1. inode
  3. Thursday, 12 September 2013
I'm using the same templete J51-Evolution but has problems in submenus when the site is viewed on android tablet or smartphone, both with Chrome and with the internet from Samsung.
The submenu opens, but when you click (tap) on either option, it reloads the page.
I tested with Firefox to Android and this is normal operation.
You already have a solution for this failure?
Thank you.
Marco
Hi Marco
Would you have a URL to your site so we can examine this issue?
Hi Ciarán,
I appreciate the feedback.
Below the website address for you to analyze.
http://www.erpx.com.br
Thank you.
Marco
Thank you Marco
That is rather strange. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
The problem can only be seen if you access the URL in an Android smartphone or tablet by Chrome.
If you use these same facilities Firefox menu works without any error or problem.
So in my opinion, the fault lies in the programming menu or JavaScript, because it only works properly in Chrome and Firefox Android Android is perfect.
Does it get any fix for this?
Thank you.
Marco
Hi Marco
As the issue does not appear to on the template demo (correct me if you find this not to be the case) the issue appears to be unique to your Joomla installation which is why we would need access to your Joomla administration to investigate the issue further.
