MENU
  1. fsiconcepts
  4. Monday, 22 January 2018
Hi!
I'm using the presence template and get a problem with the change to https.
The font of the hornav menu will change to a default font, if https is set.
I changed the STYLES.PHP as you recommended in other forum posts concerning https, but it does not work for any link (sub page), except the start page. Do you have any solution?
Thanks in advance.
Solved it. Sorry. I made a mistake!
