1. abseve
  3. Monday, 21 October 2013
How do we reduced the space between the paragraph in PianoForte template?
It's like double space.
Just like the demo, you will see a double space between the paragraphs
To set your paragraph margin try adding the following to the Custom CSS field of your templates parameters where 16px is your new bottom margin (by default this is 32px)...
p {
margin-bottom: 16px;
Didn't work - it moves the paragraph closer to the bottom but not the space in between paragraphs.
Do you have any other suggestions? It is very puzzling. I don't know why the template is without instruction how to change this settings.
Would you have a URL to an example of your spacing between each paragraph?
The template demo is the same way. but here is the link
http://ersenvironmental.com/demo
I mentioned this from the start - now I have to wait another 24 hours before I hear from you again.
We ask for a URL so we can see why the suggested CSS does not effect your paragraph spacing (http://www.joomla51.com/forum/support/commercial-templates/sticky-support-question-checklist).
Could you check the URL provided as it continually times out on us.
Just like the template demo - this won't time out.
http://demo.joomla51.com/?theme=PianoForte
You will see the spacing between paragraphs.
The code you sent me if bottom margin.
http://ersenvironmental.com/demo/
Adding the already suggested CSS to the demo reduces the width between the paragraphs. A more forcefull way of applying this CSS to your template overriding any CSS of extensions on your site is the following...
p {
margin-bottom: 16px !important;
We are stil unable to access your site.
I hate to ask your IP address to see if it's blocked but even if you can't, the demo is also setup the same way with extra spacing. I tried this code but in the template custom css in template mgr. but it doesn't change it. I lowers the bottom part but not decreased the space between paragraphs.
If you give your IP I will try to unblock it if it is.
Can you see it on the demo - you can see it from the demo - the spacing.
Does it work for you? try it on the demo template
I attached the screenshot
Our current IP is 109.77.179.237
We have tried the CSS on the template demo and it worked correctly. Please ensure you have done a full refresh on your browser after adding the CSS (CTRL + F5).
I followed your instructions but the same results. I whitelisted your IP so you should be able to see the website
I want to provide you with the FTP credentials and Joomla backend admin credentials but I don't know how to send it you in private.
I added this code in template custom css
p {
but if you can view this url - there is no change - what this does is decrease the bottom margin but not the space between the paragraph..
Here is what FIREBUG shows - I edited line
p {
p {
margin-bottom: 22px; ( this is nexus.css line 30 I changed this in the css before I opened a ticket)
padding-bottom: 0;
p {
margin-bottom: 10px;
margin-top: 0;
padding-bottom: 1px;
Sorry to say we are still unable to access your site. Details can be sent to [email protected] however I suspect as with your site we would not be abale to access your server via FTP.
May I suggest sending us the source of the article. You can do this by selecting all of your article, right click and hit 'View selection source' (Firefox).
<p>Environmental consulting experts serving the United States for over 17 years, headquartered in Jacksonville, Florida.</p>
<p>A certified Disadvantaged Business Enterprise (DBE). in both Georgia and Florida, a Minority Business Enterprise (MBE), and a City of Jacksonville certified Jacksonville Small and Emerging Business Enterprise (JSEB); ERS specializes in ecological assessment and documentation; vegetative community mapping; jurisdictional wetland delineations; threatened and endangered species evaluations; wildlife surveys; Environmental Impact Statements and Assessments (EIS and EA); mitigation planning and design; permitting for wetlands, protected species and mitigation banks; mitigation implementation and monitoring; habitat restoration; and protected species relocations.</p>
<p>Services are provided to both private and public sector clients for residential and commercial sites, transportation projects, parks, educational facilities, and Developments of Regional Impact (DRI). With a Qualified Airport Wildlife Biologist per FAA A/C 150/5200-36A on-staff, ERS is also an expert in the following environmental aviation areas: Wildlife Hazard Assessment (WHA), Wildlife Hazard Management Plans (WHMP), and Wildlife Hazard Training for Airport Personnel.</p>
Without access to your site all I can suggest it to add the styling inline. To do so, using the html option in your editor convert all instance of <p> to the following....
<p style="margin-bottom: 5px">
For your information this is the response we are getting when attempting to access your site...
The server at ersenvironmental.com is taking too long to respond.
This code didn't work
<p style="margin-bottom: 5px>
This only adjust the margin from the bottom of the paragraph.
It does nothing to the space from between paragraph.
It still has the double space.
I added this to the custom css in template manager and even tried to change this in the css files.
The following is to be used inline within your article, Set your article editor to CodeMirror in your Global Configuration and then add the following directly in to your article editor...
<p style="margin-bottom: 5px"> Your paragraph text goes here </p>
Failing that there is very little we can do until we can access your site and see why the previously added CSS is not working correctly.
Ok.. although incredibly slow it looks like we can now access your site. Have you since removed the below CSS from the Custom CSS field as it is not appearing in the source of your site...
p {
