1. bibi_rg
  3. Monday, 14 April 2014
Hi, I´m triying configure multimodal languages in joomla 3.2, but dont working because the main menu dont change to english menu it always shows spanish menu.
Only change to english menu when I change the default option of the themplate to english menu, but then the spanish menu dont works
Can help me someone??
oks, thanks its works fine!!
As the top menu is set from within the templates parameters instead of using a menu module the method used would change slightly. Rather than creating a menu module for each of your languages you will create a template style.
Select a Template style in your 'Template Manager' (Eg. Polaris - Default) and duplicate it for each language you want. In each of the styles then select the menus to be displayed for that language. You can then set that template style to the langauge via the 'Languages' dropdown or by assigning the correct menu items via the 'Menu Assignment' tab.
