1. Ronald81
  3. Saturday, 23 January 2021
I've got 2 issues:
1: I use the Hayley template. I would like to have the same layout as in the demo on the site. So, screen-wide image, and behind the logo and menu.
The only thing I can get working: the image shows, but much smaller, and only partly behind the menu/logo.
2: The logo (text instead of image) is not showing right on mobile devices. It is way too wide (much wider than rest of the site).
I hope you can help me!
Greetings,
Ronald
  1. http://www.lwmusic.nl
Thank you!
Works fine!
Greetz,
Ronald
Hi Ronald
To amend try also adding the following to your custom CSS field...
.logo-text h1 a {
white-space: normal;
Hey Ciaran,
thank you for your help! That did the trick!
Only the 2nd issue is left: In mobile 'view' there is a problem with the scaling of the logo (in text).
I've tried severeal CSS commands, which you have put here on the forum, but none of them did the trick...
The logo is too wide for the layout of the site. This problem occurs on another site I have (Madison).
Hope you have a solution for it....
Greetz,
Ronald
Hi Ronald
To replicate the example of the slideshow of the template demo, place the slideshow in the showcase-1a module position. You may also need to remove the padding and width of this position if not already done so. This can be done in the Module Widths tab of your template settings.
