent non dolor quis turpis placerat suscipit. Nunc quis velit magna. Lorem ipsum dolor sit amet, consectetur adipiscing elit. Vivamus et erat dolor. Vestibulum sollicitudin mollis ligula.
\r\n','\r\n
\r\n
\r\n
',1,78,'2012-06-08 20:06:56',879,'','2015-02-16 11:59:37',100,0,'0000-00-00 00:00:00','2012-06-08 20:06:56','0000-00-00 00:00:00','{\"image_intro\":\"images\\/filler4.jpg\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',6,2,'','',1,1,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(90,309,'Eodem modo typi','sample-6','
Claritas est etiam processus dynamicus, qui sequitur mutationem consuetudium lectorum. Aenean venenatis egestas iaculis. Nullam consectetur condimentum dolor at bibendum. Donec non urna quam. Duis autem vel eum iriure dolor in hendrerit.
\r\n','\r\n
\r\n
\r\n
',1,78,'2012-06-08 20:06:56',879,'','2015-02-16 11:59:11',100,0,'0000-00-00 00:00:00','2012-06-08 20:06:56','0000-00-00 00:00:00','{\"image_intro\":\"images\\/filler5.jpg\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',4,1,'','',1,1,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(91,314,'Animate on Scroll','animations-on-scroll','
We have included an option to easily add animations to almost any element of your site content. These animations are triggered once elements enter the viewport of your browser as you scroll down the page adding life and energy to your site content. Great for adding focus to particular elements of your content which you wish to bring to the attention of your visitors.
\r\n
Doing so is as simple as adding class names to the element you wish to animate via either inline through your editor or via your Module Class Suffix (Modules) or Link CSS Style (Menu Items) fields.
','',1,9,'2014-02-15 14:28:38',879,'','2014-08-25 21:20:02',75,0,'0000-00-00 00:00:00','2014-02-15 14:28:38','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',17,7,'','',1,189,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(92,316,'Font Awesome','font-awesome','
Font Awesome is a pictographic language of web-related actions which delivers over 300 icons. The Font Awesome webfont and CSS files are licensed under CC BY 3.0 and you can find the full examples of usage at Font Awesome - http://fortawesome.github.com/Font-Awesome
\r\n\r\n
Add class fa-CLASS_NAME to any element, best used with a <span>.
\r\n\r\n
\r\n Can also be added to any menu item using the Link CSS Style field in your menu item settings or to a module title using the Header Class field in your module settings.\r\n
\r\n\r\n
New Icons in Font Awesome4.2
\r\n
\r\n
fa-area-chart
\r\n
fa-at
\r\n
fa-bell-slash
\r\n
fa-bell-slash-o
\r\n
fa-bicycle
\r\n
fa-binoculars
\r\n
fa-birthday-cake
\r\n
fa-bus
\r\n
fa-calculator
\r\n
fa-cc
\r\n
fa-cc-amex
\r\n
fa-cc-discover
\r\n
fa-cc-mastercard
\r\n
fa-cc-paypal
\r\n
fa-cc-stripe
\r\n
fa-cc-visa
\r\n
fa-copyright
\r\n
fa-eyedropper
\r\n
fa-futbol-o
\r\n
fa-google-wallet
\r\n
fa-ils
\r\n
fa-ioxhost
\r\n
fa-lastfm
\r\n
fa-lastfm-square
\r\n
fa-line-chart
\r\n
fa-meanpath
\r\n
fa-newspaper-o
\r\n
fa-paint-brush
\r\n
fa-paypal
\r\n
fa-pie-chart
\r\n
fa-plug
\r\n
fa-shekel
\r\n
fa-slideshare
\r\n
fa-soccer-ball-o
\r\n
fa-toggle-off
\r\n
fa-toggle-on
\r\n
fa-trash
\r\n
fa-tty
\r\n
fa-twitch
\r\n
fa-wifi
\r\n
fa-yelp
\r\n
\r\n\r\n
Web Application Icons
\r\n\r\n
\r\n
fa-adjust
\r\n
fa-anchor
\r\n
fa-archive
\r\n
fa-arrows
\r\n
fa-arrows-h
\r\n
fa-arrows-v
\r\n
fa-asterisk
\r\n
fa-ban
\r\n
fa-bar-chart-o
\r\n
fa-barcode
\r\n
fa-bars
\r\n
fa-beer
\r\n
fa-bell
\r\n
fa-bell-o
\r\n
fa-bolt
\r\n
fa-book
\r\n
fa-bookmark
\r\n
fa-bookmark-o
\r\n
fa-briefcase
\r\n
fa-bug
\r\n
fa-building-o
\r\n
fa-bullhorn
\r\n
fa-bullseye
\r\n
fa-calendar
\r\n
fa-calendar-o
\r\n
fa-camera
\r\n
fa-camera-retro
\r\n
fa-caret-square-o-down
\r\n
fa-caret-square-o-left
\r\n
fa-caret-square-o-right
\r\n
fa-caret-square-o-up
\r\n
fa-certificate
\r\n
fa-check
\r\n
fa-check-circle
\r\n
fa-check-circle-o
\r\n
fa-check-square
\r\n
fa-check-square-o
\r\n
fa-circle
\r\n
fa-circle-o
\r\n
fa-clock-o
\r\n
fa-cloud
\r\n
fa-cloud-download
\r\n
fa-cloud-upload
\r\n
fa-code
\r\n
fa-code-fork
\r\n
fa-coffee
\r\n
fa-cog
\r\n
fa-cogs
\r\n
fa-comment
\r\n
fa-comment-o
\r\n
fa-comments
\r\n
fa-comments-o
\r\n
fa-compass
\r\n
fa-credit-card
\r\n
fa-crop
\r\n
fa-crosshairs
\r\n
fa-cutlery
\r\n
fa-dashboard (alias)
\r\n
fa-desktop
\r\n
fa-dot-circle-o
\r\n
fa-download
\r\n
fa-edit (alias)
\r\n
fa-ellipsis-h
\r\n
fa-ellipsis-v
\r\n
fa-envelope
\r\n
fa-envelope-o
\r\n
fa-eraser
\r\n
fa-exchange
\r\n
fa-exclamation
\r\n
fa-exclamation-circle
\r\n
fa-exclamation-triangle
\r\n
fa-external-link
\r\n
fa-external-link-square
\r\n
fa-eye
\r\n
fa-eye-slash
\r\n
fa-female
\r\n
fa-fighter-jet
\r\n
fa-film
\r\n
fa-filter
\r\n
fa-fire
\r\n
fa-fire-extinguisher
\r\n
fa-flag
\r\n
fa-flag-checkered
\r\n
fa-flag-o
\r\n
fa-flash (alias)
\r\n
fa-flask
\r\n
fa-folder
\r\n
fa-folder-o
\r\n
fa-folder-open
\r\n
fa-folder-open-o
\r\n
fa-frown-o
\r\n
fa-gamepad
\r\n
fa-gavel
\r\n
fa-gear (alias)
\r\n
fa-gears (alias)
\r\n
fa-gift
\r\n
fa-glass
\r\n
fa-globe
\r\n
fa-group (alias)
\r\n
fa-hdd-o
\r\n
fa-headphones
\r\n
fa-heart
\r\n
fa-heart-o
\r\n
fa-home
\r\n
fa-inbox
\r\n
fa-info
\r\n
fa-info-circle
\r\n
fa-key
\r\n
fa-keyboard-o
\r\n
fa-laptop
\r\n
fa-leaf
\r\n
fa-legal (alias)
\r\n
fa-lemon-o
\r\n
fa-level-down
\r\n
fa-level-up
\r\n
fa-lightbulb-o
\r\n
fa-location-arrow
\r\n
fa-lock
\r\n
fa-magic
\r\n
fa-magnet
\r\n
fa-mail-forward (alias)
\r\n
fa-mail-reply (alias)
\r\n
fa-mail-reply-all
\r\n
fa-male
\r\n
fa-map-marker
\r\n
fa-meh-o
\r\n
fa-microphone
\r\n
fa-microphone-slash
\r\n
fa-minus
\r\n
fa-minus-circle
\r\n
fa-minus-square
\r\n
fa-minus-square-o
\r\n
fa-mobile
\r\n
fa-mobile-phone (alias)
\r\n
fa-money
\r\n
fa-moon-o
\r\n
fa-music
\r\n
fa-pencil
\r\n
fa-pencil-square
\r\n
fa-pencil-square-o
\r\n
fa-phone
\r\n
fa-phone-square
\r\n
fa-picture-o
\r\n
fa-plane
\r\n
fa-plus
\r\n
fa-plus-circle
\r\n
fa-plus-square
\r\n
fa-plus-square-o
\r\n
fa-power-off
\r\n
fa-print
\r\n
fa-puzzle-piece
\r\n
fa-qrcode
\r\n
fa-question
\r\n
fa-question-circle
\r\n
fa-quote-left
\r\n
fa-quote-right
\r\n
fa-random
\r\n
fa-refresh
\r\n
fa-reply
\r\n
fa-reply-all
\r\n
fa-retweet
\r\n
fa-road
\r\n
fa-rocket
\r\n
fa-rss
\r\n
fa-rss-square
\r\n
fa-search
\r\n
fa-search-minus
\r\n
fa-search-plus
\r\n
fa-share
\r\n
fa-share-square
\r\n
fa-share-square-o
\r\n
fa-shield
\r\n
fa-shopping-cart
\r\n
fa-sign-in
\r\n
fa-sign-out
\r\n
fa-signal
\r\n
fa-sitemap
\r\n
fa-smile-o
\r\n
fa-sort
\r\n
fa-sort-alpha-asc
\r\n
fa-sort-alpha-desc
\r\n
fa-sort-amount-asc
\r\n
fa-sort-amount-desc
\r\n
fa-sort-asc
\r\n
fa-sort-desc
\r\n
fa-sort-down (alias)
\r\n
fa-sort-numeric-asc
\r\n
fa-sort-numeric-desc
\r\n
fa-sort-up (alias)
\r\n
fa-spinner
\r\n
fa-square
\r\n
fa-square-o
\r\n
fa-star
\r\n
fa-star-half
\r\n
fa-star-half-empty (alias)
\r\n
fa-star-half-full (alias)
\r\n
fa-star-half-o
\r\n
fa-star-o
\r\n
fa-subscript
\r\n
fa-suitcase
\r\n
fa-sun-o
\r\n
fa-superscript
\r\n
fa-tablet
\r\n
fa-tachometer
\r\n
fa-tag
\r\n
fa-tags
\r\n
fa-tasks
\r\n
fa-terminal
\r\n
fa-thumb-tack
\r\n
fa-thumbs-down
\r\n
fa-thumbs-o-down
\r\n
fa-thumbs-o-up
\r\n
fa-thumbs-up
\r\n
fa-ticket
\r\n
fa-times
\r\n
fa-times-circle
\r\n
fa-times-circle-o
\r\n
fa-tint
\r\n
fa-toggle-down (alias)
\r\n
fa-toggle-left (alias)
\r\n
fa-toggle-right (alias)
\r\n
fa-toggle-up (alias)
\r\n
fa-trash-o
\r\n
fa-trophy
\r\n
fa-truck
\r\n
fa-umbrella
\r\n
fa-unlock
\r\n
fa-unlock-alt
\r\n
fa-unsorted (alias)
\r\n
fa-upload
\r\n
fa-user
\r\n
fa-users
\r\n
fa-video-camera
\r\n
fa-volume-down
\r\n
fa-volume-off
\r\n
fa-volume-up
\r\n
fa-warning (alias)
\r\n
fa-wheelchair
\r\n
fa-wrench
\r\n
\r\n\r\n
Form Control Icons
\r\n
\r\n
fa-check-square
\r\n
fa-check-square-o
\r\n
fa-circle
\r\n
fa-circle-o
\r\n
fa-dot-circle-o
\r\n
fa-minus-square
\r\n
fa-minus-square-o
\r\n
fa-plus-square
\r\n
fa-plus-square-o
\r\n
fa-square
\r\n
fa-square-o
\r\n
\r\n\r\n
Currency Icons
\r\n
\r\n
fa-bitcoin (alias)
\r\n
fa-btc
\r\n
fa-cny (alias)
\r\n
fa-dollar (alias)
\r\n
fa-eur
\r\n
fa-euro (alias)
\r\n
fa-gbp
\r\n
fa-inr
\r\n
fa-jpy
\r\n
fa-krw
\r\n
fa-money
\r\n
fa-rmb (alias)
\r\n
fa-rouble (alias)
\r\n
fa-rub
\r\n
fa-ruble (alias)
\r\n
fa-rupee (alias)
\r\n
fa-try
\r\n
fa-turkish-lira (alias)
\r\n
fa-usd
\r\n
fa-won (alias)
\r\n
fa-yen (alias)
\r\n
\r\n\r\n
Text Editor Icons
\r\n
\r\n
fa-align-center
\r\n
fa-align-justify
\r\n
fa-align-left
\r\n
fa-align-right
\r\n
fa-bold
\r\n
fa-chain (alias)
\r\n
fa-chain-broken
\r\n
fa-clipboard
\r\n
fa-columns
\r\n
fa-copy (alias)
\r\n
fa-cut (alias)
\r\n
fa-dedent (alias)
\r\n
fa-eraser
\r\n
fa-file
\r\n
fa-file-o
\r\n
fa-file-text
\r\n
fa-file-text-o
\r\n
fa-files-o
\r\n
fa-floppy-o
\r\n
fa-font
\r\n
fa-indent
\r\n
fa-italic
\r\n
fa-link
\r\n
fa-list
\r\n
fa-list-alt
\r\n
fa-list-ol
\r\n
fa-list-ul
\r\n
fa-outdent
\r\n
fa-paperclip
\r\n
fa-paste (alias)
\r\n
fa-repeat
\r\n
fa-rotate-left (alias)
\r\n
fa-rotate-right (alias)
\r\n
fa-save (alias)
\r\n
fa-scissors
\r\n
fa-strikethrough
\r\n
fa-table
\r\n
fa-text-height
\r\n
fa-text-width
\r\n
fa-th
\r\n
fa-th-large
\r\n
fa-th-list
\r\n
fa-underline
\r\n
fa-undo
\r\n
fa-unlink (alias)
\r\n
\r\n\r\n
Directional Icons
\r\n
\r\n
fa-angle-double-down
\r\n
fa-angle-double-left
\r\n
fa-angle-double-right
\r\n
fa-angle-double-up
\r\n
fa-angle-down
\r\n
fa-angle-left
\r\n
fa-angle-right
\r\n
fa-angle-up
\r\n
fa-arrow-circle-down
\r\n
fa-arrow-circle-left
\r\n
fa-arrow-circle-o-down
\r\n
fa-arrow-circle-o-left
\r\n
fa-arrow-circle-o-right
\r\n
fa-arrow-circle-o-up
\r\n
fa-arrow-circle-right
\r\n
fa-arrow-circle-up
\r\n
fa-arrow-down
\r\n
fa-arrow-left
\r\n
fa-arrow-right
\r\n
fa-arrow-up
\r\n
fa-arrows
\r\n
fa-arrows-alt
\r\n
fa-arrows-h
\r\n
fa-arrows-v
\r\n
fa-caret-down
\r\n
fa-caret-left
\r\n
fa-caret-right
\r\n
\r\n
\r\n
\r\n
\r\n
fa-caret-up
\r\n
fa-chevron-circle-down
\r\n
fa-chevron-circle-left
\r\n
fa-chevron-circle-right
\r\n
fa-chevron-circle-up
\r\n
fa-chevron-down
\r\n
fa-chevron-left
\r\n
fa-chevron-right
\r\n
fa-chevron-up
\r\n
fa-hand-o-down
\r\n
fa-hand-o-left
\r\n
fa-hand-o-right
\r\n
fa-hand-o-up
\r\n
fa-long-arrow-down
\r\n
fa-long-arrow-left
\r\n
fa-long-arrow-right
\r\n
fa-long-arrow-up
\r\n
\r\n
\r\n
\r\n
\r\n
\r\n\r\n
Video Player Icons
\r\n
\r\n
fa-arrows-alt
\r\n
fa-backward
\r\n
fa-compress
\r\n
fa-eject
\r\n
fa-expand
\r\n
fa-fast-backward
\r\n
fa-fast-forward
\r\n
fa-forward
\r\n
fa-pause
\r\n
fa-play
\r\n
fa-play-circle
\r\n
fa-play-circle-o
\r\n
fa-step-backward
\r\n
fa-step-forward
\r\n
fa-stop
\r\n
fa-youtube-play
\r\n
\r\n\r\n
Brand Icons
\r\n
\r\n
fa-adn
\r\n
fa-android
\r\n
fa-angellist
\r\n
fa-apple
\r\n
fa-behance
\r\n
fa-behance-square
\r\n
fa-bitbucket
\r\n
fa-bitbucket-square
\r\n
fa-bitcoin
\r\n
fa-btc
\r\n
fa-cc-amex
\r\n
fa-cc-discover
\r\n
fa-cc-mastercard
\r\n
fa-cc-paypal
\r\n
fa-cc-stripe
\r\n
fa-cc-visa
\r\n
fa-codepen
\r\n
fa-css3
\r\n
fa-delicious
\r\n
fa-deviantart
\r\n
fa-digg
\r\n
fa-dribbble
\r\n
fa-dropbox
\r\n
fa-drupal
\r\n
fa-empire
\r\n
fa-facebook
\r\n
fa-facebook-square
\r\n
fa-flickr
\r\n
fa-foursquare
\r\n
fa-ge
\r\n
fa-git
\r\n
fa-git-square
\r\n
fa-github
\r\n
fa-github-alt
\r\n
fa-github-square
\r\n
fa-gittip
\r\n
fa-google
\r\n
fa-google-plus
\r\n
fa-google-plus-square
\r\n
fa-google-wallet
\r\n
fa-hacker-news
\r\n
fa-html5
\r\n
fa-instagram
\r\n
fa-ioxhost
\r\n
fa-joomla
\r\n
fa-jsfiddle
\r\n
fa-lastfm
\r\n
fa-lastfm-square
\r\n
fa-linkedin
\r\n
fa-linkedin-square
\r\n
fa-linux
\r\n
fa-maxcdn
\r\n
fa-meanpath
\r\n
fa-openid
\r\n
fa-pagelines
\r\n
fa-paypal
\r\n
fa-pied-piper
\r\n
fa-pied-piper-alt
\r\n
fa-pinterest
\r\n
fa-pinterest-square
\r\n
fa-qq
\r\n
fa-ra
\r\n
fa-rebel
\r\n
fa-reddit
\r\n
fa-reddit-square
\r\n
fa-renren
\r\n
fa-share-alt
\r\n
fa-share-alt-square
\r\n
fa-skype
\r\n
fa-slack
\r\n
fa-slideshare
\r\n
fa-soundcloud
\r\n
fa-spotify
\r\n
fa-stack-exchange
\r\n
fa-stack-overflow
\r\n
fa-steam
\r\n
fa-steam-square
\r\n
fa-stumbleupon
\r\n
fa-stumbleupon-circle
\r\n
fa-tencent-weibo
\r\n
fa-trello
\r\n
fa-tumblr
\r\n
fa-tumblr-square
\r\n
fa-twitch
\r\n
fa-twitter
\r\n
fa-twitter-square
\r\n
fa-vimeo-square
\r\n
fa-vine
\r\n
fa-vk
\r\n
fa-wechat
\r\n
fa-weibo
\r\n
fa-weixin
\r\n
fa-windows
\r\n
fa-wordpress
\r\n
fa-xing
\r\n
fa-xing-square
\r\n
fa-yahoo
\r\n
fa-yelp
\r\n
fa-youtube
\r\n
fa-youtube-play
\r\n
fa-youtube-square
\r\n\r\n
\r\n\r\n
Medical Icons
\r\n
\r\n
fa-ambulance
\r\n
fa-h-square
\r\n
fa-hospital-o
\r\n
fa-medkit
\r\n
fa-plus-square
\r\n
fa-stethoscope
\r\n
fa-user-md
\r\n
fa-wheelchair
\r\n
','',1,9,'2014-02-20 10:53:25',879,'','2014-09-14 14:55:00',238,0,'0000-00-00 00:00:00','2014-02-20 10:53:25','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',11,6,'','',1,62,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(93,324,'Grid Gallery','grid-gallery','
\r\n\r\n
Easily add title and description text for each image using the corresponding fields. Responsive options allow you to easily set the image box width depending on the device it is been viewed on. Multiple color choosers allow you to style the different elements of boxes to your own taste. And finally an \'On Scroll Animation\' field allows you to easily add any of the animate classes included with the template to animate the image box as it is scrolled in to view within the browser window.
','',1,9,'2014-07-30 12:00:13',879,'','2014-07-30 14:36:15',324,0,'0000-00-00 00:00:00','2014-07-30 12:00:13','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',4,5,'','',1,121,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(94,325,'Thumbs Gallery','thumbs-gallery','
{loadposition thumbsgallery}
\r\n
\r\n
','',1,9,'2014-07-30 12:01:04',879,'','2014-11-27 16:33:00',979,0,'0000-00-00 00:00:00','2014-07-30 12:01:04','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',8,4,'','',1,159,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(95,326,'About Us','about-us','
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Illo, laboriosam, quod odit quo quos itaque repellat quaerat a ad alias. Vel, nostrum id ab velit veritatis consequatur fugit sequi esse.
\r\n
Donec ornare mattis suscipit. Praesent fermentum accumsan vulputate. Sed velit nulla, sagittis non erat id, dictum vestibulum ligula. Maecenas sed enim sem. Etiam scelerisque gravida purus nec interdum. Phasellus venenatis ligula in faucibus consequat. Aliquam dictum nulla eu varius porta. Maecenas congue dui id posuere fermentum. Morbi at iaculis nibh, at semper augue.
\r\n
\r\n
\r\n
Suspendisse tristique velit vel ligula mattis
\r\n
Curabitur tincidunt iaculis est posuere
\r\n
Vestibulum vitae nibh elit phasellus sed
\r\n
','',-2,9,'2014-07-30 12:02:16',879,'','0000-00-00 00:00:00',0,0,'0000-00-00 00:00:00','2014-07-30 12:02:16','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',1,2,'','',1,0,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(96,327,'Services','services','
Iusto odio dignissimos ducimus qui blanditiis praesentium voluptatum deleniti atque corrupti quos dolores et quas molestias excepturi sint occaecati cupiditate non sit amet, consectetur adipiscing elit. Ut adipiscing elit magna. Sed et quam lacus. Fusce condimentum eleifend enim a feugiat. Pellentesque lorem ipsum dolor sit amet. Ut non libero magna. Sed et quam lacus. Fusce condimentum eleifend enim a feugiat consectetur adipiscing elit
\r\n
Mirum est notare quam littera gothica, quam nunc putamus parum claram, anteposuerit litterarum formas humanitatis per seacula quarta decima aliqua.adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna. aliqua.adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna.
','',-2,9,'2014-07-30 12:03:12',879,'','0000-00-00 00:00:00',0,0,'0000-00-00 00:00:00','2014-07-30 12:03:12','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',1,1,'','',1,0,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(97,328,'About Me','about-me','
\r\n \"about-me\"\r\n
\r\n
\r\n
Maria - Manager
\r\n
\r\n
\r\n
\r\n
\r\n
\r\n
\r\n
Lid est laborum dolo rumes fugats untras. Etharums ser quidem rerum facilis dolores nemis omnis fugats vitaes nemo minima rerums unsers sadips amets. Sed ut perspiciatis unde omnis iste natus error sit voluptatem accusantium doloremque laudantium, totam rem aperiam, eaque ipsa quae ab illo inventore veritatis et quasi architecto beatae vitae.
\r\n
Voluptatem accusantium doloremque laudantium, totam rem aperiam, eaque ipsa quae ab illo inventore veritatis et quasi architecto beatae vitae dicta sunt explicabo. Nemo enim ipsam voluptatem quia voluptas sit aspernatur aut odit aut fugit, sed quia consequuntur magni.
\r\n
','',-2,9,'2014-07-30 12:04:08',879,'','0000-00-00 00:00:00',0,0,'0000-00-00 00:00:00','2014-07-30 12:04:08','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',1,0,'','',1,0,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(98,336,'Curabitur eget nisl','sample-7','
\r\n
\r\n','\r\n
\r\n
\r\n
\r\n
\r\n
',1,78,'2012-06-08 20:06:56',879,'','2014-08-25 22:28:32',75,0,'0000-00-00 00:00:00','2012-06-08 20:06:56','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',3,0,'','',1,0,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(99,351,'Utility Classes','utility-classes','
\r\n
Inline Styling
\r\n
\r\n
<h2 class=\"padding-bottom-40\">\r\n A Sample Heading\r\n</h2>
\r\n
\r\n
Module Class Suffix (Module)
\r\n
This method is specific to modules. If you click in to the settings of any module and select the \'Advanced\' tab you will notice a \'Module Class Suffix\' field. Simply add the utility class to apply the CSS of this class to the enitre module. An popular example would be the utility class \'text-light\' which will convert all the text within a module to white which you will find useful if you have a dark background image or color set for the module area background. Note you can add as many classes as you like by simply separating them with a space.
\r\n
\"text-light\"
\r\n
\r\n
This final method is specific to menu items. Clicking in to the settings of any menu item (Menus -> [YourMenu] -> [YourMenuItem]) and selecting the \'Link Type\' you will notice a \'Link CSS Style\' field. This will allow you to apply a class to that particular menu item.
\r\n
\r\n
Text/Icons Color Classes
\r\n
\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n
Class CSS Property
text-light All containing text/icons is light
text-dark All containing text/icons is dark
\r\n\r\n
\r\n
Padding & Margin Classes
\r\n
\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n
Class CSS Property
padding-top-0 padding-top: 0px;
padding-top-5 padding-top: 5px;
padding-top-10 padding-top: 10px;
padding-top-15 padding-top: 15px;
padding-top-20 padding-top: 20px;
padding-top-30 padding-top: 30px;
padding-top-40 padding-top: 40px;
padding-top-60 padding-top: 60px;
padding-bottom-0 padding-bottom: 0px;
padding-bottom-5 padding-bottom: 5px;
padding-bottom-10 padding-bottom: 10px;
padding-bottom-15 padding-bottom: 15px;
padding-bottom-20 padding-bottom: 20px;
padding-bottom-30 padding-bottom: 30px;
padding-bottom-40 padding-bottom: 40px;
padding-bottom-60 padding-bottom: 60px;
padding-horiz-10 padding: 0 10px;
padding-horiz-20 padding: 0 20px;
padding-horiz-30 padding: 0 30px;
padding-horiz-40 padding: 0 40px;
padding-horiz-60 padding: 0 60px;
padding-vert-10 padding: 10px 0;
padding-vert-20 padding: 20px 0;
padding-vert-30 padding: 30px 0;
padding-vert-40 padding: 40px 0;
padding-vert-60 padding: 60px 0;
\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n\r\n
Class CSS Property
margin-top-0 margin-top: 0;
margin-top-5 margin-top: 5;
margin-top-10 margin-top: 10;
margin-top-15 margin-top: 15;
margin-top-20 margin-top: 20;
margin-top-30 margin-top: 30;
margin-top-40 margin-top: 40;
margin-top-60 margin-top: 60;
margin-bottom-0 margin-bottom: 0;
margin-bottom-5 margin-bottom: 5;
margin-bottom-10 margin-bottom: 10;
margin-bottom-15 margin-bottom: 15;
margin-bottom-20 margin-bottom: 20;
margin-bottom-30 margin-bottom: 30;
margin-bottom-40 margin-bottom: 40;
margin-bottom-60 margin-bottom: 60;
margin-horiz-10 margin: 0 10px;
margin-horiz-20 margin: 0 20px;
margin-horiz-30 margin: 0 30px;
margin-horiz-40 margin: 0 40px;
margin-horiz-60 margin: 0 60px;
margin-vert-10 margin: 10px 0;
margin-vert-20 margin: 20px 0;
margin-vert-30 margin: 30px 0;
margin-vert-40 margin: 40px 0;
margin-vert-60 margin: 60px 0;
\r\n\r\n
\r\n
Background Color Classes
\r\n
Class CSS Property Color
background-white color: #FFFFFF;
background-black color: #000000;
background-gray color: #888888;
background-gray-dark color: #333333;
background-gray-light color: #cccccc;
background-gray-lighter color: #ebebeb;
\r\n\r\n
\r\n\r\n
','',1,9,'2014-11-27 23:54:19',879,'','2016-02-23 08:09:09',728,0,'0000-00-00 00:00:00','2014-11-27 23:54:19','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',77,3,'','',1,191,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(100,352,'Carousel Module','carousel-module','
\r\n Included with this the template is our J51 Carousel module. This easy to use, highly versatile and fully responsive module allows you to place any content within an attractive carousel, an excellent solution to showcase your work in a small space. It\'s many uses include displaying a portfolio of work right across to a simple testimonials module. The possibilities are endless! \r\n
\r\n
\r\n The module includes an editor field for each column of your carousel so any content you can add to a standard article editor you can also add to your carousel. You can then set the number of columns you wish visible with each slide from one up to six. Other option fields include, navigation, pagination, transition style, transition delay and transition interval. There is also responsive options to set the number of columns per slide across various screen sizes. \r\n
','',1,9,'2014-11-28 12:11:47',879,'','2014-11-28 13:18:40',979,0,'0000-00-00 00:00:00','2014-11-28 12:11:47','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',8,2,'','',1,53,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*',''),(101,367,'Welcome to Nadia','homepage-2','
\r\n
','',1,9,'2015-03-21 18:08:47',879,'','2015-05-11 12:15:32',321,0,'0000-00-00 00:00:00','2015-03-21 18:08:47','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',14,1,'','',1,0,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',1,'*',''),(102,377,'Header Image Slideshow','header-image-slideshow','
\r\nBring your website project to life by easily adding a selection of images to appear in a slideshow in the header area of your template. Setup of the slideshow is all done within the templates parameters without the need of any module extension. This has allowed us to style the slideshow to form perfectly within the styling of your template. The slideshow is fully responsive to ensure your images are displayed perfectly across all screen sizes and devices.\r\n
\r\n\"header','',1,9,'2015-05-12 11:11:59',879,'','2016-02-26 13:00:57',728,0,'0000-00-00 00:00:00','2015-05-12 11:11:59','0000-00-00 00:00:00','{\"image_intro\":\"\",\"float_intro\":\"\",\"image_intro_alt\":\"\",\"image_intro_caption\":\"\",\"image_fulltext\":\"\",\"float_fulltext\":\"\",\"image_fulltext_alt\":\"\",\"image_fulltext_caption\":\"\"}','{\"urla\":false,\"urlatext\":\"\",\"targeta\":\"\",\"urlb\":false,\"urlbtext\":\"\",\"targetb\":\"\",\"urlc\":false,\"urlctext\":\"\",\"targetc\":\"\"}','{\"show_title\":\"\",\"link_titles\":\"\",\"show_tags\":\"\",\"show_intro\":\"\",\"info_block_position\":\"\",\"show_category\":\"\",\"link_category\":\"\",\"show_parent_category\":\"\",\"link_parent_category\":\"\",\"show_author\":\"\",\"link_author\":\"\",\"show_create_date\":\"\",\"show_modify_date\":\"\",\"show_publish_date\":\"\",\"show_item_navigation\":\"\",\"show_icons\":\"\",\"show_print_icon\":\"\",\"show_email_icon\":\"\",\"show_vote\":\"\",\"show_hits\":\"\",\"show_noauth\":\"\",\"urls_position\":\"\",\"alternative_readmore\":\"\",\"article_layout\":\"\",\"show_publishing_options\":\"\",\"show_article_options\":\"\",\"show_urls_images_backend\":\"\",\"show_urls_images_frontend\":\"\"}',5,0,'','',1,13,'{\"robots\":\"\",\"author\":\"\",\"rights\":\"\",\"xreference\":\"\"}',0,'*','')
Table 'ecweb_2016b.#__content' doesn't exist SQL=/*!40000 ALTER TABLE `#__content` DISABLE KEYS */
Table 'ecweb_2016b.#__content' doesn't exist SQL=LOCK TABLES `#__content` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__content` ( `id` int(10) unsigned NOT NULL AUTO_INCREMENT, `asset_id` int(10) unsigned NOT NULL DEFAULT '0' COMMENT 'FK to the #__assets table.', `title` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `alias` varchar(400) CHARACTER SET utf8mb4 COLLATE utf8mb4_bin NOT NULL DEFAULT '', `introtext` longtext COLLATE utf8mb4_unicode_ci NOT NULL, `fulltext` longtext COLLATE utf8mb4_unicode_ci NOT NULL, `state` tinyint(3) NOT NULL DEFAULT '0', `catid` int(10) unsigned NOT NULL DEFAULT '0', `created` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `created_by` int(10) unsigned NOT NULL DEFAULT '0', `created_by_alias` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `modified` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `modified_by` int(10) unsigned NOT NULL DEFAULT '0', `checked_out` int(10) unsigned NOT NULL DEFAULT '0', `checked_out_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `publish_up` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `publish_down` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `images` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `urls` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `attribs` varchar(5120) COLLATE utf8mb4_unicode_ci NOT NULL, `version` int(10) unsigned NOT NULL DEFAULT '1', `ordering` int(11) NOT NULL DEFAULT '0', `metakey` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `metadesc` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `access` int(10) unsigned NOT NULL DEFAULT '0', `hits` int(10) unsigned NOT NULL DEFAULT '0', `metadata` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `featured` tinyint(3) unsigned NOT NULL DEFAULT '0' COMMENT 'Set if article is featured.', `language` char(7) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'The language code for the article.', `xreference` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'A reference to enable linkages to external data sets.', PRIMARY KEY (`id`), KEY `idx_access` (`access`), KEY `idx_checkout` (`checked_out`), KEY `idx_state` (`state`), KEY `idx_catid` (`catid`), KEY `idx_createdby` (`created_by`), KEY `idx_featured_catid` (`featured`,`catid`), KEY `idx_language` (`language`), KEY `idx_xreference` (`xreference`) ) ENGINE=InnoDB AUTO_INCREMENT=103 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__contact_details' doesn't exist SQL=/*!40000 ALTER TABLE `#__contact_details` ENABLE KEYS */
Table 'ecweb_2016b.#__contact_details' doesn't exist SQL=INSERT INTO `#__contact_details` VALUES (1,'Contact Name Here','name','Position','Sea Crest,\r\nTop Road,\r\n','Strandhill','Co. Sligo','Ireland','IE','00353-888-888','00353-888-888','
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Cras nec suscipit magna. Suspendisse lacinia interdum felis eu consectetur. Vivamus sit amet ante est, sit amet rutrum augue. Cras non sem sem, at eleifend mi. Nam liber tempor cum soluta nobis eleifend option congue nihil imperdiet doming id quod mazim placerat facer possim assum. Aenean venenatis egestas iaculis. Nullam consectetur condimentum dolor at bibendum. Nulla in enim quis ipsum pulvinar imperdiet vitae nec velit. Donec non urna quam.
','images/contact_image.png','top','info@joomla51.com',1,1,0,'0000-00-00 00:00:00',1,'{\"show_contact_category\":\"\",\"show_contact_list\":\"\",\"presentation_style\":\"\",\"show_tags\":\"\",\"show_name\":\"\",\"show_position\":\"\",\"show_email\":\"\",\"show_street_address\":\"\",\"show_suburb\":\"\",\"show_state\":\"\",\"show_postcode\":\"\",\"show_country\":\"\",\"show_telephone\":\"\",\"show_mobile\":\"\",\"show_fax\":\"\",\"show_webpage\":\"\",\"show_misc\":\"\",\"show_image\":\"\",\"allow_vcard\":\"\",\"show_articles\":\"\",\"show_profile\":\"\",\"show_links\":\"1\",\"linka_name\":\"Twitter\",\"linka\":\"http:\\/\\/twitter.com\\/joomla\",\"linkb_name\":\"YouTube\",\"linkb\":\"http:\\/\\/http://www.youtube.com\\/user\\/joomla\",\"linkc_name\":\"Facebook\",\"linkc\":\"http:\\/\\/www.facebook.com\\/joomla\",\"linkd_name\":\"FriendFeed\",\"linkd\":\"http:\\/\\/friendfeed.com\\/joomla\",\"linke_name\":\"Scribed\",\"linke\":\"http:\\/\\/www.scribd.com\\/people\\/view\\/504592-joomla\",\"contact_layout\":\"\",\"show_email_form\":\"\",\"show_email_copy\":\"\",\"banned_email\":\"\",\"banned_subject\":\"\",\"banned_text\":\"\",\"validate_session\":\"\",\"custom_reply\":\"\",\"redirect\":\"\"}',0,16,1,'','','last','first','middle','en-GB','2011-01-01 00:00:01',879,'','2014-06-11 12:20:13',787,'','','{\"robots\":\"\",\"rights\":\"\"}',1,'','0000-00-00 00:00:00','0000-00-00 00:00:00',4,53),(2,'Webmaster','webmaster','','','','','','','','','','',NULL,'webmaster@example.com',0,-2,0,'0000-00-00 00:00:00',1,'{\"show_contact_category\":\"\",\"show_contact_list\":\"\",\"presentation_style\":\"\",\"show_name\":\"\",\"show_position\":\"\",\"show_email\":\"\",\"show_street_address\":\"\",\"show_suburb\":\"\",\"show_state\":\"\",\"show_postcode\":\"\",\"show_country\":\"\",\"show_telephone\":\"\",\"show_mobile\":\"\",\"show_fax\":\"\",\"show_webpage\":\"\",\"show_misc\":\"\",\"show_image\":\"\",\"allow_vcard\":\"\",\"show_articles\":\"\",\"show_profile\":\"\",\"show_links\":\"\",\"linka_name\":\"\",\"linka\":\"\",\"linkb_name\":\"\",\"linkb\":\"\",\"linkc_name\":\"\",\"linkc\":\"\",\"linkd_name\":\"\",\"linkd\":\"\",\"linke_name\":\"\",\"linke\":\"\",\"show_email_form\":\"1\",\"show_email_copy\":\"1\",\"banned_email\":\"\",\"banned_subject\":\"\",\"banned_text\":\"\",\"validate_session\":\"1\",\"custom_reply\":\"\",\"redirect\":\"\"}',0,34,1,'','','','','','en-GB','2011-01-01 00:00:01',879,'','2011-01-01 00:00:01',42,'','','{\"robots\":\"\",\"rights\":\"\"}',1,'','0000-00-00 00:00:00','0000-00-00 00:00:00',1,0),(3,'Owner','owner','','','','','','','','','
I\'m the owner of this store.
','',NULL,'',0,-2,0,'0000-00-00 00:00:00',2,'{\"show_contact_category\":\"\",\"show_contact_list\":\"\",\"presentation_style\":\"\",\"show_name\":\"\",\"show_position\":\"\",\"show_email\":\"\",\"show_street_address\":\"\",\"show_suburb\":\"\",\"show_state\":\"\",\"show_postcode\":\"\",\"show_country\":\"\",\"show_telephone\":\"\",\"show_mobile\":\"\",\"show_fax\":\"\",\"show_webpage\":\"\",\"show_misc\":\"\",\"show_image\":\"\",\"allow_vcard\":\"\",\"show_articles\":\"\",\"show_profile\":\"\",\"show_links\":\"\",\"linka_name\":\"\",\"linka\":\"\",\"linkb_name\":\"\",\"linkb\":\"\",\"linkc_name\":\"\",\"linkc\":\"\",\"linkd_name\":\"\",\"linkd\":\"\",\"linke_name\":\"\",\"linke\":\"\",\"show_email_form\":\"\",\"show_email_copy\":\"\",\"banned_email\":\"\",\"banned_subject\":\"\",\"banned_text\":\"\",\"validate_session\":\"\",\"custom_reply\":\"\",\"redirect\":\"\"}',0,36,1,'','','','','','*','2011-01-01 00:00:01',879,'','2011-01-01 00:00:01',42,'','','{\"robots\":\"\",\"rights\":\"\"}',1,'','0000-00-00 00:00:00','0000-00-00 00:00:00',1,0),(4,'Buyer','buyer','','','','','','','','','
I am in charge of buying fruit. If you sell good fruit, contact me.
','',NULL,'',0,-2,0,'0000-00-00 00:00:00',1,'{\"show_contact_category\":\"\",\"show_contact_list\":\"\",\"presentation_style\":\"\",\"show_name\":\"\",\"show_position\":\"\",\"show_email\":\"\",\"show_street_address\":\"\",\"show_suburb\":\"\",\"show_state\":\"\",\"show_postcode\":\"\",\"show_country\":\"\",\"show_telephone\":\"\",\"show_mobile\":\"\",\"show_fax\":\"\",\"show_webpage\":\"\",\"show_misc\":\"\",\"show_image\":\"\",\"allow_vcard\":\"\",\"show_articles\":\"\",\"show_profile\":\"\",\"show_links\":\"0\",\"linka_name\":\"\",\"linka\":\"\",\"linkb_name\":\"\",\"linkb\":\"\",\"linkc_name\":\"\",\"linkc\":\"\",\"linkd_name\":\"\",\"linkd\":\"\",\"linke_name\":\"\",\"linke\":\"\",\"show_email_form\":\"\",\"show_email_copy\":\"\",\"banned_email\":\"\",\"banned_subject\":\"\",\"banned_text\":\"\",\"validate_session\":\"\",\"custom_reply\":\"\",\"redirect\":\"\"}',0,36,1,'','','','','','*','2011-01-01 00:00:01',879,'','2011-01-01 00:00:01',42,'','','{\"robots\":\"\",\"rights\":\"\"}',1,'','0000-00-00 00:00:00','0000-00-00 00:00:00',1,0),(5,'Bananas','bananas','Scientific Name: Musa','Image Credit: Enzik\r\nRights: Creative Commons Share Alike Unported 3.0\r\nSource: http://commons.wikimedia.org/wiki/File:Bananas_-_Morocco.jpg','','Type: Herbaceous','Large Producers: India, China, Brasil','','','','
Bananas are a great source of potassium.
\r\n
','images/sampledata/fruitshop/bananas_2.jpg',NULL,'',0,-2,0,'0000-00-00 00:00:00',1,'{\"show_contact_category\":\"show_with_link\",\"show_contact_list\":\"\",\"presentation_style\":\"plain\",\"show_name\":\"\",\"show_position\":\"1\",\"show_email\":\"\",\"show_street_address\":\"\",\"show_suburb\":\"\",\"show_state\":\"1\",\"show_postcode\":\"\",\"show_country\":\"1\",\"show_telephone\":\"\",\"show_mobile\":\"\",\"show_fax\":\"\",\"show_webpage\":\"\",\"show_misc\":\"\",\"show_image\":\"\",\"allow_vcard\":\"\",\"show_articles\":\"\",\"show_profile\":\"\",\"show_links\":\"1\",\"linka_name\":\"Wikipedia: Banana English\",\"linka\":\"http:\\/\\/en.wikipedia.org\\/wiki\\/Banana\",\"linkb_name\":\"Wikipedia: \\u0939\\u093f\\u0928\\u094d\\u0926\\u0940 \\u0915\\u0947\\u0932\\u093e\",\"linkb\":\"http:\\/\\/hi.wikipedia.org\\/wiki\\/%E0%A4%95%E0%A5%87%E0%A4%B2%E0%A4%BE\",\"linkc_name\":\"Wikipedia:Banana Portugu\\u00eas\",\"linkc\":\"http:\\/\\/pt.wikipedia.org\\/wiki\\/Banana\",\"linkd_name\":\"Wikipedia: \\u0411\\u0430\\u043d\\u0430\\u043d \\u0420\\u0443\\u0441\\u0441\\u043a\\u0438\\u0439\",\"linkd\":\"http:\\/\\/ru.wikipedia.org\\/\\u0411\\u0430\\u043d\\u0430\\u043d\",\"linke_name\":\"\",\"linke\":\"\",\"contact_layout\":\"beez5:encyclopedia\"}',0,39,1,'','','','','','*','2011-01-01 00:00:01',879,'','2011-01-01 00:00:01',42,'','','{\"robots\":\"\",\"rights\":\"\"}',0,'','0000-00-00 00:00:00','0000-00-00 00:00:00',1,0),(6,'Apples','apples','Scientific Name: Malus domestica','Image Credit: Fievet\r\nRights: Public Domain\r\nSource: http://commons.wikimedia.org/wiki/File:Pommes_vertes.JPG','','Family: Rosaceae','Large: Producers: China, United States','','','','
Apples are a versatile fruit, used for eating, cooking, and preserving.
\r\n
There are more that 7500 different kinds of apples grown around the world.
','images/sampledata/fruitshop/apple.jpg',NULL,'',0,-2,0,'0000-00-00 00:00:00',1,'{\"show_contact_category\":\"\",\"show_contact_list\":\"\",\"presentation_style\":\"plain\",\"show_name\":\"\",\"show_position\":\"\",\"show_email\":\"\",\"show_street_address\":\"\",\"show_suburb\":\"\",\"show_state\":\"\",\"show_postcode\":\"\",\"show_country\":\"\",\"show_telephone\":\"\",\"show_mobile\":\"\",\"show_fax\":\"\",\"show_webpage\":\"\",\"show_misc\":\"\",\"show_image\":\"\",\"allow_vcard\":\"\",\"show_articles\":\"\",\"show_profile\":\"\",\"show_links\":\"1\",\"linka_name\":\"Wikipedia: Apples English\",\"linka\":\"http:\\/\\/en.wikipedia.org\\/wiki\\/Apple\",\"linkb_name\":\"Wikipedia: Manzana Espa\\u00f1ol \",\"linkb\":\"http:\\/\\/es.wikipedia.org\\/wiki\\/Manzana\",\"linkc_name\":\"Wikipedia: \\u82f9\\u679c \\u4e2d\\u6587\",\"linkc\":\"http:\\/\\/zh.wikipedia.org\\/zh\\/\\u82f9\\u679c\",\"linkd_name\":\"Wikipedia: Tofaa Kiswahili\",\"linkd\":\"http:\\/\\/sw.wikipedia.org\\/wiki\\/Tofaa\",\"linke_name\":\"\",\"linke\":\"\",\"contact_layout\":\"beez5:encyclopedia\"}',0,38,1,'','','','','','*','2011-01-01 00:00:01',879,'','2011-01-01 00:00:01',42,'','','{\"robots\":\"\",\"rights\":\"\"}',0,'','0000-00-00 00:00:00','0000-00-00 00:00:00',1,0),(7,'Tamarind','tamarind','Scientific Name: Tamarindus indica','Image Credit: Franz Eugen Köhler, Köhler\'s Medizinal-Pflanzen \r\nRights: Public Domain\r\nSource:http://commons.wikimedia.org/wiki/File:Koeh-134.jpg','','Family: Fabaceae','Large Producers: India, United States','','','','
Tamarinds are a versatile fruit used around the world. In its young form it is used in hot sauces; ripened it is the basis for many refreshing drinks.
\r\n
','images/sampledata/fruitshop/tamarind.jpg',NULL,'',0,-2,0,'0000-00-00 00:00:00',1,'{\"show_contact_category\":\"\",\"show_contact_list\":\"\",\"presentation_style\":\"plain\",\"show_name\":\"\",\"show_position\":\"\",\"show_email\":\"\",\"show_street_address\":\"\",\"show_suburb\":\"\",\"show_state\":\"\",\"show_postcode\":\"\",\"show_country\":\"\",\"show_telephone\":\"\",\"show_mobile\":\"\",\"show_fax\":\"\",\"show_webpage\":\"\",\"show_misc\":\"\",\"show_image\":\"\",\"allow_vcard\":\"\",\"show_articles\":\"\",\"show_profile\":\"\",\"show_links\":\"1\",\"linka_name\":\"Wikipedia: Tamarind English\",\"linka\":\"http:\\/\\/en.wikipedia.org\\/wiki\\/Tamarind\",\"linkb_name\":\"Wikipedia: \\u09a4\\u09c7\\u0981\\u09a4\\u09c1\\u09b2 \\u09ac\\u09be\\u0982\\u09b2\\u09be \",\"linkb\":\"http:\\/\\/bn.wikipedia.org\\/wiki\\/\\u09a4\\u09c7\\u0981\\u09a4\\u09c1\\u09b2 \",\"linkc_name\":\"Wikipedia: Tamarinier Fran\\u00e7ais\",\"linkc\":\"http:\\/\\/fr.wikipedia.org\\/wiki\\/Tamarinier\",\"linkd_name\":\"Wikipedia:Tamaline lea faka-Tonga\",\"linkd\":\"http:\\/\\/to.wikipedia.org\\/wiki\\/Tamaline\",\"linke_name\":\"\",\"linke\":\"\",\"contact_layout\":\"beez5:encyclopedia\"}',0,57,1,'','','','','','*','2011-01-01 00:00:01',879,'','2011-01-01 00:00:01',42,'','','{\"robots\":\"\",\"rights\":\"\"}',0,'','0000-00-00 00:00:00','0000-00-00 00:00:00',1,0),(8,'Shop Address','shop-address','','','Our City','Our Province','Our Country','','555-555-5555','','
Here are directions for how to get to our shop.
','',NULL,'',0,-2,0,'0000-00-00 00:00:00',1,'{\"show_contact_category\":\"\",\"show_contact_list\":\"\",\"presentation_style\":\"\",\"show_name\":\"\",\"show_position\":\"\",\"show_email\":\"\",\"show_street_address\":\"\",\"show_suburb\":\"\",\"show_state\":\"\",\"show_postcode\":\"\",\"show_country\":\"\",\"show_telephone\":\"\",\"show_mobile\":\"\",\"show_fax\":\"\",\"show_webpage\":\"\",\"show_misc\":\"\",\"show_image\":\"\",\"allow_vcard\":\"\",\"show_articles\":\"\",\"show_profile\":\"\",\"show_links\":\"\",\"linka_name\":\"\",\"linka\":\"\",\"linkb_name\":\"\",\"linkb\":\"\",\"linkc_name\":\"\",\"linkc\":\"\",\"linkd_name\":\"\",\"linkd\":\"\",\"linke_name\":\"\",\"linke\":\"\",\"show_email_form\":\"\",\"show_email_copy\":\"\",\"banned_email\":\"\",\"banned_subject\":\"\",\"banned_text\":\"\",\"validate_session\":\"\",\"custom_reply\":\"\",\"redirect\":\"\"}',0,35,1,'','','','','','*','2011-01-01 00:00:01',879,'','2011-01-01 00:00:01',42,'','','{\"robots\":\"\",\"rights\":\"\"}',1,'','0000-00-00 00:00:00','0000-00-00 00:00:00',1,0)
Table 'ecweb_2016b.#__contact_details' doesn't exist SQL=/*!40000 ALTER TABLE `#__contact_details` DISABLE KEYS */
Table 'ecweb_2016b.#__contact_details' doesn't exist SQL=LOCK TABLES `#__contact_details` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__contact_details` ( `id` int(11) NOT NULL AUTO_INCREMENT, `name` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `alias` varchar(400) CHARACTER SET utf8mb4 COLLATE utf8mb4_bin NOT NULL DEFAULT '', `con_position` varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT NULL, `address` mediumtext COLLATE utf8mb4_unicode_ci, `suburb` varchar(100) COLLATE utf8mb4_unicode_ci DEFAULT NULL, `state` varchar(100) COLLATE utf8mb4_unicode_ci DEFAULT NULL, `country` varchar(100) COLLATE utf8mb4_unicode_ci DEFAULT NULL, `postcode` varchar(100) COLLATE utf8mb4_unicode_ci DEFAULT NULL, `telephone` varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT NULL, `fax` varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT NULL, `misc` longtext COLLATE utf8mb4_unicode_ci, `image` varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT NULL, `imagepos` varchar(20) COLLATE utf8mb4_unicode_ci DEFAULT NULL, `email_to` varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT NULL, `default_con` tinyint(1) unsigned NOT NULL DEFAULT '0', `published` tinyint(1) NOT NULL DEFAULT '0', `checked_out` int(10) unsigned NOT NULL DEFAULT '0', `checked_out_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `ordering` int(11) NOT NULL DEFAULT '0', `params` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `user_id` int(11) NOT NULL DEFAULT '0', `catid` int(11) NOT NULL DEFAULT '0', `access` int(10) unsigned NOT NULL DEFAULT '0', `mobile` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `webpage` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `sortname1` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL, `sortname2` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL, `sortname3` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL, `language` char(7) COLLATE utf8mb4_unicode_ci NOT NULL, `created` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `created_by` int(10) unsigned NOT NULL DEFAULT '0', `created_by_alias` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `modified` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `modified_by` int(10) unsigned NOT NULL DEFAULT '0', `metakey` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `metadesc` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `metadata` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `featured` tinyint(3) unsigned NOT NULL DEFAULT '0' COMMENT 'Set if article is featured.', `xreference` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'A reference to enable linkages to external data sets.', `publish_up` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `publish_down` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `version` int(10) unsigned NOT NULL DEFAULT '1', `hits` int(10) unsigned NOT NULL DEFAULT '0', PRIMARY KEY (`id`), KEY `idx_access` (`access`), KEY `idx_checkout` (`checked_out`), KEY `idx_state` (`published`), KEY `idx_catid` (`catid`), KEY `idx_createdby` (`created_by`), KEY `idx_featured_catid` (`featured`,`catid`), KEY `idx_language` (`language`), KEY `idx_xreference` (`xreference`) ) ENGINE=InnoDB AUTO_INCREMENT=9 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__categories' doesn't exist SQL=/*!40000 ALTER TABLE `#__categories` ENABLE KEYS */
Table 'ecweb_2016b.#__categories' doesn't exist SQL=INSERT INTO `#__categories` VALUES (1,0,0,0,137,0,'','system','ROOT','root','','',1,0,'0000-00-00 00:00:00',1,'{}','','','',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(9,34,1,131,132,1,'uncategorised','com_content','Uncategorised','uncategorised','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-01-01 00:00:01',18,'*',1),(10,35,1,129,130,1,'uncategorised','com_banners','Uncategorised','uncategorised','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\",\"foobar\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(11,36,1,125,126,1,'uncategorised','com_contact','Uncategorised','uncategorised','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(12,37,1,61,62,1,'uncategorised','com_newsfeeds','Uncategorised','uncategorised','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(13,38,1,57,58,1,'uncategorised','com_weblinks','Uncategorised','uncategorised','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(14,39,1,9,56,1,'sample-data-articles','com_content','Sample Data-Articles','sample-data-articles','','',-2,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(15,40,1,127,128,1,'sample-data-banners','com_banners','Sample Data-Banners','sample-data-banners','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\",\"foobar\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(16,41,1,63,124,1,'sample-data-contact','com_contact','Sample Data-Contact','sample-data-contact','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(17,42,1,59,60,1,'sample-data-newsfeeds','com_newsfeeds','Sample Data-Newsfeeds','sample-data-newsfeeds','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(18,43,1,1,8,1,'sample-data-weblinks','com_weblinks','Sample Data-Weblinks','sample-data-weblinks','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(19,44,14,10,39,2,'sample-data-articles/joomla','com_content','Joomla!','joomla','','',-2,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-01-01 00:00:01',0,'*',1),(20,45,19,11,38,3,'sample-data-articles/joomla/extensions','com_content','Extensions','extensions','','
The Joomla! content management system lets you create webpages of various types using extensions. There are 5 basic types of extensions: components, modules, templates, languages, and plugins. Your website includes the extensions you need to create a basic website in English, but thousands of additional extensions of all types are available. The Joomla! Extensions Directory is the largest directory of Joomla extensions.
',-2,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-12-27 11:57:22',0,'*',1),(21,46,20,12,13,4,'sample-data-articles/joomla/extensions/components','com_content','Components','components','','
\"ComponentComponents are larger extensions that produce the major content for your site. Each component has one or more \"views\" that control how content is displayed. In the Joomla administrator there are additional extensions such as Menus, Redirection, and the extension managers.
',-2,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-12-27 11:58:12',0,'*',1),(22,47,20,14,25,4,'sample-data-articles/joomla/extensions/modules','com_content','Modules','modules','','
\"MediaModules are small blocks of content that can be displayed in positions on a web page. The menus on this site are displayed in modules. The core of Joomla! includes 24 separate modules ranging from login to search to random images. Each module has a name that starts mod_ but when it displays it has a title. In the descriptions in this section, the titles are the same as the names.
',-2,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-12-27 11:59:44',0,'*',1),(23,48,20,26,33,4,'sample-data-articles/joomla/extensions/templates','com_content','Templates','templates','','
\"MediaTemplates give your site its look and feel. They determine layout, colours, typefaces, graphics and other aspects of design that make your site unique. Your installation of Joomla comes prepackaged with three front end templates and two backend templates. Help
',-2,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-12-27 12:04:51',0,'*',1),(24,49,20,34,35,4,'sample-data-articles/joomla/extensions/languages','com_content','Languages','languages','','
\"LanguagesJoomla! installs in English, but translations of the interfaces, sample data and help screens are available in dozens of languages. Help
\r\n
Translation information
\r\n
If there is no language pack available for your language, instructions are available for creating your own translation, which you can also contribute to the community by starting a translation team to create an accredited translation.
\r\n
Translations of the interfaces are installed using the extensions manager in the site administrator and then managed using the language manager.
\r\n
If you have two or more languages installed you may enable the language switcher plugin and module. They should always be used together. If you create multilingual content and mark your content, menu items or modules as being in specific languages and follow the complete instructions your users will be able to select a specific content language using the module. By default both the plugin and module are disabled.
\r\n
Joomla 2.5 installs with a language override manager that allows you to change the specific words (such as Edit or Search) used in the Joomla application.
\r\n
There are a number of extensions that can help you manage translations of content available in the Joomla! Extensions Directory.
',-2,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2012-01-17 16:18:40',0,'*',1),(25,50,20,36,37,4,'sample-data-articles/joomla/extensions/plugins','com_content','Plugins','plugins','','
\"PluginPlugins are small task oriented extensions that enhance the Joomla! framework. Some are associated with particular extensions and others, such as editors, are used across all of Joomla. Most beginning users do not need to change any of the plugins that install with Joomla. Help
',-2,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-12-27 12:11:56',0,'*',1),(26,51,14,40,49,2,'sample-data-articles/park-site','com_content','Park Site','park-site','','',-2,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-01-01 00:00:01',0,'en-GB',1),(27,52,26,41,42,3,'sample-data-articles/park-site/park-blog','com_content','Park Blog','park-blog','','
Here is where I will blog all about the parks of Australia.
\r\n
You can make a blog on your website by creating a category to write your blog posts in (this one is called Park Blog). Each blog post will be an article in that category. If you make a category blog menu link with 1 column it will look like this page, if you display the category description then this part is displayed.
\r\n
To enhance your blog you may want to add extensions for comments, interacting with social network sites, tagging, and keeping in contact with your readers. You can also enable the syndication that is included in Joomla (in the Integration Options set Show Feed Link to Show and make sure to display the syndication module on the page).
',-2,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"images\\/sampledata\\/parks\\/banner_cradle.jpg\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-12-27 12:15:40',0,'en-GB',1),(28,53,26,43,48,3,'sample-data-articles/park-site/photo-gallery','com_content','Photo Gallery','photo-gallery','','
\r\n
These are my photos from parks I have visited (I didn\'t take them, they are all from Wikimedia Commons).
\r\n
This shows you how to make a simple image gallery using articles in com_content.
\r\n
In each article put a thumbnail image before a \"readmore\" and the full size image after it. Set the article to Show Intro Text: Hide.
',-2,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-01-01 00:00:01',0,'en-GB',1),(29,54,14,50,55,2,'sample-data-articles/fruit-shop-site','com_content','Fruit Shop Site','fruit-shop-site','','',-2,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-01-01 00:00:01',0,'*',1),(30,55,29,51,52,3,'sample-data-articles/fruit-shop-site/growers','com_content','Growers','growers','','
We search the whole countryside for the best fruit growers.
\r\n
You can let each supplier have a page that he or she can edit. To see this in action you will need to create a user who is in the suppliers group.
\r\n
Create one page in the growers category for that user and make that supplier the author of the page. That user will be able to edit his or her page.
\r\n
This illustrates the use of the Edit Own permission.
',-2,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-12-27 12:17:40',0,'*',1),(31,56,18,2,3,2,'sample-data-weblinks/park-links','com_weblinks','Park Links','park-links','','
Here are links to some of my favorite parks.
\r\n
The weblinks component provides an easy way to make links to external sites that are consistently formatted and categorised. You can create weblinks from the front end of your site.
',1,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"images\\/sampledata\\/parks\\/banner_cradle.jpg\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-01-01 00:00:01',0,'en-GB',1),(32,57,18,4,7,2,'sample-data-weblinks/joomla-specific-links','com_weblinks','Joomla! Specific Links','joomla-specific-links','','
A selection of links that are all related to the Joomla Project.
',1,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-12-27 12:32:00',0,'*',1),(33,58,32,5,6,3,'sample-data-weblinks/joomla-specific-links/other-resources','com_weblinks','Other Resources','other-resources','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(34,59,16,64,65,2,'sample-data-contact/park-site','com_contact','Park Site','park-site','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-01-01 00:00:01',0,'en-GB',1),(35,60,16,66,123,2,'sample-data-contact/shop-site','com_contact','Shop Site','shop-site','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(36,61,35,67,68,3,'sample-data-contact/shop-site/staff','com_contact','Staff','staff','','
Please feel free to contact our staff at any time should you need assistance.
',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(37,62,35,69,122,3,'sample-data-contact/shop-site/fruit-encyclopedia','com_contact','Fruit Encyclopedia','fruit-encyclopedia','','
Our directory of information about different kinds of fruit.
We love fruit and want the world to know more about all of its many varieties.
Although it is small now, we work on it whenever we have a chance.
All of the images can be found in Wikimedia Commons.
\"Apples\"
This encyclopedia is implemented using the contact component, each fruit a separate contact and a category for each letter. A CSS style is used to create the horizontal layout of the alphabet headings.
If you wanted to, you could allow some users (such as your growers) to have access to just this category in the contact component and let them help you to create new content for the encyclopedia.
',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(38,63,37,70,71,4,'sample-data-contact/shop-site/fruit-encyclopedia/a','com_contact','A','a','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(39,64,37,72,73,4,'sample-data-contact/shop-site/fruit-encyclopedia/b','com_contact','B','b','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(40,65,37,74,75,4,'sample-data-contact/shop-site/fruit-encyclopedia/c','com_contact','C','c','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(41,66,37,76,77,4,'sample-data-contact/shop-site/fruit-encyclopedia/d','com_contact','D','d','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(42,67,37,78,79,4,'sample-data-contact/shop-site/fruit-encyclopedia/e','com_contact','E','e','','',0,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(43,68,37,80,81,4,'sample-data-contact/shop-site/fruit-encyclopedia/f','com_contact','F','f','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(44,69,37,82,83,4,'sample-data-contact/shop-site/fruit-encyclopedia/g','com_contact','G','g','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(45,70,37,84,85,4,'sample-data-contact/shop-site/fruit-encyclopedia/h','com_contact','H','h','','',0,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(46,71,37,86,87,4,'sample-data-contact/shop-site/fruit-encyclopedia/i','com_contact','I','i','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(47,72,37,88,89,4,'sample-data-contact/shop-site/fruit-encyclopedia/j','com_contact','J','j','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(48,73,37,90,91,4,'sample-data-contact/shop-site/fruit-encyclopedia/k','com_contact','K','k','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(49,74,37,92,93,4,'sample-data-contact/shop-site/fruit-encyclopedia/l','com_contact','L','l','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(50,75,37,94,95,4,'sample-data-contact/shop-site/fruit-encyclopedia/m','com_contact','M','m','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(51,76,37,96,97,4,'sample-data-contact/shop-site/fruit-encyclopedia/n','com_contact','N','n','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(52,77,37,98,99,4,'sample-data-contact/shop-site/fruit-encyclopedia/o','com_contact','O','o','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(53,78,37,100,101,4,'sample-data-contact/shop-site/fruit-encyclopedia/p','com_contact','P','p','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(54,79,37,102,103,4,'sample-data-contact/shop-site/fruit-encyclopedia/q','com_contact','Q','q','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(55,80,37,104,105,4,'sample-data-contact/shop-site/fruit-encyclopedia/r','com_contact','R','r','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(56,81,37,106,107,4,'sample-data-contact/shop-site/fruit-encyclopedia/s','com_contact','S','s','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(57,82,37,108,109,4,'sample-data-contact/shop-site/fruit-encyclopedia/t','com_contact','T','t','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(58,83,37,110,111,4,'sample-data-contact/shop-site/fruit-encyclopedia/u','com_contact','U','u','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(59,84,37,112,113,4,'sample-data-contact/shop-site/fruit-encyclopedia/v','com_contact','V','v','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(60,85,37,114,115,4,'sample-data-contact/shop-site/fruit-encyclopedia/w','com_contact','W','w','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(61,86,37,116,117,4,'sample-data-contact/shop-site/fruit-encyclopedia/x','com_contact','X','x','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(62,87,37,118,119,4,'sample-data-contact/shop-site/fruit-encyclopedia/y','com_contact','Y','y','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(63,88,37,120,121,4,'sample-data-contact/shop-site/fruit-encyclopedia/z','com_contact','Z','z','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(64,93,22,15,16,5,'sample-data-articles/joomla/extensions/modules/articles-modules','com_content','Content Modules','articles-modules','','
Content modules display article and other information from the content component.
',-2,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-01-01 00:00:01',0,'*',1),(65,94,22,17,18,5,'sample-data-articles/joomla/extensions/modules/user-modules','com_content','User Modules','user-modules','','
User modules interact with the user system, allowing users to login, show who is logged-in, and showing the most recently registered users.
',-2,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-12-27 12:00:50',0,'*',1),(66,95,22,19,20,5,'sample-data-articles/joomla/extensions/modules/display-modules','com_content','Display Modules','display-modules','','
These modules display information from components other than content and user. These include weblinks, news feeds and the media manager.
',-2,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(67,96,22,21,22,5,'sample-data-articles/joomla/extensions/modules/utility-modules','com_content','Utility Modules','utility-modules','','
Utility modules provide useful functionality such as search, syndication and statistics.
',-2,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-12-27 12:01:34',0,'*',1),(68,97,23,31,32,5,'sample-data-articles/joomla/extensions/templates/atomic','com_content','Atomic','atomic','','
\"The
\r\n
Atomic is a minimal template designed to be a skeleton for making your own template and to learn about Joomla! templating.
\r\n
\r\n
Home Page
\r\n
Typography
\r\n
',-2,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-12-27 12:08:16',0,'*',1),(69,98,23,27,28,5,'sample-data-articles/joomla/extensions/templates/beez-20','com_content','Beez 20','beez-20','','
\"Beez_20
\r\n
Beez 2.0 is a versatile, easy to customise template that works for a variety of sites. It meets major accessibility standards and demonstrates a range of css and javascript techniques. It is the default template that installs with Joomla!
\r\n
\r\n
Home Page
\r\n
Typography
\r\n
',-2,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-01-01 00:00:01',0,'*',1),(70,99,23,29,30,5,'sample-data-articles/joomla/extensions/templates/beez-5','com_content','Beez 5','beez-5','','
\"Beez5
\r\n
Beez 5 is an html5 implementation of a Joomla! template. It uses a number of html5 techniques to enhance the presentation of a site. It is used as the template for the Fruit Shop sample site.
\r\n
\r\n
Home Page
\r\n
Typography
\r\n
',-2,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-12-27 12:06:57',0,'*',1),(72,108,28,44,45,4,'sample-data-articles/park-site/photo-gallery/animals','com_content','Animals','animals','','',-2,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-01-01 00:00:01',0,'en-GB',1),(73,109,28,46,47,4,'sample-data-articles/park-site/photo-gallery/scenery','com_content','Scenery','scenery','','',-2,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-01-01 00:00:01',0,'en-GB',1),(75,166,22,23,24,5,'sample-data-articles/joomla/extensions/modules/navigation-modules','com_content','Navigation Modules','navigation-modules','','
Navigation modules help your visitors move through your site and find what they need.
\r\n
Menus provide your site with structure and help your visitors navigate your site. Although they are all based on the same menu module, the variety of ways menus are used in the sample data show how flexible this module is.
\r\n
A menu can range from extremely simple (for example the top menu or the menu for the Australian Parks sample site) to extremely complex (for example the About Joomla! menu with its many levels). They can also be used for other types of presentation such as the site map linked from the \"This Site\" menu.
\r\n
Breadcrumbs provide users with information about where they are in a site.
',-2,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-01-01 00:00:01',0,'*',1),(76,167,29,53,54,3,'sample-data-articles/fruit-shop-site/recipes','com_content','Recipes','recipes','','
Customers and suppliers can post their favorite recipes for fruit here.
\r\n
A good idea is to promote the use of metadata keywords to make finding other recipes for the same fruit easier.
\r\n
To see this in action, create a user assigned to the customer group and a user assigned to the suppliers group. These users will be able to create their own recipe pages and edit those pages. They will not be able to edit other users\' pages.
',-2,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',42,'2011-12-27 12:18:25',0,'*',1),(77,169,1,133,134,1,'uncategorised','com_users.notes','Uncategorised','uncategorised','','',1,0,'0000-00-00 00:00:00',1,'{\"target\":\"\",\"image\":\"\"}','','','{\"page_title\":\"\",\"author\":\"\",\"robots\":\"\"}',879,'2011-01-01 00:00:01',0,'2011-01-01 00:00:01',0,'*',1),(78,178,1,135,136,1,'sample-content','com_content','Sample Content','sample-content','','\r\n',1,0,'0000-00-00 00:00:00',1,'{\"category_layout\":\"\",\"image\":\"\"}','','','{\"author\":\"\",\"robots\":\"\"}',879,'2012-06-30 12:55:59',42,'2012-07-29 12:43:26',21,'*',1)
Table 'ecweb_2016b.#__categories' doesn't exist SQL=/*!40000 ALTER TABLE `#__categories` DISABLE KEYS */
Table 'ecweb_2016b.#__categories' doesn't exist SQL=LOCK TABLES `#__categories` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__categories` ( `id` int(11) NOT NULL AUTO_INCREMENT, `asset_id` int(10) unsigned NOT NULL DEFAULT '0' COMMENT 'FK to the #__assets table.', `parent_id` int(10) unsigned NOT NULL DEFAULT '0', `lft` int(11) NOT NULL DEFAULT '0', `rgt` int(11) NOT NULL DEFAULT '0', `level` int(10) unsigned NOT NULL DEFAULT '0', `path` varchar(400) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `extension` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `title` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL, `alias` varchar(400) CHARACTER SET utf8mb4 COLLATE utf8mb4_bin NOT NULL DEFAULT '', `note` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `description` longtext COLLATE utf8mb4_unicode_ci NOT NULL, `published` tinyint(1) NOT NULL DEFAULT '0', `checked_out` int(11) unsigned NOT NULL DEFAULT '0', `checked_out_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `access` int(10) unsigned NOT NULL DEFAULT '0', `params` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `metadesc` varchar(1024) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'The meta description for the page.', `metakey` varchar(1024) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'The meta keywords for the page.', `metadata` varchar(2048) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'JSON encoded metadata properties.', `created_user_id` int(10) unsigned NOT NULL DEFAULT '0', `created_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `modified_user_id` int(10) unsigned NOT NULL DEFAULT '0', `modified_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `hits` int(10) unsigned NOT NULL DEFAULT '0', `language` char(7) COLLATE utf8mb4_unicode_ci NOT NULL, `version` int(10) unsigned NOT NULL DEFAULT '1', PRIMARY KEY (`id`), KEY `cat_idx` (`extension`,`published`,`access`), KEY `idx_access` (`access`), KEY `idx_checkout` (`checked_out`), KEY `idx_left_right` (`lft`,`rgt`), KEY `idx_language` (`language`), KEY `idx_path` (`path`(100)), KEY `idx_alias` (`alias`(100)) ) ENGINE=InnoDB AUTO_INCREMENT=79 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__banners' doesn't exist SQL=/*!40000 ALTER TABLE `#__banners` ENABLE KEYS */
Table 'ecweb_2016b.#__banners' doesn't exist SQL=INSERT INTO `#__banners` VALUES (2,3,0,'Shop 1','shop-1',0,91,2,'http://shop.joomla.org/amazoncom-bookstores.html',1,15,'Get books about Joomla! at the Joomla! Book Shop.','',0,1,'','{\"imageurl\":\"images\\/banners\\/white.png\",\"width\":\"\",\"height\":\"\",\"alt\":\"Joomla! Books\"}',0,'',-1,0,0,0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00','2011-01-01 00:00:01','en-GB',0,'','0000-00-00 00:00:00',0,1),(3,2,0,'Shop 2','shop-2',0,141,2,'http://shop.joomla.org',1,15,'T Shirts, caps and more from the Joomla! Shop.','',0,2,'','{\"imageurl\":\"images\\/banners\\/white.png\",\"width\":\"\",\"height\":\"\",\"alt\":\"Joomla! Shop\"}',0,'',-1,0,0,0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00','2011-01-01 00:00:01','en-GB',0,'','0000-00-00 00:00:00',0,1),(4,1,0,'Support Joomla!','support-joomla',0,60,1,'http://contribute.joomla.org',1,15,'Your contributions of time, talent and money make Joomla possible.','',0,3,'','{\"imageurl\":\"images\\/banners\\/white.png\",\"width\":\"\",\"height\":\"\",\"alt\":\"\"}',0,'',-1,0,0,0,'0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00','0000-00-00 00:00:00','en-GB',0,'','0000-00-00 00:00:00',0,1)
Table 'ecweb_2016b.#__banners' doesn't exist SQL=/*!40000 ALTER TABLE `#__banners` DISABLE KEYS */
Table 'ecweb_2016b.#__banners' doesn't exist SQL=LOCK TABLES `#__banners` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__banners` ( `id` int(11) NOT NULL AUTO_INCREMENT, `cid` int(11) NOT NULL DEFAULT '0', `type` int(11) NOT NULL DEFAULT '0', `name` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `alias` varchar(400) CHARACTER SET utf8mb4 COLLATE utf8mb4_bin NOT NULL DEFAULT '', `imptotal` int(11) NOT NULL DEFAULT '0', `impmade` int(11) NOT NULL DEFAULT '0', `clicks` int(11) NOT NULL DEFAULT '0', `clickurl` varchar(200) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `state` tinyint(3) NOT NULL DEFAULT '0', `catid` int(10) unsigned NOT NULL DEFAULT '0', `description` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `custombannercode` varchar(2048) COLLATE utf8mb4_unicode_ci NOT NULL, `sticky` tinyint(1) unsigned NOT NULL DEFAULT '0', `ordering` int(11) NOT NULL DEFAULT '0', `metakey` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `params` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `own_prefix` tinyint(1) NOT NULL DEFAULT '0', `metakey_prefix` varchar(400) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `purchase_type` tinyint(4) NOT NULL DEFAULT '-1', `track_clicks` tinyint(4) NOT NULL DEFAULT '-1', `track_impressions` tinyint(4) NOT NULL DEFAULT '-1', `checked_out` int(10) unsigned NOT NULL DEFAULT '0', `checked_out_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `publish_up` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `publish_down` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `reset` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `created` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `language` char(7) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `created_by` int(10) unsigned NOT NULL DEFAULT '0', `created_by_alias` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `modified` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `modified_by` int(10) unsigned NOT NULL DEFAULT '0', `version` int(10) unsigned NOT NULL DEFAULT '1', PRIMARY KEY (`id`), KEY `idx_state` (`state`), KEY `idx_own_prefix` (`own_prefix`), KEY `idx_banner_catid` (`catid`), KEY `idx_language` (`language`), KEY `idx_metakey_prefix` (`metakey_prefix`(100)) ) ENGINE=InnoDB AUTO_INCREMENT=5 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__banner_tracks' doesn't exist SQL=/*!40000 ALTER TABLE `#__banner_tracks` ENABLE KEYS */
Table 'ecweb_2016b.#__banner_tracks' doesn't exist SQL=/*!40000 ALTER TABLE `#__banner_tracks` DISABLE KEYS */
Table 'ecweb_2016b.#__banner_tracks' doesn't exist SQL=LOCK TABLES `#__banner_tracks` WRITE
Unknown character set: 'utf8mb4' SQL=CREATE TABLE `#__banner_tracks` ( `track_date` datetime NOT NULL, `track_type` int(10) unsigned NOT NULL, `banner_id` int(10) unsigned NOT NULL, `count` int(10) unsigned NOT NULL DEFAULT '0', PRIMARY KEY (`track_date`,`track_type`,`banner_id`), KEY `idx_track_date` (`track_date`), KEY `idx_track_type` (`track_type`), KEY `idx_banner_id` (`banner_id`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__banner_clients' doesn't exist SQL=/*!40000 ALTER TABLE `#__banner_clients` ENABLE KEYS */
Table 'ecweb_2016b.#__banner_clients' doesn't exist SQL=INSERT INTO `#__banner_clients` VALUES (1,'Joomla!','Administrator','email@email.com','',1,0,'0000-00-00 00:00:00','',0,'',-1,-1,-1),(2,'Shop','Example','example@example.com','',1,0,'0000-00-00 00:00:00','',0,'',-1,0,0),(3,'Bookstore','Bookstore Example','example@example.com','',1,0,'0000-00-00 00:00:00','',0,'',-1,0,0)
Table 'ecweb_2016b.#__banner_clients' doesn't exist SQL=/*!40000 ALTER TABLE `#__banner_clients` DISABLE KEYS */
Table 'ecweb_2016b.#__banner_clients' doesn't exist SQL=LOCK TABLES `#__banner_clients` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__banner_clients` ( `id` int(11) NOT NULL AUTO_INCREMENT, `name` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `contact` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `email` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `extrainfo` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `state` tinyint(3) NOT NULL DEFAULT '0', `checked_out` int(10) unsigned NOT NULL DEFAULT '0', `checked_out_time` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `metakey` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL, `own_prefix` tinyint(4) NOT NULL DEFAULT '0', `metakey_prefix` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '', `purchase_type` tinyint(4) NOT NULL DEFAULT '-1', `track_clicks` tinyint(4) NOT NULL DEFAULT '-1', `track_impressions` tinyint(4) NOT NULL DEFAULT '-1', PRIMARY KEY (`id`), KEY `idx_own_prefix` (`own_prefix`), KEY `idx_metakey_prefix` (`metakey_prefix`(100)) ) ENGINE=InnoDB AUTO_INCREMENT=4 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__associations' doesn't exist SQL=/*!40000 ALTER TABLE `#__associations` ENABLE KEYS */
Table 'ecweb_2016b.#__associations' doesn't exist SQL=/*!40000 ALTER TABLE `#__associations` DISABLE KEYS */
Table 'ecweb_2016b.#__associations' doesn't exist SQL=LOCK TABLES `#__associations` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__associations` ( `id` int(11) NOT NULL COMMENT 'A reference to the associated item.', `context` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'The context of the associated item.', `key` char(32) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'The key for the association computed from an md5 on associated ids.', PRIMARY KEY (`context`,`id`), KEY `idx_key` (`key`) ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
Table 'ecweb_2016b.#__assets' doesn't exist SQL=/*!40000 ALTER TABLE `#__assets` ENABLE KEYS */
Table 'ecweb_2016b.#__assets' doesn't exist SQL=INSERT INTO `#__assets` VALUES (1,0,1,692,0,'root.1','Root Asset','{\"core.login.site\":{\"6\":1,\"2\":1},\"core.login.admin\":{\"6\":1},\"core.login.offline\":[],\"core.admin\":{\"8\":1},\"core.manage\":{\"7\":1},\"core.create\":{\"6\":1,\"3\":1},\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"core.edit.own\":{\"6\":1,\"3\":1}}'),(2,1,2,3,1,'com_admin','com_admin','{}'),(3,1,4,11,1,'com_banners','com_banners','{\"core.admin\":{\"7\":1},\"core.manage\":{\"6\":1},\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(4,1,12,13,1,'com_cache','com_cache','{\"core.admin\":{\"7\":1},\"core.manage\":{\"7\":1}}'),(5,1,14,15,1,'com_checkin','com_checkin','{\"core.admin\":{\"7\":1},\"core.manage\":{\"7\":1}}'),(6,1,16,17,1,'com_config','com_config','{}'),(7,1,18,87,1,'com_contact','com_contact','{\"core.admin\":{\"7\":1},\"core.manage\":{\"6\":1},\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[],\"core.edit.own\":[]}'),(8,1,88,335,1,'com_content','com_content','{\"core.admin\":{\"7\":1},\"core.manage\":{\"6\":1},\"core.create\":{\"3\":1},\"core.delete\":[],\"core.edit\":{\"4\":1},\"core.edit.state\":{\"5\":1},\"core.edit.own\":[]}'),(9,1,336,337,1,'com_cpanel','com_cpanel','{}'),(10,1,338,339,1,'com_installer','com_installer','{\"core.admin\":[],\"core.manage\":{\"7\":0},\"core.delete\":{\"7\":0},\"core.edit.state\":{\"7\":0}}'),(11,1,340,341,1,'com_languages','com_languages','{\"core.admin\":{\"7\":1},\"core.manage\":[],\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(12,1,342,343,1,'com_login','com_login','{}'),(13,1,344,345,1,'com_mailto','com_mailto','{}'),(14,1,346,347,1,'com_massmail','com_massmail','{}'),(15,1,348,349,1,'com_media','com_media','{\"core.admin\":{\"7\":1},\"core.manage\":{\"6\":1},\"core.create\":{\"3\":1},\"core.delete\":{\"5\":1},\"core.edit\":[],\"core.edit.state\":[]}'),(16,1,350,351,1,'com_menus','com_menus','{\"core.admin\":{\"7\":1},\"core.manage\":[],\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(17,1,37,38,1,'com_messages','com_messages','{\"core.admin\":{\"7\":1},\"core.manage\":{\"7\":1}}'),(18,1,354,577,1,'com_modules','com_modules','{\"core.admin\":{\"7\":1},\"core.manage\":[],\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(19,1,578,585,1,'com_newsfeeds','com_newsfeeds','{\"core.admin\":{\"7\":1},\"core.manage\":{\"6\":1},\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(20,1,586,587,1,'com_plugins','com_plugins','{\"core.admin\":{\"7\":1},\"core.manage\":[],\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(21,1,588,589,1,'com_redirect','com_redirect','{\"core.admin\":{\"7\":1},\"core.manage\":[]}'),(22,1,590,591,1,'com_search','com_search','{\"core.admin\":{\"7\":1},\"core.manage\":{\"6\":1}}'),(23,1,592,593,1,'com_templates','com_templates','{\"core.admin\":{\"7\":1},\"core.manage\":[],\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(24,1,594,597,1,'com_users','com_users','{\"core.admin\":{\"7\":1},\"core.manage\":[],\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(25,1,598,615,1,'com_weblinks','com_weblinks','{\"core.admin\":{\"7\":1},\"core.manage\":{\"6\":1},\"core.create\":{\"3\":1,\"10\":0,\"12\":0},\"core.delete\":[],\"core.edit\":{\"4\":1},\"core.edit.state\":{\"5\":1}}'),(26,1,616,617,1,'com_wrapper','com_wrapper','{}'),(33,1,678,679,1,'com_finder','com_finder','{\"core.admin\":{\"7\":1},\"core.manage\":{\"6\":1}}'),(34,8,105,152,2,'com_content.category.9','Uncategorised','{\"core.create\":{\"10\":0,\"12\":0},\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(35,3,7,8,2,'com_banners.category.10','Uncategorised','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(36,7,23,24,2,'com_contact.category.11','Uncategorised','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(37,19,581,582,2,'com_newsfeeds.category.12','Uncategorised','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(38,25,605,606,2,'com_weblinks.category.13','Uncategorised','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(39,8,153,314,2,'com_content.category.14','Sample Data-Articles','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(40,3,9,10,2,'com_banners.category.15','Sample Data-Banners','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(41,7,25,86,2,'com_contact.category.16','Sample Data-Contact','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(42,19,583,584,2,'com_newsfeeds.category.17','Sample Data-Newsfeeds','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(43,25,607,614,2,'com_weblinks.category.18','Sample Data-Weblinks','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(44,39,154,267,3,'com_content.category.19','Joomla!','{\"core.create\":{\"10\":0,\"12\":0},\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(45,44,155,248,4,'com_content.category.20','Extensions','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(46,45,156,169,5,'com_content.category.21','Components','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(47,45,170,219,5,'com_content.category.22','Modules','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(48,45,220,231,5,'com_content.category.23','Templates','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(49,45,232,233,5,'com_content.category.24','Languages','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(50,45,234,247,5,'com_content.category.25','Plugins','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(51,39,268,295,3,'com_content.category.26','Park Site','{\"core.create\":{\"10\":0,\"12\":0},\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(52,51,269,274,4,'com_content.category.27','Park Blog','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(53,51,275,294,4,'com_content.category.28','Photo Gallery','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(54,39,296,309,3,'com_content.category.29','Fruit Shop Site','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(55,54,297,302,4,'com_content.category.30','Growers','{\"core.create\":{\"12\":0},\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[],\"core.edit.own\":{\"10\":1}}'),(56,43,608,609,3,'com_weblinks.category.31','Park Links','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(57,43,610,613,3,'com_weblinks.category.32','Joomla! Specific Links','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(58,57,611,612,4,'com_weblinks.category.33','Other Resources','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(59,41,26,27,3,'com_contact.category.34','Park Site','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(60,41,28,85,3,'com_contact.category.35','Shop Site','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(61,60,29,30,4,'com_contact.category.36','Staff','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(62,60,31,84,4,'com_contact.category.37','Fruit Encyclopedia','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(63,62,32,33,5,'com_contact.category.38','A','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(64,62,34,35,5,'com_contact.category.39','B','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(65,62,36,37,5,'com_contact.category.40','C','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(66,62,38,39,5,'com_contact.category.41','D','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(67,62,40,41,5,'com_contact.category.42','E','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(68,62,42,43,5,'com_contact.category.43','F','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(69,62,44,45,5,'com_contact.category.44','G','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(70,62,46,47,5,'com_contact.category.45','H','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(71,62,48,49,5,'com_contact.category.46','I','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(72,62,50,51,5,'com_contact.category.47','J','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(73,62,52,53,5,'com_contact.category.48','K','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(74,62,54,55,5,'com_contact.category.49','L','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(75,62,56,57,5,'com_contact.category.50','M','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(76,62,58,59,5,'com_contact.category.51','N','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(77,62,60,61,5,'com_contact.category.52','O','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(78,62,62,63,5,'com_contact.category.53','P','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(79,62,64,65,5,'com_contact.category.54','Q','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(80,62,66,67,5,'com_contact.category.55','R','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(81,62,68,69,5,'com_contact.category.56','S','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(82,62,70,71,5,'com_contact.category.57','T','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(83,62,72,73,5,'com_contact.category.58','U','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(84,62,74,75,5,'com_contact.category.59','V','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(85,62,76,77,5,'com_contact.category.60','W','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(86,62,78,79,5,'com_contact.category.61','X','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(87,62,80,81,5,'com_contact.category.62','Y','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(88,62,82,83,5,'com_contact.category.63','Z','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(93,47,171,180,6,'com_content.category.64','Content Modules','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(94,47,181,188,6,'com_content.category.65','User Modules','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(95,47,189,200,6,'com_content.category.66','Display Modules','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(96,47,201,212,6,'com_content.category.67','Utility Modules','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(97,48,221,222,6,'com_content.category.68','Atomic','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(98,48,223,224,6,'com_content.category.69','Beez 20','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(99,48,225,226,6,'com_content.category.70','Beez5','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(100,48,227,228,6,'com_content.category.71','Milky Way','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(105,46,157,158,6,'com_content.article.9','Contact','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(106,46,159,160,6,'com_content.article.10','Content','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(107,109,287,288,6,'com_content.article.11','Cradle Mountain','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(108,53,276,285,5,'com_content.category.72','Animals','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(109,53,286,293,5,'com_content.category.73','Scenery','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(110,95,190,191,7,'com_content.article.12','Custom HTML Module','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(111,54,303,304,4,'com_content.article.13','Directions','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(112,50,235,236,6,'com_content.article.14','Editors','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(113,50,237,238,6,'com_content.article.15','Editors-xtd','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(114,95,192,193,7,'com_content.article.16','Feed Display','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(115,52,270,271,5,'com_content.article.17','First Blog Post','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(116,52,272,273,5,'com_content.article.18','Second Blog Post','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(117,95,194,195,7,'com_content.article.19','Footer Module','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(118,54,305,306,4,'com_content.article.20','Fruit Shop','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(119,44,249,250,4,'com_content.article.21','Getting Help','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(120,44,251,252,4,'com_content.article.22','Getting Started','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(121,55,298,299,5,'com_content.article.23','Happy Orange Orchard','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(123,108,277,278,6,'com_content.article.25','Koala','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(124,96,202,203,7,'com_content.article.26','Language Switcher','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(125,93,172,173,7,'com_content.article.27','Latest Articles Module','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(126,94,182,183,7,'com_content.article.28','Login Module','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(127,166,216,217,7,'com_content.article.29','Menu Module','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(128,93,174,175,7,'com_content.article.30','Most Read Content','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(129,93,176,177,7,'com_content.article.31','News Flash','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(130,44,253,254,4,'com_content.article.32','Options','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(131,108,279,280,6,'com_content.article.33','Phyllopteryx','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(132,109,289,290,6,'com_content.article.34','Pinnacles','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(133,44,255,256,4,'com_content.article.35','Professionals','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(134,95,196,197,7,'com_content.article.36','Random Image Module','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(135,93,178,179,7,'com_content.article.37','Related Items Module','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(136,44,257,258,4,'com_content.article.38','Sample Sites','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(137,46,161,162,6,'com_content.article.39','Search','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(138,96,204,205,7,'com_content.article.40','Search Module','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(139,50,239,240,6,'com_content.article.41','Search ','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(140,39,310,311,3,'com_content.article.42','Site Map','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(141,108,281,282,6,'com_content.article.43','Spotted Quoll','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(142,96,206,207,7,'com_content.article.44','Statistics Module','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(143,96,208,209,7,'com_content.article.45','Syndicate Module','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(144,50,241,242,6,'com_content.article.46','System','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(145,44,259,260,4,'com_content.article.47','The Joomla! Community','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(146,44,261,262,4,'com_content.article.48','The Joomla! Project','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(147,48,229,230,6,'com_content.article.49','Typography','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(148,44,263,264,4,'com_content.article.50','Upgraders','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(149,50,243,244,6,'com_content.article.51','User','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(150,46,163,164,6,'com_content.article.52','Users','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(151,44,265,266,4,'com_content.article.53','Using Joomla!','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(152,46,165,166,6,'com_content.article.54','Weblinks','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(153,95,198,199,7,'com_content.article.55','Weblinks Module','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(154,94,184,185,7,'com_content.article.56','Who\'s Online','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(155,108,283,284,6,'com_content.article.57','Wobbegone','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(156,55,300,301,5,'com_content.article.58','Wonderful Watermelon','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(157,96,210,211,7,'com_content.article.59','Wrapper Module','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(158,46,167,168,6,'com_content.article.60','News Feeds','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(160,50,245,246,6,'com_content.article.62','Content','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(163,109,291,292,6,'com_content.article.65','Ormiston Pound','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(165,94,186,187,7,'com_content.article.66','Latest Users Module','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(166,47,215,218,6,'com_content.category.75','Navigation Modules','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[],\"core.edit.own\":[]}'),(167,54,307,308,4,'com_content.category.76','Recipes','{\"core.create\":{\"12\":1,\"10\":1},\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[],\"core.edit.own\":{\"12\":1,\"10\":1}}'),(168,34,106,107,3,'com_content.article.67','What\'s New in 1.5?','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(169,24,595,596,2,'com_users.notes.category.77','Uncategorised',''),(170,34,108,109,3,'com_content.article.71','Module Positions','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(171,34,110,111,3,'com_content.article.72','Template Parameters','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(172,34,112,113,3,'com_content.article.73','Template Styles','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(173,34,114,115,3,'com_content.article.74','Layout Options','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(174,34,116,117,3,'com_content.article.75','Typography','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(175,178,320,321,3,'com_content.article.76','Vivamus sit amet ante','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(176,178,316,317,3,'com_content.article.77','Lacinia interdum felis','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(178,8,315,334,2,'com_content.category.78','Sample Content','{\"core.create\":[],\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[],\"core.edit.own\":[]}'),(179,178,318,319,3,'com_content.article.79','Velit esse molestie','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(180,178,322,323,3,'com_content.article.80','Nulla in enim quis','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(181,178,330,331,3,'com_content.article.81','Placerat facer possim','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(182,178,328,329,3,'com_content.article.82','Integer consectetur euismo','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(183,34,118,119,3,'com_content.article.83','Module Variations','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(184,34,120,121,3,'com_content.article.84','Responsive Design','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(185,34,122,123,3,'com_content.article.85','Replaceable Background Image','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(186,34,124,125,3,'com_content.article.86','Color Choosers','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(187,34,126,127,3,'com_content.article.87','Element Styles','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(188,34,128,129,3,'com_content.article.88','Welcom To Nadia','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(189,1,682,683,1,'com_joomlaupdate','com_joomlaupdate','{}'),(190,1,684,685,1,'com_tags','com_tags','{}'),(191,1,686,687,1,'com_contenthistory','com_contenthistory','{}'),(192,1,688,689,1,'com_ajax','com_ajax','{}'),(193,1,690,691,1,'com_postinstall','com_postinstall','{}'),(210,18,355,356,2,'com_modules.module.187','Module Bottom-1A','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(211,18,357,358,2,'com_modules.module.188','Module Bottom-1B','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(212,18,359,360,2,'com_modules.module.189','Module Bottom-1C','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(213,18,361,362,2,'com_modules.module.190','Module Bottom-1D','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(214,18,363,364,2,'com_modules.module.191','Module Bottom-1E','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(215,18,365,366,2,'com_modules.module.192','Module Bottom-1F','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(216,18,367,368,2,'com_modules.module.133','Module Bottom-2A','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(217,18,369,370,2,'com_modules.module.134','Module Bottom-2B','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(218,18,371,372,2,'com_modules.module.157','Module Bottom-2C','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(219,18,373,374,2,'com_modules.module.193','Module Bottom-2D','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(220,18,375,376,2,'com_modules.module.194','Module Bottom-2E','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(221,18,377,378,2,'com_modules.module.195','Module Bottom-2F','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(222,18,379,380,2,'com_modules.module.196','Module Base-1A','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(223,18,381,382,2,'com_modules.module.197','Module Base-1B','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(224,18,383,384,2,'com_modules.module.198','Module Base-1C','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(225,18,385,386,2,'com_modules.module.199','Module Base-1D','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(226,18,387,388,2,'com_modules.module.201','Module Base-1E','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(227,18,389,390,2,'com_modules.module.200','Module Base-1F','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(228,18,391,392,2,'com_modules.module.128','Module Base-2A','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(229,18,393,394,2,'com_modules.module.129','Module Base-2B','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(230,18,395,396,2,'com_modules.module.183','Module Base-2C','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(231,18,397,398,2,'com_modules.module.184','Module Base-2D','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(232,18,399,400,2,'com_modules.module.185','Module Base-2E','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(233,18,401,402,2,'com_modules.module.186','Module Base-2F','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(234,18,403,404,2,'com_modules.module.130','Module Footer-1','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(235,18,405,406,2,'com_modules.module.131','Module Footer-2','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(236,18,407,408,2,'com_modules.module.175','Module Top-1A','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(237,18,409,410,2,'com_modules.module.176','Module Top-1B','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(238,18,411,412,2,'com_modules.module.177','Module Top-1C','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(239,18,413,414,2,'com_modules.module.178','Module Top-1D','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(240,18,415,416,2,'com_modules.module.179','Module Top-1E','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(241,18,417,418,2,'com_modules.module.180','Module Top-1F','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(242,18,419,420,2,'com_modules.module.103','Module Top-2A','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(243,18,421,422,2,'com_modules.module.102','Module Top-2B','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(244,18,423,424,2,'com_modules.module.101','Module Top-2C','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(245,18,425,426,2,'com_modules.module.119','Module Top-2D','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(246,18,427,428,2,'com_modules.module.142','Module Top-2E','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(247,18,429,430,2,'com_modules.module.143','Module Top-2F','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(248,18,431,432,2,'com_modules.module.246','Module Top-3A','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(249,18,433,434,2,'com_modules.module.247','Module Top-3B','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(250,18,435,436,2,'com_modules.module.248','Module Top-3C','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(251,18,437,438,2,'com_modules.module.249','Module Top-3D','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(252,18,439,440,2,'com_modules.module.250','Module Top-3E','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(253,18,441,442,2,'com_modules.module.251','Module Top-3F','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(254,18,443,444,2,'com_modules.module.136','Module ContentTop-A','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(255,18,445,446,2,'com_modules.module.137','Module ContentTop-B','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(256,18,447,448,2,'com_modules.module.181','Module ContentTop-C','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(257,18,449,450,2,'com_modules.module.144','Module Content Bottom-A','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(258,18,451,452,2,'com_modules.module.145','Module Content Bottom-B','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(259,18,453,454,2,'com_modules.module.182','Module Content Bottom-C','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(260,18,455,456,2,'com_modules.module.357','Module Tab-1tab','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(261,18,457,458,2,'com_modules.module.358','Module Tab-1tab','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(262,18,459,460,2,'com_modules.module.359','Module Tab-1tab','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(263,18,461,462,2,'com_modules.module.360','Module Tab-1tab','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(265,18,463,464,2,'com_modules.module.226','Parameters Thumbnails','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(276,18,465,466,2,'com_modules.module.173','Module Sidecol-A','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(277,18,467,468,2,'com_modules.module.202','Styling','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(278,18,469,470,2,'com_modules.module.203','Menus','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(279,18,471,472,2,'com_modules.module.210','Custom CSS','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(280,18,473,474,2,'com_modules.module.261','title-tick','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(281,18,475,476,2,'com_modules.module.267','title-tick style-box','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(283,18,477,478,2,'com_modules.module.205','Logo','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(284,18,479,480,2,'com_modules.module.206','Layout Options','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(285,18,481,482,2,'com_modules.module.208','Copyright Information','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(286,18,483,484,2,'com_modules.module.262','title-plus','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(287,18,485,486,2,'com_modules.module.269','title-plus style-box','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(288,18,487,488,2,'com_modules.module.207','Module Widths','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(289,18,489,490,2,'com_modules.module.209','Social Media Icons','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(290,18,491,492,2,'com_modules.module.211','Custom Code','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(291,18,493,494,2,'com_modules.module.263','title-arrow','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(292,18,495,496,2,'com_modules.module.270','title-arrow style-box','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(293,18,497,498,2,'com_modules.module.308','Responsive Options','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(294,18,499,500,2,'com_modules.module.264','title-star','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(295,18,501,502,2,'com_modules.module.273','title-star style-box','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(296,18,503,504,2,'com_modules.module.258','title-pen','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(297,18,505,506,2,'com_modules.module.266','title-pen style-box','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(298,18,507,508,2,'com_modules.module.257','title-mail','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(299,18,509,510,2,'com_modules.module.268','title-mail style-box','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(300,18,511,512,2,'com_modules.module.260','title-screen','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(301,18,513,514,2,'com_modules.module.271','title-screen style-box','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(302,18,515,516,2,'com_modules.module.259','title-bubble','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(303,18,517,518,2,'com_modules.module.272','title-bubble style-box','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(304,18,519,520,2,'com_modules.module.372','Module Header-1','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(308,178,324,325,3,'com_content.article.89','Mauris ligula justo','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(309,178,326,327,3,'com_content.article.90','Eodem modo typi','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(311,18,521,522,2,'com_modules.module.377','Endless Styling Possibilities','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(314,34,130,131,3,'com_content.article.91','Animate on Scroll','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(315,18,523,524,2,'com_modules.module.380','Animate on Scroll','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(316,34,132,133,3,'com_content.article.92','Font Awesome','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(320,18,525,526,2,'com_modules.module.172','Module Sidecol-B','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(321,18,527,528,2,'com_modules.module.384','Module Header-2','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(324,34,134,135,3,'com_content.article.93','Grid Gallery','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(325,34,136,137,3,'com_content.article.94','Thumbs Gallery','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(326,34,138,139,3,'com_content.article.95','About Us','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(327,34,140,141,3,'com_content.article.96','Services','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(328,34,142,143,3,'com_content.article.97','About Me','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(329,18,529,530,2,'com_modules.module.387','GridGallery Example','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(330,18,531,532,2,'com_modules.module.388','ThumbsGallery Example','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(331,18,533,534,2,'com_modules.module.278','Breadcrumbs','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(336,178,332,333,3,'com_content.article.98','Curabitur eget nisl','{\"core.delete\":[],\"core.edit\":[],\"core.edit.state\":[]}'),(338,18,535,536,2,'com_modules.module.394','Latest News','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(348,18,537,538,2,'com_modules.module.404','Example Carousel','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(350,18,539,540,2,'com_modules.module.406','Endless Styling Possibilities - text-light','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(351,34,144,145,3,'com_content.article.99','Utility Classes','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(352,34,146,147,3,'com_content.article.100','Carousel Module','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1}}'),(359,18,541,542,2,'com_modules.module.413','Homepage GridGallery','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(363,18,543,544,2,'com_modules.module.304','Login Form',''),(367,34,148,149,3,'com_content.article.101','Welcome to Nadia','{\"core.delete\":[],\"core.edit\":{\"4\":1},\"core.edit.state\":{\"5\":1}}'),(370,18,545,546,2,'com_modules.module.422','Homepage Carousel','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(372,18,547,548,2,'com_modules.module.424','Homepage Sidecol Filler','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(373,18,549,550,2,'com_modules.module.425','Homepage Text Bottom-2 Header','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(376,18,551,552,2,'com_modules.module.428','Module Showcase','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(377,34,150,151,3,'com_content.article.102','Header Image Slideshow','{\"core.delete\":[],\"core.edit\":{\"4\":1},\"core.edit.state\":{\"5\":1}}'),(382,18,553,554,2,'com_modules.module.433','Disclaimer','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(383,18,555,556,2,'com_modules.module.434','Vestibulum aucto','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(384,18,557,558,2,'com_modules.module.435','Aenean sollicitudin','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(385,18,559,560,2,'com_modules.module.436','Praesent placerat','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(386,18,561,562,2,'com_modules.module.437','Vivamus vestibulum','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(387,18,563,564,2,'com_modules.module.438','Cras ornare tristique','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(388,18,565,566,2,'com_modules.module.439','Nunc dignissim','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(389,18,567,568,2,'com_modules.module.440','Design with Passion','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(390,18,569,570,2,'com_modules.module.441','Base Logo','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(391,18,571,572,2,'com_modules.module.442','Portfolio','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(392,18,573,574,2,'com_modules.module.443','Example Styles Carousel - Dark Text','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}'),(393,18,575,576,2,'com_modules.module.444','Example Styles Carousel - Light Text','{\"core.delete\":{\"6\":1},\"core.edit\":{\"6\":1,\"4\":1},\"core.edit.state\":{\"6\":1,\"5\":1},\"module.edit.frontend\":[]}')
Table 'ecweb_2016b.#__assets' doesn't exist SQL=/*!40000 ALTER TABLE `#__assets` DISABLE KEYS */
Table 'ecweb_2016b.#__assets' doesn't exist SQL=LOCK TABLES `#__assets` WRITE
Unknown collation: 'utf8mb4_unicode_ci' SQL=CREATE TABLE `#__assets` ( `id` int(10) unsigned NOT NULL AUTO_INCREMENT COMMENT 'Primary Key', `parent_id` int(11) NOT NULL DEFAULT '0' COMMENT 'Nested set parent.', `lft` int(11) NOT NULL DEFAULT '0' COMMENT 'Nested set lft.', `rgt` int(11) NOT NULL DEFAULT '0' COMMENT 'Nested set rgt.', `level` int(10) unsigned NOT NULL COMMENT 'The cached level in the nested tree.', `name` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'The unique name for the asset.\n', `title` varchar(100) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'The descriptive title for the asset.', `rules` varchar(5120) COLLATE utf8mb4_unicode_ci NOT NULL COMMENT 'JSON encoded access control.', PRIMARY KEY (`id`), UNIQUE KEY `idx_asset_name` (`name`), KEY `idx_lft_rgt` (`lft`,`rgt`), KEY `idx_parent_id` (`parent_id`) ) ENGINE=InnoDB AUTO_INCREMENT=394 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
