1. aroldoschwab
  3. Tuesday, 12 September 2017
Boa noite....
Comprei o template J51_Artisan e estou com problemas....
Gostaria de alterar a cor da barra lateral esquerda (onde apresenta o logo e menu... e abaixo os links sociais) transformando o fundo em degradê....
Alguma ideia????
traduzido no google
Good evening....
I bought the J51_Artisan template and I'm having problems ....
I would like to change the color of the left sidebar (where it displays the logo and menu ... and below the social links) turning the background into gradient ....
Any idea????
Would you have a URL to an example of your sidebar and details of the colors you wish to use within your gradient?
Good Morning....
site: http://www.teste.infobnews.com.br
... on the left side, where is the logo, the menu and the social links .... the color is always solid .... I would like it to start underneath in black and lighten until finished in white (gradient) .. .. I will send a sample of degraded area so that it understands better ok ????
Thanks for the prompt reply .... and congratulations on the service ....
The site is still under construction (test) ....
One question: how to make an art to put of background but without losing the fixed form in which it presents ????
Hugs
  1. http://www.teste.infobnews.com.br
Unfortunately we are unable to open your site (connection timed out). Regardless to amend try adding the following to the Custom CSS field of your templates parameters..
.sidebar_wrapper {
background-image: linear-gradient(to bottom, transparent, rgba(0, 0, 0, 0.8) 100%);
Ensure that the sidebar background is set to white (#FFFFFF).
Thank you very much....
This worked very well ....
At first I was in doubt if the code should be placed in the file "cost.css" in the CSS folder .... but then I remembered the specific area to add codes in the template configuration parameters themselves.
I am sad that I have not been able to look at the site .... but I ask you to try again .... it is functional ....
Thanks again and again for your prompt response ....
Hugs....
Sorry to say we are still unable to access your site. Attempting to access http://www.teste.infobnews.com.br/ gives us a 'Server not found' error.
Good Morning....
Interesting not being able to access .... but now the site is already in the right address and fully functional if you want to try to access ....
http://www.infobnews.com.br
Hugs
  1. http://www.infobnews.com.br
