1. milian
  4. Wednesday, 16 October 2019
The Module positions of the Desktop version of the PianoForte template is for us:
S-C-S or S-S-C or C-S-S
So far so good.
For the result of the mobile module the order of presentation is always
S
S
C
As you see the Content is served as last on mobile.
But we want the Content above the Modules in mobile. Like this:
S
C
S
Is there to build in an extra option by you the set this choice also for mobile?
Or another way to change this in the .php ?
Best regards,
Milian
Hi Milian
https://www.boekhandelpraamstra.nl/ja30/
I send you the login in a DM.
Can you make it generic so that i can use it on different locations and after an update...
regards, milian
I have added the needed CSS (Custom CSS field) to place your content above the side column modules on smaller screens.
Thanks Ciaran,
I will look into it tomorrow.
Regards,
Milian
Thanks Ciaran,
Your added css gives now indeed:
C
Side-A
Side-B
But the preferred choice is
Side-A
C
Side-B
and/or
Side-A
Side-B
C
It depends on the actual website-content witch order we prefer.
In other words. We like to choose one of the three posibilities (as the desktop version)
You're making me very happy about this, because I love PianoForte!
How can I change this 2 orders in the css code below?
-----------your modified present mobile view -- C S S ---
#main {
display: flex;
flex-direction: column;
#content_remainder {
order: -1;
--------------- EOF ------
Hi Milian
For a little more control you can use the following custom CSS instead, editing the order value to your own taste...
#main {
display: flex;
order: 1;
#sidecol_a {
order: 2;
#sidecol_b {
order: 3;
Thanks! Ciaran.
