1. Giorgini
  3. Thursday, 28 April 2016
I can see correctly the "Great Vibes" font only from some computers.
What should I do ?
I'm sorry Ciaran, but it's still not working...
Fabio
Hi Fabio
I have applied the following fix to your template... http://stackoverflow.com/questions/25694456/google-fonts-giving-no-access-control-allow-origin-header-is-present-on-the-r
Has this helped in resolving the issue for you?
I modified the htaccess.txt uder the "public_html" folder, but nothing changes.
I tried to copy htaccess.txt as .htaccess, but nothing changes.
Fabio
Hi Fabio
Could you try adding the following to the end of your htaccess file in the root of your Joomla installation...
 <FilesMatch "\.(ttf|otf|eot|woff)$">
<IfModule mod_headers.c>
Header set Access-Control-Allow-Origin "*"
</IfModule>
</FilesMatch>
yes....i got errors !!
(index):1 Font from origin 'http://fonts.gstatic.com' has been blocked from loading by Cross-Origin Resource Sharing policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'http://www.labastidedeclaude.com' is therefore not allowed access.
If you want I can give you a teamviewer connection to the PC that doesn't work
Fabio,
Hi Fabio
We are at a bit of a loss here. It's an issue that has not been reported before. Are you getting any errors in your console (Google Chrome -> F12 -> Console)? If so could you post the error below.
unfortunately the issue still remains.
Fabio
Thank you Fabio
I have updated how your Google fonts are loaded (removing the 'http:'). Has this resolved the issue?
Sent
Hi Fabio
I've disabled all the plugins and modules....but, unfortunately, the problem still remains.
I have the same issue if I view the demo-template http://demo.joomla51.com/0116/ (then I think it's not a joomla configuration problem).
instead if I view the google font at the address https://www.google.com/fonts/specimen/Great+Vibes , it see the font correctly.
Fabio.
Hi Fabio
You could try disabling any 3rd party plugins to ensure these are not effecting the loading of your Google fonts.
If the issue is only present on some pages then consider disabling all your modules and see if this resolves the issue. If it does then enable them one by one until you find the offending module.
I understand that it's difficult to solve this (strange) issue.
>Have you had this issue with other sites loading Google fonts?
I try to set "Great Vibes" to Article Head font og this site: http://www.nextsolution.prato.it (template: Virtuoso).
and It has the same behavior
>Have you tried loading your site outside of your office connection?
Yes...same behavior, in some PC it works in other PC it doesn't
Fabio
Hi Fabio
Unfortunately it is very hard for us to offer advice when we are unable to replicate the issue. It sounds like a local issue where Google fonts are not loaded. Have you had this issue with other sites loading Google fonts? Have you tried loading your site outside of your office connection?
Yes, I have verified that I have the same issues with all Google fonts.
I have 5 PC in my office, it works correctly on 3 (with Windows 7 and Windows 10 using Chrome e Firefox) and it doesn't work on 2 (with Windows 7 and Windows 10 using Chrome and Firefox).
Fabio.
Unfortunately we have been unable to replicate this issue. We have tried a number of devices with various browsers to the same effect. Are you have similar issues with all Google fonts?
Hi, this is the URL:
http://www.labastidedeclaude.com/
thanks
