1. expertbeginner
  3. Saturday, 02 March 2013
I'm currently working with the Privilege template and have noticed the following whilst using 'Inspect Element' in Google Chrome (errors are generated):
Line 9 of styles.php (
<link rel="stylesheet" href="templates/<?php echo $this->template ?>/css/<?php echo $this->params->get('colorStyle'); ?>.css" type="text/css" />;) refers to the colorStyle parameter which doesn't exist.
The other issues can be viewed in the attached image.
Regards,
Martyn.
Hi Martyn
To amend this issue try removing the following from your templates styles.php (../templates/j51_privilege/php/styles/php)
<link rel="stylesheet" href="/templates/<?php echo $this->template ?>/css/<?php echo $this->params->get('colorStyle'); ?>.css" type="text/css" />
I had already removed the line, but thought I'd let you know of its existence as it won't be restricted to my installation.
The other issues shown in the image are after the line was removed.
Also, f.y.i., the installation used was the demo content install included with the template.
Regards,
Martyn.
Opps sorry.. I read your post incorrectly.
For the Google fonts error may I suggest the following post.. http://www.joomla51.com/forum/support/commercial-templates/j51-presence-web-safe-fonts-problem#3038
For the Cerbox error try removing the following from ../modules/mod_j51thumbsgallery/mod_j51thumbsgallery.php
window.addEvent('domready', function(){
$$('.gallery a.ceraBox').cerabox();
</script>
Done and dusted. Thanks.
Regards,
Martyn.
