1. ulrich.zellweger@gmail.com
  3. Friday, 13 September 2019
I have the template madison with carousel module and layer slideshow modul. There is a promblem with this extensions.
https://www.ferien-falera.ch/test4
(there are both extensions, the text from carousel module does not show the text. And the layer slider module shows a navigation bar. This are the same modules as the exampe link below)
(here you see the carousel module works correctly without layer slider module)
https://www.ferien-falera.ch/ferienwohnung
(here you see the layer slider module works correctly without carousel module)
You now where the mistake is?
Thank you.
Ulrich
Hi Ulrich
Please find attached the latest update of the Carousel module. Does installing this update resolve the issue?
Thanks for the file. It works!
Ulrich
I discovered a problem on the smartphone. After the update, i have noticed that the site over the text from the carousel on the phone can not be moved vertically. If you look at the template madison, there it is possible. Take a look at the picture.
(vertical move on phone is over the text not possible)
https://www.joomla51.com/demo/0125/
(vertical move on phone is over the text possible)
What can I do to solve the problem?
Ulrich
.touch .owl-item {
pointer-events: none;
Thanks. That works perfect.
Ulrich
