1. luca
  3. Wednesday, 27 May 2015
i have a problem with your template J51 HABITATE. I have modules on sidebarcol b. In mobile version i want the sidebar content under the main content and not this in first position.
How can i set the sidebarcol b under the main content?
To change the stacking order of your side column modules try adding the following to the Body Custom Code field of your templates parameters...
jQuery(document).load(jQuery(window).bind("resize", listenWidth));
function listenWidth( e ) {
if(jQuery(window).width()<959)
jQuery("#sidecol_b").remove().insertAfter(jQuery("#content_remainder"));
} else {
jQuery("#sidecol_b").remove().insertBefore(jQuery("#content_remainder"));
jQuery("#sidecol_a").remove().insertAfter(jQuery("#content_remainder"));
} else {
jQuery("#sidecol_a").remove().insertBefore(jQuery("#content_remainder"));
</script>
But this does't work in J51-Classic.
Any onther solution?
You can also try the suggestion in the following post... http://www.joomla51.com/forum/8-commercial-templates/7720-how-can-i-make-sidecolum-b-stack-under#19479
