MENU
  1. KChev
  4. Monday, 21 August 2017
I’m using Kodaline for a site and the client wanted a slideshow on the homepage. I installed a J51 slideshow extension that came with an older template (Beaumont) but the slides are a bit jerky. I notice that your more recent templates don’t feature slideshows — is this extension no longer supported?
PS - the Module Positions file that came with the Kodaline template extras doesn’t reflect all the possible positions now. It would be helpful if you could update that.
Kim
Hi Kim
The Beaumont slideshow is still supported and should not cause you any issues. Would you have a URL to an example of your issue?
