1. Lars Melzer
  3. Thursday, 10 March 2016
Hello.
For mobile sight have i this code editing
allowParentLinks: true,
How can this fuction working in the hompage-design? I use the template "florence".
Regards, Lars
Hi Lars
Sorry but I do not understand your query. Would you have a URL to an example of your issue so I may better understand?
Hello Ciarán.
My Projektsite:
m.com/index.php/labels/guidi">http://test.hide-m.com/index.php
Parents menu items are not linked in the browser.
I click on Labels -> GUIDI the submenu are listed entries only. The page GUIDI but not displayed.
For me it's better the page GUIDI also displayed. -> m.com/index.php/labels/guidi">http://test.hide-m.com/index.php/labels/guidi
In the Mobile View is already working, because I have set the code "allowParentLinks" to TRUE.
Are they available for the browser menu?
Greeting Lars
Hi Lars
May I suggest the following forum post on this query.. http://www.joomla51.com/forum/8-commercial-templates/7922-menu-with-submenus-won-t-open-its-content#19956
Hello.
I've already tried, but does not work well.
$ (This) .removeAttr ('href');
Yes, it works - but now the sub-menu items are always visible.
Greeting Lars
Hi Lars
If we set your template to follow the link then there would be no way to access the sub menu items. The only option I can think of is to leave your sub items visible at all times. To disable the accordion style menu and instead display all menu items remove the following from your templates scripts.js (../templates/j51_florence/js/ scripts.js line5-22)...
// Main Menu
$('.hornav li.parent > a').on('click', function(){
$(this).removeAttr('href');
var element = $(this).parent('li');
if (element.hasClass('open')) {
element.removeClass('open');
element.find('li').removeClass('open');
element.find('ul').slideUp();
else {
element.addClass('open');
element.children('ul').slideDown();
element.siblings('li').children('ul').slideUp();
element.siblings('li').removeClass('open');
element.siblings('li').find('li').removeClass('open');
element.siblings('li').find('ul').slideUp();
