1. Gunnar
  3. Wednesday, 10 January 2024
Situation:
  • Freshly installed Joomla 5.0.1, unaltered after installation.
  • The default Cassiopeia Template works as expected.
  • The Nina Template is installed and set as default.
  • No errors in the admin console.
  • When accessing the site, I now get an error message: "Cannot access protected property Joomla\CMS\Menu\MenuItem::$params".
The $menu->params used on line 41 in index.php was deprecated in Joomla 3.7 and gives an exception in Joomla 4.0+.
I thought all templates were Joomla 5 compatible, but I obviously got that wrong.
I changed it to $menu->getParams() and no longer get an error message when browsing the site. On the other hand, I don't get anything else either; I get a completely blank page.
Does this mean I must revert to Joomla 3 to use my template?
Could I ask you to allow us access to your extensions manager so we can examine this issue further? As long as you have the Behaviour - Backward Compatibility plugin enabled, your template should work with Joomla 5 without any issues.
