1. ziggy
  4. Wednesday, 26 December 2012
Joomla 3.0.2
Great template, but I have a serius problem.
Fresh install and login form enabled. In frontend, I can login perfectly with a valid (Registered) User, the site are refreshed and user are logged. But if I insert a invalid user/pass or blank pass also, site send me to blank page. The same for "Create an Account" link.
I'd tried to find the problem, and I believe that are on mootools125.js, but I can't fix it.
some help from someone more skilled please?
Hi Hammas
Are you having the same issue with the default Beez template? Have you tried the latest version of the template (http://www.joomla51.com/templates/j51-oxygen)?
Yes, Im using the last version.
bezz have "similar" problem but very different issue. Bezz3 work fine when I remove from hide.js two code lines, once I trace the problem was easy fixed without any additional issue
Other themes work perfectly
I can bypass the problem only commented/deleting a function on mootools125.js, but them I lost some animations features or hover transparency for example.
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. Please mention this post in your email.
  3. # 3
