1. UKPonchoMan
  3. Thursday, 23 April 2015
There are three changes I am trying to make to my site (http://www.usaf-sig.org) for which I would appreciate assistance...
1. I would like to reduce the gap between the top of the page and the top of the content - therefore reducing the gap between the logo and the content section;
2. I would like to move the "hits" counter from the right hand side bar into the hornav menu bar if possible;
3. I don't know how to make the standard J51 search bar visible.
All help greatfully received!
Chris
Hi Chris
1. Try adding the following to the Custom CSS field of your templates parameters...
#container_header {
height: 125px;
#socialmedia {
top: 125px;
2. Your best option would be to create a new module position to accommodate your module in this area of the template. Details on doing so can be found here.. http://www.joomla51.com/tutorials/item/creating-a-new-module-position-in-the-header-area-of-your-template
3. AN option to enable the search is available in your templates parameters (Extensions -> Template Manager -> [YourTemplateStyle] -> Search
1. Works great, but the slogan has disappeared - is there CSS code to adjust it?
2. Will give this a try
3. The Polaris template doesn't have an option for "Search" for some reason??
Chris
Hi Chris
1. Try also adding the following to your Custom CSS field (adjust to taste)...
p.site-slogan {
position: absolute;
top: 30px;
3. My apologies, this is correct. There is no search field integrated in to our Polaris template. The only option would to be create a search module in one of the available module positions. For details on creating a new module position in the header area of your template can be found here... http://www.joomla51.com/tutorials/item/creating-a-new-module-position-in-the-header-area-of-your-template
Thanks Cieran - that resolves the first problem and gives me a way forward on the other two. Much appreciated!
Chris
