1. salinger
  4. Wednesday, 26 November 2014
I am working with Calibra Template on joomla 3, http://havienne.at/index.php/
Footermenu (Impressum), copyright info and the icons should be in one row. Impressum on the left side, the icons in the center, and the copyright info on the right side (see attached jpg).
Footermenu and icons are modules with position footermenu. How can I convert the copyright info of the template to a module position? There is a possibilty in the modules for the copyright info, but then I have the copyright info twice (and with unnecessary text). Can you please give me an idea how to that, thank you.
Kind regards, Marion
Presuming I understand you correctly could you try adding the following to the Custom CSS field of your templates parameters...
#container_copyright .wrapper960 {
border-top: 0 none;
position: relative;
#copyright {
position: absolute;
right: 0;
top: 70px;
Thank you Ciarán,
that has helped, but only impressum should be on the same vertical position as "Alle Rechte"...see attached screen (havienne.tiff)...
http://www.havienne.at/index.php
and what code can I use for the mobile version? it should look like the attached picture "vision", now it looks like the attached pic "now"
THAAAAANK YOU!!!!!
regards, marion
Try adding the following to the Custom CSS field of your templates parameters..
#footermenu ul {
position: relative;
top: 40px;
I am not really sure if it is possible for to achieve your 'vision' screenshot. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will see can we achieve anything like it. For our reference please paste a link to this post in your email.
Thank you Ciarán , perfekt !!!! I have sent you admin access by mail!
Kind regards marion
Hi Marion
Sorry to say after much experimenting what you wish to achieve is not easily possible. Is there any reason the module positions available within the template for this area are not been used (base-1a, base-1b, and base-1c) instead? These module positions are styled as you wish by default.
Thanks a lot for trying Ciarán, I will try it with the base positions..
regards marion
Hi Ciarán,
one more question regarding this http://website...www.havienne.at/index.php
I'd like to have the footer menu "Impressum" and "Rechtliche Hinweise" in a horizontal menu...could you please tell me in which div I shall write the code? thank you kind regards Marion
Hi Marion
Try adding the following to the Custom CSS field of your templates parameters...
.base-1 .menu li {
border-bottom: medium none;
float: left;
.base-1 .menu li a {
margin-top: 0 !important;
No sorry, that did not work...do you want to have a look at the backend please ?
Sure. Details can be sent to [email protected]. For our reference please paste a link to this post in your email.
You had the following text in your custom CSS field which was effecting your CSS. Removing this text has alllowed the CSS to work correctly.
Footer Menü horizontal
Any CSS comments should be in the format..
/* Footer Menü horizontal */
