1. cloudfaction
  3. Friday, 18 March 2016
can you tell me why: sometimes ( on some pages) the slideshow does not start? and why is the bottom space there, its a vertical scroll inside a vertical scroll. this is the url.
i am at a loss..
http://goo.gl/RN0xvr
body.vegas-container {
overflow: visible;
the double scroll is gone. but on the 'tips' page, i still get no slideshow. (for instance, more pages are blank)
There appears to be an error with your JomClassifieds module which which I suspect is causing this issue....
TypeError: $jomClassifieds(...).sortable is not a function
- $jomClassifieds( 'table#image tbody' ).sortable({
Please ensure you have the latest version of this module installed. Disabling the module resolves the issue.
contacted component supplier, problem fixed!, again, thank you!
