1. salinger
  4. Wednesday, 11 October 2023
can you please look here
https://www.gebhart.or.at/joomla4/index.php/impressum
I would like to have a pic (green wave) in the bottom module, placed it in the template settings, but it doesn't appear like it should. it appears if you scroll slowly. it should be placed instead the grey field on the bottom.
Thank you, Marion
Hi Marion
#container_bottom1_modules {
background-attachment: inherit;
Thanks Ciaran, but unfortunately still the same :-(
kind regards Marion
Hi Marion
Your background image to the bottom module should now fill the position.
Hi Ciaran, no it does not appear at all...just a grey background... I put it already online so you can find it here:
http://www.gebhart.or.at
and just to let you know I do not get an email when you are posting in the forum... this occurred since several months... kind regards, Marion
