1. nextdigital
  3. Monday, 23 May 2022
I bought the ARIANA templete and chose to install the J51_Ariana_DemoInstaller.zip, proceeding as it is in the J51 tutorial (https://www.joomla51.com/tutorials/demo-installer/setting-up-the-demo-installer)
However, in the Joomla installation, I can't get past the first step - the installation is "stuck" on the 1st screen (pic attached).
PHP version is 7.4 (I tried other older versions, without success). The database was previously created correctly.
I tried to load the Demo files in the public.html folder in two different ways: uploading zipped and unzipping on the server, and uploading already unzipped - with the same result.
Can you help me?
Thank you for the update and for sharing your solution.
Strangely these txt files do not exist in the demo installer zip file so are possibly been added by the host zip extraction.
We found a solution before that!
The failure can be resolved by deleting all TXTs from the "Installation" folder.
See the images.
Attachments (3)
We have just updated the Ariana template demo installer to the latest version of Joomla 3 (3.10.9) which should hopefully resolve any issues for you. We have tested locally across a number of environments and we are unable to replicate any issues. To obtain simply re-download from your Joomla51 template downloads.
