1. tcm1003
  4. Sunday, 17 June 2018
Hello 51,
I have a little problem with the "minor update" of caitlin to version 1.0.3.
By the way: The changelog tells me version 1.0.3, while the templateDetails.xml is still on 1.0.2. (Is this bug-worthy? ;) )
Referred to the changelog entry 1.0.3 the update did "remove the sidecol background faux column"...
Ok, I'm not sure what your intention was, but I thought before, the last version number shows patchs and bug fixes, not major design changes.
Before the update my sidecolumns fit with the outer border of the template - now there's a 30px margin.
Before the update my sidecolumns background went to the "ground" of the page - now it cuts off after the modules.
I attached two screenshots, one before and one after the update.
EDIT: Second screenshot in reply because of upload error.
I buyed caitlin because it fit my needs with it's design, but I don't think, that a minor update should change this design that much. But now I have to use the old version (without any other bug fixes like with the vegas script - feels like forced update of windows 10...).
So, is this change in this form intentionally or did you plan anything other? Would like to know whether it's "bug-worthy" or not...
Greetings from germany,
tcm1003 / Tore Meyerdierks
EDIT: Found my mistake with the second screenshot. Reupload!
Hi Tore
Thank you for bringing this issue to our attention. We should have indeed replaced the faux columns with a suitable alternative with the 1.0.3 update. I have just resolved this issue with the latest update (1.0.4). Once installed your side columns should behave as before prior to updating to 1.0.3.
