OK, this might be a weird question and probably obvious that I am a novice.. but I am finally enjoying the learning experience.  I promise I am trying to research every possible means before I ask her on the forum.
So I have the Privilege Template Design.. Under Demo you show Template Perimeters, Module Variations.
1) How do I revise the template design for other pages.  For example, If I change it under J51_Privilege - Default, won't this mess up my home page that I've designed
2) When I try to use sidecol-a or sidecol-b on other pages, aka, Module Custom HTML , it uses the default style from the template default
Maybe my question is, How do I change the template layout options for other pages to custom fit what I need for that particular page without interfering with the home page?  Do I create additional template style options using the same template. :unsure:
I'm also trying to widen a module width on another page to accompany a form, but it's using the module width in the default template.
How do I get my other page to look like this - http://www.demo.joomla51.com/privilege
You are here: Home Layout Options Content
If I keep talking I will continue to confuse myself.. Thanks  :side:
