1. Hammur
  4. Wednesday, 11 February 2015
Hello :)
For this site http://faroexpo.konsult.fo/, we decided to turn off the responsive option (Template manager > Responsive Option > No)
Now this does basically work fine, but for some particular screen sizes, the main hornav menu gets out of order showing as a vertical list overlapping the content below. As well as the social Media Icons gets moved to the left too.
This can be seen if you zoom on the page in a browser (for me it occurs at 150% and 160% zoom level)
Is it possible to get a fix for this?
Screenshot from mobile:
Hey :)
To amend could you try adding the following to the Custom CSS field of your templates parameters...
#hornav, .hornavmenu {
display: inline !important;
.hornavmenumobile {
display: none !important;
Hey Ciarán
Your css looks to work fine when I check it using Firebug on my site, however when I enter it into the "template custom css" the css
It doesn't work or take effect for the particular screen size, it looks like there is already another similar css overruling it located:
[right]inline: 389[/right]
Even though I place it at the top of my Custom CSS field.
Not sure about where I can change this as 'inline:389' doesn't really give me a direction on which file it's in.
