I tried to use some instructions you provided for someone else with another template, thinking that the basic instructions must be the same for multi-language install.  I received some error messages re: TinyMCE.. I don't know, can't remember.  But,  can you tell me if the instructions are the same that I found on Joomla.org
http://help.joomla.org/files/EN-GB_multilang_tutorial.pdf
If not what part should I pickup from.. I'm thinking you already have most of this prepared.  I don't know where to begin.
Also how can I put the language drop menu on the right side of the "search".  Thanks
April
