I have the template "Juliet" installed on a new website and have the following problems:
1.) Sidecolumn Positioning "Before Component" does not work ("After Component" works fine). It does not matter if the "Mobile Menu Type" is "SlickNav" oder "SlideOut".
2.) In the module J51_thumbsgallery (see bottom of frontpage) no "next / back" buttons" are displayed. Wiping on mobile devices works fine, but there's no way to change between images on a computer without touchscreen. Each image has to be clicked separately and closed again.
Thanks a lot for your support and best regards ...
Volker
