1. markus
  3. Thursday, 27 October 2022
I have a problem with the "Emani" template.
After the demo installation, the error message "Class "Joomla\Plugin\Behaviour\Taggable\Extension\Taggable" not found " appears. Neither front nor back end work.
Greetings Markus
Hi Markus
I have just updated the Emani template demo installer to the latest version of Joomla and rebuilt it which should hopefully resolve this issue. To obtain, re-download your Nina template from your 'Template Downloads'.
Hi -
I got the same error from the Nina J4 1.1.11 Demo Installer and the Hannah J4 1.0 Demo Installer. I found a solution in Github that worked for me:
After you do your installation,.go into your installation files and delete the file "administrator/cache/autoload_psr4.php". I used FileZilla to delete the file.
Some people on Github said that file deletion worked and some said it didn't. It worked for me. https://github.com/joomla/joomla-cms/issues/38474
