1. applehc
  3. Sunday, 22 March 2020
I am trying to install Joomla with the demo and I am having problems. It stops me in the middle of the installation.
I have followed the following steps:
https://www.joomla51.com/tutorials/demo-installer/setting-up-the-demo-installer
I am attaching an image, I hope to solve it soon.
Solved. Thanks
The same problem continues, I can't install it. It stops in the middle. You can check?
I have just updated the Lifestyle template demo to the latest version of Joomla. This should hopefully resolve any issues you are experiencing. To obtain this updated version simply re-download your template from your Joomla51 Downloads.
The problem is with Lifestyle template.
Greets.
For which of our templates are you having this issue?
