I made a website for a client which uses the Privilege template. It looks awesome but there's an issue with the menu on an iPad. The mainmenu shows correct, but the subitems don't open.
I found there are some issues with Joomla menu's and iOS7 maybe this has something to do with it?
Also, I'm a bit confused with regards to the 'hornav' menu. When I set it to 'Yes' in the template options, there's no menu at all, if I just use the standard Joomla menu it displays correct (at least on a PC). Is that supposed to happen?
The site where I'm testing the template.
Joomla-version: 3.20.
