  1. adminfed
  3. Friday, 17 February 2017
My question is about the Chelsea template. My site is only accessible via HTTPS. When loading the site, it says the "Particles" script can't be loaded as it's not safe. When I check the script that is being loaded I see the following one:
http://cdn.jsdelivr.net/particles.js/2.0.0/particles.min.js
I presume it can't be loaded because it's not HTTPS. Is there any way to make this script work with HTTPS ?
Peter
Thank you. It's working.
Hi Peter
If you open your templates index.php (../templates/j51_serenity/index.php), you will see the call for the particle.js near the end of the file. Changing the CDN URL to https://cdn.... should resolve the issue.
