I am currently migrating an old Joomla 1.5 site to Joomla 3.2.1. Now I wanted to install the Resonate template in the new Joomla 3.2.1 and encountered the following problem: I unpacked the download file and tried to install the zip-file for Joomla 3.x via Joomla Extension Manager.
The template could not be installed because the XML installation file was not found, although it is included in the zip-File. Then I tried to upload the file to the tmp-directory via FTP. It did not work, either. Now I tried to install the free Oxygen Template and encountered the same problem...
I didn't have problems installing a template from a different supplier, though.
I would be very grateful for some advice to solve the problem.
Here's some information on my system configuration.
Thank you very much in advance!
Regards, lissy1778
