Having problems upgrading the Joomla install from 3.9.3 when using PHP 7.2.
If I use PHP 7.0 or earlier, the Joomla updater works fine. If I use PHP 7.1 or 7.2 i just get a black screen and the update doesn't work. However if I do the Joomla update and then perform the PHP upgrade, all appears to be OK in the front end and back end of the site.
Joomla have told me that is is more than likely an issue with a template or third party component/module etc.
Are you aware of any issue with the Joomla 51 templates and recent versions of PHP?
Thanks, Paul
