1. Norbert
  2. General
  3. Thursday, 27 December 2018
Hi, I have tried to upgrade from PHP 7.1 to 7.2 without success. The complete joomla site can't be access after the upgrade. PHP 7.1 works without problems. There are no really helpful information in the log files to sort out the root cause. I got the information that the most issues are caused by incompatible templates. Can you tell me that the template "J51_Classic - Standard" is compatible with PHP 7.2?
Since upgrading is the issue only present in thy frontend? Can you still access your Joomla administration?
Presuming you can access your Joomla administration does enabling one of the default Joomla templates (Protostar) resolve the issue?
  2. General
Hi Ciaran, thanks for your answer. I have fixed the issue. The root cause was a incomplete php 7.2.
  2. General
